I’m trying to familiarize with MDL code, so I’m using “execution_cuda” example from mdl sdk examples.
I want to change the example material and use a material I choose. So I’m trying to use a gold_yellow material that is inside a gold.mdl from nvidia mdl materials.
gold.mdl is as follows:
* Copyright 1986, 2017 NVIDIA Corporation. All rights reserved.
MDL MATERIALS ARE PROVIDED PURSUANT TO AN END USER LICENSE AGREEMENT,
WHICH WAS ACCEPTED IN ORDER TO GAIN ACCESS TO THIS FILE. IN PARTICULAR,
THE MDL MATERIALS ARE PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO ANY WARRANTIES OF
MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT OF
COPYRIGHT, PATENT, TRADEMARK, OR OTHER RIGHT. IN NO EVENT SHALL NVIDIA
CORPORATION BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, INCLUDING
ANY GENERAL, SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES,
WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF
THE USE OR INABILITY TO USE THE MDL MATERIALS OR FROM OTHER DEALINGS IN
THE MDL MATERIALS.
mdl 1.2;
import anno::*;
import ::nvidia::core_definitions::flex_material;
import ::state::normal;
const string COPYRIGHT =
" Copyright 1986, 2017 NVIDIA Corporation. All rights reserved.\n"
" MDL MATERIALS ARE PROVIDED PURSUANT TO AN END USER LICENSE AGREEMENT,\n"
" WHICH WAS ACCEPTED IN ORDER TO GAIN ACCESS TO THIS FILE. IN PARTICULAR,\n"
" THE MDL MATERIALS ARE PROVIDED \"AS IS\", WITHOUT WARRANTY OF ANY KIND,\n"
" EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO ANY WARRANTIES OF\n"
" MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT OF\n"
" COPYRIGHT, PATENT, TRADEMARK, OR OTHER RIGHT. IN NO EVENT SHALL NVIDIA\n"
" CORPORATION BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY, INCLUDING ANY\n"
" GENERAL, SPECIAL, INDIRECT, INCIDENTAL, OR CONSEQUENTIAL DAMAGES, WHETHER IN\n"
" AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM, OUT OF THE USE OR\n"
" INABILITY TO USE THE MDL MATERIALS OR FROM OTHER DEALINGS IN THE MDL MATERIALS.\n";
export material gold_white(
color base_color = color ( 1.f , 0.9828275f , 0.9322785f)
anno::display_name("Color"),
anno::description("Choose the color of the metal."),
anno::in_group("Appearance")
float reflection_roughness = 0.05f
anno::display_name("Reflection Roughness"),
anno::description("Higher roughness values lead to bigger highlights and blurrier reflections."),
float anisotropy = 0.f
anno::display_name("Anisotropy"),
anno::description("Higher values will stretch highlights."),
anno::in_group("Appearance"),
anno::hard_range(0.0,1.0)
float anisotropy_rotation = 0.f
anno::display_name("Anisotropy Rotation"),
anno::description("Changes the orientation of anisotropy."),
float3 bump = state::normal()
anno::display_name("Bump"),
anno::description("Attach bump or normal maps here"),
anno::display_name("Gold - White"),
anno::description("Design - Metal - Gold - White"),
anno::author("NVIDIA vMaterials"),
anno::copyright_notice(COPYRIGHT)
::nvidia::core_definitions::flex_material(
base_color: base_color,
diffuse_roughness: 0.f,
is_metal: true,
reflectivity: 1.f,
reflection_roughness: reflection_roughness,
anisotropy: anisotropy,
anisotropy_rotation: anisotropy_rotation,
transparency: 0.f,
transmission_color: color ( 1.f , 1.f , 1.f),
volume_color: color ( 1.f , 1.f , 1.f),
transmission_roughness: 0.f,
base_thickness: 0.1f,
ior: 0.47f,
thin_walled: false,
normal: bump);
export material gold_yellow(
color base_color = color ( 0.9489647f , 0.6940823f , 0.3203804f)
anno::hard_range(0.0,1.0),
anno::display_name("Gold - Yellow"),
anno::description("Design - Metal - Gold - Yellow"),
is_metal: true,
reflectivity: 1.f,
transparency: 0.f,
ior: 2.5f,
thin_walled: false,
normal: bump);
and I try to run the program like this:
execution_cuda.exe --mdl_path “E:\MDL\materials\gold.mdl” “::mdl::gold::gold_yellow”
and I get error here:
mdl_impexp_api->load_module(transaction.get(), module_name.c_str(), context.get());
if (!print_messages(context.get()))
exit_failure("Loading module '%s' failed.", module_name.c_str());
as It never find the module. I can’t find what the qualified name should be, I tried lots of combinations like:
::gold::gold_yellow
::gold_yellow::gold_yellow
::mdl::gold_yellow
::gold.mdl::gold_yellow
But i can’t figure out the right one, as I don’t see inside gold.mdl any module definition.
Thanks in advance.
