I alread had Isaac sim2022 installed on ubuntu20 when updating to ubuntu22 in order to use ros2 humble. Before installing, I had deleted the original path data of Isaac sim and I found that Omniverse was not working and reinstalled it and Isaac sim.
Can anyone work with me to solve this problem?
Here is the log of error report when installing Isaac sim.
Error occurred during installation of Isaac Sim: Command failed: “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/omni.isaac.sim.post.install.sh”
2022-07-26 16:18:02 [610ms] [Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file: ‘/home/dongchan/.local/share/ov/data/Kit/Isaac-Sim/2022.1/a276e7d9-8332-4974-14f9c0ae-cf12f4d5.dmp’, code: 0, error: ‘SSL connect error’, response:
2022-07-26 16:18:02 [610ms] [Error] [carb.crashreporter-breakpad.plugin] {status = SendFailed (4)}
2022-07-26 16:18:02 [710ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
- For Ubuntu, it requires server-xorg-core 1.20.7+ and a display to work without --no-window.
- For Linux dockers, the setup is not complete. Install the latest driver, xServer and NVIDIA container runtime.
2022-07-26 16:18:02 [725ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
2022-07-26 16:18:02 [726ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices for compatibilityMode!
2022-07-26 16:18:02 [1,114ms] [Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file: ‘/home/dongchan/.local/share/ov/data/Kit/Isaac-Sim/2022.1/dabaac3f-44e6-44d8-2926baa2-7c53798d.dmp’, code: 0, error: ‘SSL connect error’, response:
2022-07-26 16:18:02 [1,114ms] [Error] [carb.crashreporter-breakpad.plugin] {status = SendFailed (4)}
2022-07-26 16:18:03 [1,933ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
2022-07-26 16:18:03 [1,933ms] [Error] [omni.kit.imgui_renderer.plugin] _prepareDefaultWindow: invalid device attached to the default window!
UsdE57FileFormat
OmniAssetFileFormat
2022-07-26 16:18:06 [4,639ms] [Error] [carb] [Plugin: libomni.videoencoding.plugin.so] Could not load the dynamic library from /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.videoencoding/bin/libomni.videoencoding.plugin.so. Error: libcuda.so.1: cannot open shared object file: No such file or directory
2022-07-26 16:18:06 [4,640ms] [Error] [omni.ext.plugin] [ext: omni.videoencoding-0.1.0] failed to load native plugin: /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.videoencoding/bin/libomni.videoencoding.plugin.so
2022-07-26 16:18:06 [4,644ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::IVideoEncoding (pluginName: nullptr)
At:
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/exts/omni.videoencoding/video_encoding/impl/video_encoding.py(59): on_startup
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(135): _startup_ext
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/carb/profiler/init.py(80): wrapper
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(186): startup
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(268): startup_extension
PythonExtension.cpp::startup()(2):
2022-07-26 16:18:06 [4,644ms] [Error] [omni.ext.plugin] [ext: omni.videoencoding-0.1.0] Failed to startup python extension.
2022-07-26 16:18:06 [4,693ms] [Error] [omni.kit.window.viewport.plugin] renderer::IRenderer is invalid
2022-07-26 16:18:06 [4,693ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
2022-07-26 16:18:06 [4,693ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required plugins
2022-07-26 16:18:06 [4,730ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.kit.capture.viewport. Error: No module named ‘video_encoding’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/python/lib/python3.7/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1006, in _gcd_import
File “”, line 983, in _find_and_load
File “”, line 967, in _find_and_load_unlocked
File “”, line 677, in _load_unlocked
File “”, line 728, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.capture.viewport-1.1.9+cp37/omni/kit/capture/viewport/init.py”, line 10, in
from .extension import CaptureExtension
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.capture.viewport-1.1.9+cp37/omni/kit/capture/viewport/extension.py”, line 22, in
from .video_generation import VideoGenerationHelper
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.capture.viewport-1.1.9+cp37/omni/kit/capture/viewport/video_generation.py”, line 12, in
from video_encoding import get_video_encoding_interface
ModuleNotFoundError: No module named ‘video_encoding’
2022-07-26 16:18:06 [4,730ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.capture.viewport’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.capture.viewport-1.1.9+cp37’ failed to load.
At:
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(177): startup
2022-07-26 16:18:06 [4,730ms] [Error] [omni.ext.plugin] [ext: omni.kit.capture.viewport-1.1.9] Failed to startup python extension.
2022-07-26 16:18:07 [5,388ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.kit.window.movie_capture. Error: No module named ‘video_encoding’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.window.movie_capture-1.2.11+cp37/omni/kit/window/movie_capture/init.py”, line 10, in
from .extension import MovieCaptureExtension
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.window.movie_capture-1.2.11+cp37/omni/kit/window/movie_capture/extension.py”, line 13, in
from .window import MovieCaptureWindow
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.window.movie_capture-1.2.11+cp37/omni/kit/window/movie_capture/window.py”, line 14, in
import omni.kit.capture.viewport
2022-07-26 16:18:07 [5,388ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.window.movie_capture’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.kit.window.movie_capture-1.2.11+cp37’ failed to load.
At:
2022-07-26 16:18:07 [5,388ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.movie_capture-1.2.11] Failed to startup python extension.
2022-07-26 16:18:07 [6,176ms] [Error] [carb] [Plugin: libomni.physx.plugin.so] Could not load the dynamic library from /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx-1.4.12-5.1/bin/libomni.physx.plugin.so. Error: libcuda.so.1: cannot open shared object file: No such file or directory
2022-07-26 16:18:07 [6,176ms] [Error] [omni.ext.plugin] [ext: omni.physx-1.4.12-5.1] failed to load native plugin: /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx-1.4.12-5.1/bin/libomni.physx.plugin.so
2022-07-26 16:18:07 [6,198ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::physx::IPhysx (pluginName: nullptr)
At:
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx-1.4.12-5.1/omni/physx/init.py(7): _get_interface
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx-1.4.12-5.1/omni/physx/init.py(11): get_physx_interface
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx-1.4.12-5.1/omni/physx/scripts/extension.py(20): on_startup
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py(137): _startup_ext
2022-07-26 16:18:07 [6,198ms] [Error] [omni.ext.plugin] [ext: omni.physx-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:07 [6,277ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:07 [6,277ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysxSceneQuery v1.0] failed to be resolved.
2022-07-26 16:18:07 [6,278ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:07 [6,278ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysxSceneQuery v1.0] failed to be resolved.
2022-07-26 16:18:07 [6,278ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::isaac::dynamic_control::DynamicControl (pluginName: nullptr)
At:
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.dynamic_control/omni/isaac/dynamic_control/scripts/extension.py(20): on_startup
2022-07-26 16:18:07 [6,278ms] [Error] [omni.ext.plugin] [ext: omni.isaac.dynamic_control-1.0.0] Failed to startup python extension.
2022-07-26 16:18:07 [6,315ms] [Error] [carb] [Plugin: libomni.physx.tensors.plugin.so] Could not load the dynamic library from /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.tensors-1.4.12-5.1/bin/libomni.physx.tensors.plugin.so. Error: libcuda.so.1: cannot open shared object file: No such file or directory
2022-07-26 16:18:07 [6,315ms] [Error] [omni.ext.plugin] [ext: omni.physx.tensors-0.1.0] failed to load native plugin: /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.tensors-1.4.12-5.1/bin/libomni.physx.tensors.plugin.so
2022-07-26 16:18:08 [6,491ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.core. Error: No module named ‘omni.isaac.dynamic_control’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/init.py”, line 9, in
from omni.isaac.core.physics_context.physics_context import PhysicsContext
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/physics_context/init.py”, line 9, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/physics_context/physics_context.py”, line 14, in
from omni.isaac.core.utils.prims import get_prim_at_path, get_prim_path, is_prim_path_valid
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core/omni/isaac/core/utils/prims.py”, line 20, in
from omni.isaac.dynamic_control import _dynamic_control
ModuleNotFoundError: No module named ‘omni.isaac.dynamic_control’
2022-07-26 16:18:08 [6,491ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.core’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core’ failed to load.
At:
2022-07-26 16:18:08 [6,491ms] [Error] [omni.ext.plugin] [ext: omni.isaac.core-1.15.1] Failed to startup python extension.
2022-07-26 16:18:09 [7,724ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.range_sensor. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.range_sensor/omni/isaac/range_sensor/init.py”, line 11, in
from .scripts.commands import *
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.range_sensor/omni/isaac/range_sensor/scripts/commands.py”, line 15, in
from omni.isaac.core.utils.stage import get_next_free_path
ModuleNotFoundError: No module named ‘omni.isaac.core’
2022-07-26 16:18:09 [7,724ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.range_sensor’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.range_sensor’ failed to load.
At:
2022-07-26 16:18:09 [7,724ms] [Error] [omni.ext.plugin] [ext: omni.isaac.range_sensor-0.4.2] Failed to startup python extension.
2022-07-26 16:18:09 [7,847ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.physxcommands. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.commands-1.4.12-5.1/omni/physxcommands/init.py”, line 6, in
from omni.physx.scripts import physicsUtils, utils, deformableUtils, particleUtils
ModuleNotFoundError: No module named ‘omni.physx’
2022-07-26 16:18:09 [7,847ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxcommands’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.commands-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [7,847ms] [Error] [omni.ext.plugin] [ext: omni.physx.commands-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::IPhysxVisualization v0.1] failed to be resolved.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::IPhysxAuthoring v0.3] failed to be resolved.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::IPhysxCooking v1.0] failed to be resolved.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::usdparser::IPhysxUsdLoad v0.2] failed to be resolved.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::IPhysxAttachment v0.1] failed to be resolved.
2022-07-26 16:18:09 [7,927ms] [Error] [carb] [Plugin: omni.physxui.plugin] Dependency: [omni::physx::IPhysxParticles v0.1] failed to be resolved.
2022-07-26 16:18:09 [7,935ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.physxui from /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.ui-1.4.12-5.1. Error: ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py”, line 151, in _custom_importer
return _import_public(ext_module.path, ext_module.name)
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/omni/ext/impl/_internal.py”, line 78, in _import_public
module = import_module(module_name)
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/plugins/bindings-python/carb/profiler/init.py”, line 78, in wrapper
r = f(*args, **kwds)
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.ui-1.4.12-5.1/omni/physxui/init.py”, line 8, in
from .scripts.extension import *
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.ui-1.4.12-5.1/omni/physxui/scripts/extension.py”, line 7, in
from omni.physx.bindings._physx import ErrorEvent
File “”, line 963, in _find_and_load_unlocked
File “”, line 906, in _find_spec
File “”, line 1280, in find_spec
File “”, line 1246, in _get_spec
File “”, line 1115, in iter
File “”, line 1103, in _recalculate
File “”, line 1099, in _get_parent_path
KeyError: ‘omni.physx’
2022-07-26 16:18:09 [7,935ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxui’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.ui-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [7,935ms] [Error] [omni.ext.plugin] [ext: omni.physx.ui-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:09 [7,985ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.tests. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.tests/omni/isaac/tests/init.py”, line 10, in
from .test_physics import *
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.tests/omni/isaac/tests/test_physics.py”, line 14, in
import omni.physx
2022-07-26 16:18:09 [7,986ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.tests’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.tests’ failed to load.
At:
2022-07-26 16:18:09 [7,986ms] [Error] [omni.ext.plugin] [ext: omni.isaac.tests-0.0.0] Failed to startup python extension.
2022-07-26 16:18:09 [8,059ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.kit.property.physx. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.kit.property.physx/omni/kit/property/physx/init.py”, line 4, in
from .utils import get_title_from_schema, rebuild_property_window, get_widget_name
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.kit.property.physx/omni/kit/property/physx/utils.py”, line 6, in
from omni.physx.scripts import utils
2022-07-26 16:18:09 [8,059ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.kit.property.physx’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.kit.property.physx’ failed to load.
At:
2022-07-26 16:18:09 [8,059ms] [Error] [omni.ext.plugin] [ext: omni.kit.property.physx-0.1.0] Failed to startup python extension.
2022-07-26 16:18:09 [8,115ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.physxdemos. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.demos-1.4.12-5.1/omni/physxdemos/init.py”, line 14, in
from omni.physx import get_physx_interface
2022-07-26 16:18:09 [8,115ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxdemos’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.demos-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [8,115ms] [Error] [omni.ext.plugin] [ext: omni.physx.demos-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:09 [8,162ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.physxtests from /home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.tests-1.4.12-5.1. Error: ‘omni.physxui’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.tests-1.4.12-5.1/omni/physxtests/init.py”, line 7, in
from omni.physxui.scripts.ui import WindowMenuItem
KeyError: ‘omni.physxui’
2022-07-26 16:18:09 [8,163ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxtests’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.tests-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [8,163ms] [Error] [omni.ext.plugin] [ext: omni.physx.tests-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:09 [8,234ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.physxcamera. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.camera-1.4.12-5.1/omni/physxcamera/init.py”, line 11, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.camera-1.4.12-5.1/omni/physxcamera/scripts/extension.py”, line 2, in
import omni.physx
2022-07-26 16:18:09 [8,234ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxcamera’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.camera-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [8,234ms] [Error] [omni.ext.plugin] [ext: omni.physx.camera-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:09 [8,301ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.physxcct. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.cct-1.4.12-5.1/omni/physxcct/init.py”, line 8, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.cct-1.4.12-5.1/omni/physxcct/scripts/extension.py”, line 2, in
from .physxCct import PhysXCct
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.cct-1.4.12-5.1/omni/physxcct/scripts/physxCct.py”, line 8, in
from . import utils, externals
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.cct-1.4.12-5.1/omni/physxcct/scripts/utils.py”, line 11, in
2022-07-26 16:18:09 [8,301ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxcct’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.cct-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [8,301ms] [Error] [omni.ext.plugin] [ext: omni.physx.cct-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:09 [8,354ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.physxvehicle. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.vehicle-1.4.12-5.1/omni/physxvehicle/init.py”, line 11, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.vehicle-1.4.12-5.1/omni/physxvehicle/scripts/extension.py”, line 2, in
import omni.physx
2022-07-26 16:18:09 [8,354ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxvehicle’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.vehicle-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:09 [8,354ms] [Error] [omni.ext.plugin] [ext: omni.physx.vehicle-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:10 [8,527ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
2022-07-26 16:18:10 [8,527ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation devices!
2022-07-26 16:18:10 [8,540ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.articulation_inspector. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.articulation_inspector/omni/isaac/articulation_inspector/init.py”, line 10, in
from .extension import *
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.articulation_inspector/omni/isaac/articulation_inspector/extension.py”, line 21, in
from omni.isaac.core.utils.stage import get_stage_units
2022-07-26 16:18:10 [8,540ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.articulation_inspector’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.articulation_inspector’ failed to load.
At:
2022-07-26 16:18:10 [8,540ms] [Error] [omni.ext.plugin] [ext: omni.isaac.articulation_inspector-0.1.2] Failed to startup python extension.
2022-07-26 16:18:10 [8,862ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.physics_inspector. Error: No module named ‘omni.isaac.dynamic_control’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.physics_inspector/omni/isaac/physics_inspector/init.py”, line 10, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.physics_inspector/omni/isaac/physics_inspector/extension.py”, line 13, in
from omni.isaac.dynamic_control import _dynamic_control as dc
2022-07-26 16:18:10 [8,862ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.physics_inspector’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.physics_inspector’ failed to load.
At:
2022-07-26 16:18:10 [8,862ms] [Error] [omni.ext.plugin] [ext: omni.isaac.physics_inspector-0.1.1] Failed to startup python extension.
2022-07-26 16:18:10 [8,980ms] [Error] [carb.scripting-python.plugin] AttributeError: ‘NoneType’ object has no attribute ‘get_ui_draw_event_stream’
At:
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.core-103.2.7+103.1.lx64.r.cp37/omni/paint/system/core/painter/brush_widget.py(51): init
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.core-103.2.7+103.1.lx64.r.cp37/omni/paint/system/core/painter/painter.py(71): init
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.core-103.2.7+103.1.lx64.r.cp37/omni/paint/system/core/painter/painter.py(98): get_instance
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.core-103.2.7+103.1.lx64.r.cp37/omni/paint/system/core/extension.py(39): on_startup
2022-07-26 16:18:10 [8,980ms] [Error] [omni.ext.plugin] [ext: omni.paint.system.core-103.2.7] Failed to startup python extension.
2022-07-26 16:18:10 [9,106ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.physxzerogravity. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.zerogravity-1.4.12-5.1/omni/physxzerogravity/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.zerogravity-1.4.12-5.1/omni/physxzerogravity/scripts/extension.py”, line 12, in
import omni.physx
2022-07-26 16:18:10 [9,106ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.physxzerogravity’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/kit/extsPhysics/omni.physx.zerogravity-1.4.12-5.1’ failed to load.
At:
2022-07-26 16:18:10 [9,106ms] [Error] [omni.ext.plugin] [ext: omni.physx.zerogravity-1.4.12-5.1] Failed to startup python extension.
2022-07-26 16:18:10 [9,166ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.paint.system.ui. Error: No module named ‘omni.paint.system.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.ui-103.4.6+103.1.cp37/omni/paint/system/ui/init.py”, line 1, in
from .extension import get_instance, PaintToolExtension
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.ui-103.4.6+103.1.cp37/omni/paint/system/ui/extension.py”, line 7, in
from .paint_tool import PaintToolWindow
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.ui-103.4.6+103.1.cp37/omni/paint/system/ui/paint_tool/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.ui-103.4.6+103.1.cp37/omni/paint/system/ui/paint_tool/paint_tool.py”, line 20, in
from omni.paint.system.core import PainterEventType, PAINT_MODES, PainterEventStream
ModuleNotFoundError: No module named ‘omni.paint.system.core’
2022-07-26 16:18:10 [9,166ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.paint.system.ui’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.system.ui-103.4.6+103.1.cp37’ failed to load.
At:
2022-07-26 16:18:10 [9,166ms] [Error] [omni.ext.plugin] [ext: omni.paint.system.ui-103.4.6] Failed to startup python extension.
2022-07-26 16:18:10 [9,294ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.paint.brush.scatter. Error: No module named ‘omni.paint.system.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.scatter-103.1.13+103.1.cp37/omni/paint/brush/scatter/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.scatter-103.1.13+103.1.cp37/omni/paint/brush/scatter/extension.py”, line 3, in
from omni.paint.system.core import register_brush, unregister_brush
2022-07-26 16:18:10 [9,294ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.paint.brush.scatter’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.scatter-103.1.13+103.1.cp37’ failed to load.
At:
2022-07-26 16:18:10 [9,294ms] [Error] [omni.ext.plugin] [ext: omni.paint.brush.scatter-103.1.13] Failed to startup python extension.
2022-07-26 16:18:11 [9,402ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.paint.brush.scripting. Error: No module named ‘omni.paint.system.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.scripting-103.6.6+103.1.cp37/omni/paint/brush/scripting/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.scripting-103.6.6+103.1.cp37/omni/paint/brush/scripting/extension.py”, line 13, in
2022-07-26 16:18:11 [9,402ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.paint.brush.scripting’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.scripting-103.6.6+103.1.cp37’ failed to load.
At:
2022-07-26 16:18:11 [9,402ms] [Error] [omni.ext.plugin] [ext: omni.paint.brush.scripting-103.6.6] Failed to startup python extension.
2022-07-26 16:18:11 [9,447ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.paint.brush.modify. Error: No module named ‘omni.paint.system.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.modify-103.1.6+103.1.cp37/omni/paint/brush/modify/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.modify-103.1.6+103.1.cp37/omni/paint/brush/modify/extension.py”, line 14, in
2022-07-26 16:18:11 [9,447ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.paint.brush.modify’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.modify-103.1.6+103.1.cp37’ failed to load.
At:
2022-07-26 16:18:11 [9,447ms] [Error] [omni.ext.plugin] [ext: omni.paint.brush.modify-103.1.6] Failed to startup python extension.
2022-07-26 16:18:11 [9,490ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.paint.brush.attribute. Error: No module named ‘omni.paint.system.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.attribute-103.3.3+103.1.cp37/omni/paint/brush/attribute/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.attribute-103.3.3+103.1.cp37/omni/paint/brush/attribute/extension.py”, line 13, in
2022-07-26 16:18:11 [9,490ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.paint.brush.attribute’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.attribute-103.3.3+103.1.cp37’ failed to load.
At:
2022-07-26 16:18:11 [9,490ms] [Error] [omni.ext.plugin] [ext: omni.paint.brush.attribute-103.3.3] Failed to startup python extension.
2022-07-26 16:18:11 [9,532ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.paint.brush.select. Error: No module named ‘omni.paint.system.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.select-103.1.2+103.1.cp37/omni/paint/brush/select/init.py”, line 1, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.select-103.1.2+103.1.cp37/omni/paint/brush/select/extension.py”, line 14, in
2022-07-26 16:18:11 [9,533ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.paint.brush.select’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.paint.brush.select-103.1.2+103.1.cp37’ failed to load.
At:
2022-07-26 16:18:11 [9,533ms] [Error] [omni.ext.plugin] [ext: omni.paint.brush.select-103.1.2] Failed to startup python extension.
2022-07-26 16:18:16 [14,419ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:16 [14,419ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysxSceneQuery v1.0] failed to be resolved.
2022-07-26 16:18:16 [14,419ms] [Error] [carb] [Plugin: omni.isaac.motion_planning.plugin] Dependency: [omni::isaac::dynamic_control::DynamicControl v0.1] failed to be resolved.
2022-07-26 16:18:16 [14,419ms] [Error] [carb] [Plugin: omni.isaac.motion_planning.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:16 [14,420ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:16 [14,420ms] [Error] [carb] [Plugin: omni.isaac.dynamic_control.plugin] Dependency: [omni::physx::IPhysxSceneQuery v1.0] failed to be resolved.
2022-07-26 16:18:16 [14,420ms] [Error] [carb] [Plugin: omni.isaac.motion_planning.plugin] Dependency: [omni::isaac::dynamic_control::DynamicControl v0.1] failed to be resolved.
2022-07-26 16:18:16 [14,420ms] [Error] [carb] [Plugin: omni.isaac.motion_planning.plugin] Dependency: [omni::physx::IPhysx v1.0] failed to be resolved.
2022-07-26 16:18:16 [14,420ms] [Error] [carb.scripting-python.plugin] RuntimeError: Failed to acquire interface: omni::isaac::motion_planning::MotionPlanning (pluginName: nullptr)
At:
/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.motion_planning/omni/isaac/motion_planning/scripts/extension.py(16): on_startup
2022-07-26 16:18:16 [14,420ms] [Error] [omni.ext.plugin] [ext: omni.isaac.motion_planning-0.2.0] Failed to startup python extension.
2022-07-26 16:18:16 [14,848ms] [Error] [omni.graph.core._impl.register_ogn_nodes] Failed to import Python OmniGraph node OgnOnTime.py - No module named ‘omni.physx’
2022-07-26 16:18:16 [15,010ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.surface_gripper. Error: No module named ‘omni.isaac.dynamic_control’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.surface_gripper/omni/isaac/surface_gripper/init.py”, line 12, in
from .scripts import *
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.surface_gripper/omni/isaac/surface_gripper/scripts/init.py”, line 10, in
from .surface_gripper import SurfaceGripper
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.surface_gripper/omni/isaac/surface_gripper/scripts/surface_gripper.py”, line 10, in
2022-07-26 16:18:16 [15,010ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.surface_gripper’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.surface_gripper’ failed to load.
At:
2022-07-26 16:18:16 [15,010ms] [Error] [omni.ext.plugin] [ext: omni.isaac.surface_gripper-0.1.2] Failed to startup python extension.
2022-07-26 16:18:16 [15,068ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.motion_generation. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/init.py”, line 10, in
from omni.isaac.motion_generation.articulation_motion_policy import ArticulationMotionPolicy
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/articulation_motion_policy.py”, line 11, in
from .motion_policy_interface import MotionPolicy
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/motion_policy_interface.py”, line 10, in
from omni.isaac.motion_generation.world_interface import WorldInterface
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.motion_generation/omni/isaac/motion_generation/world_interface.py”, line 11, in
import omni.isaac.core.objects
2022-07-26 16:18:16 [15,068ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.motion_generation’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.motion_generation’ failed to load.
At:
2022-07-26 16:18:16 [15,068ms] [Error] [omni.ext.plugin] [ext: omni.isaac.motion_generation-3.1.2] Failed to startup python extension.
2022-07-26 16:18:16 [15,138ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.utils. Error: No module named ‘omni.isaac.dynamic_control’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.utils/omni/isaac/utils/init.py”, line 11, in
from .scripts.commands import * # populates commands list
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.utils/omni/isaac/utils/scripts/commands.py”, line 14, in
2022-07-26 16:18:16 [15,138ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.utils’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.utils’ failed to load.
At:
2022-07-26 16:18:16 [15,138ms] [Error] [omni.ext.plugin] [ext: omni.isaac.utils-0.1.11] Failed to startup python extension.
2022-07-26 16:18:16 [15,199ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.core_nodes. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core_nodes/omni/isaac/core_nodes/init.py”, line 1, in
from .impl import Extension
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core_nodes/omni/isaac/core_nodes/impl/init.py”, line 7, in
from .extension import Extension
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core_nodes/omni/isaac/core_nodes/impl/extension.py”, line 15, in
from omni.isaac.core.utils.stage import get_current_stage
2022-07-26 16:18:16 [15,199ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.core_nodes’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.core_nodes’ failed to load.
At:
2022-07-26 16:18:16 [15,199ms] [Error] [omni.ext.plugin] [ext: omni.isaac.core_nodes-0.9.0] Failed to startup python extension.
2022-07-26 16:18:16 [15,266ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.isaac_sensor. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.isaac_sensor/omni/isaac/isaac_sensor/init.py”, line 11, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.isaac_sensor/omni/isaac/isaac_sensor/scripts/commands.py”, line 13, in
2022-07-26 16:18:16 [15,266ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.isaac_sensor’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.isaac_sensor’ failed to load.
At:
2022-07-26 16:18:16 [15,266ms] [Error] [omni.ext.plugin] [ext: omni.isaac.isaac_sensor-0.3.4] Failed to startup python extension.
2022-07-26 16:18:16 [15,320ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.universal_robots. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/init.py”, line 9, in
from omni.isaac.universal_robots.ur10 import UR10
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.universal_robots/omni/isaac/universal_robots/ur10.py”, line 11, in
from omni.isaac.core.robots.robot import Robot
2022-07-26 16:18:16 [15,320ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.universal_robots’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.universal_robots’ failed to load.
At:
2022-07-26 16:18:16 [15,320ms] [Error] [omni.ext.plugin] [ext: omni.isaac.universal_robots-0.2.1] Failed to startup python extension.
2022-07-26 16:18:17 [15,422ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.synthetic_utils. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/init.py”, line 12, in
from .writers import *
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/writers/init.py”, line 13, in
from .ycb_video import YCBVideoWriter
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/writers/ycb_video.py”, line 18, in
2022-07-26 16:18:17 [15,422ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.synthetic_utils’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.synthetic_utils’ failed to load.
At:
2022-07-26 16:18:17 [15,422ms] [Error] [omni.ext.plugin] [ext: omni.isaac.synthetic_utils-0.2.1] Failed to startup python extension.
2022-07-26 16:18:17 [15,479ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.demos.franka_leonardo. Error: No module named ‘omni.isaac.motion_planning’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.demos/omni/isaac/demos/franka_leonardo.py”, line 19, in
from omni.isaac.motion_planning import _motion_planning
ModuleNotFoundError: No module named ‘omni.isaac.motion_planning’
2022-07-26 16:18:17 [15,479ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.demos.franka_leonardo’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.demos’ failed to load.
At:
2022-07-26 16:18:17 [15,479ms] [Error] [omni.ext.plugin] [ext: omni.isaac.demos-0.1.3] Failed to startup python extension.
2022-07-26 16:18:17 [15,561ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.dofbot. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.dofbot/omni/isaac/dofbot/init.py”, line 9, in
from omni.isaac.dofbot.dofbot import DofBot
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.dofbot/omni/isaac/dofbot/dofbot.py”, line 11, in
2022-07-26 16:18:17 [15,561ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.dofbot’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.dofbot’ failed to load.
At:
2022-07-26 16:18:17 [15,561ms] [Error] [omni.ext.plugin] [ext: omni.isaac.dofbot-0.2.0] Failed to startup python extension.
2022-07-26 16:18:17 [15,614ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.quadruped. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.quadruped/omni/isaac/quadruped/init.py”, line 9, in
from omni.isaac.quadruped.quadruped import Quadruped
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.quadruped/omni/isaac/quadruped/quadruped.py”, line 10, in
2022-07-26 16:18:17 [15,614ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.quadruped’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.quadruped’ failed to load.
At:
2022-07-26 16:18:17 [15,614ms] [Error] [omni.ext.plugin] [ext: omni.isaac.quadruped-1.1.2] Failed to startup python extension.
2022-07-26 16:18:17 [15,667ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.franka. Error: No module named ‘omni.isaac.core’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.franka/omni/isaac/franka/init.py”, line 9, in
from omni.isaac.franka.franka import Franka
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.franka/omni/isaac/franka/franka.py”, line 11, in
2022-07-26 16:18:17 [15,667ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.franka’ in ‘/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.franka’ failed to load.
At:
2022-07-26 16:18:17 [15,667ms] [Error] [omni.ext.plugin] [ext: omni.isaac.franka-0.0.0] Failed to startup python extension.
2022-07-26 16:18:17 [15,735ms] [Error] [omni.graph.core._impl.register_ogn_nodes] Failed to import Python OmniGraph node OgnHolonomicController.py - No module named ‘omni.isaac.core’
2022-07-26 16:18:17 [15,737ms] [Error] [omni.graph.core._impl.register_ogn_nodes] Failed to import Python OmniGraph node OgnDifferentialController.py - No module named ‘omni.isaac.core’
2022-07-26 16:18:17 [15,739ms] [Error] [omni.graph.core._impl.register_ogn_nodes] Failed to import Python OmniGraph node OgnHolonomicRobotUsdSetup.py - No module named ‘omni.isaac.core’
2022-07-26 16:18:17 [15,761ms] [Error] [omni.ext.impl.custom_importer] Failed to import python module omni.isaac.physics_utilities. Error: No module named ‘omni.physx’. Traceback:
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.physics_utilities/omni/isaac/physics_utilities/init.py”, line 10, in
File “/home/dongchan/.local/share/ov/pkg/isaac_sim-2022.1.0/exts/omni.isaac.physics_utilities/omni/isaac/physics_utilities/extension.py”, line 19, in
