Here is the terminal message after running the “follow_target_with_rmpflow.py” standalone example:
PS C:\Users\23and> & C:/.venv/Scripts/python.exe c:/ov/isaac-sim-4.2.0/standalone_examples/api/omni.isaac.franka/follow_target_with_rmpflow.py
[Warning] [omni.isaac.kit.simulation_app] Modules: [‘omni.kit_app’] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(…)
Starting kit application with the following args: [‘C:\.venv\Lib\site-packages\isaacsim\exts\omni.isaac.kit\omni\isaac\kit\simulation_app.py’, ‘C:\.venv\Lib\site-packages\isaacsim\apps/omni.isaac.sim.python.kit’, ‘–/app/tokens/exe-path=C:\.venv\Lib\site-packages\omni’, ‘–/persistent/app/viewport/displayOptions=3094’, ‘–/rtx/materialDb/syncLoads=True’, ‘–/rtx/hydra/materialSyncLoads=True’, ‘–/omni.kit.plugin/syncUsdLoads=True’, ‘–/app/renderer/resolution/width=1280’, ‘–/app/renderer/resolution/height=720’, ‘–/app/window/width=1440’, ‘–/app/window/height=900’, ‘–/renderer/multiGpu/enabled=True’, ‘–/app/fastShutdown=True’, ‘–ext-folder’, ‘C:\.venv\Lib\site-packages\isaacsim/exts’, ‘–ext-folder’, ‘C:\.venv\Lib\site-packages\isaacsim/apps’, ‘–/physics/cudaDevice=0’, ‘–portable’]
Passing the following args to the base kit application:
[Info] [carb] Logging to file: c:/.venv/lib/site-packages/omni/logs/Kit/Isaac-Sim/4.2/kit_20250114_170442.log
2025-01-14 22:04:42 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn’t available.
2025-01-14 22:04:43 [443ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.capture-0.0.0+10a4b5c0.wx64.r.cp310] Extensions config ‘extension.toml’ doesn’t exist ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.capture-0.0.0+10a4b5c0.wx64.r.cp310’ or ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.capture-0.0.0+10a4b5c0.wx64.r.cp310/config’
2025-01-14 22:04:43 [453ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.core-1.0.2+10a4b5c0.wx64.r.cp310] Extensions config ‘extension.toml’ doesn’t exist ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.core-1.0.2+10a4b5c0.wx64.r.cp310’ or ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.core-1.0.2+10a4b5c0.wx64.r.cp310/config’
2025-01-14 22:04:43 [453ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.imgui-1.0.1+10a4b5c0.wx64.r.cp310] Extensions config ‘extension.toml’ doesn’t exist ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.imgui-1.0.1+10a4b5c0.wx64.r.cp310’ or ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.imgui-1.0.1+10a4b5c0.wx64.r.cp310/config’
2025-01-14 22:04:43 [453ms] [Warning] [omni.ext.plugin] [ext: omni.kit.renderer.init-0.0.0+10a4b5c0.wx64.r] Extensions config ‘extension.toml’ doesn’t exist ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.init-0.0.0+10a4b5c0.wx64.r’ or ‘c:/.venv/lib/site-packages/isaacsim/extscache/omni.kit.renderer.init-0.0.0+10a4b5c0.wx64.r/config’
[1.166s] [ext: omni.blobkey-1.1.2] startup
[1.170s] [ext: omni.kit.async_engine-0.0.1] startup
[1.977s] [ext: omni.stats-1.0.1] startup
[1.994s] [ext: omni.datastore-0.0.0] startup
[2.002s] [ext: omni.client-1.2.0] startup
[2.166s] [ext: omni.ujitso.default-1.0.0] startup
[2.174s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[2.220s] [ext: omni.assets.plugins-0.0.0] startup
[2.313s] [ext: omni.gpu_foundation-0.0.0] startup
[2.456s] [ext: carb.windowing.plugins-1.0.0] startup
[2.617s] [ext: omni.kit.renderer.init-0.0.0] startup
[2.643s] [ext: omni.kit.pipapi-0.0.0] startup
[2.661s] [ext: omni.materialx.libs-1.0.4] startup
[2.777s] [ext: omni.kit.pip_archive-0.0.0] startup
[2.784s] [ext: omni.usd.config-1.0.4] startup
[2.822s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.830s] [ext: omni.usd.libs-1.0.1] startup
[3.194s] [ext: omni.iray.libs-0.0.0] startup
[3.456s] [ext: omni.mdl.neuraylib-0.2.8] startup
[3.473s] [ext: omni.mdl-55.0.1] startup
2025-01-14 22:04:45 [3,311ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-01-14 22:04:45 [3,312ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Iris(R) Xe Graphics
2025-01-14 22:04:45 [3,313ms] [Error] [gpu.foundation.plugin] Multiple Installable Client Drivers (ICDs) are found for the same GPU on the system. This causes the same GPU to be reported multiple times by more than one driver and leads to instability or crash.
For Windows, a clean driver reinstallation may be required. It might also happen after connecting with some certain remote desktop applications.
| Driver Version: 561.17 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4070 Laptop… | | | 7948 MB | 10de | 3b160100… |
| | | | | | 2860 | c802a368… |
| | | | | | 1 | |
| 1 | Intel(R) Iris(R) Xe Graphics | | | 16198 MB | 8086 | 0e120100… |
| | | | | | a7a0 | 8680a0a7… |
| | | | | | N/A | |
| 2 | Intel(R) Iris(R) Xe Graphics | | | 16198 MB | 8086 | f3141000… |
| | | | | | a7a0 | 8680a0a7… |
| | | | | | N/A | |
| OS: Windows 11 Pro, Version: 10.0 (24H2), Build: 26100, Kernel: 10.0.26100.2605
| Processor: 13th Gen Intel(R) Core™ i9-13900H | Cores: 14 | Logical: 20
| Total Memory (MB): 32397 | Free Memory: 20715
| Total Page/Swap (MB): 34445 | Free Page/Swap: 16436
[3.576s] [ext: omni.kit.usd.mdl-1.0.1] startup
2025-01-14 22:04:46 [3,457ms] [Error] [gpu.foundation.plugin] Multiple Installable Client Drivers (ICDs) are found for the same GPU on the system. This causes the same GPU to be reported multiple times by more than one driver and leads to instability or crash.
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 2860 | c802a368… |
| | | | | | 1 | |
| | | | | | a7a0 | 8680a0a7… |
| | | | | | N/A | |
| | | | | | a7a0 | 8680a0a7… |
| | | | | | N/A | |
| Total Memory (MB): 32397 | Free Memory: 20698
| Total Page/Swap (MB): 34445 | Free Page/Swap: 16431
2025-01-14 22:04:46 [3,460ms] [Error] [omni.gpu_foundation_factory.plugin] Failed to create any GPU devices, including an attempt with compatibility mode.
[4.119s] [ext: omni.kit.telemetry-0.5.0] startup
[4.158s] [ext: omni.kit.loop-isaac-1.2.0] startup
[4.168s] [ext: omni.kit.test-1.1.0] startup
[4.676s] [ext: omni.appwindow-1.1.8] startup
[4.707s] [ext: omni.kit.renderer.core-1.0.2] startup
[4.816s] [ext: omni.kit.renderer.capture-0.0.0] startup
[4.909s] [ext: omni.kit.renderer.imgui-1.0.1] startup
[5.225s] [ext: omni.ui-2.25.22] startup
[5.339s] [ext: omni.kit.mainwindow-1.0.3] startup
[5.362s] [ext: carb.audio-0.1.0] startup
[5.377s] [ext: omni.uiaudio-1.0.0] startup
[5.393s] [ext: omni.kit.uiapp-0.0.0] startup
[5.393s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[5.431s] [ext: omni.usd.schema.audio-0.0.0] startup
[5.466s] [ext: omni.usd.schema.forcefield-106.1.9] startup
[5.525s] [ext: omni.anim.navigation.schema-106.1.0] startup
[5.551s] [ext: omni.usd.schema.semantics-0.0.0] startup
[5.575s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[5.598s] [ext: omni.usd.schema.anim-0.0.0] startup
[5.727s] [ext: omni.anim.graph.schema-106.1.0] startup
[5.763s] [ext: omni.usd.schema.isaac-2.1.0] startup
[5.817s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[5.855s] [ext: omni.usd.schema.physx-106.1.9] startup
[5.948s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[5.977s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[6.039s] [ext: omni.kit.widget.nucleus_connector-1.1.9] startup
[6.091s] [ext: omni.graph.exec-0.9.4] startup
[6.095s] [ext: omni.kit.usd_undo-0.1.8] startup
[6.107s] [ext: omni.kit.actions.core-1.0.0] startup
[6.131s] [ext: omni.kit.exec.core-0.13.4] startup
[6.159s] [ext: omni.kit.menu.core-1.0.4] startup
[6.174s] [ext: omni.kit.commands-1.4.9] startup
[6.244s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[6.317s] [ext: omni.kit.menu.utils-1.5.27] startup
[6.429s] [ext: omni.kit.clipboard-1.0.4] startup
[6.437s] [ext: omni.kit.widget.graph-1.12.15] startup
[6.535s] [ext: omni.kit.widget.filter-1.1.4] startup
[6.549s] [ext: omni.timeline-1.0.10] startup
[6.565s] [ext: omni.usd_resolver-1.0.0] startup
[6.601s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[6.626s] [ext: omni.usd.core-1.4.1] startup
[6.637s] [ext: omni.resourcemonitor-105.0.1] startup
[6.662s] [ext: usdrt.scenegraph-7.5.0] startup
[6.908s] [ext: omni.activity.core-1.0.1] startup
[6.920s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[6.944s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[7.050s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[7.058s] [ext: omni.kit.window.extensions-1.4.11] startup
[7.168s] [ext: omni.usd-1.12.2] startup
[7.447s] [ext: omni.kvdb-106.1.9] startup
[7.472s] [ext: omni.kit.property.adapter.core-1.0.1] startup
[7.512s] [ext: omni.ui_query-1.1.4] startup
[7.524s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[7.542s] [ext: omni.convexdecomposition-106.1.9] startup
[7.568s] [ext: omni.localcache-106.1.9] startup
[7.587s] [ext: omni.kit.property.adapter.fabric-1.0.1] startup
[7.625s] [ext: omni.kit.property.adapter.usd-1.0.1] startup
[7.653s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[7.679s] [ext: omni.usdphysics-106.1.9] startup
[7.684s] [ext: omni.hsscclient-1.1.1] startup
[7.697s] [ext: omni.inspect-1.0.1] startup
[7.710s] [ext: omni.kit.widget.settings-1.2.2] startup
[7.742s] [ext: omni.kit.widget.path_field-2.0.10] startup
[7.766s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[7.792s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[7.812s] [ext: omni.kit.widget.options_button-1.0.3] startup
[7.830s] [ext: omni.kit.widget.context_menu-1.2.2] startup
[7.850s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[7.874s] [ext: omni.kit.widget.filebrowser-2.10.51] startup
[7.966s] [ext: omni.kit.search_core-1.0.5] startup
[7.981s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[7.992s] [ext: omni.ui.scene-1.10.3] startup
[8.034s] [ext: omni.kit.widget.search_delegate-1.0.5] startup
[8.063s] [ext: omni.kit.notification_manager-1.0.9] startup
[8.098s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[8.116s] [ext: omni.kit.window.filepicker-2.10.40] startup
[8.339s] [ext: omni.kit.widget.prompt-1.0.7] startup
[8.352s] [ext: omni.kit.usd.layers-2.1.36] startup
[8.445s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[8.494s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[8.530s] [ext: omni.graph.tools-1.79.0] startup
[8.963s] [ext: omni.graph.core-2.179.2] startup
[8.983s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[8.987s] [ext: omni.graph.image.core-0.4.5] startup
[8.994s] [ext: omni.ujitso.client-0.0.0] startup
[8.997s] [ext: omni.kit.window.preferences-1.6.0] startup
[9.089s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[9.100s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[9.145s] [ext: omni.physx.foundation-106.1.9] startup
[9.179s] [ext: omni.graph.image.nodes-1.1.0] startup
[9.193s] [ext: omni.kit.window.file_exporter-1.0.30] startup
[9.220s] [ext: omni.kit.hotkeys.core-1.3.5] startup
[9.222s] [ext: omni.kit.context_menu-1.8.1] startup
[9.262s] [ext: omni.volume-0.5.0] startup
[9.296s] [ext: omni.kit.widget.stage-2.11.2] startup
[9.471s] [ext: omni.hydra.rtx-1.0.0] startup
[9.560s] [ext: omni.kit.window.file_importer-1.1.12] startup
[9.581s] [ext: omni.hydra.engine.stats-1.0.2] startup
[9.590s] [ext: omni.kit.raycast.query-1.0.5] startup
[9.612s] [ext: omni.kit.material.library-1.5.6] startup
[9.717s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[9.732s] [ext: omni.kit.hydra_texture-1.3.9] startup
[9.757s] [ext: omni.kit.viewport.registry-104.0.6] startup
[9.769s] [ext: omni.kit.stage_template.core-1.1.22] startup
[9.780s] [ext: omni.kit.window.drop_support-1.0.3] startup
[9.792s] [ext: omni.kit.widget.viewport-106.1.0] startup
[9.854s] [ext: omni.kit.viewport.legacy_gizmos-1.1.0] startup
[9.864s] [ext: omni.kit.window.file-1.3.54] startup
[9.904s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[9.918s] [ext: omni.kit.viewport.window-107.0.6] startup
