Failed to load Isaac Sim
Hi All,
I have problems starting up Isaac Sim. It did start before on Ubuntu 22.04. But after some restarts now it does not want to load.
I started Isaac Sim with the launcher and added the extra args -v -vv. It gets stuck on following line:
[4.163s] [ext: omni.kit.window.material_graph-1.5.0] startup
2022-11-25 08:01:06 [4,127ms] [Verbose] [omni.ext.plugin] IFileSystem::subscribeToChangeEvents: '/home/robertoapruzzese/.local/share/ov/pkg/isaac_sim-2022.1.1/kit/exts/omni.kit.numpy.common/omni/kit/numpy'
2022-11-25 08:01:06 [4,127ms] [Verbose] [omni.ext.plugin] IFileSystem::subscribeToChangeEvents: '/home/robertoapruzzese/.local/share/ov/pkg/isaac_sim-2022.1.1/kit/exts/omni.kit.numpy.common/omni/kit/numpy/common'
2022-11-25 08:01:06 [4,133ms] [Info] [omni.ext.impl._internal] Searching for classes derived from 'omni.ext.IExt' in 'omni.kit.window.material_graph' ('/home/robertoapruzzese/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.kit.window.material_graph-1.5.0+cp37')
2022-11-25 08:01:06 [4,133ms] [Info] [omni.ext.impl._internal] Found class `GraphExtension` derived from `omni.ext.IExt` in module: 'omni.kit.window.material_graph' in '/home/robertoapruzzese/.local/share/ov/pkg/isaac_sim-2022.1.1/exts/omni.kit.window.material_graph-1.5.0+cp37'. Calling `on_startup`.
2022-11-25 08:01:09 [6,951ms] [Verbose] [carb.audio.notify] onDeviceRemoved '{0.0.1.00000000}.{26a2e0a1-0d68-43a0-e3e8-cab79f33feee}'
2022-11-25 08:01:09 [6,951ms] [Verbose] [carb.audio.context] 1 -> 2
2022-11-25 08:01:09 [6,951ms] [Verbose] [carb.audio.context] 2 -> 1
2022-11-25 08:01:11 [8,769ms] [Verbose] [carb.audio.notify] onDeviceAdded '{0.0.1.00000000}.{26a2e0a1-0d68-43a0-e3e8-cab79f33feee}'
2022-11-25 08:01:11 [8,769ms] [Verbose] [carb.audio.context] 1 -> 2
2022-11-25 08:01:11 [8,769ms] [Verbose] [carb.audio.context] 2 -> 1
Thanks for the help!
I solved the issue by unloading an extensions that I loaded in.
