PyDs Image Folder Inference
• Hardware Platform (Jetson / GPU) : both
• DeepStream Version: 7.1
from pyds import ?
IMG_DIR = "/testing"
MODEL_CONFIG = "config_infer_testing.txt"
Hi team,
I’m using DeepStream 7.1 and want to run inference on images stored in a folder (like /testing), using PyDS and my config_infer_testing.txt.
I don’t want to use any video or camera input — just load images one by one, pass them through the DeepStream pipeline, and get the output embeddings (like a n-d vector).
I tried using NvDsInferContext from pyds but it says it’s not available.
What’s the correct way to load and infer individual images using PyDS or DeepStream Python API?
Refer to the following command line to build your python program. For dGPU, delete the mjpeg property of nvv4l2decoder. If you want to infer the images in the entire directory, consider using multifilesrc
gst-launch-1.0 -e nvstreammux name=mux batch-size=1 width=1920 height=1080 ! nvinfer config-file-path=/opt/nvidia/deepstream/deepstream/sources/apps/sample_apps/deepstream-test1/dstest1_pgie_config.txt ! nvvideoconvert ! nvdsosd ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=I420" ! nvjpegenc ! filesink location=out1.jpg filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg ! jpegparse ! nvv4l2decoder mjpeg=true ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=(string)NV12" ! mux.sink_0
Hi @junshengy ..
First of all thank you so much for replying…I am trying to build a DeepStream pipeline to perform inference on images using nvinfer (YOLOv8 model) but I’m running into issues with linking elements in my pipeline.
Here’s the command I tried:
gst-launch-1.0 -e \
  filesrc location=/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg ! \
  jpegparse ! nvv4l2decoder ! nvvideoconvert ! \
  "video/x-raw(memory:NVMM), format=NV12" ! \
  nvstreammux name=mux batch-size=1 width=1280 height=720 ! \
  nvinfer config-file-path=config_infer_primary_yoloV8_F-H.txt ! fakesink
But I get this error:
WARNING: erroneous pipeline: could not link nvvideoconvert0 to mux, mux can't handle caps video/x-raw(memory:NVMM), format=(string)NV12
I also tried this more complex pipeline with decode, infer, and saving the output:
gst-launch-1.0 -e \
  nvstreammux name=mux batch-size=1 width=1920 height=1080 ! \
  nvinfer config-file-path=config_infer_primary_yoloV8_F-H.txt ! \
  nvvideoconvert ! nvdsosd ! nvvideoconvert ! "video/x-raw(memory:NVMM), format=I420" ! \
  nvjpegenc ! filesink location=out1.jpg \
This gives me:
WARNING: erroneous pipeline: no property "mjpeg" in element "nvv4l2decoder0"
My questions:
  1. How can I fix the pipeline so nvvideoconvert output is compatible with nvstreammux? I keep seeing caps negotiation errors around video/x-raw(memory:NVMM), format=NV12.
  2. How can I infer on a directory of images efficiently? Would multifilesrc be appropriate? Any example pipelines?
  3. I want to extract the raw tensor output from nvinfer (or parse the tensor output) for custom post-processing in Python.
    • Is there a way to do this using the DeepStream Python bindings (pyds)?
    • Any minimal example or guidance on how to access the tensor data from the inference output metadata?
I’d really appreciate any help or pointers.
Thanks in advance!
This pipeline is wrong so it won’t work.
Refer to the above reply to solve this problem
According to the above reply, build the pipeline and it will work normally.
Assuming your images are named frame_0001.jpg, frame_0002.jpg, etc., you can use the following command:
gst-launch-1.0 multifilesrc location="frame_%04d.jpg" index=1 caps="image/jpeg,framerate=(fraction)30/1" ! nvv4l2decoder  !  ............
/opt/nvidia/deepstream/deepstream/sources/deepstream_python_apps/apps/deepstream-ssd-parser shows how to use pyds to parse the output tensor
Actually, this worked !!
root@Nitro-AN515-56:~/DS_test# gst-launch-1.0 -e     uridecodebin uri=file:///opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg !     nvvideoconvert !     "video/x-raw(memory:NVMM), format=NV12" !     m.sink_0     nvstreammux name=m batch-size=1 width=1280 height=720 !     nvinfer config-file-path=config_infer_primary_yoloV8_F-H.txt ! fakesink
Setting pipeline to PAUSED ...
0:00:00.274510246   266 0x5b6371896ba0 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/root/DeepStream-Yolo/p-h_model_b1_gpu0_fp16.engine
Implicit layer support has been deprecated
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:327 [Implicit Engine Info]: layers num: 0
0:00:00.274546046   266 0x5b6371896ba0 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<nvinfer0> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /root/DeepStream-Yolo/p-h_model_b1_gpu0_fp16.engine
0:00:00.281131583   266 0x5b6371896ba0 INFO                 nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<nvinfer0> [UID 1]: Load new model:config_infer_primary_yoloV8_F-H.txt sucessfully
Pipeline is PREROLLING ...
Using GPU 0 (NVIDIA GeForce GTX 1650, 14 SMs, 1024 th/SM max, CC 7.5, ECC off)
nvstreammux: Successfully handled EOS for source_id=0
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
Redistribute latency...
New clock: GstSystemClock
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:00.001340582
Setting pipeline to NULL ...
Freeing pipeline ...
same in pyds…
import sys
import gi
import os # Import os module for path manipulation
# Import bus_call from common.bus_call
# Ensure that '/root/deepstream_python_apps/apps/' is in your PYTHONPATH or sys.path
# or that the common module is otherwise discoverable.
sys.path.append('/root/deepstream_python_apps/apps/')
from common.bus_call import bus_call
gi.require_version('Gst', '1.0')
from gi.repository import GObject, Gst, GLib
import pyds # DeepStream Python Bindings
# Define pipeline properties
MUXER_WIDTH = 1280
MUXER_HEIGHT = 720
BATCH_SIZE = 1 # Simplest case: 1 stream in batch
# --- Common Paths and Configuration ---
CURRENT_DIR = os.path.dirname(os.path.abspath(__file__))
IMAGE_FILE = '/opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg'
CONFIG_FILE_PATH = os.path.join(CURRENT_DIR, "config_infer_primary_yoloV8_F-H.txt")
# --- Main Function ---
def main():
    # 1. Standard GStreamer initialization
    # Gst.init(None) initializes the GStreamer library.
    Gst.init(None)
    # 2. Create the GStreamer pipeline
    # Gst.Pipeline.new() creates an empty pipeline.
    pipeline = Gst.Pipeline.new("simplest-deepstream-pipeline")
    # 3. Create GStreamer elements
    # Gst.ElementFactory.make() creates an element by its factory name.
    # The second argument is a unique name for the element instance.
    # Source: uridecodebin - Decodes data from a URI (file, RTSP, etc.)
    print(f"Creating uridecodebin for: {IMAGE_FILE}...")
    source = Gst.ElementFactory.make("uridecodebin", "uri-decode-bin")
    # Set the URI property to the image file
    source.set_property("uri", f"file://{IMAGE_FILE}")
    # Video Converter: nvvideoconvert - Converts video formats on NVIDIA GPU
    print("Creating nvvideoconvert...")
    nvvidconv = Gst.ElementFactory.make("nvvideoconvert", "nvvideo-converter")
    # Capsfilter: Ensures the format is NV12 and memory is NVMM (NVIDIA Memory)
    # This is crucial for DeepStream elements like nvstreammux.
    print("Creating capsfilter for NVMM, NV12...")
    caps_nvmm_nv12 = Gst.ElementFactory.make("capsfilter", "caps-nvmm-nv12")
    # Define the capabilities (format, memory type, resolution)
    caps_string = f"video/x-raw(memory:NVMM), format=NV12, width={MUXER_WIDTH}, height={MUXER_HEIGHT}"
    caps = Gst.Caps.from_string(caps_string)
    caps_nvmm_nv12.set_property("caps", caps)
    # Stream Muxer: nvstreammux - Batches frames from multiple sources
    # This is a core DeepStream element.
    print("Creating nvstreammux...")
    streammux = Gst.ElementFactory.make("nvstreammux", "stream-muxer")
    streammux.set_property("width", MUXER_WIDTH)
    streammux.set_property("height", MUXER_HEIGHT)
    streammux.set_property("batch-size", BATCH_SIZE)
    # For file sources, it's generally not a 'live' stream in the traditional sense for muxer
    streammux.set_property("nvbuf-memory-type", 0) # 0 for NVBUF_MEM_CUDA_UNIFIED
    # Primary GIE (Inference Engine): nvinfer - Runs AI models
    # This element performs the actual deep learning inference.
    print("Creating nvinfer...")
    pgie = Gst.ElementFactory.make("nvinfer", "primary-gie")
    # Set the actual config file path
    print(f"Setting nvinfer config-file-path to: {CONFIG_FILE_PATH}")
    pgie.set_property("config-file-path", CONFIG_FILE_PATH)
    # Sink: fakesink - Discards data, useful for testing pipeline flow
    print("Creating fakesink...")
    sink = Gst.ElementFactory.make("fakesink", "fake-sink")
    sink.set_property("sync", False) # Don't sync to clock for fakesink
    sink.set_property("qos", False) # Disable Quality-of-Service for fakesink
    # 4. Add elements to the pipeline
    # All elements must be added to the pipeline before linking.
    print("Adding elements to pipeline...")
    pipeline.add(source)
    pipeline.add(nvvidconv)
    pipeline.add(caps_nvmm_nv12)
    pipeline.add(streammux)
    pipeline.add(pgie)
    pipeline.add(sink)
    # 5. Link elements
    # Link elements in the correct order.
    # Source -> nvvideoconvert -> capsfilter -> nvstreammux.sink_0
    # nvstreammux.src -> nvinfer -> fakesink
    # Callback for uridecodebin's dynamically created pads
    def cb_newpad(decodebin, decoder_src_pad, data):
        print("In cb_newpad")
        caps = decoder_src_pad.get_current_caps()
        gststruct = caps.get_structure(0)
        gstname = gststruct.get_name()
        # Check if the pad is for video and has NVMM memory features
        if gstname.find("video") != -1 and decoder_src_pad.has_current_caps() and \
           decoder_src_pad.get_current_caps().get_features(0).contains("memory:NVMM"):
            print("Decoder current pad has NVMM memory features, linking to nvvideoconvert.")
            # Link decodebin output to nvvideoconvert
            decoder_src_pad.link(nvvidconv.get_static_pad("sink"))
        else:
            sys.stderr.write(f"WARNING: Decodebin pad {gstname} does not have NVMM video caps or is not video. Skipping.\n")
    source.connect("pad-added", cb_newpad, pipeline)
    # Link nvvideoconvert to capsfilter
    nvvidconv.link(caps_nvmm_nv12)
    # Get a request pad from nvstreammux for source_id=0 (first stream)
    # This is how individual sources connect to the muxer.
    sinkpad = streammux.get_request_pad(f"sink_{0}")
    # Corrected linking: Link the source pad of caps_nvmm_nv12 to the sinkpad of streammux
    caps_nvmm_nv12.get_static_pad("src").link(sinkpad)
    # Link nvstreammux source pad to nvinfer sink pad
    streammux.link(pgie)
    # Link nvinfer source pad to fakesink sink pad
    pgie.link(sink)
    # 6. Set up a GLib MainLoop
    # The main loop is necessary to run the GStreamer pipeline and process events.
    loop = GLib.MainLoop()
    # 7. Set up a bus watch to catch messages from the pipeline
    # This allows the script to react to pipeline events like EOS or errors.
    bus = pipeline.get_bus()
    bus.add_signal_watch()
    # Connect the imported bus_call function
    bus.connect("message", bus_call, loop)
    # 8. Start the pipeline
    # Set the pipeline state to PLAYING to start processing.
    print("Setting pipeline to PLAYING...\n")
    pipeline.set_state(Gst.State.PLAYING)
    # 9. Run the GLib MainLoop
    # This blocks until the loop is quit (e.g., by EOS or error).
    try:
        loop.run()
    except KeyboardInterrupt:
        # Handle Ctrl+C gracefully
        pass
    # 10. Clean up
    # Set the pipeline state to NULL to release all resources.
    print("Exiting and freeing pipeline resources...")
    pipeline.set_state(Gst.State.NULL)
# --- Entry Point ---
if __name__ == '__main__':
    sys.exit(main())
outputs
root@Nitro-AN515-56:~/DS_test# python3 infer_img_test.py
Creating uridecodebin for: /opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.jpg...
Creating nvinfer...
Setting nvinfer config-file-path to: /root/DS_face_rec/config_infer_primary_yoloV8_F-H.txt
/root/DS_face_rec/infer_img_test.py:124: DeprecationWarning: Gst.Element.get_request_pad is deprecated
0:00:00.266536084   886 0x562c191691c0 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:2092> [UID = 1]: deserialized trt engine from :/root/DeepStream-Yolo/p-h_model_b1_gpu0_fp16.engine
0:00:00.266573308   886 0x562c191691c0 INFO                 nvinfer gstnvinfer.cpp:684:gst_nvinfer_logger:<primary-gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2195> [UID = 1]: Use deserialized engine model: /root/DeepStream-Yolo/p-h_model_b1_gpu0_fp16.engine
0:00:00.273276063   886 0x562c191691c0 INFO                 nvinfer gstnvinfer_impl.cpp:343:notifyLoadModelStatus:<primary-gie> [UID 1]: Load new model:/root/DS_face_rec/config_infer_primary_yoloV8_F-H.txt sucessfully
In cb_newpad
End-of-stream
