Hi
I use face detection model under DS_ROOT/samples/configs/tlt_pretrained_models,I modified the main configuration file for file deepstream-test3.py to use the face detection model
pgie.set_property('config-file-path', "config_infer_primary_facedetectir.txt")
The program ran successfully,However, when the face is 3 meters away from the camera, the program can not detect the face. Do you have any good suggestions to enhance the distance of face detection? For example: other available TRT models for face detection.
Hi @837331759 ,
Please share the setup info as other topic does.
