Python Gstreamer Binding Slow on Appsrc NvJpeg Appsink
JP5.1.4 Ubuntu 20.04 Jetson Orin NX flash from SDKManger with Deepstream
I run gst-launch-1.0 videotestsrc ! video/x-raw, width=3840, height=2160 ! nvjpegenc ! filesink location=output.jpeg and the app read ROS around 0.03 second
However, I write it in python with appsink in, appsrc out, it become 0.07s, which is even slower than opencv imencode or the raw jpegenc in Gst.
I guess it is some gstreamer or python numpy issue.
Also, I tested with pynvjpeg a pip package binding NvJpeg, but same result, very slow.
import gi
import numpy as np
import time
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GObject
Gst.init(None)
class GStreamerApp:
    def __init__(self):
        self.pipeline_str = (
            "appsrc name=source format=3 ! videoconvert ! video/x-raw, width=3840, height=2160 ! "
            "videoconvert ! "
            "nvjpegenc ! "
            "appsink name=sink emit-signals=true"
        self.pipeline = Gst.parse_launch(self.pipeline_str)
        self.appsrc = self.pipeline.get_by_name('source')
        self.appsink = self.pipeline.get_by_name('sink')
        self.appsink.set_property('emit-signals', True)
        self.appsink.connect('new-sample', self.on_new_sample)
        # Set appsrc properties
        self.appsrc.set_property('caps', Gst.Caps.from_string('video/x-raw, format=RGB, width=3840, height=2160'))
    def on_new_sample(self, sink):
        sample = sink.emit('pull-sample')
        # buf = sample.get_buffer()
        return Gst.FlowReturn.OK
    def push_frame(self, frame):
        # Create a GStreamer buffer from the NumPy array
        buffer = Gst.Buffer.new_wrapped(frame.tobytes())
        self.appsrc.emit('push-buffer', buffer)
    def run(self):
        self.pipeline.set_state(Gst.State.PLAYING)
        try:
            # Simulate pushing frames into appsrc
            while True:
                # Create a dummy NumPy frame (e.g., a solid color)
                frame = np.full((2160, 3840, 3), fill_value=255, dtype=np.uint8)  # White frame
                self.push_frame(frame)
                # time.sleep(1)  # Adjust the sleep time as needed
        except KeyboardInterrupt:
            pass
        finally:
            self.pipeline.set_state(Gst.State.NULL)
if __name__ == "__main__":
    app = GStreamerApp()
    app.run()
What is ROS?
There are two videoconvert in the second pipeline, why do you compare two different pipeline?
Found the cause. The root cause off the topic.
At least, I want to share my code, contribute to the community, as I less saw example for python gst-binding.
For your app, use 2 python threads to feed the enc or dec, then use 2 another thread to wait the result. You also can apply FIFO queue to improve the code.
import numpy as np
import gi
from gi.repository import GObject, Gst
from threading import Event
class NvJpegEnc:
    def __init__(self, ):
        Gst.init(None)
        pipeline_str = (
            "appsrc name=source block=1 ! "
            "videoconvert ! "
            "nvvidconv ! nvjpegenc Enableperf=1 ! "
        self.pipeline = Gst.parse_launch(pipeline_str)
        self.width = None
        self.height = None
        self.result = None
        self.received = Event()
        self.appsrc = self.pipeline.get_by_name("source")
        # self.cap = Gst.Caps.from_string(
        #     f"video/x-raw,format=RGBx,width={self.width},height={self.height},framerate=1"
        # self.appsrc.set_property("caps", self.cap)
        #self.appsrc.set_property("block", True)
        #self.pipeline.set_state(Gst.State.PAUSED)
    def on_new_sample(self, appsink):
        """Callback function to handle new samples."""
        sample = appsink.emit('pull-sample')
        print("Received a encode new sample")
        if sample:
            buffer = sample.get_buffer()
            success, map_info = buffer.map(Gst.MapFlags.READ)
            if success:
                buffer.unmap(map_info)
                self.result = map_info.data
            else:
                self.result = None
            self.received.set()
            self.received.clear()
    def push(self, image):
        h,w,c = image.shape
        if h != self.height or w != self.width:
            self.height = h
            self.width = w
            self.appsrc.set_property("caps", Gst.Caps.from_string(
                f"video/x-raw,format=RGB ,width={w},height={h},framerate=1/1"
        buffer = Gst.Buffer.new_wrapped(image.tobytes())
    def get(self, timeout=1):
        self.received.wait(timeout)
        return self.result
    def clean(self):
        self.received.set()
        self.result = None
        self.appsrc.emit('end-of-stream')
class NvJpegDec:
    def __init__(self):
        # Initialize GStreamer
        Gst.init(None)
        pipeline_str = (
            "nvjpegdec Enableperf=1 ! nvvidconv ! video/x-raw,format=RGBA ! "
        self.result = None
            f"image/jpeg"
        print("Received a decode new sample")
        if sample:
            if success:
                caps = sample.get_caps()
                width = caps.get_structure(0).get_value("width")
                height = caps.get_structure(0).get_value("height")
                format = caps.get_structure(0).get_value("format")
                if format == 'RGB' or format == 'BGR':
                    image = np.ndarray(
                        shape=(height, width, 3),
                        buffer=map_info.data,
                        dtype=np.uint8
                else:
                    # for nvvidconv
                    image = np.ndarray(
                        shape=(height, width, 4),
                        dtype=np.uint8
                    image =  cv2.cvtColor(image, cv2.COLOR_RGBA2RGB)
                self.result = image
            else:
                self.result = None
        self.received.set()
    def push(self, bytes):
        #print('push')
        buffer = Gst.Buffer.new_wrapped(bytes)
        return self.result
    def clean(self):
        self.received.set()
        self.result = None
# Example usage
    import time
    import cv2
    import datetime
    def test():
        enc = NvJpegEnc()
        dec = NvJpegDec()
        img = np.zeros((2160, 3840, 3), dtype=np.uint8)
        #img = cv2.imread('')
        img = cv2.resize(img, (2160, 3840))
        for _ in range(300):
            #print(img.shape)
            _img = img.copy()
            print(_img.shape)
            nowstr = datetime.datetime.now().strftime("%Y-%m-%d %H:%M:%S")
            cv2.putText(_img, nowstr, (200,300), 4, 4, (0))
            start = time.perf_counter()
            #rtn, encoded = cv2.imencode('.jpg', img)
            enc.push(_img)
            end = time.perf_counter()
            encoded = enc.get()
            if encoded is None:
                print('encoded none')
                continue
            print('encoded used', 1/(end-start), (end-start))
            #decoded = cv2.imdecode(encoded, cv2.IMREAD_ANYCOLOR)
            dec.push(encoded)
            print('decoded used', 1/(end-start), (end-start))
            decoded = dec.get()
            #print(decoded.shape)
            if decoded is None:
                print('decoded none')
                continue
            cv2.imshow('raw1', cv2.resize(_img, (640, 480)))
            cv2.imshow('decoded1', cv2.resize(decoded, (640, 480)))
            cv2.waitKey(1)
            #time.sleep(1/15)
        enc.clean()
        dec.clean()
        cv2.destroyAllWindows()
    test()
As I see,
appsrc name=source block=1 ! videoconvert ! "nvvidconv ! nvjpegenc Enableperf=1 ! appsink name=sink emit-signals=true,
the videoconvert slow down the whole pipeline, however, my app use RGB/BGR as input instead of RGBA. Any way to remove the videoconvert but keep using RGB.
The “nvvideoconvert” is enough to convert “RGB” to “RGBA(memory:NVMM)”
appsrc name=source block=1 !  nvvideoconvert ! nvjpegenc ...
