Mellanox OFED 4.6 on CentOS w/kernel 4.4
Hello!
I’m trying to run Mellanox OFED with latest kernel-lt from elrepo.
Everything builds fine, but after restart server does not boot.
I tried on physcal server and VM under ESXi 6.7
Using latest stock CentOS 7.6 kernel - everything works fine, but I cannot compile SCST, so I tried with 4.4 kernel.
Adapter - Mellanox ConnectX-4 Lx 10/25GbE
Tried once again
Installation finished successfully.
Preparing… ################################# [100%]
Updating / installing…
1:mlnx-fw-updater-4.6-1.0.1.1 ################################# [100%]
Added 'RUN_FW_UPDATER_ONBOOT=no to /etc/infiniband/openib.conf
Attempting to perform Firmware update…
To load the new driver, run:
/etc/init.d/openibd restart
[root@stor-node2 MLNX_OFED_LINUX-4.6-1.0.1.1-rhel7.6-ext]# /etc/init.d/openibd restart
Unloading HCA driver: [ OK ]
Loading HCA driver and Access Layer: [ OK ]
And after that
Hello Dmitry,
Many thanks for posting your request on the Mellanox Community.
Based on the information provided, I was not able to reproduce the issue on the default kernel of CentOS 7.6, which is 3.10.0-957.el7.x86_64. I was able to compile and install the latest version available through → svn checkout p/scst/svn - Revision 9610: /trunk scst-svn
As for the 4.4 kernel version, it is impossible to test and validate all new kernels released after our official MLNX_OFED GA driver release. We do support all new kernels delivered through the official Linux distribution channels, so I also tested kernel version 3.10.0-957.27.2.el7, and also with this version I did not experience any issue rebuilding SCST with our latest MLNX_OFED driver.
As SCST is a Community driven subsystem, we recommend to reach out to the community, to see if this is related to the latest kernel-lt.
Many thanks,
~Mellanox Technical Support
