Script started on Wed 12 Feb 2014 09:03:20 AM MST
This program will install the MLNX_OFED_LINUX package on your machine.
Note that all other Mellanox, OEM, OFED, or Distribution IB packages will be removed.
Do you want to continue?[y/N]:y
Uninstalling the previous version of MLNX_OFED_LINUX
Starting MLNX_OFED_LINUX-2.1-1.0.0 installation …
… [ list of RPMs being installed ]
Device (03:00.0):
03:00.0 InfiniBand: Mellanox Technologies MT27600 [Connect-IB]
Link Width: 8x
PCI Link Speed: Unknown
Device (03:00.0):
WARNING - device 03:00.0 The MaxReadRequest size is set too low (512 bytes) and will affect performance.
Please consult your server’s vendor and if possible change BIOS settings or use setpci to configure MaxReadReq to 4096 bytes.
/sbin/setpci -s 03:00.0 68.W
2xxx
Change to 4096 bytes:
/sbin/setpci -s 03:00.0 68.W=5xxx
Installation finished successfully.
Attempting to perform Firmware update…
Querying Mellanox devices firmware …
Device #1:
Device: 0000:03:00.0
Part Number: –
Description:
PSID:
Versions: Current Available
FW –
Status: Failed to open device
Failed to query 1 device(s).
Log File: /tmp/MLNX_OFED_LINUX-2.1-1.0.0.4277.logs/fw_update.log
Failed to update Firmware.
See /tmp/MLNX_OFED_LINUX-2.1-1.0.0.4277.logs/fw_update.log
Please reboot your system for the changes to take effect.
root@karma01:/home/bill.mcbee/infiniband# cat /tmp/MLNX_OFED_LINUX-2.1-1.0.0.4277.logs/fw_update.log
CMD: /tmp/sfxter_Wr77SN/mlxfwmanager_sriov_dis_x86_64/mlxfwmanager_pci -u --log-on-update -L /tmp/MLNX_OFED_LINUX-2.1-1.0.0.4277.logs/fw_update.log -y
Device #1:
Part Number: –
Description:
PSID:
FW –
root@karma01:/home/bill.mcbee/infiniband# hca_self_test.ofed
---- Performing Adapter Device Self Test ----
Number of CAs Detected … 1
PCI Device Check … PASS
/usr/bin/hca_self_test.ofed: line 165: [: too many arguments
Host Driver RPM Check … FAIL
REASON: no RPMs found for currently booted kernel 2.6.32-431.3.1.el6.x86_64
Kernel Arch … x86_64
Host Driver Version … NA
Firmware Check on CA #0 (HCA) … NA
Host Driver Initialization … NA
Number of CA Ports Active … NA
Error Counter Check … NA
Kernel Syslog Check … NA
Node GUID on CA #0 (HCA) … NA
------------------ DONE ---------------------
Script done on Wed 12 Feb 2014 09:26:42 AM MST
