Hi, I want to use the STL geometry support, but I got the error:
“ModuleNotFoundError: No module named ‘pysdf.sdf’; ‘pysdf’ is not a package”
It is said that “Make sure ‘libsdf.so’ is in LD_LIBRARY_PATH and pysdf is installed”
I have installed the pysdf and I can import pysdf. But I cannot find the position of libsdf.so.
How can I put the ‘libsdf.so’ into the LD_LIBRARY_PATH?
I am using the docker with driver version of 525.116.04 and CUDA version of 12.0. BTW, I also want to know how to get the version of the modulus I am using.
Thank you!
