trt_file_path = “./yolox_tiny.trt”
if not os.path.exists(trt_file_path):
raise FileNotFoundError(f"The TensorRT file does not exist: {trt_file_path}")
try:
with open(trt_file_path, “rb”) as f:
engine_data = f.read()
if len(engine_data) == 0:
raise RuntimeError(“The TensorRT file is empty”)
runtime = trt.Runtime(trt_logger)
engine = runtime.deserialize_cuda_engine(engine_data)
if engine is None:
raise RuntimeError("The engine failed to load")
context = engine.create_execution_context()
print("The engine and context have been loaded correctly")
except Exception as e:
print(f"An error has occurred: {e}")
In this program, I am loading the trt file that I created, but in ‘engine = runtime.deserialize_cuda_engine(engine_data)’, the engine becomes Null and I get the error ‘The engine failed to load’. Why is this happening? I appreciate your response.
Thank you for your response. The log is as follows. I appreciate your cooperation.
[07/09/2024-16:41:05] [TRT] [I] Loaded engine size: 11 MiB
[07/09/2024-16:41:05] [TRT] [W] Using an engine plan file across different models of devices is not recommended and is likely to affect performance or even cause errors.
[07/09/2024-16:41:05] [TRT] [E] 1: [pluginV2Runner.cpp::load::299] Error Code 1: Serialization (Serialization assertion creator failed.Cannot deserialize plugin since corresponding IPluginCreator not found in Plugin Registry)
[07/09/2024-16:41:05] [TRT] [E] 4: [runtime.cpp::deserializeCudaEngine::65] Error Code 4: Internal Error (Engine deserialization failed.)
