when trying to install Isaac Sim 2022.1.1 from the Omniverse Launcher the following error occurs:
Error occurred during installation of Isaac Sim: Command failed: “/home/panda/.local/share/ov/pkg/isaac_sim-2022.1.1/omni.isaac.sim.post.install.sh”
UsdE57FileFormat
OmniAssetFileFormat
2022-09-28 16:58:38 [3,628ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2022-09-28 16:58:44 [9,550ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file ‘/home/panda/.local/share/ov/data/Kit/Isaac-Sim/2022.1/4339450a-f556-41f2-c0726094-889902f5.dmp’
2022-09-28 16:58:44 [9,550ms] [Error] [carb.crashreporter-breakpad.plugin] dump file size is -1 bytes, file is not readable.
2022-09-28 16:58:44 [9,551ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 3375 thread 3375
2022-09-28 16:58:44 [9,551ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 3375 backtrace follows:
2022-09-28 16:58:44 [9,580ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libcarb.events.plugin.so!std::basic_string, std::allocator >::~basic_string()+0xde4 (??:?)
2022-09-28 16:58:44 [9,599ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libcarb.assets.plugin.so!std::basic_string, std::allocator >::basic_string(std::string const&, unsigned long, unsigned long)+0x8e54 (??:?)
2022-09-28 16:58:44 [9,617ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libcarb.datasource-file.plugin.so!std::basic_string, std::allocator >::~basic_string()+0x424 (??:?)
2022-09-28 16:58:44 [9,636ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libgpu.foundation.plugin.so!std::fill(std::_Bit_iterator, std::_Bit_iterator, bool const&)+0x374 (??:?)
2022-09-28 16:58:44 [9,654ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libcarb.datasource-omniclient.plugin.so!std::_V2::condition_variable_any::~condition_variable_any()+0x1044 (??:?)
2022-09-28 16:58:44 [9,671ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libomni.kit.renderer.plugin.so!std::__future_base::_Result::_M_destroy()+0x3674 (??:?)
2022-09-28 16:58:44 [9,688ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: librtx.materialdb.plugin.so!std::mutex::lock()+0x224 (??:?)
2022-09-28 16:58:44 [9,711ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
/home/panda/.local/share/ov/pkg/isaac_sim-2022.1.1/omni.isaac.sim.post.install.sh: Zeile 17: 3375 Speicherzugriffsfehler (Speicherabzug geschrieben) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
Regarding installed drivers and hardware:
nvidia-smi -L
GPU 0: NVIDIA GeForce RTX 3090 (UUID: GPU-b5efba7d-6f46-2d7c-4cf3-679f77247a4f)
nvidia-smi
| NVIDIA-SMI 470.141.03 Driver Version: 470.141.03 CUDA Version: 11.4 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 On | N/A |
| 0% 52C P8 45W / 350W | 247MiB / 24259MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1104 G /usr/lib/xorg/Xorg 35MiB |
| 0 N/A N/A 1612 G /usr/lib/xorg/Xorg 107MiB |
| 0 N/A N/A 1741 G /usr/bin/gnome-shell 87MiB |
The installation of create succeeded.
I cleared the .cache/ov/Kit folder and tried again without success.
I appreciate any ideas on where the remaining problem lies. Best, Josh
