Hello! I’ve been following the tutorial for building C++ extensions in Isaac Sim, using the Kit extension template c++. I managed to build and run the examples on Ubuntu 22.04 with the command:
./_build/linux-x86_64/release/omni.app.example.extension_browser.sh
However, I encountered an issue when sourcing the extensions to the /home/user/Documents/Kit/shared
folder. Although I was able to load the extension into Isaac Sim 2022.2.1, the following error occurred on extension startup:
[256.951s] [ext: omni.example.cpp.hello_world-1.0.0] startup
2023-08-15 10:45:24 [256,930ms] [Error] [carb] [Plugin: libomni.example.cpp.hello_world.plugin.so] Incompatible Framework API minor version: 0
2023-08-15 10:45:24 [256,931ms] [Warning] [carb] Potential plugin preload failed: /home/nikola/kit-extension-template-cpp/_build/linux-x86_64/release/exts/omni.example.cpp.hello_world/bin/libomni.example.cpp.hello_world.plugin.so
2023-08-15 10:45:24 [256,931ms] [Error] [omni.ext.plugin] [ext: omni.example.cpp.hello_world-1.0.0] failed to load native plugin: /home/nikola/kit-extension-template-cpp/_build/linux-x86_64/release/exts/omni.example.cpp.hello_world/bin/libomni.example.cpp.hello_world.plugin.so
Has anyone encountered this issue or have any insights on how to fix it? Thanks!
