Failed to install isaac sim 2021.2.0 version
Hi Team,
I tried to install the Isaac sim on my ubuntu 18.04 env. It showed the following errors.
Would you please give me the advice to solve this issue?
Error occurred during installation of Isaac Sim: Command failed: "/home/nvidia/.local/share/ov/pkg/isaac_sim-2021.2.0/omni.isaac.sim.post.install.sh"
X Error of failed request:  GLXBadFBConfig
  Major opcode of failed request:  152 (GLX)
  Minor opcode of failed request:  34 ()
  Serial number of failed request:  194
  Current serial number in output stream:  192
/home/nvidia/.local/share/ov/pkg/isaac_sim-2021.2.0/omni.isaac.sim.post.install.sh: line 4:  4204 Segmentation fault      (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
If need more detail on my environments, please let me know.
Best regards.
Kaka
Hi, please share the output of nvidia-smi
You can try running Isaac Sim directly with.
/home/nvidia/.local/share/ov/pkg/isaac_sim-2021.2.0/isaac-sim.sh
Hi
Here is the log file when I run that script directly.
nvidia@omniverse:~$ /home/nvidia/.local/share/ov/pkg/isaac_sim-2021.2.0/isaac-sim.sh
[Info] [carb] Logging to file: /home/nvidia/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.2/kit_20211201_220346.log
[0.191s] [ext: omni.kit.pipapi-0.0.0] startup
[0.199s] [ext: omni.usd.config-1.0.0] startup
[0.200s] [ext: omni.usd.libs-1.0.0] startup
[0.441s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.447s] [ext: omni.stats-0.0.0] startup
[0.450s] [ext: omni.gpu_foundation-0.0.0] startup
[0.462s] [ext: omni.isaac.pip_archive-0.1.0] startup
[0.567s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.573s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.578s] [ext: omni.hydra.iray-0.1.0] startup
[0.584s] [ext: omni.kit.async_engine-0.0.0] startup
[0.593s] [ext: omni.kit.loop-default-0.1.0] startup
[0.593s] [ext: omni.assets.plugins-0.0.0] startup
[0.596s] [ext: omni.appwindow-1.0.0] startup
2021-12-01 13:03:47 [566ms] [Error] [carb.windowing-glfw.plugin] GLFW initialization failed.
2021-12-01 13:03:47 [566ms] [Error] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.2]) (impl: carb.windowing-glfw.plugin)
2021-12-01 13:03:47 [566ms] [Error] [omni.appwindow.plugin] Failed to acquire IWindowing interface
[0.601s] [ext: omni.client-0.1.0] startup
[0.615s] [ext: omni.kit.renderer.core-0.0.0] startup
2021-12-01 13:03:47 [825ms] [Error] [carb.windowing-glfw.plugin] GLFW initialization failed.
2021-12-01 13:03:47 [825ms] [Error] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.2]) (impl: carb.windowing-glfw.plugin)
| Driver Version: 470.82      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA A40-12Q                   | Yes: 0 |     | 12534   MB | 10de      | 0          |
|     |                                  |        |     |            | 2235      | 61f2dff0.. |
| OS: Linux omniverse, Version: 5.4.0-91-generic
| Processor: Intel(R) Xeon(R) Silver 4114 CPU @ 2.20GHz | Cores: Unknown | Logical: 8
| Total Memory (MB): 32089 | Free Memory: 28795
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2021-12-01 13:03:48 [1,170ms] [Error] [carb.windowing-glfw.plugin] GLFW initialization failed.
2021-12-01 13:03:48 [1,170ms] [Error] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.2]) (impl: carb.windowing-glfw.plugin)
2021-12-01 13:03:48 [1,509ms] [Warning] [gpu.foundation.plugin] Different GPUs have different availalbe VRAM. The texture streaming system will be limited to the lower VRAM number
2021-12-01 13:03:48 [2,095ms] [Error] [carb.windowing-glfw.plugin] GLFW initialization failed.
2021-12-01 13:03:48 [2,095ms] [Error] [carb] Failed to startup plugin carb.windowing-glfw.plugin (interfaces: [carb::windowing::IGLContext v1.0],[carb::windowing::IWindowing v1.2]) (impl: carb.windowing-glfw.plugin)
2021-12-01 13:03:49 [2,292ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!carbOnPluginStartup
2021-12-01 13:03:49 [2,293ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-12-01 13:03:49 [2,320ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-12-01 13:03:49 [2,321ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.appwindow.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)
2021-12-01 13:03:49 [2,322ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2021-12-01 13:03:49 [2,322ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-12-01 13:03:49 [2,323ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-12-01 13:03:49 [2,324ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.ext.plugin.so!carbOnPluginPostShutdown
2021-12-01 13:03:49 [2,326ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<std::string, std::allocator<std::string> >::_M_realloc_insert<std::string&>(__gnu_cxx::__normal_iterator<std::string*, std::vector<std::string, std::allocator<std::string> > >, std::string&)
2021-12-01 13:03:49 [2,329ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!carbOnPluginShutdown
2021-12-01 13:03:49 [2,332ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)
2021-12-01 13:03:49 [2,334ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-12-01 13:03:49 [2,337ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-12-01 13:03:49 [2,339ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)
2021-12-01 13:03:49 [2,342ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::operator=(std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> > const&)
2021-12-01 13:03:49 [2,345ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)
2021-12-01 13:03:49 [2,347ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-12-01 13:03:49 [2,347ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-12-01 13:03:49 [2,350ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-12-01 13:03:49 [2,350ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Also, here is the nvidia-smi output.
Wed Dec  1 22:29:09 2021
| NVIDIA-SMI 470.82.01    Driver Version: 470.82.01    CUDA Version: 11.4     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA A40-12Q      On   | 00000000:02:00.0 Off |                    0 |
| N/A   N/A    P8    N/A /  N/A |   1047MiB / 12107MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1304      G   /usr/lib/xorg/Xorg                 23MiB |
The Drivers and GPU looks OK. Some questions to help me figure this out:
Are you originally installing and launching Isaac Sim from the Omniverse Launcher? Can you reproduce the crash with Create or other Omniverse apps?
Are you running on a local workstation or remotely accessing the workstation (via vnc or other). If remotely, do you have the workstation running Isaac Sim connected to a display monitor?
Thank you for your response. Here is my answers.
Yes, I installed the Isaac Sim from Omniverse Launcher.
Other application like create was able to install from Omniverse Launcher but it could not run correctly.
It was run on remotely accessing the workstation. As you can see form nvidia-smi, it setup on EXSi with Grid(vWS) env.
Is it possible to run the omniverse application on grid env?
Just for your information, I tried to run the script from terminal on VNC and showed the following errors.
[Info] [carb] Logging to file: /home/nvidia/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.2/kit_20211202_094446.log
[0.438s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.444s] [ext: omni.stats-0.0.0] startup
[0.447s] [ext: omni.gpu_foundation-0.0.0] startup
[0.458s] [ext: omni.isaac.pip_archive-0.1.0] startup
[0.563s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.569s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.574s] [ext: omni.hydra.iray-0.1.0] startup
[0.580s] [ext: omni.kit.async_engine-0.0.0] startup
[0.589s] [ext: omni.kit.loop-default-0.1.0] startup
[0.589s] [ext: omni.assets.plugins-0.0.0] startup
[0.592s] [ext: omni.appwindow-1.0.0] startup
[0.611s] [ext: omni.client-0.1.0] startup
[0.626s] [ext: omni.kit.renderer.core-0.0.0] startup
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2235      | 61f2dff0.. |
| Total Memory (MB): 32089 | Free Memory: 29643
  Serial number of failed request:  284
  Current serial number in output stream:  282
Best regards.
Kaka
Thanks, it makes sense now.
I’m not an expert in EXSi and GRID. You may need to get support from VMWare or NVIDIA GRID team and see if they support Vulkan applications. I have seen our Ominverse Apps working on VMWare Horizon though.
Our recommended method for remote/Cloud deployments of Isaac Sim is to use a headless container and streaming it using WebSockets. See 3. Deploy to Cloud — Omniverse Robotics documentation.
I can confirm that on the VMWare ESXI 7.0.3 neither Omniverse Create or Isaac Sim are able to run. The VM is Ubuntu 20.04 LTS with 16vCPUs and 24GB of RAM while the GPU is A4000.
Isaac Sim:
iuser@vm:~/.local/share/ov/pkg/isaac_sim-2021.2.0$ ./isaac-sim.sh
[Info] [carb] Logging to file: /home/iuser/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.2/kit_20211202_092507.log
[0.378s] [ext: omni.usd.config-1.0.0] startup
[0.380s] [ext: omni.usd.libs-1.0.0] startup
[0.703s] [ext: omni.kit.pipapi-0.0.0] startup
[0.710s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.716s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.722s] [ext: omni.hydra.iray-0.1.0] startup
[0.732s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.740s] [ext: omni.stats-0.0.0] startup
[0.743s] [ext: omni.gpu_foundation-0.0.0] startup
[0.761s] [ext: omni.isaac.pip_archive-0.1.0] startup
[0.878s] [ext: omni.assets.plugins-0.0.0] startup
[0.886s] [ext: omni.kit.async_engine-0.0.0] startup
[0.894s] [ext: omni.kit.loop-default-0.1.0] startup
[0.895s] [ext: omni.client-0.1.0] startup
[0.925s] [ext: omni.appwindow-1.0.0] startup
[0.943s] [ext: omni.kit.test-0.0.0] startup
[1.048s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 470.86 | Graphics API: Vulkan
| | | | | | Device-ID | UUID |
| 0 | NVIDIA RTX A4000 | Yes: 0 | | 16622 MB | 10de | 0 |
| | | | | | 24b0 | af8e3ba5… |
| OS: Linux vm, Version: 5.11.0-41-generic
| Processor: AMD Ryzen Threadripper PRO 3955WX 16-Cores | Cores: Unknown | Logical: 16
| Total Memory (MB): 24043 | Free Memory: 21068
Major opcode of failed request: 153 (GLX)
Minor opcode of failed request: 0 ()
Serial number of failed request: 275
Current serial number in output stream: 275
Omniverse Create:
iuser@vm:~/.local/share/ov/pkg/create-2021.3.7$ ./omni.create.sh
[Info] [carb] Logging to file: /home/iuser/.nvidia-omniverse/logs/Kit/Create.Next/2021.3/kit_20211202_092922.log
[0.099s] [ext: omni.assets.plugins-0.0.0] startup
[0.101s] [ext: omni.kit.window.splash-0.0.0] startup
[0.127s] [ext: omni.kit.async_engine-0.0.0] startup
[0.134s] [ext: omni.kit.agent-0.1.0] startup
[0.135s] [ext: omni.kit.splash-0.2.1] startup
[0.141s] [ext: omni.kit.pipapi-0.0.0] startup
[0.145s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.150s] [ext: omni.usd.config-1.0.0] startup
[0.151s] [ext: omni.usd.libs-1.0.0] startup
[0.301s] [ext: omni.stats-0.0.0] startup
[0.303s] [ext: omni.gpu_foundation-0.0.0] startup
[0.308s] [ext: omni.kit.telemetry-0.1.0] startup
[Warning] [omni.telemetry.transmitter] Couldn’t acquire tokens interface and initialize default tokens.
[0.315s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.319s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.322s] [ext: omni.hydra.iray-0.1.0] startup
[0.325s] [ext: omni.kit.loop-default-0.1.0] startup
[0.326s] [ext: omni.appwindow-1.0.0] startup
[0.340s] [ext: omni.client-0.1.0] startup
[0.347s] [ext: omni.kit.test-0.0.0] startup
[0.426s] [ext: omni.kit.renderer.core-0.0.0] startup
| | | | | | Device-ID | UUID |
| | | | | | 24b0 | af8e3ba5… |
| Total Memory (MB): 24043 | Free Memory: 21009
Serial number of failed request: 283
Current serial number in output stream: 283
In the case of Omniverse Create the splash screen remains indefinitely on the screen.
This is very disappointing for small companies/developers as the ESXi is good platform to reuse the hardware between day where creation work is done and evening where deep learning / simulations are run. Can you please coordinate any support across NVIDIA + VMware to resolve this issue?
Thank you
I have managed to make significant progress this morning on this issue. After checking that the VM is able to run
sudo apt install mesa-utils
glxgears
I launched Isaac from the command line as follows:
cd /.local/share/ov/pkg/isaac_sim-2021.2.0
MESA_GL_VERSION_OVERRIDE=4.6 ./isaac-sim.sh
I was happy to see that the simulator was brought up and we are in the process of verifying that our existing bare metal experiments - see github link - will work identically in the Ubuntu VM (with A4000 passthrough) running in ESXI host and accessed via its esxi remote console (‎VMware Remote Console App - App Store).
https://github.com/pantelis-classes/omniverse-ai
same problem, i have a server with redhat 8 in host os and a VM Ubuntu 18.04 without screen connected to the server. I access it remotely. And nothing works for me, anyone have any other solution ?
Thank you.
Similar error while installing Isaac Sim 2021.2.1 using Omniverse-Launcher as Nvidia tutorial.
Error occurred during installation of Isaac Sim: Command failed: “/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh”
Major opcode of failed request: 154 (GLX)
Serial number of failed request: 187
Current serial number in output stream: 185
/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh: line 10: 2985 Segmentation fault (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
Because, recently I am getting problem of remote desktop connection with AWS EC2 container of Isaac Sim AMI image, so I’m trying install Isaac Sim as the tutorial 2. Basic Isaac Sim Installation on a AWS EC2 instance by connecting Remote Desktop from my PC (It is not using Isaac Sim AMI image, instead, I’m installing on local computer of AWS EC2 instance directly from Omniveres Launcher, just using Remote Desktop)
But this installation error happens, and I cannot run directly as below because the isaac_sim folder does not exist yet:
I tried one more time and report again the symptom of the installation failure:
Environment
AWS EC2 g4dn.xlarge
Ubuntu 18.04 AMI Image
Isaac Sim native installation as written in the Isaac Sim tutorial
Problem 1
After installing Nucleus server, the ‘Search Service’ happens error as the photo below:
Problem 2
While installing Isaac Sim, it is stopped with the following errors and warning:
WARNING: You are using pip version 20.1.1; however, version 22.0.4 is available.
You should consider upgrading via the ‘/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.1/kit/python/bin/python3 -m pip install --upgrade pip’ command.
/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.1/omni.isaac.sim.post.install.sh: line 10: 12269 Segmentation fault (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
I am also getting the same error.
I use A40 GPU, launched through ‘Omniverse launcher’ and I use it Remotely using VNC. Can anyone please clarify that is this issue with Remotely accessing the Server using VNC ?
And after the below error, the folder is getting “/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.0” removed.
However the lower version "Isaac Sim 2021.1.0 ", installs properly through Omniverse Launcher in Remote Server. But it isn’t getting launched.
Error occurred during installation of Isaac Sim: Command failed: “/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.0/omni.isaac.sim.post.install.sh”
WARNING: You are using pip version 20.1.1; however, version 22.1.1 is available.
You should consider upgrading via the ‘/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.0/kit/python/bin/python3 -m pip install --upgrade pip’ command.
Major opcode of failed request: 150 (GLX)
Serial number of failed request: 182
Current serial number in output stream: 180
/home/ubuntu/.local/share/ov/pkg/isaac_sim-2021.2.0/omni.isaac.sim.post.install.sh: line 4: 29432 Segmentation fault (core dumped) ${SCRIPT_DIR}/omni.isaac.sim.warmup.sh
I am running into the same issue here and I see the need to update the MESA_GL version while running the isaac-sim.sh from the terminal as the best fix however as others have mentioned, when the omniverse install fails, it removes the isaac_sim-202X.X.X folder and all of the files so that I cannot run the .sh file. Is there a location where I can download and extract the isaac_sim-202X.X.X installation files so I can run it from the terminal?
If you set the MESA_GL version before running the launcher app does that allow you to install ?
Right-click and exit the launcher before re-launching directly from the terminal where you set the MESA_GL version
I can confirm that the above hint works. To install IsaacSim via Omniverse Launcher first, EXIT IT from the menu and than restart it from the terminal with forcing OpenGl 4.6:
MESA_GL_VERSION_OVERRIDE=4.6 ./omniverse-launcher-linux.AppImage
