Where is the cuopt library downloaded from?
Trying to run the python version of the api, the example imports cuopt library for direct access to the solver. Where can I find this library?
Hi @ryanmelnick,
the library is only available within the ea-cuopt container image.
There is resource here NVIDIA NGC, referenced in the “Quick Links” post, that has a wrapper for mounting and running a local Python program on the container.
That will let you easily run a Python API program, and it includes an example. If you would like to use kubernetes, I can help you put together a deployment that essentially does the same thing.
