Isaac Sim 2023.1.0 fails to import omni.isaac.core when running as GUI (isaac-sim.bat)
I have unistalled and reinstalled isaac sim 2023.1.0 several times and each time I want to run isaac-sim as GUI, I am facings issues which prevent me to access practically all the extension examples.
Kindly refer to the following:
Loading user config located at: ‘C:/Users/sergi/AppData/Local/ov/data/Kit/Isaac-Sim/2023.1/user.config.json’
[Info] [carb] Logging to file: C:/Users/sergi/.nvidia-omniverse/logs/Kit/Isaac-Sim/2023.1/kit_20231027_115643.log
2023-10-27 03:56:43 [27ms] [Warning] [omni.ext.plugin] [ext: omni.kit.converter.cad-200.0.0-rc.4+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [27ms] [Warning] [omni.ext.plugin] [ext: omni.kit.converter.cad_core-200.0.0-rc.3+105.0.wx64.r.cp310] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [30ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.usd-103.4.2+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [30ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.core-103.4.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [31ms] [Warning] [omni.ext.plugin] [ext: omni.kit.widget.timeline-105.0.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [32ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.modifier.titlebar-105.1.10+105.wx64.cp310] Built using kit version: 105. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [33ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.sequencer-103.4.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [34ms] [Warning] [omni.ext.plugin] [ext: omni.paint.brush.attributes-1.3.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2023-10-27 03:56:43 [37ms] [Warning] [omni.ext.plugin] [ext: omni.usd.schema.sequence-2.3.0+105.0.wx64.r.cp310] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
[0.330s] [ext: omni.kit.async_engine-0.0.0] startup
[0.877s] [ext: omni.assets.plugins-0.0.0] startup
[0.884s] [ext: omni.activity.core-1.0.1] startup
[0.891s] [ext: omni.taskagent-0.0.0] startup
[0.893s] [ext: omni.datastore-0.0.0] startup
[0.896s] [ext: omni.client-1.0.1] startup
[0.911s] [ext: omni.ujitso-0.0.0] startup
[0.915s] [ext: omni.stats-0.0.0] startup
[0.919s] [ext: omni.activity.profiler-1.0.2] startup
[0.928s] [ext: omni.gpu_foundation-0.0.0] startup
[0.969s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.973s] [ext: omni.rtx.shadercache.d3d12-1.0.0] startup
[0.977s] [ext: carb.windowing.plugins-1.0.0] startup
[1.153s] [ext: omni.kit.renderer.init-0.0.0] startup
[1.615s] [ext: omni.kit.pipapi-0.0.0] startup
[1.618s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.619s] [ext: omni.pip.compute-1.2.0] startup
[1.621s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[1.768s] [ext: omni.pip.cloud-1.0.1] startup
[1.787s] [ext: omni.isaac.core_archive-2.2.1] startup
[1.789s] [ext: omni.mtlx-0.1.0] startup
[1.791s] [ext: omni.usd.config-1.0.3] startup
[1.808s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.813s] [ext: omni.usd.libs-1.0.0] startup
2023-10-27 03:56:44 [1,740ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) UHD Graphics
2023-10-27 03:56:44 [1,743ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) UHD Graphics
[1.984s] [ext: omni.kit.loop-default-0.2.0] startup
[1.986s] [ext: omni.kit.test-0.0.0] startup
[1.989s] [ext: omni.isaac.ml_archive-1.1.3] startup
[1.991s] [ext: omni.kit.telemetry-0.4.0] startup
[2.008s] [ext: omni.usd.schema.semantics-0.0.0] startup
| Driver Version: 528.49 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4080 Laptop… | Yes: 0 | | 12011 MB | 10de | f7650100… |
| | | | | | 27a0 | 0 |
| | | | | | 1 | |
| 1 | Intel(R) UHD Graphics | | | 128 MB | 8086 | 05610100… |
| | | | | | a788 | 0 |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (22H2), Build: 22621, Kernel: 10.0.22621.2428
| Processor: 13th Gen Intel(R) Core™ i9-13950HX | Cores: 24 | Logical: 32
| Total Memory (MB): 65234 | Free Memory: 49645
| Total Page/Swap (MB): 69330 | Free Page/Swap: 50046
[7.824s] [ext: omni.isaac.core-2.10.2] startup
2023-10-27 03:56:50 [7,768ms] [Error] [omni.ext._impl._internal] Failed to import python module omni.isaac.core from c:\users\sergi\appdata\local\ov\pkg\isaac_sim-2023.1.0\exts\omni.isaac.core. Error: [WinError 127] The specified procedure could not be found. Error loading “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.pip.torch-2_0_1-2.0.2+105.1.wx64/torch-2-0-1/torch\lib\cublas64_11.dll” or one of its dependencies… Traceback:
File “c:\users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py\omni\ext_impl_internal.py”, line 187, in custom_importer
return import_public(ext_module.path, ext_module.name, reload_enabled)
File "c:\users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py\carb\profiler_init
.py", line 83, in wrapper
r = f(*args, **kwds)
File “c:\users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py\omni\ext_impl_internal.py”, line 94, in import_public
module = import_module(module_name)
File “c:\users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py\omni\ext_impl\custom_importer.py”, line 76, in import_module
return importlib.import_module(name)
File "c:\users\sergi\appdata\local\ov\pkg\isaac_sim-2023.1.0\kit\python\lib\importlib_init
.py", line 126, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1050, in _gcd_import
File “”, line 1027, in _find_and_load
File “”, line 1006, in _find_and_load_unlocked
File “”, line 688, in _load_unlocked
File “”, line 883, in exec_module
File “”, line 241, in _call_with_frames_removed
File “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.core/omni/isaac/core/init.py”, line 11, in
from omni.isaac.core.physics_context.physics_context import PhysicsContext
File “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.core/omni/isaac/core/physics_context/init.py”, line 9, in
File “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.core/omni/isaac/core/physics_context/physics_context.py”, line 15, in
from omni.isaac.core.utils.prims import get_prim_at_path, get_prim_path, is_prim_path_valid
File “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.core/omni/isaac/core/utils/prims.py”, line 24, in
from omni.isaac.core.utils.types import SDF_type_to_Gf
File “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/exts/omni.isaac.core/omni/isaac/core/utils/types.py”, line 12, in
import torch
File “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.pip.torch-2_0_1-2.0.2+105.1.wx64/torch-2-0-1/torch/init.py”, line 122, in
raise err
OSError: [WinError 127] The specified procedure could not be found. Error loading “c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.pip.torch-2_0_1-2.0.2+105.1.wx64/torch-2-0-1/torch\lib\cublas64_11.dll” or one of its dependencies.
2023-10-27 03:56:51 [7,822ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: ‘omni.isaac.core’ in ‘c:\users\sergi\appdata\local\ov\pkg\isaac_sim-2023.1.0\exts\omni.isaac.core’ failed to load.
At:
c:\users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py\omni\ext_impl_internal.py(213): startup
c:\users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/kit/kernel/py\omni\ext_impl_internal.py(328): startup_extension
PythonExtension.cpp::startup()(2):
2023-10-27 03:56:51 [7,831ms] [Error] [omni.ext.plugin] [ext: omni.isaac.core-2.10.2] Failed to startup python extension.
Contrary to running standalone examples through python.bat, that is actually doable.
Could you please give any hint what is happening?
Kind Regards,
I attach the full log:
kit_20231101_091736.log (1.9 MB)
I can execute standalone examples so I just don’t know what is wrong when I try running as GUI.
I am looking forward for your reply.
@sochongl looking at the log, a few lines caught my attention:
2023-11-01 01:18:16 [40,278ms] [Info] [ogn_registration] Finding OmniGraph extension content manager for omni.isaac.ros2_bridge-2.3.8 in module omni.isaac.ros2_bridge.tests at c:\users\sergi\appdata\local\ov\pkg\isaac_sim-2023.1.0\exts\omni.isaac.ros2_bridge
2023-11-01 01:18:16 [40,284ms] [Info] [ogn_registration] OGN register omni.isaac.ros2_bridge-2.3.8 took 232365700.000000
2023-11-01 01:18:16 [40,284ms] [Error] [omni.ext.python] OSError: [WinError 127] The specified procedure could not be found. Error loading "c:/users/sergi/appdata/local/ov/pkg/isaac_sim-2023.1.0/extscache/omni.pip.torch-2_0_1-2.0.2+105.1.wx64/torch-2-0-1/torch\lib\cublas64_11.dll" or one of its dependencies.
do you have ros2 bridge extension enabled by chance? if so, i would encourage you to refer to this pinned thread by the dev -
Hi, it turned out that there was an issue with XR Experience extension, which I was using, I just disabled it and then reloaded Isaac Sim from isaac-sim.bat (as administrator) and then everything was fine.
Besides, with the hotfix recently provided, such problem has not been showing up so far.
Indeed, I followed the steps to install ros humble on windows, but that was not affecting the startup process.
Thank you for your suggestion though.
