I try the tutorial, and I export the “model_gn.engine” successfully.
I want to load the engine file with code:
import tensorrt as trt
engine_path="model_gn.engine"
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
with open(engine_path, "rb") as f, trt.Runtime(TRT_LOGGER) as runtime:
engine = runtime.deserialize_cuda_engine(f.read())
Then I got the error
[04/23/2023-15:53:59] [TRT] [E] 1: [pluginV2Runner.cpp::load::292] Error Code 1: Serialization (Serialization assertion creator failed.Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
[04/23/2023-15:53:59] [TRT] [E] 4: [runtime.cpp::deserializeCudaEngine::49] Error Code 4: Internal Error (Engine deserialization failed.)
