Error occurred during installation of Isaac Sim: Command failed: "/home/dhruvm/.local/share/ov/pkg/isaac_sim-2022.1.0/omni.isaac.sim.post.install.sh"
Hello, I’m getting the following error while installing ISAAC SIm. I’m installing it via the omniverse launcher in my local pc
Error occurred during installation of Isaac Sim: Command failed: “/home/dhruvm/.local/share/ov/pkg/isaac_sim-2022.1.0/omni.isaac.sim.post.install.sh”
X Error of failed request: GLXBadFBConfig
Major opcode of failed request: 152 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 194
Current serial number in output stream: 194
2022-06-18 03:05:50 [2,209ms] [Error] [omni.core.ITypeFactory] ITypeFactory must not be destructed post-main. plugins will not be unloaded.
/home/dhruvm/.local/share/ov/pkg/isaac_sim-2022.1.0/omni.isaac.sim.post.install.sh: line 17: 4860 Segmentation fault (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
This is my nvidia-smi output
Fri Jun 17 23:04:20 2022
| NVIDIA-SMI 510.73.05 Driver Version: 510.73.05 CUDA Version: 11.6 |
| | | MIG M. |
| 0 NVIDIA GeForce … Off | 00000000:01:00.0 Off | N/A |
| N/A 53C P0 N/A / N/A | 9MiB / 4096MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1052 G /usr/lib/xorg/Xorg 4MiB |
| 0 N/A N/A 1805 G /usr/lib/xorg/Xorg 4MiB |
It seems you don’t have a GPU!
I have an NVIDIA Geforce RTX 3050 Ti
Also, I have a dual boot system. In windows, ISAAC Sim works fine but it does not in Ubuntu (20.04)
I had the same problem when I tried to install the ISAAC SIM on a server through chrome remote desktop.
I solved the problem by reinstalling the GPU driver on the server and installing ISAAC locally.
Did you try to change your driver version to the recommended on in the doc?
@dhruvm1 fully exit from the launcher (close it in the taskbar)
then set this environment variable in a new terminal window
export MESA_GL_VERSION_OVERRIDE=4.6
and start the launcher in that same terminal, try installing again, does the same error occur?
Yes, still the same error occurs.
What is the output of
glxinfo | grep "OpenGL version"
After using the export command it says this:
OpenGL version string: 4.6 (Compatibility Profile) Mesa 21.2.6
You’re trying to install 2022.1.0. That one is still beta version. I have same problem too. Probably still not compatible with all gpus.
I recommend you to install other versions of Isaac Sim.
Hi, please share the output of nvidia-smi. It looks like you have 4GB or VRAM. We recommend a minimum of 8GB of VRAM to have a good experience.
Were you able to run Isaac Sim, Create and Code on Windows and load Isaac Sim assets on them successfully on Windows?
