MDL material path failed
I encounted error when I created a materials (OmniSurface)
Ubuntu: 22.04
GPU: A6000
IsaacSim: 4.5.1
IsaacLab: 2.1.0
IsaacSim installed by pip (using conda environment) ( I followed Installation using Isaac Sim pip — Isaac Lab Documentation )
After I created a materials in World:
2025-12-03 10:16:36 [33,666ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::Z73file_3A::home::Z99vmo_2Ddell3680::anaconda3::envs::env_isaaclab::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniSurface’ in module path
2025-12-03 10:16:36 [33,666ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::Z73file_3A::home::Z99vmo_2Ddell3680::anaconda3::envs::env_isaaclab::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniSurface
2025-12-03 10:16:36 [33,666ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::Z73file_3A::home::Z99vmo_2Ddell3680::anaconda3::envs::env_isaaclab::lib::Z0Cpython3_2E10::ZC9site_2Dpackages::omni::mdl::core::Base::OmniSurface
2025-12-03 10:16:36 [33,673ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from /home/nta/anaconda3/envs/env_isaaclab/lib/python3.10/site-packages/omni/mdl/core/Base/OmniSurface.mdl
2025-12-03 10:16:36 [33,725ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::
2025-12-03 10:16:36 [33,725ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::
2025-12-03 10:16:36 [33,727ms] [Error] [asyncio] Task exception was never retrieved
future: <Task finished name=‘Task-183’ coro=<UsdShadeBaseWidget.load_mdl_modules..load_module() done, defined at /home/nta/miniconda3/envs/env_isaaclab/lib/python3.10/site-packages/isaacsim/extscache/omni.kit.property.material-1.10.17+d02c707b/omni/kit/property/material/scripts/widgets/usdshade/base_widget.py:336> exception=ErrorException(Error in 'pxrInternal_v0_22__pxrReserved_::Neuray::LoadModule’ at line 242 in file ../../source/plugins/omni.usdMdl/neuray.cpp : ‘‘rtx::neuraylib::MdlModuleId’ for ‘’ is Invalid’)>
File “/home/nta/miniconda3/envs/env_isaaclab/lib/python3.10/site-packages/isaacsim/extscache/omni.kit.property.material-1.10.17+d02c707b/omni/kit/property/material/scripts/widgets/usdshade/base_widget.py”, line 337, in load_module
UsdMdl.RegistryUtils.AddModuleToRegistry(source_asset)
pxr.Tf.ErrorException:
Error in ‘pxrInternal_v0_22__pxrReserved__::Neuray::LoadModule’ at line 242 in file ../../source/plugins/omni.usdMdl/neuray.cpp : ‘‘rtx::neuraylib::MdlModuleId’ for ‘’ is Invalid’
How to fix it??
Hi apologies for the delay. Have you gotten past this issue yet, or is it still blocking you?
This usually means the OmniSurface MDL file is not installed or not on the MDL search path.
– In your env_isaaclab, check that …/site-packages/omni/mdl/core/Base/OmniSurface.mdl actually exists. If not, reinstall Isaac Sim via the official pip steps for 4.5.1, including the extensions/extscache package.
– In Isaac Sim settings, add …/site-packages/omni/mdl to the MDL search paths if it is missing, then restart.
– If it still fails, try clearing Omniverse user data (~/.nvidia-omniverse or ~/.local/share/ov, path can vary), restart Isaac Sim, and test again.
