Hello!
How can I set pthread_setschedparam (SCHED_FIFO) without changing sched_rt_runtime_us to -1?
See details at https://devtalk.nvidia.com/default/topic/1038742/pthread_setschedparam-sched_fifo-fails/
Thank you!
Hello!
Thank you!
Could you try r32.2.1 and apply the rt patch to try.
Reference to below topic for the rt patches.
https://devtalk.nvidia.com/default/topic/1065701
https://devtalk.nvidia.com/default/topic/1064519
Thank you for the answer!
Unfortunately, applying the rt patch is not appropriate solition for us. Is there any other?
Unfortunately it’s native kernel issue I don’t have others solution now. But you can try r28.3 that kernel version is k4.4 should be without problem.
