How does one relate the entry function names in the output from --ptxas-options=-v to the global kernels in the source file – for example, the output of “make ptxas=1” from /C/src/reduction has lines such as:
ptxas info : Compiling entry function '_Z7reduce6IdLj1ELb0EEvPT_S1_j' for 'sm_20'
ptxas info : Used 16 registers, 52 bytes cmem[0], 4 bytes cmem[16]
ptxas info : Compiling entry function '_Z7reduce6IdLj2ELb0EEvPT_S1_j' for 'sm_20'
and reduce6() has the prototype:
template <class T, unsigned int blockSize, bool nIsPow2>
__global__ void
reduce6(T *g_idata, T *g_odata, unsigned int n);
So which flavor of reduce6 does _Z7reduce6IdLj1ELb0EEvPT_S1_j correspond to?
Thanks,
