PyTorch doesn't see Cuda device
After reading the following article PyTorch for Jetson and installing the package there for torch 1.10.0, I run torch.cuda.is_available() and get false. Is there a setup instruction I’m missing to get it to recognize the GPU? My Jetpack version is 4.4
It’s possible to upgrade your device into JetPack 4.6.1 first?
We test PyTorch 1.10.0 with JetPack4.6.1, and it works good.
>>> import torch
True
Unfortunately, I can’t upgrade my jetpack version, but I can use an older version of torch if there is one that’s supported.
torch >=1.7.0
Based on the instructions, PyTorch 1.10 should work on JetPack4.4.
We are checking this internally.
Will share more information with you later.
We test PyTorch 1.10 on a Xavier set up with JetPack4.4.
It also works normally.
$ python3
Python 3.6.9 (default, Dec  8 2021, 21:08:43)
[GCC 8.4.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import torch
True
