Q3400-RA doesn't work on PRBS test using the mlxlink
I am trying to do some prbs test between 2 switches and use this cmd as suggested but it seems like this is not working properly. This is the cmd that I use - sudo mlxlink -d /dev/mst/mt54004_pciconf2 -p 6 --cable --prbs_select HOST --rx_prbs PRBS31 --tx_prbs PRBS31 --rx_rate XDR --tx_rate XDR --test_mode EN .
Is there any other command or suggestion on how to run PRBS test ? The switch are in nvos
For mlxlink reading on these switches running NVOS, like Black Mamba (QM3400), need to use the following convention for the port syntax:
conf0 x/1-2/3
conf1 x/1-2/2
conf2 x/1-2/1
conf3 x/1-2/4
So, for port sw6p1 we’ll need to run the following command:
mlxlink -d -p 30/1/plane 1-4 depends on mst device
i.e.:
mlxlink -d /dev/mst/mt54004_pciconf0 -p 6/1/3 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf1 -p 6/1/2 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf2 -p 6/1/1 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf3 -p 6/1/4 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf0 -p 6/2/3 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf1 -p 6/2/2 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf2 -p 6/2/1 -e -m -c
mlxlink -d /dev/mst/mt54004_pciconf3 -p 6/2/4 -e -m -c
The -p 30/1/plane in the above should have been 6/1/plane.
Thank you for the reply.
I run this cmd → admin@nvos:~$ sudo mlxlink -d /dev/mst/mt54004_pciconf2 -p 1/1/1 --test_mode EN --rx_prbs PRBS31 --tx_prbs PRBS31 --rx_rate XDR --tx_rate XDR
to trigger the PRBS test but after I am trying to see the reading but I do see the PRBS mode tuning was not performed . For PRBS test, what data we need to focus on?
admin@nvos:~$ sudo mlxlink -d /dev/mst/mt54004_pciconf2 -p 1/1/1 -e -m -c
Test Mode Info
RX PRBS Mode                       : PRBS31
TX PRBS Mode                       : PRBS31
RX Lane Rate                       : 212.5G
TX Lane Rate                       : 212.5G
Tuning Status                      : PRBS mode tuning was not performed.
Lock Status                        :
Module Info
Temperature [C]                    : N/A
Voltage [mV]                       : N/A
Bias Current [mA]                  : N/A
Rx Power Current [dBm]             : N/A
Tx Power Current [dBm]             : N/A
Identifier                         : OSFP
Compliance                         : IB XDR
Cable Technology                   : 1310 nm EML
Cable Type                         : Optical Module (separated)
OUI                                : Nvidia
Vendor Name                        : NVIDIA
Vendor Part Number                 : 980-9IAH1-00XM00
Vendor Serial Number               : MT2528FT41712
Rev                                : B1
Wavelength [nm]                    : 1311
Transfer Distance [m]              : 0.0
Attenuation (5g,7g,12g,25g)[dB]    : N/A
FW Version                         : 70.240.126
Digital Diagnostic Monitoring      : No
Power Class                        : 33.5 W max
CDR RX                             :
CDR TX                             :
LOS Alarm                          : N/A
SNR Media Lanes [dB]               : N/A
SNR Host Lanes [dB]                : N/A
IB Cable Width                     : 1x,2x
Memory Map Revision                : 64
Linear Direct Drive                : 0
Cable Breakout                     : Unspecified
SMF Length                         : 500m
MAX Power                          : 134
Cable Rx AMP                       : 0
Cable Rx Emphasis (Pre)            : 2
Cable Rx Post Emphasis             : 0
Cable Tx Equalization              : 0
Wavelength Tolerance               : 6.5nm
Module State                       : Ready state
DataPath state [per lane]          : N/A
Rx Output Valid [per lane]         : N/A
Nominal bit rate                   : N/A
Rx Power Type                      : Average power
Manufacturing Date                 : 10_07_25
Active Set Host Compliance Code    : IB XDR
Active Set Media Compliance Code   :
Error Code Response                : ConfigUndefined
Module FW Fault                    : N/A
DataPath FW Fault                  : N/A
Tx Fault [per lane]                : N/A
Tx LOS [per lane]                  : N/A
Tx CDR LOL [per lane]              : N/A
Rx LOS [per lane]                  : N/A
Rx CDR LOL [per lane]              : N/A
Tx Adaptive EQ Fault [per lane]    : N/A
Physical Counters and BER Info (PRBS)
Time Since Last Clear [Min]        : 0.1
PRBS Errors                        :
PRBS BER                           : 0E-0
hello,我最近在3400交换机上发现一个mlxlink_plane_wrapper的命令,请问这个命令的具体用法和示例可以提供一下嘛?
