PTX miscompiled to SASS in a specific case (shared memory buffer index)?
kernel.ptx (3.9 KB)
I believe I am seeing the attached PTX being miscompiled at CUDA JIT optimization level 2 or above, and I can confirm this is happening with both CUDA 11.8 (520.61.05) and CUDA 12.0 (525.89.02) (tried for sm_86 and sm_61). Here is the part that I think is being miscompiled. We have a 256 4-byte element shared-memory buffer, and despite the guard (setp branch to LBB0_3 if r17 > 255), the buffer is being accessed outside of its size at line 65: st.shared.f32 [%rd23], %f10.
  // demoted variable
  .shared .align 4 .b8 __wg___inference_reduction_1d_parallel_2d_contraction_25_Sum_kernel_0[1024];
  mov.u32   %r1, %ctaid.x;
  mov.u32   %r17, %tid.x;
  bar.sync  0;
  setp.gt.s32   %p1, %r17, 255;
  @%p1 bra  LBB0_3;
  ld.param.u64  %rd10, [__inference_reduction_1d_parallel_2d_contraction_25_Sum_kernel_param_1];
  cvta.to.global.u64  %rd2, %rd10;
  mul.lo.s32  %r3, %r1, 768;
  add.s32   %r16, %r17, -256;
  mad.lo.s32  %r15, %r17, 3, %r3;
  mul.wide.s32  %rd11, %r17, 4;
  mov.u64   %rd12, __wg___inference_reduction_1d_parallel_2d_contraction_25_Sum_kernel_0;
  add.s64   %rd23, %rd12, %rd11;
LBB0_2:
  mul.wide.s32  %rd13, %r15, 4;
  add.s64   %rd14, %rd2, %rd13;
  ld.global.f32   %f5, [%rd14];
  add.f32   %f6, %f5, 0f00000000;
  add.s32   %r12, %r15, 1;
  mul.wide.s32  %rd15, %r12, 4;
  add.s64   %rd16, %rd2, %rd15;
  ld.global.f32   %f7, [%rd16];
  add.f32   %f8, %f6, %f7;
  add.s32   %r13, %r15, 2;
  mul.wide.s32  %rd17, %r13, 4;
  add.s64   %rd18, %rd2, %rd17;
  ld.global.f32   %f9, [%rd18];
  add.f32   %f10, %f8, %f9;
  st.shared.f32   [%rd23], %f10;
  add.s32   %r16, %r16, 256;
  add.s32   %r15, %r15, 768;
  add.s64   %rd23, %rd23, 1024;
  setp.gt.u32   %p2, %r16, 2147483391;
  @%p2 bra  LBB0_2;
LBB0_3:
This isn’t generated from CUDA; so I don’t have a CUDA program to provide to execute and reproduce. The guard itself appears to be correctly rendered in the SASS (checked via ptxas -O2 kernel.ptx --gpu-name sm_86 -o kernel.o && cuobjdump --dump-sass kernel.o | less), but I believe the offset into the buffer is being generated incorrectly at O2 and higher.
Either at opt level O1 or lower or with an extra guard on the buffer index (% 255 or min(…, 255)), we obtain a correct in-bounds access (no CUDA_ERROR_ILLEGAL_ADDRESS). I understand higher opt levels may expose other latent issues, but the PTX here looks fine. The buffer access here is simply tid.x (r17) times four.
I do not see any obvious reasons why this would not get compiled correctly. Have you extracted the generated SASS from the JIT cache to correlate it to the PTX?
I have not done this in years, but I think the way I did this in the past is nuke the entire JIT cache directory tree, JIT compile the kernel, open the cached compiled kernel file and look for ELF as the start of the embedded object file, extract from there into a .o file, then disassemble that.
You could also just file a bug with NVIDIA. But it would advantageous in terms of a speedy handling of the bug to be able to point out where things go wrong.
Thanks. I noticed in a previous post (I think authored by you as well) that using the NSight Eclipse to step through the SASS would help figure out where things may go wrong. Would that be an easier alternative (to extracting SASS from the JIT cache)? I haven’t tried either. This isn’t from CUDA, but I have a way to execute the IR (the PTX is generated from something much high-level via MLIR → LLVM → ptx → cubin) and executed. It’s the store index into the 1024-byte shared memory buffer that’s overrunning - although the PTX itself guarantees that the index is less than 1024.
I have not dealt with JIT-compiled code in nearly a decade, so cannot really recommend the “best” course of action. Extracting the object file from the file in the JIT cache was quite painless using emacs, as I recall. Finding the correct file necessitated nuking the entire JIT cache directory tree first; after that it is easy.
in case anybody cares you can get the SASS also with:
nvcc -arch=sm_86 -cubin -o kernel.cubin kernel.ptx
cuobjdump -sass kernel.cubin
OP has also provided a method that I assume is correct.
I’m not sure why extracting the SASS from the JIT cache is needed, unless you are testing the theory that the driver JIT compiler is producing something different than the offline compiler (ptxas). If that is the case, then the driver version certainly matters.
Using the method I indicated on CUDA 11.4, the SASS seems to be:
        code for sm_86
                Function : __inference_reduction_1d_parallel_2d_contraction_25_Sum_kernel
        .headerflags    @"EF_CUDA_SM86 EF_CUDA_PTX_SM(EF_CUDA_SM86)"
        /*0000*/                   MOV R1, c[0x0][0x28] ;                              /* 0x00000a0000017a02 */
        /* 0x000fc40000000f00 */
        /*0010*/                   S2R R0, SR_TID.X ;                                  /* 0x0000000000007919 */
        /* 0x000e220000002100 */
        /*0020*/                   ULDC.64 UR4, c[0x0][0x118] ;                        /* 0x0000460000047ab9 */
        /* 0x000fe20000000a00 */
        /*0030*/                   BSSY B0, 0x950 ;                                    /* 0x0000091000007945 */
        /* 0x000fe40003800000 */
        /*0040*/                   S2R R3, SR_CTAID.X ;                                /* 0x0000000000037919 */
        /* 0x000e680000002500 */
        /*0050*/                   BAR.SYNC 0x0 ;                                      /* 0x0000000000007b1d */
        /* 0x000fec0000000000 */
        /*0060*/                   ISETP.GT.AND P0, PT, R0, 0xff, PT ;                 /* 0x000000ff0000780c */
        /* 0x001fda0003f04270 */
        /*0070*/               @P0 BRA 0x940 ;                                         /* 0x000008c000000947 */
        /* 0x000fea0003800000 */
        /*0080*/                   IADD3 R5, R0, -0x100, RZ ;                          /* 0xffffff0000057810 */
        /* 0x002fe40007ffe0ff */
        /*0090*/                   LEA R4, R3, R0, 0x8 ;                               /* 0x0000000003047211 */
        /* 0x000fe400078e40ff */
        /*00a0*/                   ISETP.GE.U32.AND P1, PT, R5, 0x7ffffeff, PT ;       /* 0x7ffffeff0500780c */
        /* 0x000fc60003f26070 */
        /*00b0*/                   IMAD R4, R4, 0x3, RZ ;                              /* 0x0000000304047824 */
        /* 0x000fd400078e02ff */
        /*00c0*/               @P1 MOV R11, 0x4 ;                                      /* 0x00000004000b1802 */
        /* 0x000fe40000000f00 */
        /*00d0*/               @P1 IADD3 R8, R4.reuse, 0x1, RZ ;                       /* 0x0000000104081810 */
        /* 0x040fe40007ffe0ff */
        /*00e0*/               @P1 IADD3 R10, R4.reuse, 0x2, RZ ;                      /* 0x00000002040a1810 */
        /* 0x040fe20007ffe0ff */
        /*00f0*/               @P1 IMAD.WIDE R6, R4, R11, c[0x0][0x168] ;              /* 0x00005a0004061625 */
        /* 0x000fc800078e020b */
        /*0100*/               @P1 IMAD.WIDE R8, R8, R11.reuse, c[0x0][0x168] ;        /* 0x00005a0008081625 */
        /* 0x080fe400078e020b */
        /*0110*/               @P1 LDG.E R6, [R6.64] ;                                 /* 0x0000000406061981 */
        /* 0x000ea4000c1e1900 */
        /*0120*/               @P1 IMAD.WIDE R10, R10, R11, c[0x0][0x168] ;            /* 0x00005a000a0a1625 */
        /* 0x000fe400078e020b */
        /*0130*/               @P1 LDG.E R9, [R8.64] ;                                 /* 0x0000000408091981 */
        /* 0x000ee8000c1e1900 */
        /*0140*/               @P1 LDG.E R11, [R10.64] ;                               /* 0x000000040a0b1981 */
        /* 0x000f22000c1e1900 */
        /*0150*/               @P1 IADD3 R5, R5, 0x100, RZ ;                           /* 0x0000010005051810 */
        /* 0x000fe20007ffe0ff */
        /*0160*/                   BSSY B1, 0x5d0 ;                                    /* 0x0000046000017945 */
        /* 0x000fe20003800000 */
        /*0170*/                   PLOP3.LUT P0, PT, P1, PT, PT, 0x8, 0x0 ;            /* 0x000000000000781c */
        /* 0x000fc40000f0e170 */
        /*0180*/                   IADD3 R2, -R5, 0x7ffffeff, RZ ;                     /* 0x7ffffeff05027810 */
        /* 0x000fe40007ffe1ff */
        /*0190*/               @P1 IADD3 R4, R4, 0x300, RZ ;                           /* 0x0000030004041810 */
        /* 0x000fe40007ffe0ff */
        /*01a0*/                   ISETP.GT.AND P2, PT, R2, 0x300, PT ;                /* 0x000003000200780c */
        /* 0x000fe40003f44270 */
        /*01b0*/                   SHF.L.U32 R2, R0, 0x2, RZ ;                         /* 0x0000000200027819 */
        /* 0x000fe200000006ff */
        /*01c0*/               @P1 FADD R12, RZ, R6 ;                                  /* 0x00000006ff0c1221 */
        /* 0x004fc80000000000 */
        /*01d0*/               @P1 FADD R12, R12, R9 ;                                 /* 0x000000090c0c1221 */
        /* 0x008fc80000000000 */
        /*01e0*/               @P1 FADD R7, R12, R11 ;                                 /* 0x0000000b0c071221 */
        /* 0x010fca0000000000 */
        /*01f0*/               @P1 STS [R2], R7 ;                                      /* 0x0000000702001388 */
        /* 0x0001e40000000800 */
        /*0200*/               @P1 IADD3 R2, R2, 0x400, RZ ;                           /* 0x0000040002021810 */
        /* 0x001fe20007ffe0ff */
        /*0210*/              @!P2 BRA 0x5c0 ;                                         /* 0x000003a00000a947 */
        /*0220*/                   PLOP3.LUT P0, PT, PT, PT, PT, 0x8, 0x0 ;            /* 0x000000000000781c */
        /* 0x000fc40003f0e170 */
        /*0230*/                   MOV R7, 0x4 ;                                       /* 0x0000000400077802 */
        /*0240*/                   IADD3 R8, R4.reuse, 0x1, RZ ;                       /* 0x0000000104087810 */
        /*0250*/                   IADD3 R12, R4.reuse, 0x300, RZ ;                    /* 0x00000300040c7810 */
        /*0260*/                   IMAD.WIDE R10, R4.reuse, R7.reuse, c[0x0][0x168] ;  /* 0x00005a00040a7625 */
        /* 0x0c0fe200078e0207 */
        /*0270*/                   IADD3 R22, R4.reuse, 0x600, RZ ;                    /* 0x0000060004167810 */
        /*0280*/                   IADD3 R24, R4, 0x900, RZ ;                          /* 0x0000090004187810 */
        /*0290*/                   IMAD.WIDE R8, R8, R7.reuse, c[0x0][0x168] ;         /* 0x00005a0008087625 */
        /* 0x080fe200078e0207 */
        /*02a0*/                   IADD3 R16, R4.reuse, 0x301, RZ ;                    /* 0x0000030104107810 */
        /*02b0*/                   LDG.E R6, [R10.64] ;                                /* 0x000000040a067981 */
        /* 0x0000a2000c1e1900 */
        /*02c0*/                   IADD3 R18, R4, 0x601, RZ ;                          /* 0x0000060104127810 */
        /*02d0*/                   IMAD.WIDE R22, R22, R7.reuse, c[0x0][0x168] ;       /* 0x00005a0016167625 */
        /*02e0*/                   IADD3 R14, R4, 0x2, RZ ;                            /* 0x00000002040e7810 */
        /*02f0*/                   LDG.E R8, [R8.64] ;                                 /* 0x0000000408087981 */
        /* 0x0002e4000c1e1900 */
        /*0300*/                   IMAD.WIDE R24, R24, R7.reuse, c[0x0][0x168] ;       /* 0x00005a0018187625 */
        /*0310*/                   IADD3 R26, R4.reuse, 0x302, RZ ;                    /* 0x00000302041a7810 */
        /*0320*/                   LDG.E R22, [R22.64] ;                               /* 0x0000000416167981 */
        /*0330*/                   IADD3 R10, R4, 0x901, RZ ;                          /* 0x00000901040a7810 */
        /*0340*/                   IMAD.WIDE R12, R12, R7.reuse, c[0x0][0x168] ;       /* 0x00005a000c0c7625 */
        /*0350*/                   IADD3 R28, R4.reuse, 0x602, RZ ;                    /* 0x00000602041c7810 */
        /*0360*/                   LDG.E R24, [R24.64] ;                               /* 0x0000000418187981 */
        /* 0x000f62000c1e1900 */
        /*0370*/                   IADD3 R30, R4, 0x902, RZ ;                          /* 0x00000902041e7810 */
        /*0380*/                   IMAD.WIDE R16, R16, R7, c[0x0][0x168] ;             /* 0x00005a0010107625 */
        /* 0x000fc400078e0207 */
        /*0390*/                   LDG.E R20, [R12.64] ;                               /* 0x000000040c147981 */
        /* 0x000164000c1e1900 */
        /*03a0*/                   IMAD.WIDE R18, R18, R7.reuse, c[0x0][0x168] ;       /* 0x00005a0012127625 */
        /* 0x080fe400078e0207 */
        /*03b0*/                   LDG.E R9, [R16.64] ;                                /* 0x0000000410097981 */
        /* 0x002364000c1e1900 */
        /*03c0*/                   IMAD.WIDE R10, R10, R7.reuse, c[0x0][0x168] ;       /* 0x00005a000a0a7625 */
        /*03d0*/                   LDG.E R21, [R18.64] ;                               /* 0x0000000412157981 */
        /*03e0*/                   IMAD.WIDE R14, R14, R7, c[0x0][0x168] ;             /* 0x00005a000e0e7625 */
        /*03f0*/                   LDG.E R11, [R10.64] ;                               /* 0x000000040a0b7981 */
        /* 0x000f64000c1e1900 */
        /*0400*/                   IMAD.WIDE R16, R26, R7.reuse, c[0x0][0x168] ;       /* 0x00005a001a107625 */
        /* 0x082fe400078e0207 */
        /*0410*/                   LDG.E R14, [R14.64] ;                               /* 0x000000040e0e7981 */
        /*0420*/                   IMAD.WIDE R12, R28, R7.reuse, c[0x0][0x168] ;       /* 0x00005a001c0c7625 */
        /* 0x081fe400078e0207 */
        /*0430*/                   LDG.E R16, [R16.64] ;                               /* 0x0000000410107981 */
        /*0440*/                   IMAD.WIDE R18, R30, R7, c[0x0][0x168] ;             /* 0x00005a001e127625 */
        /*0450*/                   LDG.E R12, [R12.64] ;                               /* 0x000000040c0c7981 */
        /* 0x000f68000c1e1900 */
        /*0460*/                   LDG.E R18, [R18.64] ;                               /* 0x0000000412127981 */
        /*0470*/                   IADD3 R5, R5, 0x400, RZ ;                           /* 0x0000040005057810 */
        /* 0x000fc80007ffe0ff */
        /*0480*/                   ISETP.GE.U32.AND P1, PT, R5, 0x7ffffbff, PT ;       /* 0x7ffffbff0500780c */
        /* 0x000fe40003f26070 */
        /*0490*/                   IADD3 R4, R4, 0xc00, RZ ;                           /* 0x00000c0004047810 */
        /*04a0*/                   FADD R7, RZ, R6 ;                                   /* 0x00000006ff077221 */
        /*04b0*/                   FADD R7, R7, R8 ;                                   /* 0x0000000807077221 */
        /* 0x008fe20000000000 */
        /*04c0*/                   FADD R22, RZ, R22 ;                                 /* 0x00000016ff167221 */
        /* 0x010fe20000000000 */
        /*04d0*/                   FADD R24, RZ, R24 ;                                 /* 0x00000018ff187221 */
        /* 0x020fe20000000000 */
        /*04e0*/                   FADD R20, RZ, R20 ;                                 /* 0x00000014ff147221 */
        /* 0x000fc80000000000 */
        /*04f0*/                   FADD R9, R20, R9 ;                                  /* 0x0000000914097221 */
        /* 0x000fe20000000000 */
        /*0500*/                   FADD R21, R22, R21 ;                                /* 0x0000001516157221 */
        /*0510*/                   FADD R11, R24, R11 ;                                /* 0x0000000b180b7221 */
        /*0520*/                   FADD R7, R7, R14 ;                                  /* 0x0000000e07077221 */
        /*0530*/                   FADD R9, R9, R16 ;                                  /* 0x0000001009097221 */
        /*0540*/                   FADD R21, R21, R12 ;                                /* 0x0000000c15157221 */
        /*0550*/                   FADD R11, R11, R18 ;                                /* 0x000000120b0b7221 */
        /* 0x000fe40000000000 */
        /*0560*/                   STS [R2], R7 ;                                      /* 0x0000000702007388 */
        /* 0x000fe80000000800 */
        /*0570*/                   STS [R2+0x400], R9 ;                                /* 0x0004000902007388 */
        /*0580*/                   STS [R2+0x800], R21 ;                               /* 0x0008001502007388 */
        /*0590*/                   STS [R2+0xc00], R11 ;                               /* 0x000c000b02007388 */
        /*05a0*/                   IADD3 R2, R2, 0x1000, RZ ;                          /* 0x0000100002027810 */
        /*05b0*/              @!P1 BRA 0x230 ;                                         /* 0xfffffc7000009947 */
        /* 0x000fea000383ffff */
        /*05c0*/                   BSYNC B1 ;                                          /* 0x0000000000017941 */
        /*05d0*/                   IADD3 R6, -R5, 0x7ffffeff, RZ ;                     /* 0x7ffffeff05067810 */
        /* 0x000fe20007ffe1ff */
        /*05e0*/                   BSSY B1, 0x800 ;                                    /* 0x0000021000017945 */
        /* 0x000fe60003800000 */
        /*05f0*/                   ISETP.GT.AND P1, PT, R6, 0x100, PT ;                /* 0x000001000600780c */
        /* 0x000fda0003f24270 */
        /*0600*/              @!P1 BRA 0x7f0 ;                                         /* 0x000001e000009947 */
        /*0610*/                   MOV R11, 0x4 ;                                      /* 0x00000004000b7802 */
        /*0620*/                   IADD3 R6, R4.reuse, 0x300, RZ ;                     /* 0x0000030004067810 */
        /*0630*/                   IADD3 R14, R4.reuse, 0x1, RZ ;                      /* 0x00000001040e7810 */
        /*0640*/                   IMAD.WIDE R12, R4.reuse, R11, c[0x0][0x168] ;       /* 0x00005a00040c7625 */
        /* 0x040fe200078e020b */
        /*0650*/                   IADD3 R8, R4, 0x301, RZ ;                           /* 0x0000030104087810 */
        /* 0x000fc60007ffe0ff */
        /*0660*/                   IMAD.WIDE R6, R6, R11.reuse, c[0x0][0x168] ;        /* 0x00005a0006067625 */
        /* 0x080fe200078e020b */
        /*0670*/                   IADD3 R16, R4.reuse, 0x2, RZ ;                      /* 0x0000000204107810 */
        /*0680*/                   LDG.E R12, [R12.64] ;                               /* 0x000000040c0c7981 */
        /* 0x000ea2000c1e1900 */
        /*0690*/                   IADD3 R10, R4, 0x302, RZ ;                          /* 0x00000302040a7810 */
        /*06a0*/                   IMAD.WIDE R14, R14, R11.reuse, c[0x0][0x168] ;      /* 0x00005a000e0e7625 */
        /*06b0*/                   LDG.E R6, [R6.64] ;                                 /* 0x0000000406067981 */
        /* 0x000ee4000c1e1900 */
        /*06c0*/                   IMAD.WIDE R8, R8, R11.reuse, c[0x0][0x168] ;        /* 0x00005a0008087625 */
        /*06d0*/                   LDG.E R15, [R14.64] ;                               /* 0x000000040e0f7981 */
        /* 0x000f24000c1e1900 */
        /*06e0*/                   IMAD.WIDE R16, R16, R11, c[0x0][0x168] ;            /* 0x00005a0010107625 */
        /* 0x000fc400078e020b */
        /*06f0*/                   LDG.E R8, [R8.64] ;                                 /* 0x0000000408087981 */
        /*0700*/                   IMAD.WIDE R10, R10, R11, c[0x0][0x168] ;            /* 0x00005a000a0a7625 */
        /*0710*/                   LDG.E R17, [R16.64] ;                               /* 0x0000000410117981 */
        /*0720*/                   LDG.E R10, [R10.64] ;                               /* 0x000000040a0a7981 */
        /*0730*/                   PLOP3.LUT P0, PT, PT, PT, PT, 0x8, 0x0 ;            /* 0x000000000000781c */
        /* 0x000fe40003f0e170 */
        /*0740*/                   IADD3 R5, R5, 0x200, RZ ;                           /* 0x0000020005057810 */
        /* 0x000fc40007ffe0ff */
        /*0750*/                   IADD3 R4, R4, 0x600, RZ ;                           /* 0x0000060004047810 */
        /*0760*/                   FADD R12, RZ, R12 ;                                 /* 0x0000000cff0c7221 */
        /* 0x004fe20000000000 */
        /*0770*/                   FADD R13, RZ, R6 ;                                  /* 0x00000006ff0d7221 */
        /* 0x008fc60000000000 */
        /*0780*/                   FADD R12, R12, R15 ;                                /* 0x0000000f0c0c7221 */
        /*0790*/                   FADD R13, R13, R8 ;                                 /* 0x000000080d0d7221 */
        /* 0x020fc60000000000 */
        /*07a0*/                   FADD R7, R12, R17 ;                                 /* 0x000000110c077221 */
        /*07b0*/                   FADD R13, R13, R10 ;                                /* 0x0000000a0d0d7221 */
        /*07c0*/                   STS [R2], R7 ;                                      /* 0x0000000702007388 */
        /*07d0*/                   STS [R2+0x400], R13 ;                               /* 0x0004000d02007388 */
        /*07e0*/                   IADD3 R2, R2, 0x800, RZ ;                           /* 0x0000080002027810 */
        /* 0x001fc40007ffe0ff */
        /*07f0*/                   BSYNC B1 ;                                          /* 0x0000000000017941 */
        /*0800*/                   ISETP.GT.U32.OR P0, PT, R5, 0x7ffffeff, P0 ;        /* 0x7ffffeff0500780c */
        /* 0x000fda0000704470 */
        /*0810*/              @!P0 BRA 0x940 ;                                         /* 0x0000012000008947 */
        /*0820*/                   MOV R11, 0x4 ;                                      /* 0x00000004000b7802 */
        /*0830*/                   IADD3 R8, R4.reuse, 0x1, RZ ;                       /* 0x0000000104087810 */
        /*0840*/                   IADD3 R10, R4.reuse, 0x2, RZ ;                      /* 0x00000002040a7810 */
        /*0850*/                   IMAD.WIDE R6, R4, R11, c[0x0][0x168] ;              /* 0x00005a0004067625 */
        /*0860*/                   IMAD.WIDE R8, R8, R11.reuse, c[0x0][0x168] ;        /* 0x00005a0008087625 */
        /*0870*/                   LDG.E R6, [R6.64] ;                                 /* 0x0000000406067981 */
        /*0880*/                   IMAD.WIDE R10, R10, R11, c[0x0][0x168] ;            /* 0x00005a000a0a7625 */
        /*0890*/                   LDG.E R9, [R8.64] ;                                 /* 0x0000000408097981 */
        /*08a0*/                   LDG.E R11, [R10.64] ;                               /* 0x000000040a0b7981 */
        /*08b0*/                   IADD3 R5, R5, 0x100, RZ ;                           /* 0x0000010005057810 */
        /*08c0*/                   IADD3 R4, R4, 0x300, RZ ;                           /* 0x0000030004047810 */
        /*08d0*/                   ISETP.GT.U32.AND P0, PT, R5, 0x7ffffeff, PT ;       /* 0x7ffffeff0500780c */
        /* 0x000fe20003f04070 */
        /*08e0*/                   FADD R12, RZ, R6 ;                                  /* 0x00000006ff0c7221 */
        /*08f0*/                   FADD R12, R12, R9 ;                                 /* 0x000000090c0c7221 */
        /*0900*/                   FADD R13, R12, R11 ;                                /* 0x0000000b0c0d7221 */
        /*0910*/                   STS [R2], R13 ;                                     /* 0x0000000d02007388 */
        /*0920*/                   IADD3 R2, R2, 0x400, RZ ;                           /* 0x0000040002027810 */
        /*0930*/               @P0 BRA 0x820 ;                                         /* 0xfffffee000000947 */
        /*0940*/                   BSYNC B0 ;                                          /* 0x0000000000007941 */
        /* 0x002fea0003800000 */
        /*0950*/                   BAR.SYNC 0x0 ;                                      /* 0x0000000000007b1d */
        /*0960*/                   ISETP.GT.AND P0, PT, R0, RZ, PT ;                   /* 0x000000ff0000720c */
        /* 0x000fe20003f04270 */
        /*0970*/                   BSSY B0, 0xb10 ;                                    /* 0x0000019000007945 */
        /* 0x000fd80003800000 */
        /*0980*/               @P0 BRA 0xb00 ;                                         /* 0x0000017000000947 */
        /*0990*/                   MOV R2, 0x4 ;                                       /* 0x0000000400027802 */
        /* 0x000fca0000000f00 */
        /*09a0*/                   IMAD.WIDE R2, R3, R2, c[0x0][0x198] ;               /* 0x0000660003027625 */
        /* 0x000fca00078e0202 */
        /*09b0*/                   LDG.E R13, [R2.64] ;                                /* 0x00000004020d7981 */
        /* 0x000162000c1e1900 */
        /*09c0*/                   BSSY B1, 0xaf0 ;                                    /* 0x0000012000017945 */
        /*09d0*/                   MOV R12, RZ ;                                       /* 0x000000ff000c7202 */
        /*09e0*/                   LDS.128 R8, [R12] ;                                 /* 0x000000000c087984 */
        /* 0x000e680000000c00 */
        /*09f0*/                   LDS.128 R4, [R12+0x10] ;                            /* 0x000010000c047984 */
        /* 0x0004e40000000c00 */
        /*0a00*/                   IADD3 R12, R12, 0x20, RZ ;                          /* 0x000000200c0c7810 */
        /* 0x004fc80007ffe0ff */
        /*0a10*/                   ISETP.NE.AND P0, PT, R12, 0x400, PT ;               /* 0x000004000c00780c */
        /* 0x000fe20003f05270 */
        /*0a20*/                   FADD R8, R8, R13 ;                                  /* 0x0000000d08087221 */
        /* 0x022fc80000000000 */
        /*0a30*/                   FADD R9, R9, R8 ;                                   /* 0x0000000809097221 */
        /*0a40*/                   FADD R10, R10, R9 ;                                 /* 0x000000090a0a7221 */
        /*0a50*/                   FADD R11, R11, R10 ;                                /* 0x0000000a0b0b7221 */
        /*0a60*/                   FADD R4, R11, R4 ;                                  /* 0x000000040b047221 */
        /*0a70*/                   FADD R5, R5, R4 ;                                   /* 0x0000000405057221 */
        /*0a80*/                   FADD R6, R6, R5 ;                                   /* 0x0000000506067221 */
        /*0a90*/                   FADD R13, R7, R6 ;                                  /* 0x00000006070d7221 */
        /*0aa0*/               @P0 BRA 0x9e0 ;                                         /* 0xffffff3000000947 */
        /*0ab0*/                   ISETP.GE.AND P0, PT, R0.reuse, -0xff, PT ;          /* 0xffffff010000780c */
        /* 0x040fe40003f06270 */
        /*0ac0*/                   IADD3 R0, R0, 0x100, RZ ;                           /* 0x0000010000007810 */
        /* 0x000fd60007ffe0ff */
        /*0ad0*/              @!P0 BRA 0x9d0 ;                                         /* 0xfffffef000008947 */
        /*0ae0*/                   BSYNC B1 ;                                          /* 0x0000000000017941 */
        /*0af0*/                   STG.E [R2.64], R13 ;                                /* 0x0000000d02007986 */
        /* 0x0003e4000c101904 */
        /*0b00*/                   BSYNC B0 ;                                          /* 0x0000000000007941 */
        /*0b10*/                   BAR.SYNC 0x0 ;                                      /* 0x0000000000007b1d */
        /*0b20*/                   EXIT ;                                              /* 0x000000000000794d */
        /*0b30*/                   BRA 0xb30;                                          /* 0xfffffff000007947 */
        /* 0x000fc0000383ffff */
        /*0b40*/                   NOP;                                                /* 0x0000000000007918 */
        /* 0x000fc00000000000 */
        /*0b50*/                   NOP;                                                /* 0x0000000000007918 */
        /*0b60*/                   NOP;                                                /* 0x0000000000007918 */
        /*0b70*/                   NOP;                                                /* 0x0000000000007918 */
        /*0b80*/                   NOP;                                                /* 0x0000000000007918 */
        /*0b90*/                   NOP;                                                /* 0x0000000000007918 */
        /*0ba0*/                   NOP;                                                /* 0x0000000000007918 */
        /*0bb0*/                   NOP;                                                /* 0x0000000000007918 */
        /*0bc0*/                   NOP;                                                /* 0x0000000000007918 */
        /*0bd0*/                   NOP;                                                /* 0x0000000000007918 */
        /*0be0*/                   NOP;                                                /* 0x0000000000007918 */
        /*0bf0*/                   NOP;                                                /* 0x0000000000007918 */
I would not suggest filing a bug with NVIDIA for an incomplete test case. I can’t imagine why an “ordinary” CUDA test case can’t be built around this, and indeed it could be useful for inspection/debug. I don’t expect anyone at NVIDIA is going to spend time trying to reverse engineer what the set of “proper” allocations would be to run a presumed correct version of the test, by studying your PTX.
You would almost certainly get asked to provide a complete test case using a NVIDIA toolchain, if you want anyone to look at it.
Thanks - I too feel there shouldn’t be a difference between the AOT mode and the JIT mode - both would be using the same compilation flow given the same optimization level and options. I’m attaching the SASS with O1 and O2 for the kernel.ptx.
An ordinary CUDA test case will almost certainly not yield the same sequence of instructions in PTX that may reproduce the bug if it indeed is a bug in one of the passes from PTX → SASS - the distance from CUDA is too much to build a reproducer.
Depends on how we look at it. You are right that the test case is incomplete from an end-to-end execution standpoint, but a compiler developer debugging mis-compilation would be testing the input and output of a potential culprit pass, and closer to a unit test is what is desirable instead of an integration test from a compiler engineering standpoint. The PTX → SASS part going through an -O pipeline would apply several tens of passes, I assume, and the input/output of the culprit pass is what would contribute to a unit test case for a compiler developer to debug and verify. I verified that O0 and O1 levels for CUDA JIT lead to correctly executing code here, but anything opt level 2 or above doesn’t.
All of this said, in order to demonstrate there is indeed an issue with the SASS generated, I would need to provide a way to execute the PTX (with a driver), but this would require a lot of setup (MLIR/LLVM trunk build) for the reproducer because the host + device code is compiled in a specific way into a single module that wouldn’t allow one to start from PTX. (The compiled function is passed numpy arrays from Python.) But I suspect someone from the compiler team would ultimately just look at the PTX → SASS steps to see where the code was being incorrectly lowered.
O2.s (42.2 KB)
O1.s (15.2 KB)
That makes no sense to me at all. A ptx kernel is ready to go. You already have a PTX kernel. I compiled it successfully, already. You modify a CUDA sample code like vectorAddDrv to suck in your ptx file, build program using the driver API, and of course launch the kernel with appropriate allocations and parameters. That’s it. There is no such thing as a numpy array being fed into a PTX kernel. It takes C-style pointers, scalars, and that is it. PTX knows nothing about higher level objects. With a bit more information I could do it myself. It’s not anywhere near as hard or involved as you seem to be suggesting. But yes, it is not zero work. And I think it is work that NVIDIA is unlikely to do for you.
We can agree to disagree. Nobody is going to assume a lowering error without a test case to confirm it. I’ll say this based on experience. If you submit a bug like what is in this post so far, the incoming processing team (QA) is almost certainly going to ask you for a self-contained reproducer. I doubt that I am wrong there, based on my experience. Bugs don’t go directly to the development team, and even if they somehow did, the dev team would kick it right back to QA if there is no in-house reproducer.
Do as you wish, of course. The bug system has no validation of this type for entry of a bug. The rub will come when a human looks at it. Perhaps you will prove me wrong.
Good luck!
I see - I didn’t realize this was what you meant. (I had read it as writing an equivalent CUDA C test case that nearly generates that PTX.) Setting up CUDA with inline PTX should be pretty straightforward and I will hope that it reproduces the issue we observed on the JIT path. (The SASS can be compared if it really doesn’t.)
At least historically, that assumption was not valid. The release cycles for CUDA releases with the offline version of ptxas and the driver releases with the JIT version of ptxas incorporated in them never lined up perfectly due to engineering release processes. That means subtle differences existed and a given JIT compiler in a driver never matched any particular offline compiler version perfectly (very close, certainly; but close only counts in horseshoes and hand grenades).
This is why I learned how to extract object files from the JIT cache for code that was JIT compiled in a customer’s use case, to make absolutely sure the compiler used by me and by customer were bit-for-bit identical.
Has any of this changed? I don’t know and would err on the side of caution.
not inline PTX
Study the vectorAddDrv sample code. Use the kernel.ptx file you already posted in your first posting in this thread. Verbatim.
It is certainly true that a bug report won’t be looked at by NVIDIA’s developers until NVIDIA’s customer-facing engineers have reproduced the issue in-house first. Bug filers should include as much information as possible to make repro easy (so minimal, self-contained repro codes) and also respond to follow-up questions and requests from NVIDIA’s repro team in a timely manner.
One important advantage the bug reporting process has over forum discussions is that it ensures confidentiality: only the bug filer and relevant NVIDIA personnel have access to the information supplied. This means that more, and more detailed, information can be made available compared to a forum discussion.
Generally speaking, I find that people bringing alleged bugs to this forum are often very guarded about all kinds of information that I would consider necessary to resolve the issue at hand. The lack of information leads to speculation, false leads, etc; it is all very inefficient. That is why I tend to encourage CUDA programmers to file bug reports instead of trying to resolve suspected bugs in this forum.
Here you go: a CUDA-based reproducer that reproduces the issue both ways:
# Using the typical compiler.
$ nvcc --ptxas-options --opt-level=0  -O3 -arch=sm_80 -o test_case test_case.cu; ./test_case
# Runs fine.
$ nvcc --ptxas-options --opt-level=3  -O3 -arch=sm_80 -o test_case test_case.cu; ./test_case
cudaDeviceSynchronize failed after kernel launch. Cuda error code: an illegal memory access was encountered.
Same test case and issue reproduced via CUDA driver API:
$ nvcc test_case_driver_version.cpp -lcuda;
# Run with PTX opt level 3, and it results in an illegal memory access.
./a.out 3;
# Run the same code with PTX optimization level 0, and it executes fine.
./a.out 0;
test_case_driver_version.cpp (9.7 KB)
README.md (656 Bytes)
test_case.cu (5.1 KB)
reduction_kernel.ptx (2.6 KB)
splendid.
If you want to file a bug, I think you’ll be better off. I doubt I would spend much time with it, because although I can navigate PTX, its much less familiar to me compared to CUDA C++. And given that it seems to work or not based on ptxas optimization level, that certainly is a possible indicator (not a guarantee) of a toolchain problem.
Thanks for the pointer. I filed a bug, but I don’t see a way I can upload the test case.
https://developer.nvidia.com/nvidia_bug/4027772
If they are going to follow up via a separate channel, that should be fine. I’m not sure I should paste everything inline. (The bug comment section doesn’t understand markdown formatting.)
They typically do follow up on a private channel (email). You can also just include a link to this forum posting in your bug report, to indicate where to get the files.
I’ve already dropped a link to this forum posting in your bug report.
This is resolved as of CUDA 12.2 .
