omni.app.mini.sh has ended with error (55): b'Loading user Test Kitconfig located at: /home/d/.local/share/ov/data/Kit/omni.app.mini/0.1/user.config.json\n[lnfo] [carb] Logging to file: /home/d/.nvidia-omniverse/logs/Kit/omni.app.mini/0.1/kit_20240702_144721.log\n[0.054s] Failed to solve s0me dependencies locally, syncing with extension registry..In[0.055s]
[ext: omni.kit.async_engine-0.0.0] startup\n[0.057s] [ext: omni.client-1.1.0] startup\n[0.074s] [ext: omni.kit.registry.nucleus-0.0.0] startup\n"
In principle it should not be a problem to run Isaac Sim.
This warning indicates that some Omniverse extensions to run the script are not found locally and therefore it will sync with the Omniverse public registry to download them.
Hi @toni.nv
I recently ran into this error, and although Isaac sim will run, Isaac Lab will not. So this is an issue that I am trying to fix. do you know how to get them locally or how to solve this issue?
I ran the compatibility checker, it worked including the test kit, but then when installing isaac sim I got an error, so I tried to do a fresh install by deleting folders relating to isaac sim, and now when I run isaac lab and the test kit button on the compatibility checker, I get the same error. do you know how to fix it?
