From my understanding, Omniverse Create supports MaterialX since ver3. I found the extension for MaterialX in Omniverse Create and enabled it, but till could not find a concrete way to import it.
Could you tell me how to import MaterialX to Omniverse Create?
Hello @teyon.son! I’ve just got confirmation from the dev team that MaterialX isn’t supported in RTX yet. I will inform our documentation team that this needs to be updated in our docs.
MaterialX read support is supported in 2022.3.x Any USD that has loads a .mtlx document or has assigned the standard Mtlx nodes will then compile the material to MDL for use in the RTX and Iray Accurate renderers.
