Isaac Sim does not function on RTX 4070 Laptop GPU
Isaac Sim Version
4.2.0.2 (Client Challenge)
Running on Python 3.10.15
Operating System
Windows 11
GPU Information
Model: NVIDIA RTX 4070 Laptop GPU
Driver: GeForce Game Ready Driver 566.14 (Release Date: 11/12/2024)
anchu@AK ~ > nvidia-smi
NVIDIA-SMI 566.14 Driver Version: 566.14 CUDA Version: 12.7
anchu@AK ~ > nvcc --version
Copyright (c) 2005-2024 NVIDIA Corporation
Built on Thu_Mar_28_02:30:10_Pacific_Daylight_Time_2024
Cuda compilation tools, release 12.4, V12.4.131
Build cuda_12.4.r12.4/compiler.34097967_0
Topic Description
Detailed Description
I am attempting to run a standalone Python script for Isaac Sim using SimulationApp. However, I encounter several errors upon execution. The IsaacSim application itself starts, but the rendering window is completely black and inaccessible.
Steps to Reproduce
Run a script similar to the following:
from isaacsim import SimulationApp
simulation_app = SimulationApp({
    "headless": False,
    "multi_gpu": False,
    "active_gpu": 0
simulation_app.close()
Error Messages
Terminal:
2024-11-13 20:23:40 [6,797ms] [Error] [carb.graphics-vulkan.plugin] Flags 0x6 must be the same for both device and instance.
2024-11-13 20:30:05 [22,323ms] [Error] [gpu.foundation.plugin] Raytracing is not supported on GPU: 0. Hardware, driver or Operating system upgrade is required.
2024-11-13 20:30:05 [22,323ms] [Error] [carb.scenerenderer-rtx.plugin] rtx driver verification failed.
Application:
HydraEngine rtx failed creating scene renderer.
Full terminal output:
Screenshots or Videos
Additional Information
IsaacSim works as expected from the NVIDIA Omniverse Launcher.
Related Issues
Please try the recommended driver version stated in the documentation.
Also, do any of the examples under standalone_examples run successfully? Could you share nvidia-smi and the compatilibity cheker output?
Tue Nov 26 13:16:57 2024
| NVIDIA-SMI 566.14                 Driver Version: 566.14         CUDA Version: 12.7     |
| GPU  Name                  Driver-Model | Bus-Id          Disp.A | Volatile Uncorr. ECC |
|   0  NVIDIA GeForce RTX 4070 ...  WDDM  |   00000000:01:00.0 Off |                  N/A |
| N/A   48C    P8             11W /  100W |     779MiB /   8188MiB |     12%      Default |
|                                         |                        |                  N/A |
This Solution doesn’t work for me . I have the same Issue with Driver Version 566.14 on Win 11. I downgrade my Driver to 566.03 as recommended in the documentation, but the Error still there.
I have also downgraded the driver to 566.03 as recommended and the error persists. I do not recall marking the suggestion as the solution, and I am still facing the same problem.
The Win11 output shows that there are two graphics cards, one of which seems to be virtual. I don’t know if this is the cause of the problem. After trying for a long time ,I gave up Win11 and turn to Ubuntu 22.04, and everything is working now.
Please see if Linux Troubleshooting — Omniverse Developer Guide is helpful.
After attempting to debug this issue for ~2 months, I gave up and dual-booted my laptop with Ubuntu 22.04, where it instantly began functioning as intended. Ubuntu 22.04 is necessary for other programs I plan to use concurrently, so yay! The Linux Troubleshooting guide provides no guidance on this problem, and I am still unsure of the cause.
It’s great to hear that you can move forward. I will discuss this with our team and get back to you with any updates.
