I am trying to configure NFS for our infiniband network, and following the instructions at HowTo Configure NFS over RDMA (RoCE) https://community.mellanox.com/s/article/howto-configure-nfs-over-rdma--roce-x
I installed the MLNX_OFED drivers on CentOS 6.8. (I had originally configured the network and IPoIB interface using the RHEL manual (Part II. InfiniBand and RDMA Networking Part III. InfiniBand and RDMA Networking | Networking Guide | Red Hat Enterprise Linux | 7 | Red Hat Documentation ) and was using NFS over the IPoIB but was receiving a bunch of page allocation failures)
I used the mlnxofedinstall script which completed successfully and updated the firmware, e.g.:
Device (84:00.0):
84:00.0 Network controller: Mellanox Technologies MT27500 Family [ConnectX-3]
Link Width: x8
PCI Link Speed: 8GT/s
Installation finished successfully.
Preparing… ########################################### [100%]
1:mlnx-fw-updater ########################################### [100%]
Added 'RUN_FW_UPDATER_ONBOOT=no to /etc/infiniband/openib.conf
Attempting to perform Firmware update…
Querying Mellanox devices firmware …
Device #1:
Device Type: ConnectX3
Part Number: MCX354A-FCB_A2-A5
Description: ConnectX-3 VPI adapter card; dual-port QSFP; FDR IB (56Gb/s) and 40GigE; PCIe3.0 x8 8GT/s; RoHS R6
PSID: MT_1090120019
PCI Device Name: 84:00.0
Port1 GUID: e41d2d03006f89f1
Port2 GUID: e41d2d03006f89f2
Versions: Current Available
FW 2.32.5100 2.36.5150
PXE 3.4.0306 3.4.0740
Status: Update required
Found 1 device(s) requiring firmware update…
Device #1: Updating FW … Done
Restart needed for updates to take effect.
Log File: /tmp/MLNX_OFED_LINUX-3.4-1.0.0.0.17971.logs/fw_update.log
Please reboot your system for the changes to take effect.
To load the new driver, run:
/etc/init.d/openibd restart
I rebooted the system and then ran the self test:
hca_self_test.ofed
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
Kernel Arch … x86_64
Host Driver Version … MLNX_OFED_LINUX-3.4-1.0.0.0 (OFED-3.4-1.0.0): 2.6.32-642.el6.x86_64
Host Driver RPM Check … PASS
Firmware on CA #0 VPI … v2.36.5150
Host Driver Initialization … PASS
Number of CA Ports Active … 0
Port State of Port #1 on CA #0 (VPI)… INIT (InfiniBand)
Port State of Port #2 on CA #0 (VPI)… DOWN (InfiniBand)
Error Counter Check on CA #0 (VPI)… FAIL
REASON: found errors in the following counters
Errors in /sys/class/infiniband/mlx4_0/ports/1/counters
port_rcv_errors: 93
Kernel Syslog Check … PASS
Node GUID on CA #0 (VPI) … e4:1d:2d:03:00:6f:89:f0
------------------ DONE ---------------------
As you can see there is an error with the port_rcv_errors counter. Also the port state for Port #1 will remain at INIT until i start the subnet manager (/etc/init.d/opensmd start) since we have unmanaged switch. That used to start automatically. So maybe the OFED installation wasn’t completely successful?
Additionally, i am unable to configure NFS for RDMA. e.g.:
echo rdma 20049 > /proc/fs/nfsd/portlist
-bash: echo: write error: Protocol not supported
