Hi @sheikh-nv
I have tried to launch Isaac SIM via this command
/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/isaac-sim.sh --/renderer/activeGpu=1
but it shows
2022-01-20 09:54:30 [1,025ms] [Error] [gpu.foundation.plugin] The chosen activeGpu index is higher than the available GPUs. An unsupported driver might also prevent it from enumerating your devices properly.
and
2022-01-20 09:54:30 [1,039ms] [Warning] [omni.gpu_foundation_factory.plugin] RT-capable GPU not found, switching to compatibility mode
2022-01-20 09:54:30 [1,039ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create GPU foundation!
2022-01-20 09:54:30 [1,039ms] [Error] [omni.kit.renderer.plugin] GPU Foundation is not initialized!
2022-01-20 09:54:30 [1,039ms] [Error] [omni.kit.imgui_renderer.plugin] Invalid device attached to the default window!
I don’t get it, it’s very obvious that I have 5 GPUs (index 0 ~ 4) according to nvidia-smi
here is the complete error log
[Info] [carb] Logging to file: /home/ryan_lin/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.2/kit_20220120_175429.log
[0.230s] [ext: omni.kit.pipapi-0.0.0] startup
[0.238s] [ext: omni.usd.config-1.0.0] startup
[0.239s] [ext: omni.usd.libs-1.0.0] startup
[0.528s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.535s] [ext: omni.stats-0.0.0] startup
[0.537s] [ext: omni.gpu_foundation-0.0.0] startup
[0.552s] [ext: omni.isaac.pip_archive-0.1.0] startup
[0.689s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.695s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.700s] [ext: omni.hydra.iray-0.1.0] startup
[0.707s] [ext: omni.assets.plugins-0.0.0] startup
[0.711s] [ext: omni.kit.async_engine-0.0.0] startup
[0.719s] [ext: omni.kit.loop-default-0.1.0] startup
[0.720s] [ext: omni.client-0.1.0] startup
[0.744s] [ext: omni.appwindow-1.0.0] startup
[0.758s] [ext: omni.kit.test-0.0.0] startup
[0.871s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 470.57 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA DGX Display | | | 4342 MB | 10de | 0 |
| | | | | | 1fb0 | 1fefbb2d.. |
| OS: Linux dgx-govtech-a100, Version: 5.4.0-81-generic
| Processor: AMD EPYC 7742 64-Core Processor | Cores: Unknown | Logical: 128
| Total Memory (MB): 515835 | Free Memory: 501896
| Total Page/Swap (MB): 0 | Free Page/Swap: 0
2022-01-20 09:54:30 [1,025ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
- The driver is not installed properly and requires a clean re-install.
- Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
- The driver cannot enumerate any GPU: driver, display or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
- For Ubuntu, it requires server-xorg-core 1.20.7+ and a display to work without --no-window.
- For Linux dockers, the setup is not complete. Install the latest driver, xServer and NVIDIA container runtime.
2022-01-20 09:54:30 [1,039ms] [Error] [gpu.foundation.plugin] The chosen activeGpu index is higher than the available GPUs. An unsupported driver might also prevent it from enumerating your devices properly.
| | | | | | Device-ID | UUID |
| | | | | | 1fb0 | 1fefbb2d.. |
| Total Memory (MB): 515835 | Free Memory: 501895
2022-01-20 09:54:30 [1,039ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
[1.077s] [ext: omni.ui-2.5.3] startup
[1.104s] [ext: omni.kit.mainwindow-0.0.0] startup
[1.108s] [ext: omni.kit.uiapp-0.0.0] startup
[1.109s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.119s] [ext: omni.usd.schema.isaac-0.1.1] startup
[1.154s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.187s] [ext: omni.timeline-1.0.2] startup
[1.191s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.208s] [ext: carb.audio-0.1.0] startup
[1.218s] [ext: omni.kit.commands-0.0.0] startup
[1.224s] [ext: omni.usd-1.4.5] startup
[1.253s] [ext: omni.kit.asset_converter-1.1.43] startup
[1.279s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.307s] [ext: omni.services.facilities.base-1.0.0] startup
[1.310s] [ext: omni.services.core-1.1.1] startup
[1.436s] [ext: omni.services.transport.client.base-1.1.0] startup
[1.439s] [ext: omni.services.transport.server.base-1.0.0] startup
[1.442s] [ext: omni.services.client-0.2.3] startup
[1.469s] [ext: omni.kit.agent-0.1.0] startup
[1.472s] [ext: omni.services.transport.server.http-1.0.0] startup
[1.556s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[1.742s] [ext: omni.kit.thumbnails.images-0.1.0] startup
[1.748s] [ext: omni.kit.widget.path_field-2.0.3] startup
[1.753s] [ext: omni.kit.window.popup_dialog-2.0.4] startup
[1.759s] [ext: omni.kit.window.commands-0.1.1] startup
[1.771s] [ext: omni.kit.widget.browser_bar-2.0.2] startup
[1.776s] [ext: omni.kit.menu.utils-1.0.2] startup
[1.783s] [ext: omni.kit.search_core-1.0.0] startup
[1.788s] [ext: omni.kit.material.library-1.2.3] startup
[1.920s] [ext: omni.kit.menu.create-1.0.1] startup
[1.926s] [ext: omni.kit.widget.filebrowser-2.2.20] startup
[1.937s] [ext: omni.kit.context_menu-1.3.2] startup
[1.967s] [ext: omni.kvdb-0.0.0] startup
[1.973s] [ext: omni.kit.window.toolbar-1.2.1] startup
[1.984s] [ext: omni.localcache-0.0.0] startup
[1.989s] [ext: omni.convexdecomposition-1.3.14] startup
[1.994s] [ext: omni.usdphysics-1.3.14] startup
[1.995s] [ext: omni.renderer-rtx-0.0.0] startup
[1.998s] [ext: omni.kit.window.drop_support-1.0.0] startup
[2.003s] [ext: omni.hydra.rtx-0.1.0] startup
[2.020s] [ext: omni.physx-1.3.14-5.1] startup
[2.049s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.080s] [ext: omni.kit.window.viewport-0.0.0] startup
2022-01-20 09:54:31 [2,057ms] [Error] [omni.kit.window.viewport.plugin] renderer::IRenderer is invalid
2022-01-20 09:54:31 [2,057ms] [Error] [omni.kit.window.viewport.plugin] Failed to prepare GPU Foundation
2022-01-20 09:54:31 [2,057ms] [Error] [omni.kit.window.viewport.plugin] Failed to startup required plugins
2022-01-20 09:54:31 [2,066ms] [Error] [carb.scripting-python.plugin] AttributeError: 'NoneType' object has no attribute 'get_mouse_event_stream'
At:
/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.window.viewport/omni/kit/viewport/scripts/context_menu.py(27): on_startup
/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(143): _startup_ext
/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(174): startup_all_extensions_in_module
/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(225): startup_all_extensions_in_module
PythonExtension.cpp::startup()(2): <module>
2022-01-20 09:54:31 [2,066ms] [Error] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] Failed to process python module extension in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/extscore/omni.kit.window.viewport/.'.
[2.108s] [ext: omni.isaac.dynamic_control-0.1.8] startup
[2.127s] [ext: omni.isaac.lula-0.1.0] startup
[2.146s] [ext: omni.kit.notification_manager-1.0.0] startup
[2.153s] [ext: omni.kit.widget.versioning-1.3.4] startup
[2.161s] [ext: omni.syntheticdata-0.1.6] startup
[2.247s] [ext: omni.isaac.core-0.1.12] startup
2022-01-20 09:54:31 [2,225ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.isaac.core. Error: No module named 'omni.kit.viewport'. Traceback:
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py", line 65, in import_module
return importlib.import_module(name)
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/lib/python3.7/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1006, in _gcd_import
File "<frozen importlib._bootstrap>", line 983, in _find_and_load
File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 677, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 728, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/__init__.py", line 10, in <module>
from omni.isaac.core.simulation_context.simulation_context import SimulationContext
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/__init__.py", line 9, in <module>
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 14, in <module>
from omni.isaac.core.utils.viewports import set_camera_view
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/omni/isaac/core/utils/viewports.py", line 16, in <module>
import omni.kit.viewport
ModuleNotFoundError: No module named 'omni.kit.viewport'
2022-01-20 09:54:31 [2,225ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.core' in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/.' failed to load.
At:
/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/plugins/bindings-python/omni/ext/impl/_internal.py(169): startup_all_extensions_in_module
2022-01-20 09:54:31 [2,225ms] [Error] [omni.ext.plugin] [ext: omni.isaac.core-0.1.12] Failed to process python module extension in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.core/.'.
[2.271s] [ext: omni.kit.window.filepicker-2.4.12] startup
[2.331s] [ext: omni.isaac.synthetic_utils-0.1.5] startup
2022-01-20 09:54:31 [2,306ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.isaac.synthetic_utils.tests. Error: No module named 'omni.isaac.core'. Traceback:
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/tests/__init__.py", line 10, in <module>
from .test_synthetic_utils import *
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_utils/omni/isaac/synthetic_utils/tests/test_synthetic_utils.py", line 31, in <module>
from omni.isaac.core.utils.physics import simulate_async
ModuleNotFoundError: No module named 'omni.isaac.core'
2022-01-20 09:54:31 [2,306ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.synthetic_utils.tests' in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_utils/.' failed to load.
At:
2022-01-20 09:54:31 [2,306ms] [Error] [omni.ext.plugin] [ext: omni.isaac.synthetic_utils-0.1.5] Failed to process python module extension in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_utils/.'.
[2.351s] [ext: omni.kit.widget.stage-2.6.8] startup
[2.362s] [ext: omni.isaac.synthetic_recorder-0.1.0] startup
2022-01-20 09:54:31 [2,335ms] [Error] [omni.ext.impl._internal] Failed to import python module omni.isaac.synthetic_recorder. Error: No module named 'omni.isaac.synthetic_utils'. Traceback:
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_recorder/omni/isaac/synthetic_recorder/__init__.py", line 10, in <module>
from .extension import *
File "/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_recorder/omni/isaac/synthetic_recorder/extension.py", line 29, in <module>
from omni.isaac.synthetic_utils import visualization as vis
ModuleNotFoundError: No module named 'omni.isaac.synthetic_utils'
2022-01-20 09:54:31 [2,335ms] [Error] [carb.scripting-python.plugin] Exception: Extension python module: 'omni.isaac.synthetic_recorder' in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_recorder/.' failed to load.
At:
2022-01-20 09:54:31 [2,335ms] [Error] [omni.ext.plugin] [ext: omni.isaac.synthetic_recorder-0.1.0] Failed to process python module extension in '/raid/home/ryan_lin/.local/share/ov/pkg/isaac_sim-2021.2.1/exts/omni.isaac.synthetic_recorder/.'.
[2.380s] [ext: semantics.schema.editor-0.2.2] startup
[2.387s] [ext: omni.kit.widget.graph-1.1.4] startup
[2.425s] [ext: omni.kit.stage_templates-1.0.6] startup
[2.433s] [ext: omni.kit.window.property-1.6.2] startup
[2.441s] [ext: omni.kit.window.extensions-1.0.2] startup
[2.452s] [ext: omni.kit.window.file-1.3.5] startup
[2.528s] [ext: omni.kit.widget.live-0.1.0] startup
[2.530s] [ext: omni.isaac.ui-0.1.2] startup
[2.539s] [ext: omni.kit.window.content_browser-2.4.10] startup
[2.584s] [ext: omni.kit.tool.asset_exporter-1.0.8] startup
[2.596s] [ext: omni.command.usd-1.0.1] startup
[2.602s] [ext: omni.isaac.unit_converter-0.1.1] startup
[2.609s] [ext: omni.kit.property.usd-3.11.4] startup
[2.653s] [ext: omni.kit.window.status_bar-0.1.0] startup
[2.655s] [ext: omni.kit.menu.edit-1.0.3] startup
[2.664s] [ext: omni.kit.usd_undo-0.1.0] startup
[2.670s] [ext: omni.kit.tool.collect-2.0.8] startup
[2.683s] [ext: omni.kit.widget.settings-1.0.0] startup
[2.691s] [ext: omni.kit.property.skel-1.0.0] startup
[2.699s] [ext: omni.physx.commands-1.3.14-5.1] startup
[2.705s] [ext: omni.debugdraw-0.1.0] startup
[2.712s] [ext: omni.kit.profiler.window-1.3.3] startup
[2.724s] [ext: omni.kit.property.camera-1.0.3] startup
[2.732s] [ext: omni.kit.property.geometry-1.2.0] startup
[2.741s] [ext: omni.kit.property.light-1.0.4] startup
[2.749s] [ext: omni.kit.window.preferences-1.1.5] startup
[2.807s] [ext: omni.physx.ui-1.3.14-5.1] startup
2022-01-20 09:54:32 [3,022ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2022-01-20 09:54:32 [3,024ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2022-01-20 09:54:32 [3,028ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2022-01-20 09:54:32 [3,028ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.physxui.plugin.so!carbOnPluginStartup
2022-01-20 09:54:32 [3,032ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2022-01-20 09:54:32 [3,035ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!omniCoreStart
2022-01-20 09:54:32 [3,038ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2022-01-20 09:54:32 [3,042ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!releaseFramework
2022-01-20 09:54:32 [3,045ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.so!_init
2022-01-20 09:54:32 [3,048ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2022-01-20 09:54:32 [3,051ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2022-01-20 09:54:32 [3,055ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)
2022-01-20 09:54:32 [3,058ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2022-01-20 09:54:32 [3,061ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2022-01-20 09:54:32 [3,064ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2022-01-20 09:54:32 [3,068ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2022-01-20 09:54:32 [3,071ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)
2022-01-20 09:54:32 [3,074ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2022-01-20 09:54:32 [3,074ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2022-01-20 09:54:32 [3,078ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2022-01-20 09:54:32 [3,078ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
I have also tried other GPU index (0 ~ 4) to launch
GPU 0 gave me this error
2022-01-20 10:05:01 [1,153ms] [Warning] [gpu.foundation.plugin] Raytracing is not supported on GPU: 0. Skipping this device.
and other indexes gave me this error
2022-01-20 10:06:16 [680ms] [Error] [gpu.foundation.plugin] The chosen activeGpu index is higher than the available GPUs. An unsupported driver might also prevent it from enumerating your devices properly.
