hello. trying to install isaac on windows laptop alienware m17 with rtx 3080. overall install and create work fine however after isaac sim install run of isaac sim shows ‘rtx loading’ forever.
looks like not finding my video card: 2023-05-08 21:12:16 [12,617ms] [Warning] [gpu.foundation.plugin] Driver version could not be detected.
could you please advise what i’m doing wrong?
thanks in advance!
here is the full install txt:
oading user config located at: 'C:/Users/omnit/AppData/Local/ov/data/Kit/Isaac-Sim/2022.2/user.config.json'
[Info] [carb] Logging to file: C:/Users/omnit/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230508_161204.log
[0.250s] [ext: omni.stats-0.0.0] startup
[0.326s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.357s] [ext: omni.assets.plugins-0.0.0] startup
[0.360s] [ext: omni.gpu_foundation-0.0.0] startup
[0.404s] [ext: carb.windowing.plugins-1.0.0] startup
[0.661s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 528.79 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 3080 Laptop.. | Yes: 0 | | 8031 MB | 10de | 11c9a000.. |
| | | | | | 24dc | 0 |
| 1 | AMD Radeon(TM) Graphics | Yes: 1 | | 485 MB | 1002 | 10b96000.. |
| | | | | | 1681 | 0 |
| OS: Windows, Version: 10.0 (21H2), Build: 22000
| Processor: AMD Ryzen 9 6900HX with Radeon Graphics | Cores: 8 | Logical: 16
| Total Memory (MB): 31987 | Free Memory: 22286
| Total Page/Swap (MB): 54515 | Free Page/Swap: 42272
2023-05-08 21:12:05 [1,316ms] [Error] [gpu.foundation.plugin] CUDA processor count (1) does not match graphics processor count (2)
[1.379s] [ext: omni.kit.pipapi-0.0.0] startup
[1.401s] [ext: omni.usd.config-1.0.0] startup
[1.412s] [ext: omni.usd.libs-1.0.0] startup
[1.586s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.593s] [ext: omni.kit.async_engine-0.0.0] startup
[1.595s] [ext: omni.kit.loop-default-0.1.1] startup
[1.596s] [ext: omni.kit.test-0.0.0] startup
[1.646s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.683s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.693s] [ext: omni.client-0.1.1] startup
[1.707s] [ext: omni.iray.libs-0.0.0] startup
[1.726s] [ext: omni.volume-0.1.0] startup
[1.729s] [ext: omni.usd.core-1.0.4] startup
[1.731s] [ext: omni.mdl.neuraylib-0.1.0] startup
[1.736s] [ext: omni.hydra.rtx-0.1.0] startup
[1.751s] [ext: omni.hydra.iray-0.1.0] startup
[1.754s] [ext: omni.isaac.core_archive-2.0.1] startup
[1.854s] [ext: omni.services.pip_archive-0.4.2] startup
[1.857s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[1.861s] [ext: omni.isaac.ml_archive-1.1.0] startup
2023-05-08 21:12:06 [1,883ms] [Warning] [omni.ext._impl._internal] There is already a module 'gym' in 'c:\users\omnit\appdata\local\ov\pkg\isaac_sim-2022.2.1\kit\python\lib\site-packages\gym\__init__.py'. Can't import another module with the same name in public space from 'c:\users\omnit\appdata\local\ov\pkg\isaac_sim-2022.2.1\exts\omni.isaac.ml_archive\pip_prebundle'.
[1.933s] [ext: omni.appwindow-1.0.1] startup
[1.941s] [ext: omni.kit.renderer.core-0.0.0] startup
[2.004s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.009s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[2.084s] [ext: omni.ui-2.14.4] startup
[2.097s] [ext: carb.audio-0.1.0] startup
[2.099s] [ext: omni.uiaudio-1.0.0] startup
[2.102s] [ext: omni.kit.mainwindow-1.0.0] startup
[2.104s] [ext: omni.kit.uiapp-0.0.0] startup
[2.105s] [ext: omni.usd.schema.physics-1.0.0] startup
[2.116s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.215s] [ext: omni.usd.schema.isaac-1.1.0] startup
[2.235s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[2.239s] [ext: omni.usd.schema.physx-0.0.0] startup
[2.270s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[2.282s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[2.291s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[2.301s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[2.313s] [ext: omni.kit.actions.core-1.0.0] startup
[2.319s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[2.322s] [ext: omni.gpucompute.plugins-0.0.0] startup
[2.324s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[2.333s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[2.341s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[2.348s] [ext: omni.timeline-1.0.5] startup
[2.351s] [ext: omni.kit.commands-1.4.5] startup
[2.358s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[2.360s] [ext: omni.usd-1.6.30] startup
[2.399s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[2.401s] [ext: omni.usd.schema.destruction-0.4.0] startup
[2.410s] [ext: omni.kit.asset_converter-1.3.4] startup
[2.419s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[2.465s] [ext: omni.usd.schema.sequence-2.2.1] startup
[2.475s] [ext: omni.usd.schema.flow-104.1.6] startup
[2.476s] [ext: omni.inspect-1.0.1] startup
[2.480s] [ext: omni.kit.widget.path_field-2.0.4] startup
[2.482s] [ext: omni.debugdraw-0.1.1] startup
[2.486s] [ext: omni.kit.notification_manager-1.0.5] startup
[2.493s] [ext: omni.graph.core-2.65.4] startup
[2.496s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[2.498s] [ext: omni.kit.widget.versioning-1.3.8] startup
[2.502s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[2.519s] [ext: omni.kit.search_core-1.0.2] startup
[2.520s] [ext: omni.hydra.pxr-1.1.2] startup
[2.525s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[2.529s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[2.584s] [ext: omni.kit.menu.utils-1.4.7] startup
[2.597s] [ext: omni.kit.usd.layers-2.0.11] startup
[2.607s] [ext: omni.mdl-0.1.0] startup
[2.627s] [ext: omni.kit.window.file_importer-1.0.10] startup
[2.630s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[2.631s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[2.638s] [ext: omni.kit.material.library-1.3.21] startup
[2.645s] [ext: omni.kit.clipboard-1.0.0] startup
[2.646s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[2.648s] [ext: omni.kit.stage_templates-1.1.13] startup
[2.652s] [ext: omni.kit.menu.create-1.0.8] startup
[2.655s] [ext: omni.ui_query-1.1.1] startup
[2.657s] [ext: omni.kit.context_menu-1.5.12] startup
[2.662s] [ext: omni.activity.core-1.0.1] startup
[2.669s] [ext: omni.kit.window.file-1.3.32] startup
[2.673s] [ext: omni.kit.window.drop_support-1.0.1] startup
[2.674s] [ext: omni.kit.ui_test-1.2.9] startup
[2.678s] [ext: omni.kit.widget.stage-2.7.24] startup
[2.685s] [ext: omni.kit.window.property-1.8.2] startup
[2.689s] [ext: omni.kit.window.content_browser-2.6.8] startup
[2.701s] [ext: omni.kit.usd_undo-0.1.2] startup
[2.703s] [ext: omni.graph.tools-1.17.2] startup
[2.732s] [ext: omni.hydra.engine.stats-1.0.0] startup
[2.734s] [ext: omni.kit.property.usd-3.18.17] startup
[2.746s] [ext: omni.graph-1.50.2] startup
[2.796s] [ext: omni.kit.hydra_texture-1.0.11] startup
[2.801s] [ext: omni.kit.viewport.registry-104.0.2] startup
[2.805s] [ext: omni.ui.scene-1.5.18] startup
[2.811s] [ext: omni.kit.widget.viewport-104.1.16] startup
[2.815s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[2.817s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[2.820s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[2.854s] [ext: omni.kit.viewport.window-104.1.23] startup
[2.876s] [ext: omni.kit.widget.prompt-1.0.5] startup
[2.877s] [ext: omni.kit.window.extensions-1.1.1] startup
[2.885s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[2.888s] [ext: omni.kit.viewport.utility-1.0.14] startup
[2.889s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[2.893s] [ext: omni.kit.widget.settings-1.0.1] startup
[2.895s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[2.897s] [ext: omni.kit.window.preferences-1.3.8] startup
[2.924s] [ext: omni.graph.ui-1.24.2] startup
[2.970s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[2.973s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[2.979s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.983s] [ext: omni.kvdb-0.0.0] startup
[2.987s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[2.989s] [ext: omni.usdphysics-104.2.4-5.1] startup
[2.990s] [ext: omni.localcache-0.0.0] startup
[2.995s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[2.996s] [ext: omni.kit.widget.imageview-1.0.3] startup
[2.997s] [ext: omni.physx-104.2.4-5.1] startup
[3.028s] [ext: omni.isaac.debug_draw-0.2.3] startup
[3.034s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[3.038s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[3.046s] [ext: omni.graph.examples.cpp-1.4.2] startup
[3.055s] [ext: omni.graph.window.core-1.43.3] startup
[3.065s] [ext: omni.isaac.version-1.0.0] startup
[3.065s] [ext: usdrt.scenegraph-4.3.2] startup
[3.089s] [ext: omni.kit.widgets.custom-1.0.4] startup
[3.110s] [ext: omni.graph.window.action-1.5.5] startup
[3.112s] [ext: omni.graph.nodes-1.48.3] startup
[3.137s] [ext: omni.anim.retarget.core-104.2.1] startup
[3.149s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[3.151s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[3.158s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[3.161s] [ext: omni.anim.graph.core-104.2.1] startup
[3.169s] [ext: omni.kit.browser.core-2.2.2] startup
[3.176s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[3.184s] [ext: omni.curve.creator-104.1.2] startup
[3.190s] [ext: omni.physics.tensors-0.1.0] startup
[3.198s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[3.205s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[3.208s] [ext: omni.scene.visualization.core-104.4.0] startup
[3.263s] [ext: omni.ramp-104.1.3] startup
[3.269s] [ext: omni.kit.window.stage-2.3.12] startup
[3.274s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[3.277s] [ext: omni.genproc.core-104.5.14] startup
[3.304s] [ext: omni.curve.manipulator-104.7.3] startup
[3.320s] [ext: omni.physx.tensors-0.1.0] startup
[3.325s] [ext: omni.command.usd-1.0.2] startup
[3.329s] [ext: omni.kit.browser.sample-1.2.5] startup
[3.332s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[3.341s] [ext: omni.graph.io-1.2.5] startup
[3.348s] [ext: omni.graph.action-1.31.1] startup
[3.359s] [ext: omni.kit.window.cursor-1.1.1] startup
[3.361s] [ext: omni.kit.widget.spinner-1.0.4] startup
[3.363s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[3.364s] [ext: omni.graph.bundle.action-1.3.0] startup
[3.364s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[3.389s] [ext: omni.anim.graph.ui-104.2.0] startup
[3.406s] [ext: omni.isaac.core-1.46.3] startup
[4.213s] [ext: omni.graph.scriptnode-0.10.0] startup
[4.217s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 12.0
Devices:
"cpu" | AMD64 Family 25 Model 68 Stepping 1, AuthenticAMD
"cuda:0" | NVIDIA GeForce RTX 3080 Laptop GPU (sm_86)
Kernel cache: C:\Users\omnit\AppData\Local\NVIDIA Corporation\warp\Cache\0.6.3
[4.448s] [ext: omni.syntheticdata-0.2.4] startup
2023-05-08 21:12:08 [4,413ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[4.471s] [ext: omni.anim.graph.bundle-104.2.0] startup
[4.472s] [ext: omni.isaac.ui-0.8.0] startup
[4.477s] [ext: omni.isaac.lula-1.2.1] startup
[4.505s] [ext: omni.isaac.motion_planning-0.2.2] startup
[4.517s] [ext: omni.replicator.core-1.7.8] startup
2023-05-08 21:12:08 [4,574ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[4.684s] [ext: omni.isaac.utils-0.2.4] startup
[4.690s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[4.698s] [ext: omni.isaac.motion_generation-4.5.6] startup
[4.707s] [ext: omni.isaac.range_sensor-0.8.1] startup
[4.746s] [ext: omni.isaac.core_nodes-0.23.2] startup
[4.767s] [ext: omni.isaac.demos-0.3.3] startup
[4.784s] [ext: omni.isaac.sensor-5.6.3] startup
[4.801s] [ext: omni.isaac.manipulators-1.1.0] startup
[4.805s] [ext: omni.isaac.quadruped-1.3.0] startup
[5.156s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[5.160s] [ext: omni.isaac.universal_robots-0.3.2] startup
[5.162s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[5.174s] [ext: omni.isaac.franka-0.4.0] startup
[5.176s] [ext: omni.isaac.dofbot-0.3.0] startup
[5.177s] [ext: omni.isaac.diff_usd-1.0.1] startup
[5.179s] [ext: omni.isaac.examples-1.5.6] startup
[7.674s] [ext: omni.activity.pump-1.0.0] startup
[7.678s] [ext: omni.activity.usd_resolver-1.0.1] startup
[7.680s] [ext: omni.anim.skelJoint-104.2.22] startup
[7.683s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[7.689s] [ext: omni.graph.window.generic-1.3.15] startup
[7.692s] [ext: omni.isaac.extension_templates-1.0.0] startup
[7.693s] [ext: omni.activity.ui-1.0.20] startup
[7.704s] [ext: omni.anim.retarget.ui-104.2.0] startup
[7.713s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-05-08 21:12:11 [7,664ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[7.715s] [ext: omni.kit.profiler.window-2.0.5] startup
[7.840s] [ext: omni.isaac.kit-1.4.1] startup
[7.842s] [ext: omni.anim.retarget.bundle-104.2.0] startup
[7.844s] [ext: omni.activity.freeze_monitor-1.0.1] startup
[7.847s] [ext: omni.isaac.merge_mesh-0.1.2] startup
[7.849s] [ext: omni.isaac.mjcf-0.3.1] startup
[7.856s] [ext: omni.isaac.articulation_inspector-0.1.3] startup
[7.859s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[7.871s] [ext: omni.isaac.shapenet-2.0.1] startup
[7.884s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[7.894s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[7.898s] [ext: omni.isaac.synthetic_recorder-1.5.0] startup
[7.902s] [ext: omni.isaac.unit_converter-0.1.6] startup
[7.904s] [ext: omni.kit.widget.calendar-1.0.5] startup
[7.906s] [ext: omni.kit.ngsearch-0.0.10] startup
2023-05-08 21:12:12 [7,880ms] [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
[7.949s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[7.951s] [ext: omni.kit.widget.layers-1.6.11] startup
[7.966s] [ext: omni.kit.menu.stage-1.2.1] startup
[7.967s] [ext: omni.kit.tool.collect-2.1.20] startup
[7.974s] [ext: omni.kit.widget.extended_searchfield-1.0.17] startup
[7.989s] [ext: omni.isaac.urdf-0.5.9] startup
[8.021s] [ext: omni.kit.actions.window-1.1.0] startup
[8.028s] [ext: omni.kit.property.layer-1.1.4] startup
[8.031s] [ext: omni.isaac.window.about-1.1.0] startup
[8.034s] [ext: omni.kit.browser.asset-1.2.3] startup
[8.036s] [ext: omni.kit.browser.deepsearch-1.0.20] startup
[8.042s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[8.045s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[8.052s] [ext: omni.kit.property.audio-1.0.6] startup
[8.055s] [ext: omni.kit.property.camera-1.0.3] startup
[8.056s] [ext: omni.kit.property.geometry-1.2.2] startup
[8.059s] [ext: omni.kit.property.light-1.0.6] startup
[8.061s] [ext: omni.hydra.scene_api-0.1.1] startup
[8.064s] [ext: omni.kit.tool.asset_importer-2.4.0] startup
[8.070s] [ext: omni.kit.property.material-1.8.19] startup
[8.074s] [ext: omni.services.facilities.base-1.0.2] startup
[8.075s] [ext: omni.kit.property.render-1.1.0] startup
[8.077s] [ext: omni.kit.property.skel-1.0.1] startup
[8.079s] [ext: omni.kit.property.transform-1.3.5] startup
[8.084s] [ext: omni.kit.importer.cad-0.3.4] startup
2023-05-08 21:12:12 [8,036ms] [Warning] [omni.ext.plugin] [ext: omni.kit.importer.cad-0.3.4] Native plugin search dir contains several files: c:/users/omnit/appdata/local/ov/pkg/isaac_sim-2022.2.1/extscache/omni.kit.importer.cad-0.3.4+wx64.r.cp37/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[8.104s] [ext: omni.isaac.gain_tuner-0.1.1] startup
[8.106s] [ext: omni.services.core-1.3.0] startup
[8.231s] [ext: omni.anim.curve-104.16.6] startup
[8.245s] [ext: omni.anim.shared-104.14.1] startup
[8.254s] [ext: omni.kit.property.bundle-1.2.6] startup
[8.269s] [ext: omni.services.transport.client.base-1.2.1] startup
[8.272s] [ext: omni.slangnode-104.2.3] startup
[8.283s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[8.288s] [ext: omni.isaac.asset_browser-0.2.4] startup
[8.290s] [ext: omni.anim.timeline-104.0.7] startup
[8.295s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[8.300s] [ext: omni.services.client-0.4.0] startup
[8.302s] [ext: omni.kit.menu.aov-1.1.3] startup
[8.304s] [ext: omni.kit.selection-0.1.0] startup
[8.307s] [ext: omni.flowusd-104.2.4] startup
[8.327s] [ext: omni.services.transport.client.http_async-1.3.2] startup
[8.330s] [ext: omni.kit.core.collection-0.1.1] startup
[8.333s] [ext: omni.kit.menu.edit-1.1.6] startup
[8.337s] [ext: omni.isaac.physics_inspector-0.1.3] startup
[8.341s] [ext: omni.kit.menu.file-1.1.4] startup
[8.343s] [ext: omni.kit.pointclouds-0.0.16] startup
[8.347s] [ext: omni.services.starfleet.auth-0.1.4] startup
[8.355s] [ext: omni.kit.property.collection-0.1.10] startup
[8.357s] [ext: omni.kit.property.isaac-0.2.0] startup
[8.360s] [ext: omni.kit.property.sbsar-0.9.9] startup
[8.364s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[8.367s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[8.369s] [ext: omni.kit.quicksearch.hdri-0.8.11] startup
[8.371s] [ext: omni.kit.quicksearch.material-0.8.10] startup
[8.372s] [ext: semantics.schema.editor-0.3.3] startup
[8.378s] [ext: omni.kit.quicksearch.props-0.8.6] startup
[8.380s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[8.382s] [ext: omni.genproc.ui-104.1.6] startup
[8.386s] [ext: omni.rtx.window.settings-0.6.2] startup
[8.395s] [ext: omni.services.transport.server.base-1.1.0] startup
[8.397s] [ext: omni.kit.scripting-104.2.2] startup
2023-05-08 21:12:12 [8,347ms] [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] 'c:/users/omnit/appdata/local/ov/pkg/isaac_sim-2022.2.1/extscache/omni.kit.scripting-104.2.2+104.2.wx64.r.cp37/bin' in '[[native.plugin]]' was not found.
[8.404s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[8.406s] [ext: omni.isaac.physics_utilities-0.1.1] startup
[8.412s] [ext: omni.genproc.bundle-104.0.1] startup
[8.412s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[8.412s] [ext: omni.kit.agent-0.1.5] startup
[8.414s] [ext: omni.services.transport.server.http-1.1.2] startup
[8.486s] [ext: omni.kit.search.files-1.0.4] startup
[8.490s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[8.495s] [ext: omni.kit.thumbnails.mdl-1.0.20] startup
[8.500s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[8.502s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[8.506s] [ext: omni.kit.thumbnails.usd-0.5.2] startup
[8.509s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[8.511s] [ext: omni.kit.browser.material-1.3.3] startup
[8.514s] [ext: omni.kit.window.material_graph-1.6.15] startup
[8.526s] [ext: omni.kit.window.toolbar-1.4.0] startup
[8.530s] [ext: omni.kit.tool.asset_exporter-1.2.0] startup
[8.535s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[8.538s] [ext: omni.physx.commands-104.2.4-5.1] startup
[8.543s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[8.543s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[8.545s] [ext: omni.kit.window.material-1.1.3] startup
[8.553s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[8.559s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[8.560s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[8.567s] [ext: omni.physx.ui-104.2.4-5.1] startup
[8.595s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[8.599s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[8.604s] [ext: omni.kit.tool.remove_unused.controller-0.1.2] startup
[8.607s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[8.608s] [ext: omni.kit.usda_edit-1.1.10] startup
[8.618s] [ext: omni.kit.viewport.actions-104.0.3] startup
[8.621s] [ext: omni.kit.property.physx-0.1.0] startup
[8.634s] [ext: omni.physx.demos-104.2.4-5.1] startup
[8.639s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[8.639s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[8.644s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[8.644s] [ext: omni.kit.viewport.ready-1.0.2] startup
[8.645s] [ext: omni.kit.viewport_widgets_manager-1.0.6] startup
[8.648s] [ext: omni.kit.widget.live-2.0.3] startup
[8.652s] [ext: omni.physx.camera-104.2.4-5.1] startup
[8.661s] [ext: omni.physx.cct-104.2.4-5.1] startup
[8.671s] [ext: omni.kit.mesh.raycast-104.3.2] startup
[8.678s] [ext: omni.kit.widget.collection-0.1.11] startup
[8.681s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[8.698s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[8.713s] [ext: omni.kit.search.service-0.1.5] startup
[8.721s] [ext: omni.isaac.robot_description_editor-2.1.1] startup
[8.724s] [ext: omni.videoencoding-0.1.0] startup
[8.730s] [ext: omni.paint.system.core-104.5.8] startup
[8.821s] [ext: omni.kit.window.collection-0.1.11] startup
[8.824s] [ext: omni.kit.window.commands-0.2.4] startup
[8.827s] [ext: omni.iray.settings.core-0.6.4] startup
[8.833s] [ext: omni.kit.sequencer.usd-103.3.1] startup
[8.838s] [ext: omni.kit.capture.viewport-1.1.24] startup
[8.843s] [ext: omni.paint.system.ui-104.3.14] startup
[8.854s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[8.854s] [ext: omni.physx.zerogravity-104.2.4-5.1] startup
[8.866s] [ext: omni.rtx.settings.core-0.5.8] startup
[8.877s] [ext: omni.kit.preferences.time-0.2.0] startup
[8.881s] [ext: omni.kit.property.sequence-0.2.0] startup
[8.884s] [ext: omni.kit.sequencer.core-103.3.0] startup
[8.888s] [ext: omni.kit.window.console-0.2.3] startup
[8.897s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[8.902s] [ext: omni.paint.brush.scatter-104.2.12] startup
[8.911s] [ext: omni.kit.window.movie_capture-2.1.8] startup
[8.919s] [ext: omni.kit.window.privacy-0.1.0] startup
[8.921s] [ext: omni.kit.window.script_editor-1.7.2] startup
[8.925s] [ext: omni.kit.window.sequencer-103.3.4] startup
[8.960s] [ext: omni.particle.system.core-104.7.19] startup
[8.976s] [ext: omni.paint.brush.attributes-1.1.2] startup
[8.982s] [ext: omni.paint.brush.modify-104.3.2] startup
[8.989s] [ext: omni.paint.brush.scripting-104.7.0] startup
[9.000s] [ext: omni.paint.brush.select-104.3.2] startup
[9.011s] [ext: omni.scene.optimizer.core-104.1.5] startup
[9.017s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.2] startup
[9.035s] [ext: omni.graph.window.particle.system-104.5.3] startup
[9.040s] [ext: omni.particle.system.ui-104.5.1] startup
[9.052s] [ext: omni.kit.window.status_bar-0.1.5] startup
[9.056s] [ext: omni.kit.window.usd_paths-1.0.4] startup
[9.059s] [ext: omni.paint.system.bundle-104.8.26] startup
[9.060s] [ext: omni.scene.optimizer.ui-104.1.5] startup
[9.063s] [ext: omni.scene.visualization.ui-104.0.6] startup
[9.067s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load ...
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[9.070s] [ext: omni.particle.system.bundle-104.2.24] startup
[9.071s] [ext: omni.replicator.composer-1.2.10] startup
[9.078s] [ext: omni.replicator.isaac-1.7.4] startup
[9.100s] [ext: omni.resourcemonitor-1.0.0] startup
[9.107s] [ext: omni.scene.optimizer.bundle-104.1.5] startup
[9.107s] [ext: omni.scene.visualization.bundle-104.0.1] startup
[9.108s] [ext: omni.kit.stage.mdl_converter-1.0.1] startup
[9.111s] [ext: omni.services.usd-1.1.0] startup
[9.115s] [ext: omni.tools.array-104.0.12] startup
[9.125s] [ext: omni.tools.pivot-104.1.0] startup
[9.135s] [ext: omni.kit.widget.timeline-104.0.3] startup
[9.139s] [ext: omni.tools.randomizer-104.0.9] startup
[9.146s] [ext: omni.kit.quicklayout-1.1.1] startup
[9.149s] [ext: omni.kit.window.title-1.1.2] startup
[9.151s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[9.153s] [ext: omni.isaac.scene_blox-0.1.0] startup
[9.154s] [ext: omni.isaac.cortex-0.3.2] startup
[9.155s] [ext: omni.anim.curve_editor-104.12.7] startup
[9.178s] [ext: omni.isaac.onshape-0.6.2] startup
[9.809s] [ext: omni.kit.window.stats-0.1.2] startup
[9.812s] [ext: omni.isaac.app.setup-0.8.1] startup
[9.817s] Isaac Sim Version: 2022.2.1-rc.14
[9.818s] [ext: omni.isaac.assets_check-0.3.2] startup
[9.820s] [ext: omni.isaac.sim.base-2022.2.1] startup
[9.821s] [ext: omni.isaac.sim-2022.2.1] startup
[10.441s] app ready
2023-05-08 21:12:16 [12,620ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/database/DirtyPageCopy.compute.hlsl'.
2023-05-08 21:12:16 [12,621ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/database/DirtyElementsCopy.compute.hlsl'.
2023-05-08 21:12:16 [12,621ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/database/DirtyPageCopy.compute.hlsl
2023-05-08 21:12:16 [12,621ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/database/DirtyElementsCopy.compute.hlsl
2023-05-08 21:12:16 [12,622ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,658ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/SparseMemCopy.compute.hlsl'.
2023-05-08 21:12:16 [12,659ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/utils/PrefixScanBuffer.compute.hlsl'.
2023-05-08 21:12:16 [12,659ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/utils/PrefixScanTexture.compute.hlsl'.
2023-05-08 21:12:16 [12,659ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SparseMemCopy.compute.hlsl
2023-05-08 21:12:16 [12,659ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2023-05-08 21:12:16 [12,660ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanBuffer.compute.hlsl
2023-05-08 21:12:16 [12,660ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl'.
2023-05-08 21:12:16 [12,660ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl'.
2023-05-08 21:12:16 [12,660ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2023-05-08 21:12:16 [12,661ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/utils/PrefixScanTexture.compute.hlsl
2023-05-08 21:12:16 [12,661ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,661ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl'.
2023-05-08 21:12:16 [12,662ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl'.
2023-05-08 21:12:16 [12,662ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,662ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2023-05-08 21:12:16 [12,663ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2023-05-08 21:12:16 [12,663ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2023-05-08 21:12:16 [12,664ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLong.compute.hlsl
2023-05-08 21:12:16 [12,664ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,665ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/filters/LowPass.cs.hlsl'.
2023-05-08 21:12:16 [12,665ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,666ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl'.
2023-05-08 21:12:16 [12,666ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingLatLongConversion.compute.hlsl
2023-05-08 21:12:16 [12,666ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,667ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl'.
2023-05-08 21:12:16 [12,667ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,668ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,668ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl'.
2023-05-08 21:12:16 [12,670ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,672ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/TranslateInstancePosition.compute.hlsl'.
2023-05-08 21:12:16 [12,673ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,674ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/ValidateSbt.compute.hlsl'.
2023-05-08 21:12:16 [12,675ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/filters/LowPass.cs.hlsl
2023-05-08 21:12:16 [12,675ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,675ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl
2023-05-08 21:12:16 [12,676ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,677ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl
2023-05-08 21:12:16 [12,677ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,678ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lighting/EnvironmentPreprocessingApproxIBL.cs.hlsl
2023-05-08 21:12:16 [12,678ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,678ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/TranslateInstancePosition.compute.hlsl
2023-05-08 21:12:16 [12,679ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,679ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/ValidateSbt.compute.hlsl
2023-05-08 21:12:16 [12,682ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,683ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,685ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,686ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,687ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:16 [12,688ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:17 [12,729ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/ProceduralAabb.comp.hlsl'.
2023-05-08 21:12:17 [12,730ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/ProceduralAabb.comp.hlsl
2023-05-08 21:12:17 [12,731ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:17 [12,731ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/Skinning.comp.hlsl'.
2023-05-08 21:12:17 [12,732ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/Skinning.comp.hlsl
2023-05-08 21:12:17 [12,732ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/SkinNormal.comp.hlsl'.
2023-05-08 21:12:17 [12,732ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:17 [12,732ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/SkinNormal.comp.hlsl
2023-05-08 21:12:17 [12,732ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/NormalGeneration.comp.hlsl'.
2023-05-08 21:12:17 [12,733ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:17 [12,733ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/NormalGeneration.comp.hlsl
2023-05-08 21:12:17 [12,733ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/scenedb/VertexPulling.comp.hlsl'.
2023-05-08 21:12:17 [12,734ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/scenedb/VertexPulling.comp.hlsl
2023-05-08 21:12:17 [12,734ms] [Error] [gpu.foundation.plugin] PsoCompute::createPipeline and shader loading failed. RtxResult: 3
2023-05-08 21:12:17 [13,374ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/rasterizing/Line.geometry.hlsl'.
2023-05-08 21:12:17 [13,374ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/rasterizing/Line.vertex.hlsl'.
2023-05-08 21:12:17 [13,374ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/rasterizing/Point.geometry.hlsl'.
2023-05-08 21:12:17 [13,374ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/rasterizing/Line.pixel.hlsl'.
2023-05-08 21:12:17 [13,374ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/rasterizing/Point.pixel.hlsl'.
2023-05-08 21:12:17 [13,375ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.geometry.hlsl
2023-05-08 21:12:17 [13,375ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.vertex.hlsl
2023-05-08 21:12:17 [13,378ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.geometry.hlsl
2023-05-08 21:12:17 [13,378ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.vertex.hlsl
2023-05-08 21:12:17 [13,378ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.geometry.hlsl
2023-05-08 21:12:17 [13,378ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Line.pixel.hlsl
2023-05-08 21:12:17 [13,380ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/rasterizing/Point.pixel.hlsl
2023-05-08 21:12:17 [13,380ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/system/GenerateMipMap.comp.hlsl'.
2023-05-08 21:12:17 [13,381ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,381ms] [Error] [gpu.foundation.plugin] Failed to async compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,391ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,393ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,394ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,397ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,398ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,399ms] [Error] [gpu.foundation.plugin] Failed to compile compute shader: rtx/system/GenerateMipMap.comp.hlsl
2023-05-08 21:12:17 [13,426ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/raytracing/SimpleMiss.ms.hlsl'.
2023-05-08 21:12:17 [13,426ms] [Error] [gpu.foundation.plugin] Cannot load shader file 'rtx/lightspeed/ReLAX/PackInputData.cs.hlsl'.
2023-05-08 21:12:17 [13,427ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/raytracing/SimpleMiss.ms.hlsl
2023-05-08 21:12:17 [13,427ms] [Error] [gpu.foundation.plugin] buildShaderAsync() failed: rtx/lightspeed/ReLAX/PackInputData.cs.hlsl
2023-05-08 21:12:17 [13,428ms] [Error] [rtx.denoising.plugin] Failed to async compile compute shader: rtx/lightspeed/ReLAX/PackInputData.cs.hlsl
2023-05-08 21:12:17 [13,428ms] [Error] [carb.scenerenderer-rtx.plugin] Failed to create context for rtx::denoising
2023-05-08 21:12:17 [13,444ms] [Warning] [omni.hydra.rtx] HydraEngine rtx failed creating scene renderer.
