Hi
We want to set up pgi compiler on a linux (32-bit) cluster. The machine
has 32 dual-cpu compute nodes with Myrinet interconnect. We have F90
codes with MPI that will run on the cluster. Code compilation will be
done only on the head node, and the executables will be run on the
compute nodes (up to 64 cpus). Which pgi license should we buy:
Workstation or Server?
Hi Velan,
Do you mind send this question to sales@pgroup.com? They will be better able to assess your needs.
Thanks,
Mat
