After removing my AppData/ov folder i get even more errors:
cmarks@CM-1DFXD14 MINGW64 /d/isaacsim
$ ./isaac-sim.bat
[Info] [carb] Logging to file: C:/Users/cmarks/.nvidia-omniverse/logs/Kit/Isaac-Sim Full/4.5/kit_20250409_142530.log
[1.385s] [ext: omni.kit.async_engine-0.0.1] startup
[3.192s] [ext: omni.metrics.core-0.0.1] startup
[3.195s] [ext: omni.client.lib-1.0.0] startup
[3.268s] [ext: omni.blobkey-1.1.2] startup
[3.272s] [ext: omni.stats-1.0.1] startup
[3.280s] [ext: omni.datastore-0.0.0] startup
[3.290s] [ext: omni.client-1.2.2] startup
[3.315s] [ext: omni.ujitso.default-1.0.0] startup
[3.321s] [ext: omni.hsscclient-1.1.1] startup
2025-04-09 20:25:33 [3,208ms] [Warning] [omni.datastore] OmniHub is inaccessible
[3.335s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[3.349s] [ext: omni.assets.plugins-0.0.0] startup
[3.361s] [ext: omni.gpu_foundation-0.0.0] startup
[3.437s] [ext: carb.windowing.plugins-1.0.0] startup
[3.596s] [ext: omni.kit.renderer.init-0.0.0] startup
[3.599s] [ext: omni.kit.pipapi-0.0.0] startup
[3.602s] [ext: omni.kit.pip_archive-0.0.0] startup
[3.610s] [ext: omni.pip.compute-1.4.5] startup
[3.612s] [ext: omni.pip.cloud-1.1.7] startup
[3.619s] [ext: omni.isaac.core_archive-2.3.3] startup
[3.622s] [ext: omni.materialx.libs-1.0.6] startup
[3.671s] [ext: omni.isaac.ml_archive-2.1.2] startup
[3.674s] [ext: omni.usd.config-1.0.5] startup
[3.702s] [ext: omni.gpucompute.plugins-0.0.0] startup
[3.783s] [ext: omni.usd.libs-1.0.1] startup
[4.123s] [ext: omni.kit.telemetry-0.5.1] startup
[4.177s] [ext: omni.mdl-55.0.1] startup
[4.254s] [ext: omni.iray.libs-0.0.0] startup
2025-04-09 20:25:34 [4,219ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-04-09 20:25:34 [4,221ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
[4.539s] [ext: omni.mdl.neuraylib-0.2.10] startup
[4.553s] [ext: omni.kit.usd.mdl-1.0.7] startup
[4.964s] [ext: omni.kit.loop-isaac-1.2.1] startup
[4.970s] [ext: omni.kit.test-1.1.2] startup
| Driver Version: 572.61 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4060 Laptop.. | Yes: 0 | | 7960 MB | 10de | 15d90100.. |
| | | | | | 28a0 | ed609946.. |
| | | | | | 1 | |
| 1 | Intel(R) Iris(R) Xe Graphics | | | 32603 MB | 8086 | 7ad00100.. |
| | | | | | a7a0 | 8680a0a7.. |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (23H2), Build: 22631, Kernel: 10.0.22621.5185
| Processor: 13th Gen Intel(R) Core(TM) i9-13900H
| Cores: 14 | Logical Cores: 20
| Total Memory (MB): 65207 | Free Memory: 55960
| Total Page/Swap (MB): 69303 | Free Page/Swap: 59494
[5.169s] [ext: omni.appwindow-1.1.9] startup
[5.190s] [ext: omni.kit.renderer.core-1.0.2] startup
[5.205s] [ext: omni.kit.renderer.capture-0.0.0] startup
[5.218s] [ext: omni.kit.renderer.imgui-1.0.2] startup
[5.256s] [ext: omni.ui-2.26.5] startup
[5.300s] [ext: omni.kit.mainwindow-1.0.3] startup
[5.307s] [ext: carb.audio-0.1.0] startup
[5.314s] [ext: omni.uiaudio-1.0.0] startup
[5.320s] [ext: omni.kit.uiapp-0.0.0] startup
[5.322s] [ext: omni.usd.schema.metrics.assembler-106.5.0] startup
[5.331s] [ext: omni.usd.schema.semantics-0.0.0] startup
[5.350s] [ext: omni.usd.schema.audio-0.0.0] startup
[5.367s] [ext: isaacsim.robot.schema-3.1.2] startup
[5.411s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[5.541s] [ext: omni.anim.graph.schema-106.5.0] startup
[5.566s] [ext: omni.usd.schema.anim-0.0.0] startup
[5.656s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[5.674s] [ext: omni.usd_resolver-1.0.0] startup
[5.738s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[5.847s] [ext: usdrt.scenegraph-7.5.1] startup
[6.472s] [ext: omni.timeline-1.0.11] startup
[6.479s] [ext: omni.usd.core-1.4.2] startup
[6.485s] [ext: omni.resourcemonitor-107.0.0] startup
[6.593s] [ext: omni.activity.core-1.0.1] startup
[6.758s] [ext: omni.kit.widget.nucleus_connector-1.1.10] startup
[6.764s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[7.554s] [ext: omni.kit.actions.core-1.0.0] startup
[7.585s] [ext: omni.graph.exec-0.9.4] startup
[7.587s] [ext: omni.kit.commands-1.4.9] startup
[7.699s] [ext: omni.kit.usd_undo-0.1.8] startup
[7.702s] [ext: omni.kit.exec.core-0.13.4] startup
[7.743s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[7.774s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[7.825s] [ext: omni.usd-1.12.4] startup
[8.180s] [ext: omni.inspect-1.0.1] startup
[8.255s] [ext: omni.kit.notification_manager-1.0.9] startup
[8.276s] [ext: omni.graph.core-2.181.8] startup
[8.288s] [ext: isaacsim.core.deprecation_manager-0.2.2] startup
[8.354s] [ext: omni.usd.schema.forcefield-106.5.7] startup
[8.456s] [ext: omni.kit.asset_converter-2.8.3] startup
[8.617s] [ext: omni.usd.schema.isaac-3.0.2] startup
[8.619s] [ext: omni.anim.navigation.schema-106.4.0] startup
[8.635s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[8.663s] [ext: omni.usd.schema.physx-106.5.7] startup
[8.715s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[8.891s] [ext: omni.kit.property.adapter.core-1.0.2] startup
[8.903s] [ext: omni.kit.property.adapter.usd-1.0.2] startup
[8.933s] [ext: omni.kit.property.adapter.fabric-1.0.3] startup
[8.960s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[8.974s] [ext: omni.kit.helper.file_utils-0.1.9] startup
[8.992s] [ext: omni.kit.widget.path_field-2.0.11] startup
[9.012s] [ext: omni.kit.search_core-1.0.6] startup
[9.049s] [ext: omni.kit.widget.filebrowser-2.10.52] startup
[9.177s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[9.227s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[9.237s] [ext: omni.graph.tools-1.79.1] startup
[9.526s] [ext: omni.kit.widget.search_delegate-1.0.6] startup
[9.541s] [ext: omni.kit.widget.options_button-1.0.3] startup
[9.550s] [ext: omni.kit.clipboard-1.0.5] startup
[9.574s] [ext: omni.graph-1.140.2] startup
[10.285s] [ext: omni.kit.menu.core-1.1.2] startup
[10.289s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[10.319s] [ext: omni.kit.widget.context_menu-1.2.4] startup
[10.344s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[10.353s] [ext: omni.ui.scene-1.11.2] startup
[10.452s] [ext: omni.kit.widget.versioning-1.4.9] startup
[10.458s] [ext: omni.kit.usd.layers-2.2.0] startup
[10.523s] [ext: omni.kit.window.filepicker-2.11.7] startup
[10.690s] [ext: omni.kit.widget.filter-1.1.4] startup
[10.698s] [ext: omni.kit.hotkeys.core-1.3.10] startup
[10.734s] [ext: omni.kit.context_menu-1.8.3] startup
[10.761s] [ext: omni.kit.window.file_importer-1.1.14] startup
[10.788s] [ext: omni.kit.window.file_exporter-1.0.31] startup
[10.812s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[10.822s] [ext: omni.kit.stage_template.core-1.1.22] startup
[10.832s] [ext: omni.kit.widget.stage-2.11.6] startup
[10.997s] [ext: omni.hydra.engine.stats-1.0.3] startup
[11.002s] [ext: omni.kit.widget.highlight_label-1.0.3] startup
[11.005s] [ext: omni.kit.window.file-1.3.57] startup
[11.030s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[11.054s] [ext: omni.index.libs-380600.1777.0] startup
[11.055s] [ext: omni.volume-0.5.0] startup
[11.101s] [ext: omni.ujitso.client-0.0.0] startup
[11.103s] [ext: omni.index-1.0.1] startup
[11.108s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[11.112s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[11.114s] [ext: omni.hydra.rtx-1.0.0] startup
[11.328s] [ext: omni.kit.viewport.registry-104.0.6] startup
[11.331s] [ext: omni.kit.viewport.legacy_gizmos-1.0.16] startup
[11.337s] [ext: omni.kit.raycast.query-1.0.5] startup
[11.346s] [ext: omni.kit.viewport.scene_camera_model-1.0.5] startup
[11.354s] [ext: omni.kit.hydra_texture-1.4.0] startup
[11.385s] [ext: omni.kit.menu.utils-1.7.7] startup
[11.425s] [ext: omni.kit.window.drop_support-1.0.4] startup
[11.435s] [ext: omni.kit.widget.viewport-107.0.7] startup
[11.487s] [ext: omni.kit.material.library-1.5.15] startup
[11.574s] [ext: omni.convexdecomposition-106.5.7] startup
[11.604s] [ext: omni.kit.viewport.window-107.0.8] startup
[12.243s] [ext: omni.kit.window.property-1.11.5] startup
[12.281s] [ext: omni.kit.window.content_browser-2.10.3] startup
2025-04-09 20:25:42 [12,221ms] [Warning] [omni.ext._impl._internal] Found class `WrappedClass` derived from `omni.ext.IExt` in module: 'omni.kit.window.content_browser', but it was imported from other extension: 'd:\isaacsim/kit/kernel/py\omni\kit\app\_impl\__init__.py', which is not a subpath to: 'd:\isaacsim\extscache\omni.kit.window.content_browser-2.10.3+d02c707b'. Do not import `IExt` derived class from other extension in your public namespace.
[12.390s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[12.413s] [ext: omni.kit.widget.prompt-1.0.7] startup
[12.421s] [ext: omni.kit.widget.settings-1.2.2] startup
[12.444s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[12.469s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[12.487s] [ext: omni.usdphysics-106.5.7] startup
[12.492s] [ext: omni.kvdb-106.5.7] startup
[12.501s] [ext: omni.kit.window.preferences-1.7.0] startup
[12.554s] [ext: omni.physx.foundation-106.5.7] startup
[12.591s] [ext: omni.localcache-106.5.7] startup
[12.598s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[12.616s] [ext: omni.physx.cooking-106.5.7] startup
[12.646s] [ext: omni.kit.viewport.utility-1.0.18] startup
[12.649s] [ext: omni.kit.property.usd-4.2.16] startup
[12.734s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[12.762s] [ext: omni.physx-106.5.7] startup
[12.801s] [ext: omni.ui_query-1.1.7] startup
[12.804s] [ext: omni.kit.window.extensions-1.4.25] startup
[12.881s] [ext: omni.graph.action_core-1.1.7] startup
[12.894s] [ext: isaacsim.core.version-2.0.2] startup
[12.902s] [ext: omni.graph.ui-1.91.0] startup
[13.077s] [ext: omni.physx.stageupdate-106.5.7] startup
[13.112s] [ext: omni.kit.numpy.common-0.1.2] startup
[13.117s] [ext: isaacsim.storage.native-1.0.6] startup
[13.127s] [ext: omni.graph.action_nodes-1.40.1] startup
[13.156s] [ext: omni.isaac.dynamic_control-1.3.15] startup
2025-04-09 20:25:43 [13,060ms] [Warning] [omni.isaac.dynamic_control] omni.isaac.dynamic_control is deprecated as of Isaac Sim 4.5. No action is needed from end-users.
[13.187s] [ext: omni.kit.window.cursor-1.1.4] startup
[13.191s] [ext: omni.graph.image.core-0.6.0] startup
[13.201s] [ext: omni.physics.tensors-106.5.7] startup
[13.307s] [ext: omni.warp.core-1.5.0] startup
[13.671s] [ext: omni.graph.image.nodes-1.3.0] startup
[13.677s] [ext: omni.physx.tensors-106.5.7] startup
[13.685s] [ext: isaacsim.core.utils-2.2.8] startup
[13.693s] [ext: omni.graph.action-1.120.0] startup
[13.697s] [ext: omni.kit.viewport.menubar.core-107.1.2] startup
[13.804s] [ext: omni.graph.nodes-1.162.1] startup
[13.878s] [ext: isaacsim.core.simulation_manager-0.3.3] startup
[18.496s] [ext: omni.kit.widget.graph-1.12.17] startup
[18.509s] [ext: omni.kit.manipulator.viewport-107.0.1] startup
[18.513s] [ext: omni.warp-1.5.0] startup
[18.541s] [ext: omni.syntheticdata-0.6.10] startup
[18.844s] [ext: isaacsim.core.prims-0.3.7] startup
[19.042s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[19.046s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[19.085s] [ext: omni.kit.widget.stage_icons-1.0.6] startup
[19.105s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[19.116s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[19.172s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[19.205s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[19.254s] [ext: omni.kit.window.stage-2.5.11] startup
[19.280s] [ext: omni.kit.ui_test-1.3.3] startup
[19.298s] [ext: omni.kit.window.material_graph-1.8.19] startup
[19.561s] [ext: omni.kit.stage_templates-1.2.6] startup
[19.574s] [ext: omni.kit.menu.stage-1.2.5] startup
[19.585s] [ext: omni.graph.scriptnode-1.40.1] startup
[19.593s] [ext: isaacsim.gui.components-1.0.9] startup
[19.629s] [ext: isaacsim.core.api-4.2.16] startup
[19.750s] [ext: omni.replicator.core-1.11.35] startup
Warp 1.5.0 initialized:
CUDA Toolkit 11.8, Driver 12.8
Devices:
"cpu" : "Intel64 Family 6 Model 186 Stepping 2, GenuineIntel"
"cuda:0" : "NVIDIA GeForce RTX 4060 Laptop GPU" (8 GiB, sm_89, mempool enabled)
Kernel cache:
C:\Users\cmarks\AppData\Local\NVIDIA\warp\Cache\1.5.0
2025-04-09 20:25:50 [19,915ms] [Warning] [omni.replicator.core.scripts.extension] No material configuration file, adding configuration to material settings directly.
[20.037s] [ext: isaacsim.robot_motion.lula-4.0.4] startup
[20.088s] [ext: isaacsim.robot.surface_gripper-2.0.6] startup
[20.105s] [ext: isaacsim.core.nodes-2.1.4] startup
[20.136s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[20.149s] [ext: isaacsim.robot_motion.motion_generation-8.0.6] startup
[20.336s] [ext: isaacsim.robot.manipulators-3.0.4] startup
[20.406s] [ext: omni.kit.usd.collect-2.2.22] startup
[20.442s] [ext: omni.kit.browser.core-2.3.11] startup
[20.538s] [ext: isaacsim.robot.manipulators.examples-1.0.3] startup
[20.553s] [ext: omni.kit.tool.collect-2.2.16] startup
[20.580s] [ext: omni.kit.browser.folder.core-1.10.1] startup
[20.670s] [ext: isaacsim.cortex.framework-1.0.2] startup
[20.673s] [ext: isaacsim.examples.browser-0.1.8] startup
[20.703s] [ext: isaacsim.cortex.behaviors-2.0.3] startup
[20.706s] [ext: isaacsim.sensors.physics-0.3.5] startup
[20.808s] [ext: omni.kit.menu.create-1.0.17] startup
[20.826s] [ext: isaacsim.robot.policy.examples-4.0.3] startup
[20.845s] [ext: omni.kit.scripting-106.5.2] startup
[20.901s] [ext: isaacsim.robot.wheeled_robots-4.0.3] startup
[21.037s] [ext: isaacsim.examples.extension-2.0.6] startup
[21.052s] [ext: isaacsim.replicator.behavior-1.0.8] startup
[21.059s] [ext: isaacsim.examples.interactive-4.4.8] startup
[21.626s] [ext: isaacsim.sensors.physics.examples-0.1.4] startup
[21.647s] [ext: isaacsim.replicator.behavior.ui-1.0.1] startup
[21.680s] [ext: isaacsim.sensors.camera-0.2.9] startup
[21.720s] [ext: isaacsim.robot.manipulators.ui-2.1.4] startup
[21.732s] [ext: isaacsim.sensors.camera.ui-0.1.4] startup
[22.061s] [ext: omni.debugdraw-0.1.3] startup
[22.068s] [ext: omni.kit.widget.toolbar-1.7.3] startup
[22.083s] [ext: omni.kit.manipulator.transform-106.0.1] startup
[22.095s] [ext: omni.anim.navigation.core-106.4.0] startup
[22.109s] [ext: omni.kit.manipulator.tool.snap-1.5.12] startup
[22.120s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[22.124s] [ext: omni.anim.navigation.recast-106.4.0] startup
[22.136s] [ext: omni.kit.viewport.manipulator.transform-107.0.4] startup
[22.141s] [ext: omni.kit.widget.imageview-1.0.3] startup
[22.144s] [ext: omni.kit.graph.delegate.modern-1.10.8] startup
[22.150s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[22.168s] [ext: omni.fabric.commands-1.1.5] startup
[22.186s] [ext: omni.kit.manipulator.prim.core-107.0.7] startup
[22.245s] [ext: omni.kit.window.quicksearch-2.4.4] startup
[22.270s] [ext: omni.anim.shared.core-106.0.2] startup
[22.279s] [ext: omni.sensors.nv.common-2.5.0-coreapi] startup
[22.394s] [ext: omni.kit.actions.window-1.1.1] startup
[22.453s] [ext: omni.kit.manipulator.prim.fabric-107.0.4] startup
[22.489s] [ext: omni.graph.window.core-1.130.1] startup
[22.595s] [ext: omni.kit.manipulator.prim.usd-107.0.3] startup
[22.600s] [ext: omni.sensors.nv.materials-1.4.0-coreapi] startup
[22.705s] [ext: omni.kit.hotkeys.window-1.4.8] startup
[22.751s] [ext: omni.kit.viewport.actions-107.0.0] startup
[22.770s] [ext: omni.graph.window.action-1.40.0] startup
[22.789s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[22.790s] [ext: omni.sensors.nv.ids-1.4.0-coreapi] startup
[22.836s] [ext: isaacsim.util.debug_draw-2.0.2] startup
[22.849s] [ext: omni.kit.viewport.menubar.display-107.0.3] startup
[22.855s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[22.860s] [ext: omni.mdl.usd_converter-1.0.24] startup
[22.871s] [ext: omni.sensors.nv.wpm-2.4.0-coreapi] startup
[22.887s] [ext: omni.sensors.tiled-0.0.6] startup
[22.893s] [ext: omni.sensors.nv.radar-2.6.1-coreapi] startup
[22.913s] [ext: omni.sensors.nv.lidar-2.6.3-coreapi] startup
[22.931s] [ext: isaacsim.asset.importer.heightmap-2.0.3] startup
[22.941s] [ext: isaacsim.sensors.rtx-13.6.3] startup
[22.961s] [ext: omni.kit.widget.layers-1.8.2] startup
[23.098s] [ext: omni.physx.commands-106.5.7] startup
[23.138s] [ext: omni.usdphysics.ui-106.5.7] startup
[23.189s] [ext: omni.kit.stage.mdl_converter-1.0.7] startup
[23.192s] [ext: omni.isaac.block_world-2.0.2] startup
2025-04-09 20:25:53 [23,082ms] [Warning] [omni.isaac.block_world] ['omni.isaac.block_world'] has been deprecated in favor of ['isaacsim.asset.importer.heightmap']. Please update your code accordingly.
2025-04-09 20:25:53 [23,082ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.block_world', but it was imported from other extension: 'd:/isaacsim/exts/isaacsim.asset.importer.heightmap/isaacsim/asset/importer/heightmap/block_world.py', which is not a subpath to: 'd:\isaacsim\extsdeprecated\omni.isaac.block_world'. Do not import `IExt` derived class from other extension in your public namespace.
[23.204s] [ext: isaacsim.sensors.rtx.ui-0.1.2] startup
2025-04-09 20:25:53 [23,089ms] [Warning] [isaacsim.sensors.rtx.ui.extension] config_dir_path d:/isaacsim/exts/isaacsim.sensors.rtx\data\lidar_configs
[23.535s] [ext: isaacsim.sensors.physics.ui-0.1.2] startup
[23.539s] [ext: omni.physx.ui-106.5.7] startup
[23.580s] [ext: omni.usd.metrics.assembler-106.5.0] startup
[23.591s] [ext: omni.importer.onshape-0.8.1] startup
[23.613s] [ext: isaacsim.robot_setup.gain_tuner-2.0.3] startup
[23.637s] [ext: omni.usd.metrics.assembler.physics-106.5.0] startup
[23.651s] [ext: isaacsim.util.camera_inspector-1.0.4] startup
[23.658s] [ext: omni.isaac.gain_tuner-2.0.2] startup
[23.661s] [ext: isaacsim.robot_setup.grasp_editor-2.0.5] startup
[23.695s] [ext: isaacsim.asset.gen.omap-2.0.8] startup
[23.955s] [ext: omni.anim.curve.core-1.2.0] startup
[24.032s] [ext: isaacsim.robot.surface_gripper.ui-2.1.1] startup
[24.037s] [ext: omni.isaac.grasp_editor-2.0.2] startup
[24.039s] [ext: omni.isaac.occupancy_map-2.0.3] startup
2025-04-09 20:25:54 [23,923ms] [Warning] [omni.isaac.occupancy_map] omni.isaac.occupancy_map has been deprecated in favor of isaacsim.asset.gen.omap. Please update your code accordingly.
2025-04-09 20:25:54 [23,923ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.occupancy_map', but it was imported from other extension: 'd:/isaacsim/exts/isaacsim.asset.gen.omap/isaacsim/asset/gen/omap/impl/extension.py', which is not a subpath to: 'd:\isaacsim\extsdeprecated\omni.isaac.occupancy_map'. Do not import `IExt` derived class from other extension in your public namespace.
[24.043s] [ext: omni.anim.curve.ui-1.4.0] startup
[24.084s] [ext: isaacsim.util.merge_mesh-2.0.6] startup
[24.102s] [ext: isaacsim.robot_setup.assembler-2.1.5] startup
[24.122s] [ext: omni.anim.curve.bundle-1.2.3] startup
[24.123s] [ext: isaacsim.robot_setup.xrdf_editor-3.1.5] startup
[24.139s] [ext: omni.isaac.robot_assembler-2.0.2] startup
[24.141s] [ext: isaacsim.replicator.scene_blox-1.0.2] startup
[24.149s] [ext: omni.isaac.robot_description_editor-3.0.2] startup
[24.151s] [ext: isaacsim.replicator.synthetic_recorder-2.2.3] startup
[24.174s] [ext: isaacsim.core.throttling-2.0.2] startup
[24.187s] [ext: omni.isaac.scene_blox-1.0.2] startup
2025-04-09 20:25:54 [24,076ms] [Warning] [omni.isaac.scene_blox] omni.isaac.scene_blox has been deprecated in favor of isaacsim.replicator.scene_blox. Please update your code accordingly.
[24.197s] [ext: omni.graph.ui_nodes-1.40.1] startup
[24.253s] [ext: omni.isaac.synthetic_recorder-2.0.2] startup
2025-04-09 20:25:54 [24,138ms] [Warning] [omni.isaac.synthetic_recorder] omni.isaac.synthetic_recorder has been deprecated in favor of isaacsim.replicator.synthetic_recorder. Please update your code accordingly.
[24.259s] [ext: omni.isaac.throttling-2.0.2] startup
2025-04-09 20:25:54 [24,145ms] [Warning] [omni.isaac.throttling] omni.isaac.throttling has been deprecated in favor of isaacsim.core.throttling. Please update your code accordingly.
2025-04-09 20:25:54 [24,164ms] [Warning] [omni.isaac.throttling.throttling] omni.isaac.throttling.throttling has been deprecated in favor of isaacsim.core.throttling.extension. Please update your code accordingly.
[24.284s] [ext: omni.kit.browser.asset-1.3.11] startup
[24.339s] [ext: omni.graph.bundle.action-2.20.0] startup
[24.376s] [ext: omni.isaac.cortex.sample_behaviors-2.0.2] startup
2025-04-09 20:25:54 [24,268ms] [Warning] [omni.isaac.cortex] omni.isaac.cortex has been deprecated in favor of isaacsim.cortex.framework. Please update your code accordingly.
2025-04-09 20:25:54 [24,272ms] [Warning] [omni.isaac.cortex.sample_behaviors] omni.isaac.cortex.sample_behaviors has been deprecated in favor of isaacsim.cortex.behaviors. Please update your code accordingly.
[24.392s] [ext: omni.kit.core.collection-0.2.0] startup
[24.423s] [ext: omni.kit.mesh.raycast-105.4.0] startup
[24.471s] [ext: omni.kit.preferences.animation-1.2.0] startup
[24.520s] [ext: omni.graph.window.generic-1.40.0] startup
[24.572s] [ext: omni.kit.property.collection-0.2.0] startup
[24.590s] [ext: omni.kit.property.layer-1.1.8] startup
[24.623s] [ext: omni.kit.search.files-1.0.4] startup
[24.641s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[24.673s] [ext: omni.kit.window.title-1.1.5] startup
[24.681s] [ext: omni.isaac.extension_templates-2.0.2] startup
2025-04-09 20:25:55 [24,571ms] [Warning] [omni.isaac.extension_templates] omni.isaac.extension_templates has been deprecated in favor of isaacsim.examples.extension. Please update your code accordingly.
2025-04-09 20:25:55 [24,571ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.extension_templates', but it was imported from other extension: 'd:/isaacsim/exts/isaacsim.examples.extension/isaacsim/examples/extension/extension.py', which is not a subpath to: 'd:\isaacsim\extsdeprecated\omni.isaac.extension_templates'. Do not import `IExt` derived class from other extension in your public namespace.
[24.691s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[24.718s] [ext: omni.kit.stagerecorder.core-105.0.5] startup
[24.838s] [ext: omni.kit.tool.remove_unused.core-0.1.2] startup
[24.877s] [ext: omni.kit.browser.material-1.6.0] startup
[24.917s] [ext: omni.kit.property.material-1.10.17] startup
[25.053s] [ext: omni.kit.stagerecorder.ui-105.0.6] startup
[25.110s] [ext: omni.kit.widgets.custom-1.0.9] startup
[25.255s] [ext: omni.kit.usdz_export-1.0.7] startup
[25.279s] [ext: omni.kit.window.material-1.6.2] startup
[25.374s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[25.375s] [ext: omni.kit.variant.editor-106.1.1] startup
[25.517s] [ext: omni.kit.thumbnails.usd-1.0.9] startup
[25.923s] [ext: omni.kit.tool.asset_exporter-1.6.2] startup
[25.946s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[25.955s] [ext: omni.kit.usda_edit-1.1.14] startup
[26.068s] [ext: omni.kit.variant.presenter-107.0.0] startup
[26.136s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[26.260s] [ext: omni.kit.manipulator.camera-106.0.3] startup
[26.325s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[26.416s] [ext: omni.kit.viewport.menubar.render-107.0.8] startup
[26.475s] [ext: omni.rtx.window.settings-0.6.17] startup
[26.584s] [ext: isaacsim.asset.gen.omap.ui-2.0.4] startup
[26.631s] [ext: omni.scene.optimizer.core-106.1.10] startup
[27.437s] [ext: omni.kit.widget.live-2.1.8] startup
[27.451s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[27.454s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[27.457s] [ext: omni.isaac.occupancy_map.ui-2.0.3] startup
2025-04-09 20:25:58 [27,354ms] [Warning] [omni.isaac.occupancy_map.ui] omni.isaac.occupancy_map.ui has been deprecated in favor of isaacsim.asset.gen.omap.ui. Please update your code accordingly.
2025-04-09 20:25:58 [27,355ms] [Warning] [omni.ext._impl._internal] Found class `Extension` derived from `omni.ext.IExt` in module: 'omni.isaac.occupancy_map.ui', but it was imported from other extension: 'd:/isaacsim/exts/isaacsim.asset.gen.omap.ui/isaacsim/asset/gen/omap/ui/extension.py', which is not a subpath to: 'd:\isaacsim\extsdeprecated\omni.isaac.occupancy_map.ui'. Do not import `IExt` derived class from other extension in your public namespace.
[27.488s] [ext: omni.kit.converter.common-503.2.1] startup
[28.000s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[28.046s] [ext: omni.kit.widget.cache_indicator-3.0.1] startup
2025-04-09 20:25:58 [27,931ms] [Warning] [omni.kit.pipapi.pipapi] extension omni.kit.widget.cache_indicator-3.0.1 has a [python.pipapi] entry, but use_online_index=true is not set. It doesn't do anything and can be removed.
[29.408s] [ext: omni.isaac.physics_inspector-0.1.7] startup
2025-04-09 20:25:59 [29,290ms] [Warning] [omni.kit.widget.cache_indicator.cache_state_menu] Unable to detect Omniverse Cache Server. Consider installing it for better IO performance.
2025-04-09 20:25:59 [29,298ms] [Warning] [omni.isaac.physics_inspector] omni.isaac.physics_inspector has been deprecated.Replaced by Physics Visualization tools
[29.417s] [ext: isaacsim.util.physics-1.1.2] startup
[29.451s] [ext: omni.kit.converter.dgn_core-503.3.2] startup
[31.731s] [ext: omni.kit.tool.asset_importer-2.12.2] startup
[31.734s] [ext: omni.kit.converter.hoops_core-504.4.1] startup
[32.858s] [ext: omni.kit.window.script_editor-1.7.8] startup
[32.986s] [ext: omni.kit.window.usd_paths-1.0.7] startup
[33.013s] [ext: isaacsim.asset.browser-1.3.4] startup
[33.189s] [ext: omni.simready.explorer-1.1.1] startup
[33.424s] [ext: isaacsim.core.cloner-1.3.4] startup
[33.452s] [ext: omni.kit.converter.dgn-503.3.1] startup
[33.526s] [ext: omni.kit.converter.hoops-504.4.3] startup
[33.556s] [ext: isaacsim.asset.importer.mjcf-2.3.3] startup
[36.038s] [ext: isaacsim.asset.importer.urdf-2.3.10] startup
[36.720s] [ext: omni.isaac.asset_browser-1.0.2] startup
2025-04-09 20:26:07 [36,611ms] [Warning] [omni.isaac.asset_browser] omni.isaac.asset_browser has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[36.730s] [ext: omni.isaac.assets_check-0.3.9] startup
2025-04-09 20:26:07 [36,619ms] [Warning] [omni.isaac.assets_check] omni.isaac.assets_check has been deprecated in favor of isaacsim.asset.browser. Please update your code accordingly.
[36.737s] [ext: omni.isaac.cloner-1.0.2] startup
2025-04-09 20:26:07 [36,627ms] [Warning] [omni.isaac.cloner] omni.isaac.cloner has been deprecated in favor of isaacsim.core.cloner. Please update your code accordingly.
[36.745s] [ext: omni.kit.widget.calendar-1.0.8] startup
[36.773s] [ext: omni.kit.selection-0.1.5] startup
[36.795s] [ext: omni.isaac.core-4.0.3] startup
2025-04-09 20:26:07 [36,697ms] [Warning] [omni.isaac.core.physics_context.physics_context] omni.isaac.core.physics_context.physics_context has been deprecated in favor of isaacsim.core.api.physics_context.physics_context. Please update your code accordingly.
2025-04-09 20:26:07 [36,710ms] [Warning] [omni.isaac.core.simulation_context.simulation_context] omni.isaac.core.simulation_context.simulation_context has been deprecated in favor of isaacsim.core.api.simulation_context.simulation_context. Please update your code accordingly.
2025-04-09 20:26:07 [36,722ms] [Warning] [omni.isaac.core.world.world] omni.isaac.core.world.world has been deprecated in favor of isaacsim.core.api.world.world. Please update your code accordingly.
2025-04-09 20:26:07 [36,722ms] [Warning] [omni.isaac.core] omni.isaac.core has been deprecated in favor of isaacsim.core.api. Please update your code accordingly.
[36.841s] [ext: isaacsim.simulation_app-2.4.2] startup
[36.863s] [ext: omni.isaac.core_nodes-2.0.2] startup
2025-04-09 20:26:07 [36,775ms] [Warning] [omni.isaac.core_nodes] omni.isaac.core_nodes has been deprecated in favor of isaacsim.core.nodes. Please update your code accordingly.
[36.896s] [ext: omni.isaac.cortex-1.0.2] startup
[36.897s] [ext: isaacsim.robot_motion.lula_test_widget-1.0.5] startup
[36.927s] [ext: omni.kit.widget.extended_searchfield-1.0.29] startup
[37.391s] [ext: isaacsim.gui.menu-2.0.9] startup
[37.515s] [ext: omni.isaac.franka-1.0.2] startup
2025-04-09 20:26:08 [37,405ms] [Warning] [omni.isaac.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-04-09 20:26:08 [37,411ms] [Warning] [omni.isaac.franka.franka] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
2025-04-09 20:26:08 [37,417ms] [Warning] [omni.isaac.franka.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.franka. Please update your code accordingly.
[37.536s] [ext: omni.isaac.kit-2.0.3] startup
2025-04-09 20:26:08 [37,429ms] [Warning] [omni.isaac.kit] omni.isaac.kit has been deprecated in favor of isaacsim.simulation_app. Please update your code accordingly.
[37.548s] [ext: omni.isaac.lula-4.0.2] startup
2025-04-09 20:26:08 [37,437ms] [Warning] [omni.isaac.lula] omni.isaac.lula has been deprecated in favor of isaacsim.robot_motion.lula. Please update your code accordingly.
[37.556s] [ext: isaacsim.sensors.physx-2.2.4] startup
[37.809s] [ext: omni.isaac.lula_test_widget-1.0.2] startup
2025-04-09 20:26:08 [37,698ms] [Warning] [omni.isaac.lula_test_widget] omni.isaac.lula_test_widget has been deprecated in favor of isaacsim.robot_motion.lula_test_widget. Please update your code accordingly.
[37.817s] [ext: omni.isaac.manipulators-3.0.3] startup
2025-04-09 20:26:08 [37,707ms] [Warning] [omni.isaac.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,714ms] [Warning] [omni.isaac.manipulators.controllers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,720ms] [Warning] [omni.isaac.manipulators.controllers.pick_place_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,727ms] [Warning] [omni.isaac.manipulators.controllers.stacking_controller] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,733ms] [Warning] [omni.isaac.manipulators.grippers] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,740ms] [Warning] [omni.isaac.manipulators.grippers.gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,746ms] [Warning] [omni.isaac.manipulators.grippers.parallel_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,752ms] [Warning] [omni.isaac.manipulators.grippers.surface_gripper] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,760ms] [Warning] [omni.isaac.manipulators.manipulators] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
2025-04-09 20:26:08 [37,767ms] [Warning] [omni.isaac.manipulators.manipulators.single_manipulator] omni.isaac.manipulators has been deprecated in favor of isaacsim.robot.manipulators. Please update your code accordingly.
[37.886s] [ext: omni.isaac.menu-1.0.2] startup
2025-04-09 20:26:08 [37,777ms] [Warning] [omni.isaac.menu] omni.isaac.menu has been deprecated in favor of isaacsim.gui.menu. Please update your code accordingly.
[37.896s] [ext: omni.isaac.motion_generation-8.0.2] startup
2025-04-09 20:26:08 [37,786ms] [Warning] [omni.isaac.motion_generation] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,792ms] [Warning] [omni.isaac.motion_generation.articulation_kinematics_solver] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,799ms] [Warning] [omni.isaac.motion_generation.articulation_motion_policy] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,805ms] [Warning] [omni.isaac.motion_generation.articulation_trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,812ms] [Warning] [omni.isaac.motion_generation.kinematics_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,817ms] [Warning] [omni.isaac.motion_generation.lula] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,823ms] [Warning] [omni.isaac.motion_generation.lula.kinematics] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,830ms] [Warning] [omni.isaac.motion_generation.lula.motion_policies] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,837ms] [Warning] [omni.isaac.motion_generation.lula.path_planners] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,845ms] [Warning] [omni.isaac.motion_generation.lula.trajectory_generator] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,852ms] [Warning] [omni.isaac.motion_generation.motion_policy_controller] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,859ms] [Warning] [omni.isaac.motion_generation.motion_policy_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,866ms] [Warning] [omni.isaac.motion_generation.path_planner_visualizer] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,872ms] [Warning] [omni.isaac.motion_generation.path_planning_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,878ms] [Warning] [omni.isaac.motion_generation.trajectory] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
2025-04-09 20:26:08 [37,885ms] [Warning] [omni.isaac.motion_generation.world_interface] omni.isaac.motion_generation has been deprecated in favor of isaacsim.robot_motion.motion_generation. Please update your code accordingly.
[38.004s] [ext: omni.isaac.nucleus-1.0.3] startup
2025-04-09 20:26:08 [37,894ms] [Warning] [omni.isaac.nucleus] omni.isaac.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
2025-04-09 20:26:08 [37,899ms] [Warning] [omni.isaac.nucleus.nucleus] omni.isaac.nucleus.nucleus has been deprecated in favor of isaacsim.storage.native. Please update your code accordingly.
[38.018s] [ext: omni.isaac.quadruped-3.0.2] startup
2025-04-09 20:26:08 [37,907ms] [Warning] [omni.isaac.quadruped] omni.isaac.quadruped has been deprecated in favor of isaacsim.robot.policy.examples. Please update your code accordingly.
[38.026s] [ext: omni.isaac.range_sensor-4.0.2] startup
[38.032s] [ext: omni.isaac.sensor-13.0.3] startup
2025-04-09 20:26:08 [37,922ms] [Warning] [omni.isaac.sensor] omni.isaac.sensor has been deprecated in favor of isaacsim.sensors.camera, isaacsim.sensors.physics, isaacsim.sensors.physx, and isaacsim.sensors.rtx. Please update your code accordingly.
2025-04-09 20:26:08 [37,930ms] [Warning] [omni.isaac.sensor.camera] omni.isaac.sensor.camera has been deprecated in favor of isaacsim.sensors.camera.camera. Please update your code accordingly.
2025-04-09 20:26:08 [37,936ms] [Warning] [omni.isaac.sensor.camera_view] omni.isaac.sensor.camera_view has been deprecated in favor of isaacsim.sensors.camera.camera_view. Please update your code accordingly.
2025-04-09 20:26:08 [37,942ms] [Warning] [omni.isaac.sensor.commands] omni.isaac.sensor.commands has been deprecated in favor of isaacsim.sensors.physics.commands, isaacsim.sensors.physx.commands, and isaacsim.sensors.rtx.commands. Please update your code accordingly.
2025-04-09 20:26:08 [37,948ms] [Warning] [omni.isaac.sensor.contact_sensor] omni.isaac.sensor.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.contact_sensor. Please update your code accordingly.
2025-04-09 20:26:08 [37,954ms] [Warning] [omni.isaac.sensor.imu_sensor] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.imu_sensor. Please update your code accordingly.
2025-04-09 20:26:08 [37,961ms] [Warning] [omni.isaac.sensor.lidar_rtx] omni.isaac.sensor.lidar_rtx has been deprecated in favor of isaacsim.sensors.rtx.lidar_rtx. Please update your code accordingly.
2025-04-09 20:26:08 [37,967ms] [Warning] [omni.isaac.sensor.rotating_lidar_physX] omni.isaac.sensor.imu_sensor has been deprecated in favor of isaacsim.sensors.physix.rotating_lidar_physX. Please update your code accordingly.
2025-04-09 20:26:08 [37,973ms] [Warning] [omni.isaac.sensor.scripts.samples.contact_sensor] omni.isaac.sensor.scripts.samples.contact_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.contact_sensor. Please update your code accordingly.
2025-04-09 20:26:08 [37,980ms] [Warning] [omni.isaac.sensor.scripts.samples.imu_sensor] omni.isaac.sensor.scripts.samples.imu_sensor has been deprecated in favor of isaacsim.sensors.physics.scripts.samples.imu_sensor. Please update your code accordingly.
2025-04-09 20:26:08 [37,991ms] [Warning] [omni.isaac.sensor.scripts.samples.lightbeam_sensor] omni.isaac.sensor.scripts.samples.lightbeam_sensor has been deprecated in favor of isaacsim.sensors.physx.scripts.samples.lightbeam_sensor. Please update your code accordingly.
[38.112s] [ext: omni.isaac.surface_gripper-2.0.2] startup
2025-04-09 20:26:08 [38,007ms] [Warning] [omni.isaac.surface_gripper] omni.isaac.surface_gripper has been deprecated in favor of isaacsim.robot.surface_gripper. Please update your code accordingly.
[38.125s] [ext: omni.isaac.universal_robots-1.0.2] startup
2025-04-09 20:26:08 [38,016ms] [Warning] [omni.isaac.universal_robots] omni.isaac.universal_robots has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-04-09 20:26:08 [38,022ms] [Warning] [omni.isaac.universal_robots.kinematics_solver] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
2025-04-09 20:26:08 [38,028ms] [Warning] [omni.isaac.universal_robots.ur10] omni.isaac.franka has been deprecated in favor of isaacsim.robot.manipulators.examples.universal_robots. Please update your code accordingly.
[38.147s] [ext: omni.isaac.utils-2.0.2] startup
[38.162s] [ext: omni.kit.property.audio-1.0.16] startup
[38.190s] [ext: omni.kit.property.camera-1.0.9] startup
[38.210s] [ext: omni.hydra.scene_api-0.1.2] startup
[38.335s] [ext: omni.kit.property.physx-106.5.7] startup
[38.872s] [ext: omni.physx.demos-106.5.7] startup
[40.977s] [ext: omni.kit.property.geometry-1.3.3] startup
[41.017s] [ext: isaacsim.app.about-2.0.7] startup
[41.037s] [ext: omni.kit.property.light-1.0.11] startup
[41.059s] [ext: omni.kit.property.render-1.1.3] startup
[41.076s] [ext: omni.kit.property.transform-1.5.10] startup
[41.126s] [ext: omni.isaac.version-2.0.2] startup
2025-04-09 20:26:11 [41,030ms] [Warning] [omni.isaac.version] omni.isaac.version has been deprecated in favor of isaacsim.core.version. Please update your code accordingly.
[41.149s] [ext: omni.physx.vehicle-106.5.7] startup
[41.982s] [ext: omni.isaac.wheeled_robots-3.0.3] startup
2025-04-09 20:26:12 [41,867ms] [Warning] [omni.isaac.wheeled_robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,868ms] [Warning] [omni.isaac.wheeled_robots.controllers] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,868ms] [Warning] [omni.isaac.wheeled_robots.controllers.ackermann_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,869ms] [Warning] [omni.isaac.wheeled_robots.controllers.differential_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,869ms] [Warning] [omni.isaac.wheeled_robots.controllers.holonomic_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,877ms] [Warning] [omni.isaac.wheeled_robots.controllers.quintic_path_planner] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,884ms] [Warning] [omni.isaac.wheeled_robots.controllers.stanley_control] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,890ms] [Warning] [omni.isaac.wheeled_robots.controllers.wheel_base_pose_controller] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,896ms] [Warning] [omni.isaac.wheeled_robots.impl] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,897ms] [Warning] [omni.isaac.wheeled_robots.robots] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,898ms] [Warning] [omni.isaac.wheeled_robots.robots.holonomic_robot_usd_setup] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
2025-04-09 20:26:12 [41,902ms] [Warning] [omni.isaac.wheeled_robots.robots.wheeled_robot] omni.isaac.wheeled_robots has been deprecated in favor of isaacsim.robot.wheeled_robots. Please update your code accordingly.
[42.021s] [ext: omni.isaac.window.about-2.0.2] startup
2025-04-09 20:26:12 [41,907ms] [Warning] [omni.isaac.window.about] omni.isaac.window.about has been deprecated in favor of isaacsim.app.about. Please update your code accordingly.
2025-04-09 20:26:12 [41,914ms] [Warning] [omni.isaac.window.about.about] omni.isaac.window.about.about has been deprecated in favor of isaacsim.app.about.about. Please update your code accordingly.
[42.033s] [ext: isaacsim.sensors.physx.examples-2.2.4] startup
[42.051s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[42.068s] [ext: omni.kit.property.bundle-1.3.2] startup
[42.088s] [ext: isaacsim.replicator.domain_randomization-1.0.2] startup
[42.123s] [ext: omni.physx.camera-106.5.7] startup
[42.240s] [ext: omni.kit.window.toolbar-1.6.2] startup
[42.275s] [ext: omni.kit.widget.timeline-105.0.1] startup
[42.330s] [ext: omni.isaac.range_sensor.examples-2.0.3] startup
2025-04-09 20:26:12 [42,219ms] [Warning] [omni.isaac.range_sensor.examples] omni.isaac.range_sensor.examples has been deprecated in favor of isaacsim.sensors.physx.examples. Please update your code accordingly.
2025-04-09 20:26:12 [42,225ms] [Warning] [omni.isaac.range_sensor.examples.lidar_info] omni.isaac.range_sensor.examples.lidar_info has been deprecated in favor of isaacsim.sensors.physx.examples.lidar_info. Please update your code accordingly.
2025-04-09 20:26:12 [42,231ms] [Warning] [omni.isaac.range_sensor.examples.generic_info] omni.isaac.range_sensor.examples.generic_info has been deprecated in favor of isaacsim.sensors.physx.examples.generic_info. Please update your code accordingly.
[42.350s] [ext: isaacsim.replicator.writers-1.0.1] startup
[42.732s] [ext: isaacsim.gui.property-1.0.4] startup
[42.756s] [ext: omni.physx.cct-106.5.7] startup
[42.836s] [ext: omni.physx.graph-106.5.7] startup
[42.966s] [ext: omni.physx.supportui-106.5.7] startup
[43.198s] [ext: omni.physx.telemetry-106.5.7] startup
[43.228s] [ext: isaacsim.replicator.examples-1.1.2] startup
[43.238s] [ext: omni.kit.property.isaac-1.0.2] startup
2025-04-09 20:26:13 [43,129ms] [Warning] [omni.kit.property.isaac] omni.kit.property.isaac has been deprecated in favor of isaacsim.gui.property. Please update your code accordingly.
2025-04-09 20:26:13 [43,130ms] [Warning] [omni.kit.property.isaac.widgets] omni.kit.property.isaac.widgets has been deprecated in favor of isaacsim.gui.property.widgets. Please update your code accordingly.
2025-04-09 20:26:13 [43,130ms] [Warning] [omni.ext._impl._internal] Found class `IsaacPropertyWidgets` derived from `omni.ext.IExt` in module: 'omni.kit.property.isaac', but it was imported from other extension: 'd:/isaacsim/exts/isaacsim.gui.property/isaacsim/gui/property/widgets.py', which is not a subpath to: 'd:\isaacsim\extsdeprecated\omni.kit.property.isaac'. Do not import `IExt` derived class from other extension in your public namespace.
[43.249s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[43.293s] [ext: omni.kit.window.console-0.2.14] startup
[43.473s] [ext: omni.kit.window.status_bar-0.1.7] startup
[43.499s] [ext: omni.kit.widget.collection-0.1.18] startup
[43.532s] [ext: omni.physx.bundle-106.5.7] startup
[43.534s] [ext: omni.replicator.isaac-2.0.3] startup
2025-04-09 20:26:14 [43,423ms] [Warning] [omni.replicator.isaac] omni.replicator.isaac has been deprecated in favor of isaacsim.replicator.domain_randomization, isaacsim.replicator.examples, isaacsim.replicator.writers. Please update your code accordingly.
[43.543s] [ext: omni.replicator.replicator_yaml-2.0.10] startup
[43.583s] [ext: omni.rtx.settings.core-0.6.3] startup
[43.608s] [ext: omni.kit.converter.jt_core-503.2.2] startup
[44.795s] [ext: omni.usd.metrics.assembler.ui-106.5.0] startup
[44.802s] [ext: omni.kit.window.collection-0.2.0] startup
[44.806s] [ext: isaacsim.sensors.physx.ui-2.2.1] startup
[44.810s] [ext: semantics.schema.editor-0.3.10] startup
[44.815s] [ext: omni.kit.ui.actions-1.0.2] startup
[44.819s] [ext: semantics.schema.property-1.0.5] startup
[44.823s] [ext: omni.kit.converter.jt-503.2.2] startup
[44.827s] [ext: omni.kit.quicklayout-1.0.8] startup
[44.831s] [ext: omni.kit.window.commands-0.2.7] startup
[44.836s] [ext: omni.isaac.range_sensor.ui-2.0.2] startup
2025-04-09 20:26:15 [44,720ms] [Warning] [omni.isaac.range_sensor.ui] omni.isaac.range_sensor.ui has been deprecated in favor of isaacsim.sensors.physx.ui. Please update your code accordingly.
2025-04-09 20:26:15 [44,720ms] [Warning] [omni.isaac.range_sensor.ui.menu] omni.isaac.range_sensor.ui.menu has been deprecated in favor of isaacsim.sensors.physx.ui.menu. Please update your code accordingly.
[44.839s] [ext: isaacsim.robot.wheeled_robots.ui-2.1.5] startup
[44.844s] [ext: omni.kit.menu.common-1.1.9] startup
[44.849s] [ext: isaacsim.exp.base-4.5.0] startup
[44.851s] [ext: omni.kit.converter.cad-202.2.0] startup
[44.852s] [ext: omni.kit.window.stats-0.1.7] startup
[44.855s] [ext: isaacsim.app.setup-1.3.5] startup
[44.859s] Isaac Sim Full Version: 4.5.0-rc.36
[44.860s] [ext: omni.kit.profiler.window-2.3.1] startup
[44.875s] [ext: isaacsim.exp.full-4.5.0] startup
[45.540s] app ready
2025-04-09 20:26:16 [45,501ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 7508933632
2025-04-09 20:26:16 [45,502ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid false, within: false
2025-04-09 20:26:16 [45,502ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : decrement: 167690, decrement size: 7433845248
2025-04-09 20:26:16 [45,502ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : New limit 9574251 (slope: 447, intercept: 13179904)
2025-04-09 20:26:16 [45,502ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit buffer size 4287216384
2025-04-09 20:26:16 [45,502ms] [Warning] [rtx.scenedb.plugin] SceneDbContext : TLAS limit : valid true, within: true
2025-04-09 20:26:16 [45,907ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::baking_annotations' in module path
2025-04-09 20:26:16 [45,907ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::baking_annotations
2025-04-09 20:26:16 [45,907ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::baking_annotations
2025-04-09 20:26:16 [45,911ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/baking_annotations.mdl
2025-04-09 20:26:16 [45,913ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniEmissive' in module path
2025-04-09 20:26:16 [45,914ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniEmissive
2025-04-09 20:26:16 [45,914ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniEmissive
2025-04-09 20:26:16 [45,919ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniEmissive.mdl
2025-04-09 20:26:16 [45,921ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniGlass' in module path
2025-04-09 20:26:16 [45,921ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniGlass
2025-04-09 20:26:16 [45,921ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniGlass
2025-04-09 20:26:16 [45,927ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniGlass.mdl
2025-04-09 20:26:16 [45,929ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniGlass_Opacity' in module path
2025-04-09 20:26:16 [45,929ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniGlass_Opacity
2025-04-09 20:26:16 [45,929ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniGlass_Opacity
2025-04-09 20:26:16 [45,936ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniGlass_Opacity.mdl
2025-04-09 20:26:16 [45,938ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniHair' in module path
2025-04-09 20:26:16 [45,938ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniHair
2025-04-09 20:26:16 [45,938ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniHair
2025-04-09 20:26:16 [45,945ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniHair.mdl
2025-04-09 20:26:16 [45,947ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniHairPresets' in module path
2025-04-09 20:26:16 [45,947ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniHairPresets
2025-04-09 20:26:16 [45,947ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniHairPresets
2025-04-09 20:26:16 [45,953ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniHairPresets.mdl
2025-04-09 20:26:16 [45,956ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR' in module path
2025-04-09 20:26:16 [45,956ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR
2025-04-09 20:26:16 [45,956ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR
2025-04-09 20:26:16 [45,961ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniPBR.mdl
2025-04-09 20:26:16 [45,963ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBRBase' in module path
2025-04-09 20:26:16 [45,964ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBRBase
2025-04-09 20:26:16 [45,964ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBRBase
2025-04-09 20:26:16 [45,966ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniPBRBase.mdl
2025-04-09 20:26:16 [45,968ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_ClearCoat' in module path
2025-04-09 20:26:16 [45,969ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_ClearCoat
2025-04-09 20:26:16 [45,969ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_ClearCoat
2025-04-09 20:26:16 [45,974ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniPBR_ClearCoat.mdl
2025-04-09 20:26:16 [45,976ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_ClearCoat_Opacity' in module path
2025-04-09 20:26:16 [45,977ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_ClearCoat_Opacity
2025-04-09 20:26:16 [45,977ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_ClearCoat_Opacity
2025-04-09 20:26:16 [45,983ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniPBR_ClearCoat_Opacity.mdl
2025-04-09 20:26:16 [45,985ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_Opacity' in module path
2025-04-09 20:26:16 [45,985ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_Opacity
2025-04-09 20:26:16 [45,986ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniPBR_Opacity
2025-04-09 20:26:16 [45,991ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniPBR_Opacity.mdl
2025-04-09 20:26:16 [45,994ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurface' in module path
2025-04-09 20:26:16 [45,994ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurface
2025-04-09 20:26:16 [45,994ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurface
2025-04-09 20:26:16 [46,001ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniSurface.mdl
2025-04-09 20:26:16 [46,003ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfaceBlend' in module path
2025-04-09 20:26:16 [46,003ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfaceBlend
2025-04-09 20:26:16 [46,003ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfaceBlend
2025-04-09 20:26:16 [46,008ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniSurfaceBlend.mdl
2025-04-09 20:26:16 [46,010ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfaceLite' in module path
2025-04-09 20:26:16 [46,011ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfaceLite
2025-04-09 20:26:16 [46,011ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfaceLite
2025-04-09 20:26:16 [46,019ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniSurfaceLite.mdl
2025-04-09 20:26:16 [46,021ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfacePresets' in module path
2025-04-09 20:26:16 [46,021ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfacePresets
2025-04-09 20:26:16 [46,022ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::OmniSurfacePresets
2025-04-09 20:26:16 [46,026ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/OmniSurfacePresets.mdl
2025-04-09 20:26:16 [46,028ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR' in module path
2025-04-09 20:26:16 [46,028ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR
2025-04-09 20:26:16 [46,028ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR
2025-04-09 20:26:16 [46,035ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/SimPBR.mdl
2025-04-09 20:26:16 [46,037ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR_Model' in module path
2025-04-09 20:26:16 [46,037ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR_Model
2025-04-09 20:26:16 [46,038ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR_Model
2025-04-09 20:26:16 [46,043ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/SimPBR_Model.mdl
2025-04-09 20:26:16 [46,045ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR_Translucent' in module path
2025-04-09 20:26:16 [46,046ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR_Translucent
2025-04-09 20:26:16 [46,046ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Base::SimPBR_Translucent
2025-04-09 20:26:16 [46,051ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Base/SimPBR_Translucent.mdl
2025-04-09 20:26:16 [46,062ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Volume::OmniVolumeDensity' in module path
2025-04-09 20:26:16 [46,062ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Volume::OmniVolumeDensity
2025-04-09 20:26:16 [46,062ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Volume::OmniVolumeDensity
2025-04-09 20:26:16 [46,063ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-04-09 20:26:16 [46,064ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Volume/OmniVolumeDensity.mdl
2025-04-09 20:26:16 [46,066ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Volume::OmniVolumeNoise' in module path
2025-04-09 20:26:16 [46,067ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (default_scope) failed: ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Volume::OmniVolumeNoise
2025-04-09 20:26:16 [46,067ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (default_scope): ::Z73file_3A::Z17D_3A::isaacsim::kit::mdl::core::Volume::OmniVolumeNoise
2025-04-09 20:26:16 [46,077ms] [Warning] [omni.kit.material.library.material_library] process_ov_neuraylib: failed to get module from D:/isaacsim/kit/mdl/core/Volume/OmniVolumeNoise.mdl
2025-04-09 20:26:18 [47,532ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-04-09 20:26:18 [47,544ms] [Warning] [omni.kit.widget.cache_indicator.utils] No library_root key valid path in omniverse.toml
2025-04-09 20:26:20 [49,689ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults-transient/meshlights/forceDisable'
2025-04-09 20:26:21 [50,944ms] [Warning] [omni.usd-abi.plugin] No setting was found for '/rtx-defaults/post/dlss/execMode'
2025-04-09 20:26:36 [66,141ms] [Error] [rtx.neuraylib.plugin] [MDLC:COMPILER] 1.0 MDLC comp error: C120 could not find module '::Default' in module path
2025-04-09 20:26:36 [66,141ms] [Warning] [rtx.neuraylib.plugin] Loading MdlModule to DB (rtx_scope0) failed: ::Default
2025-04-09 20:26:36 [66,141ms] [Warning] [rtx.neuraylib.plugin] Loading transaction committed (this thread). MdlModule is NOT in the DB (rtx_scope0): ::Default
2025-04-09 20:26:36 [66,142ms] [Error] [rtx.neuraylib.plugin] Failed to resolve overloads. The MdlModule 'mdl::Default' is not loaded.
2025-04-09 20:26:36 [66,142ms] [Error] [carb.scenerenderer-rtx.plugin] Failed to uniquely resolve MDL material 'Default' from module 'Default.mdl'.
2025-04-09 20:29:35 [244,406ms] [Warning] [omni.hydra.rtx] HydraEngine rtx failed creating scene renderer.
There seems to be a problem loading or compiling the material libraries in mdl::core starting with the baking_annotations file.
