Note: For any Isaac Lab topics, please submit your topic to its GitHub repo (GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim) following the instructions provided on Isaac Lab’s Contributing Guidelines (Contribution Guidelines — Isaac Lab Documentation).
Isaac Sim Version
4.5.0
4.2.0
4.1.0
4.0.0
4.5.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
- Model: 4090
- Driver Version:
Topic Description
Detailed Description
(Describe the issue in detail, including what you were trying to do, what you expected to happen, and what actually happened)
I tried downloading the data center asset pack from here: Downloadable Asset Packs — Omniverse USD and loading it into isaac sim. When trying to import the usd into the scene through the content panel in the GUI, I get many errors and my asset loads colored bright red.
I have attached the error messages below. It looks like we are unable to load the materials properly. Is this due to some version issue? The data center assets are not in the isaac sim assets panel, so I am not sure how to get them into isaac sim otherwise.
Any help would be greatly appreciated!
Error Messages
(If applicable, copy and paste any error messages you received)
2025-05-12 02:32:55 [Warning] [omni.datastore] OmniHub is inaccessible
2025-05-12 02:32:55 [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored): Logitech Wireless Mouse [030000006d0400005540000011010000]
2025-05-12 02:32:55 [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored): Telink Wireless Receiver Consumer Control [030000008a2400002783000011010000]
2025-05-12 02:32:55 [Warning] [omni.log] Source: omni.hydra was already registered.
2025-05-12 02:32:55 [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
2025-05-12 02:32:55 [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
2025-05-12 02:32:55 [Warning] [omni.isaac.block_world] [‘omni.isaac.block_world’] has been deprecated in favor of [‘isaacsim.asset.importer.heightmap’]. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [isaacsim.sensors.rtx.ui.extension] config_dir_path /root/isaacsim/exts/isaacsim.sensors.rtx/data/lidar_configs
2025-05-12 02:32:55 [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.1 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn’t do anything and can be removed.
2025-05-12 02:32:55 [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. File /root/.nvidia-omniverse/config/omniverse.toml is not found. Consider installing it for better IO performance.
2025-05-12 02:32:55 [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
2025-05-12 02:32:55 [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-05-12 02:32:55 [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
2025-05-12 02:32:56 [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
2025-05-12 02:32:56 [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-05-12 02:32:56 [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
2025-05-12 02:32:56 [Warning] [carb.audio.device] audio device is misconfigured or broken {deviceIndex = 0, name = ‘default’} (The device is likely misconfigured, check your $HOME/.asoundrc)
2025-05-12 02:32:56 [Warning] [carb.audio.output] failed to retrieve the capabilities for device 0 {result = eDeviceLost (2)}
2025-05-12 02:32:56 [Warning] [carb.audio.context] failed to set the requested output during context creation. Using a null streamer instead {result = eDeviceLost (2)}
2025-05-12 02:32:56 [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/ecoMode/enabled’
2025-05-12 02:32:56 [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7374781440
2025-05-12 02:32:56 [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-05-12 02:32:56 [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7301033856
2025-05-12 02:32:56 [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9748724 (slope: 439, intercept: 13179904)
2025-05-12 02:32:56 [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287352704
2025-05-12 02:32:56 [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-05-12 02:32:56 [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults-transient/meshlights/forceDisable’
2025-05-12 02:32:56 [Warning] [omni.usd-abi.plugin] No setting was found for ‘/rtx-defaults/post/dlss/execMode’
2025-05-12 02:46:58 [Warning] [omni.kit.widget.filebrowser.model] Error populating ‘/etc/resolv.conf/’: [Errno 20] Not a directory: ‘/etc/resolv.conf/’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Glossy_Black_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Glossy_Black_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Glossy_Black_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Plastics/Plastic_Glossy_Black_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Plastics/Plastic_Glossy_Black_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_05/Looks/Plastic_shinyBlack/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Orange_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Orange_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Orange_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Plastics/Plastic_Orange_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Plastics/Plastic_Orange_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_05/Looks/Plastic_Orange_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Aluminum_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Aluminum_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_05/Looks/Metal_Aluminum/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_04/Looks/Plastic_Orange_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Paint::Powdercoat_Black_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Paint::Powdercoat_Black_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Paint::Powdercoat_Black_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Paint/Powdercoat_Black_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Paint/Powdercoat_Black_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_04/Looks/BlackGrainyPowderCoat/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_03/Looks/Plastic_shinyBlack/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_03/Looks/Plastic_Orange_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_Sheet_Metal_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_Sheet_Metal_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_Sheet_Metal_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Aluminum_Sheet_Metal_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Aluminum_Sheet_Metal_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_05/Looks/AluminumSheetMetal/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_03/Looks/AluminumSheetMetal/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Paint::Paint_Satin’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Paint::Paint_Satin
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Paint::Paint_Satin
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Paint/Paint_Satin.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Paint/Paint_Satin.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_M0623/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_G085/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_04/Looks/Metal_Aluminum/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_003/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_M081/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_D0150/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Color_D0630/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_03/Looks/Metal_Aluminum/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_02/Looks/AluminumSheetMetal/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Steel_Stainless_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Stainless_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Stainless_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Steel_Stainless_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Steel_Stainless_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Stainless_Steel/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Black_Powdercoat_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Color_A0738/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_01/Looks/BlackGrainyPowderCoat/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_02/Looks/Plastic_shinyBlack/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_M0946/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_03/Looks/BlackGrainyPowderCoat/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_008/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Glass::Glass_Clear_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Glass::Glass_Clear_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Glass::Glass_Clear_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Glass/Glass_Clear_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Glass/Glass_Clear_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Glass/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Red_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Red_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Red_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Plastics/Plastic_Red_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Plastics/Plastic_Red_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Plastic_Red_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Steel_Stainless_Brushed_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Stainless_Brushed_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Stainless_Brushed_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Steel_Stainless_Brushed_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Steel_Stainless_Brushed_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Steel_Brushed_Stainless/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Steel_Cast_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Cast_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Cast_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Steel_Cast_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Steel_Cast_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Metal_Rough/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Color_008/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_C042/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Color_I0735/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_01/Looks/AluminumSheetMetal/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_05/Looks/BlackGrainyPowderCoat/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_Polished_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_Polished_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Aluminum_Polished_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Aluminum_Polished_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Aluminum_Polished_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Metal_Aluminum_Polished_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Copper_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Copper_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Copper_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Copper_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Copper_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Copper_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Silver_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Silver_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Silver_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Silver_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Silver_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Metal_Silver/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_04/Looks/AluminumSheetMetal/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Rubber::Rubber_D’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Rubber::Rubber_D
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Rubber::Rubber_D
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Rubber/Rubber_D.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Rubber/Rubber_D.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Rubber_Black_D/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_04/Looks/Plastic_shinyBlack/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Brass_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Brass_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Brass_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Brass_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Brass_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Brass/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Black_Powdercoat_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_White_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_White_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_White_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Plastics/Plastic_White_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Plastics/Plastic_White_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Plastic_White/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Steel_Seamed_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Seamed_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Steel_Seamed_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Steel_Seamed_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Steel_Seamed_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Metal_Seamed/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Color_H0857/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_01/Looks/Plastic_Orange_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Rubber/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Color_M0623/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_M079/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_A0617/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Glass::Glass_Glazing_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Glass::Glass_Glazing_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Glass::Glass_Glazing_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Glass/Glass_Glazing_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Glass/Glass_Glazing_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Low_E_Glass/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Black_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Black_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Plastics::Plastic_Black_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Plastics/Plastic_Black_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Plastics/Plastic_Black_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Plastic_Black_MDL/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_01/Looks/Plastic_shinyBlack/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Rubber::Rubber_New_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Rubber::Rubber_New_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Rubber::Rubber_New_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Rubber/Rubber_New_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Rubber/Rubber_New_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Asphalt_New/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Color_D0713/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Metal_Silver/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module ‘::..::..::..::..::..::..::Materials::Base::Metals::Metal_Rough_A’ in module path
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (OmniUsdMdl) failed: ::..::..::..::..::..::..::Materials::Base::Metals::Metal_Rough_A
2025-05-12 02:47:46 [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (OmniUsdMdl): ::..::..::..::..::..::..::Materials::Base::Metals::Metal_Rough_A
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in LoadModule at line 242 of ../../source/plugins/omni.usdMdl/neuray.cpp – ‘rtx::neuraylib::MdlModuleId’ for ‘../../../../../../Materials/Base/Metals/Metal_Rough_A.mdl’ is Invalid
2025-05-12 02:47:46 [Error] [omni.usd] USD_MDL: in GetSdrFromDiscoveryResult at line 183 of ../../source/plugins/omni.usdMdl/moduleRegistry.cpp – Module: ‘../../../../../../Materials/Base/Metals/Metal_Rough_A.mdl’ with version ‘1’ not found in ‘MdlModuleRegistry::ModuleDataMap’.
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Metal_Rough/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DCP/Looks/Steel_Brushed_Stainless/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_01/Looks/Metal_Aluminum/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Power_and_Fiber/Looks/Aluminum/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_02/Looks/BlackGrainyPowderCoat/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_02/Looks/Metal_Aluminum/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
2025-05-12 02:47:46 [Error] [omni.hydra] Failed to create MDL shade node for prim ‘/World/DataHall_01/DataHall_Racks/Rack_42U_02/Looks/Plastic_Orange_A/Shader’. Empty identifier: ‘’ and/or subIdentifier: ‘’
