Hi, I have MaterialX materials I want to import, and since we don’t have that direct support for materialx yet (right??) I’m converting them to mdl shaders to import instead. A such generated mdl shader could look omething like this:
mdl 1.6;
using mx = materialx;
import ::df::*;
import ::base::*;
import ::math::*;
import ::state::*;
import ::anno::*;
import ::tex::*;
import ::mx::swizzle::*;
import ::mx::cm::*;
using ::mx::core import *;
using ::mx::stdlib import *;
using ::mx::pbrlib import *;
using ::mx::sampling import *;
material NG_standard_surface_surfaceshader_100
float base = 0.8,
color base_color = color(1, 1, 1),
float diffuse_roughness = 0,
float metalness = 0,
float specular = 1,
color specular_color = color(1, 1, 1),
float specular_roughness = 0.2,
uniform float specular_IOR = 1.5,
float specular_anisotropy = 0,
float specular_rotation = 0,
float transmission = 0,
color transmission_color = color(1, 1, 1),
float transmission_depth = 0,
color transmission_scatter = color(0, 0, 0),
float transmission_scatter_anisotropy = 0,
float transmission_dispersion = 0,
float transmission_extra_roughness = 0,
float subsurface = 0,
color subsurface_color = color(1, 1, 1),
color subsurface_radius = color(1, 1, 1),
float subsurface_scale = 1,
float subsurface_anisotropy = 0,
float sheen = 0,
color sheen_color = color(1, 1, 1),
float sheen_roughness = 0.3,
float coat = 0,
color coat_color = color(1, 1, 1),
float coat_roughness = 0.1,
float coat_anisotropy = 0,
float coat_rotation = 0,
uniform float coat_IOR = 1.5,
float3 coat_normal = float3(0.0),
float coat_affect_color = 0,
float coat_affect_roughness = 0,
float thin_film_thickness = 0,
float thin_film_IOR = 1.5,
float emission = 0,
color emission_color = color(1, 1, 1),
color opacity = color(1, 1, 1),
bool thin_walled = false,
float3 normal = float3(0.0),
float3 tangent = float3(0.0)
= let
float2 coat_roughness_vector_out = mx::pbrlib::mx_roughness_anisotropy(mxp_roughness:coat_roughness, mxp_anisotropy:coat_anisotropy);
float coat_tangent_rotate_degree_out = coat_rotation * 360;
color metal_reflectivity_out = base_color * base;
color metal_edgecolor_out = specular_color * specular;
float coat_affect_roughness_multiply1_out = coat_affect_roughness * coat;
float tangent_rotate_degree_out = specular_rotation * 360;
float coat_clamped_out = math::clamp(coat, 0, 1);
float3 subsurface_radius_vector_out = float3(float3(subsurface_radius).x, float3(subsurface_radius).y, float3(subsurface_radius).z);
float subsurface_selector_out = float(thin_walled);
color coat_attenuation_out = math::lerp(color(1, 1, 1), coat_color, coat);
color emission_weight_out = emission_color * emission;
color coat_emission_attenuation_out = math::lerp(color(1, 1, 1), coat_color, coat);
color opacity_luminance_out = mx::stdlib::mx_luminance_color3(opacity);
float3 coat_tangent_rotate_out = mx::stdlib::mx_rotate3d_vector3(mxp_in:tangent, mxp_amount:coat_tangent_rotate_degree_out, mxp_axis:coat_normal);
mx::pbrlib::mx_artistic_ior__result artistic_ior_result = mx::pbrlib::mx_artistic_ior(mxp_reflectivity:metal_reflectivity_out, mxp_edge_color:metal_edgecolor_out);
float coat_affect_roughness_multiply2_out = coat_affect_roughness_multiply1_out * coat_roughness;
float3 tangent_rotate_out = mx::stdlib::mx_rotate3d_vector3(mxp_in:tangent, mxp_amount:tangent_rotate_degree_out, mxp_axis:normal);
float coat_gamma_multiply_out = coat_clamped_out * coat_affect_color;
float3 subsurface_radius_scaled_out = subsurface_radius_vector_out * subsurface_scale;
color emission_weight_attenuated_out = emission_weight_out * coat_emission_attenuation_out;
float3 coat_tangent_rotate_normalize_out = math::normalize(coat_tangent_rotate_out);
float coat_affected_roughness_out = math::lerp(specular_roughness, 1, coat_affect_roughness_multiply2_out);
float3 tangent_rotate_normalize_out = math::normalize(tangent_rotate_out);
float coat_gamma_out = coat_gamma_multiply_out + 1;
float3 coat_tangent_out = mx::stdlib::mx_ifgreater_vector3(coat_anisotropy, 0, coat_tangent_rotate_normalize_out, tangent);
float2 main_roughness_out = mx::pbrlib::mx_roughness_anisotropy(mxp_roughness:coat_affected_roughness_out, mxp_anisotropy:specular_anisotropy);
float3 main_tangent_out = mx::stdlib::mx_ifgreater_vector3(specular_anisotropy, 0, tangent_rotate_normalize_out, tangent);
color coat_affected_subsurface_color_out = math::pow(subsurface_color, coat_gamma_out);
color coat_affected_diffuse_color_out = math::pow(base_color, coat_gamma_out);
material metal_bsdf_out = mx::pbrlib::mx_conductor_bsdf(mxp_weight:1, mxp_ior:artistic_ior_result.mxp_ior, mxp_extinction:artistic_ior_result.mxp_extinction, mxp_roughness:main_roughness_out, mxp_normal:normal, mxp_tangent:main_tangent_out);
material transmission_bsdf_out = mx::pbrlib::mx_dielectric_bsdf(mxp_weight:1, mxp_tint:transmission_color, mxp_ior:specular_IOR, mxp_roughness:main_roughness_out, mxp_normal:normal, mxp_tangent:main_tangent_out, mxp_scatter_mode:mx_scatter_mode_T, mxp_base:material());
material translucent_bsdf_out = mx::pbrlib::mx_translucent_bsdf(mxp_weight:1, mxp_color:coat_affected_subsurface_color_out, mxp_normal:normal);
material subsurface_bsdf_out = mx::pbrlib::mx_subsurface_bsdf(mxp_weight:1, mxp_color:coat_affected_subsurface_color_out, mxp_radius:subsurface_radius_scaled_out, mxp_anisotropy:subsurface_anisotropy, mxp_normal:normal);
material selected_subsurface_bsdf_out = mx::pbrlib::mx_mix_bsdf(mxp_fg:translucent_bsdf_out, mxp_bg:subsurface_bsdf_out, mxp_mix:subsurface_selector_out);
material diffuse_bsdf_out = mx::pbrlib::mx_oren_nayar_diffuse_bsdf(mxp_weight:base, mxp_color:coat_affected_diffuse_color_out, mxp_roughness:diffuse_roughness, mxp_normal:normal);
material subsurface_mix_out = mx::pbrlib::mx_mix_bsdf(mxp_fg:selected_subsurface_bsdf_out, mxp_bg:diffuse_bsdf_out, mxp_mix:subsurface);
material sheen_layer_out = mx::pbrlib::mx_sheen_bsdf(mxp_weight:sheen, mxp_color:sheen_color, mxp_roughness:sheen_roughness, mxp_normal:normal, mxp_base:subsurface_mix_out);
material transmission_mix_out = mx::pbrlib::mx_mix_bsdf(mxp_fg:transmission_bsdf_out, mxp_bg:sheen_layer_out, mxp_mix:transmission);
material specular_layer_out = mx::pbrlib::mx_dielectric_bsdf(mxp_weight:specular, mxp_tint:specular_color, mxp_ior:specular_IOR, mxp_roughness:main_roughness_out, mxp_normal:normal, mxp_tangent:main_tangent_out, mxp_scatter_mode:mx_scatter_mode_R, mxp_base:transmission_mix_out);
material specular_layer_with_thin_film_out = mx::pbrlib::mx_thin_film_bsdf(mxp_thickness:thin_film_thickness, mxp_ior:thin_film_IOR, mxp_base:specular_layer_out);
material metalness_mix_out = mx::pbrlib::mx_mix_bsdf(mxp_fg:metal_bsdf_out, mxp_bg:specular_layer_with_thin_film_out, mxp_mix:metalness);
material metalness_mix_attenuated_out = mx::pbrlib::mx_multiply_bsdf_color3(mxp_in1:metalness_mix_out, mxp_in2:coat_attenuation_out);
material coat_layer_out = mx::pbrlib::mx_dielectric_bsdf(mxp_weight:coat, mxp_tint:color(1, 1, 1), mxp_ior:coat_IOR, mxp_roughness:coat_roughness_vector_out, mxp_normal:coat_normal, mxp_tangent:coat_tangent_out, mxp_scatter_mode:mx_scatter_mode_R, mxp_base:metalness_mix_attenuated_out);
material emission_edf_out = mx::pbrlib::mx_uniform_edf(mxp_color:emission_weight_attenuated_out);
material shader_constructor_out = mx::pbrlib::mx_surface(coat_layer_out, emission_edf_out, float3(opacity_luminance_out).x, specular_IOR);
in material(shader_constructor_out);
export material BakingShaderMDL
float base = 1,
float specular = 1,
float sheen = 0,
float coat = 0,
float emission = 0,
uniform mx_coordinatespace_type geomprop_Nworld_space = mx_coordinatespace_type_world,
uniform mx_coordinatespace_type geomprop_Tworld_space = mx_coordinatespace_type_world,
uniform int geomprop_Tworld_index = 0,
color SR_untitled_base_color = color(0, 0.12, 0)
= let
float3 geomprop_Nworld_out = mx::stdlib::mx_normal_vector3(mxp_space:geomprop_Nworld_space);
float3 geomprop_Tworld_out = mx::stdlib::mx_tangent_vector3(mxp_space:geomprop_Tworld_space, mxp_index:geomprop_Tworld_index);
material SR_untitled_out = NG_standard_surface_surfaceshader_100(base, SR_untitled_base_color, diffuse_roughness, metalness, specular, specular_color, specular_roughness, specular_IOR, specular_anisotropy, specular_rotation, transmission, transmission_color, transmission_depth, transmission_scatter, transmission_scatter_anisotropy, transmission_dispersion, transmission_extra_roughness, subsurface, subsurface_color, subsurface_radius, subsurface_scale, subsurface_anisotropy, sheen, sheen_color, sheen_roughness, coat, coat_color, coat_roughness, coat_anisotropy, coat_rotation, coat_IOR, geomprop_Nworld_out, coat_affect_color, coat_affect_roughness, thin_film_thickness, thin_film_IOR, emission, emission_color, opacity, thin_walled, geomprop_Nworld_out, geomprop_Tworld_out);
material finalOutput__ = SR_untitled_out;
in material(finalOutput__);
As you can see it imports the materialx library.
When trying to import this mdl shader in Create I get the error “SR_untitled.mdl doesn’t contain any usable materials” and in the console it says
2022-05-02 14:51:19 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: U:\dev\Tests\SR_untitled.mdl(159,64): C152 'mx_normal_vector3' : cannot convert argument 'mxp_space' from 'enum ::materialx::core::mx_coordinatespace_type' to 'enum ::Z73file_3A::Z37d_3A::omniverse::ov::pkg::Z1Ecreate_2D2022_2E1_2E2::kit::mdl::core::mdl::materialx::core::mx_coordinatespace_type'
2022-05-02 14:51:19 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: U:\dev\Tests\SR_untitled.mdl(160,65): C152 'mx_tangent_vector3' : cannot convert argument 'mxp_space' from 'enum ::materialx::core::mx_coordinatespace_type' to 'enum ::Z73file_3A::Z37d_3A::omniverse::ov::pkg::Z1Ecreate_2D2022_2E1_2E2::kit::mdl::core::mdl::materialx::core::mx_coordinatespace_type'
2022-05-02 14:51:19 [Error] [rtx.neuraylib.plugin] Compiler Core: U:\dev\Tests\SR_untitled.mdl(159,64): C152 'mx_normal_vector3' : cannot convert argument 'mxp_space' from 'enum ::materialx::core::mx_coordinatespace_type' to 'enum ::Z73file_3A::Z37d_3A::omniverse::ov::pkg::Z1Ecreate_2D2022_2E1_2E2::kit::mdl::core::mdl::materialx::core::mx_coordinatespace_type'
2022-05-02 14:51:19 [Error] [rtx.neuraylib.plugin] Compiler Core: U:\dev\Tests\SR_untitled.mdl(160,65): C152 'mx_tangent_vector3' : cannot convert argument 'mxp_space' from 'enum ::materialx::core::mx_coordinatespace_type' to 'enum ::Z73file_3A::Z37d_3A::omniverse::ov::pkg::Z1Ecreate_2D2022_2E1_2E2::kit::mdl::core::mdl::materialx::core::mx_coordinatespace_type'
So there seem to be some problems with namespaces/the path to the materialx library.
Any tips on how to solve this?
