Cant run Isaac sim
Loading user config located at: ‘F:/Omniverse/data path/Kit/Isaac-Sim/2022.2/user.config.json’
[Info] [carb] Logging to file: C:/Users/Lukianovici/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20231005_134543.log
[0.189s] [ext: omni.stats-0.0.0] startup
[0.276s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.304s] [ext: omni.assets.plugins-0.0.0] startup
[0.307s] [ext: omni.gpu_foundation-0.0.0] startup
[0.321s] [ext: carb.windowing.plugins-1.0.0] startup
2023-10-05 10:45:43 [475ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored): vJoy Device [0300000034120000adbe000000000000]
[0.517s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-10-05 10:45:43 [588ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-RTX GPU: NVIDIA GeForce GTX 980 Ti
| Driver Version: 537.42 | Graphics API: D3D12
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce GTX 980 Ti | | | 6092 MB | 10de | c02f0000… |
| | | | | | 17c8 | 0 |
| OS: Windows, Version: 10.0, Build: 19045
| Processor: AMD Ryzen 5 5600X 6-Core Processor | Cores: 6 | Logical: 12
| Total Memory (MB): 32694 | Free Memory: 24067
| Total Page/Swap (MB): 37558 | Free Page/Swap: 25351
2023-10-05 10:45:43 [589ms] [Error] [gpu.foundation.plugin] No device could be created. Some known system issues:
  • The driver is not installed properly and requires a clean re-install.
  • Your GPUs do not support RayTracing: DXR or Vulkan ray_tracing, or hardware is excluded due to performance.
  • The driver cannot enumerate any GPU: driver, display, TCC mode or a docker issue. For Vulkan, test it with Vulkaninfo tool from Vulkan SDK, instead of nvidia-smi.
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce GTX 980 Ti | Yes: 0 | | 6092 MB | 10de | c02f0000… |
| | | | | | 17c8 | 0 |
2023-10-05 10:45:43 [694ms] [Warning] [omni.gpu_foundation_factory.plugin] RT-capable GPU not found, switching to compatibility mode
[0.748s] [ext: omni.kit.pipapi-0.0.0] startup
[0.776s] [ext: omni.usd.config-1.0.0] startup
[0.784s] [ext: omni.usd.libs-1.0.0] startup
[0.957s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.962s] [ext: omni.kit.async_engine-0.0.0] startup
[0.964s] [ext: omni.kit.loop-default-0.1.1] startup
[0.965s] [ext: omni.kit.test-0.0.0] startup
[1.010s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.044s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.051s] [ext: omni.client-0.1.1] startup
[1.061s] [ext: omni.iray.libs-0.0.0] startup
[1.075s] [ext: omni.volume-0.1.0] startup
[1.078s] [ext: omni.usd.core-1.0.4] startup
[1.078s] [ext: omni.mdl.neuraylib-0.1.0] startup
[1.083s] [ext: omni.hydra.rtx-0.1.0] startup
[1.093s] [ext: omni.hydra.iray-0.1.0] startup
[1.094s] [ext: omni.isaac.core_archive-2.0.1] startup
[1.180s] [ext: omni.services.pip_archive-0.4.2] startup
[1.184s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[1.187s] [ext: omni.isaac.ml_archive-1.1.0] startup
2023-10-05 10:45:44 [1,213ms] [Warning] [omni.ext._impl.internal] There is already a module ‘gym’ in 'f:\omniverse\library path\isaac_sim-2022.2.1\kit\python\lib\site-packages\gym_init.py’. Can’t import another module with the same name in public space from ‘f:\omniverse\library path\isaac_sim-2022.2.1\exts\omni.isaac.ml_archive\pip_prebundle’.
[1.256s] [ext: omni.appwindow-1.0.1] startup
[1.263s] [ext: omni.kit.renderer.core-0.0.0] startup
[1.296s] [ext: omni.kit.renderer.capture-0.0.0] startup
[1.300s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[1.355s] [ext: omni.ui-2.14.4] startup
[1.366s] [ext: carb.audio-0.1.0] startup
[1.366s] [ext: omni.uiaudio-1.0.0] startup
[1.368s] [ext: omni.kit.mainwindow-1.0.0] startup
[1.370s] [ext: omni.kit.uiapp-0.0.0] startup
[1.370s] [ext: omni.usd.schema.physics-1.0.0] startup
[1.379s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.440s] [ext: omni.usd.schema.isaac-1.1.0] startup
[1.454s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[1.457s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.480s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[1.488s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.495s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.502s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.511s] [ext: omni.kit.actions.core-1.0.0] startup
[1.515s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[1.517s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.518s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[1.528s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[1.533s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[1.539s] [ext: omni.timeline-1.0.5] startup
[1.541s] [ext: omni.kit.commands-1.4.5] startup
[1.547s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[1.549s] [ext: omni.usd-1.6.30] startup
[1.585s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[1.586s] [ext: omni.usd.schema.destruction-0.4.0] startup
[1.594s] [ext: omni.kit.asset_converter-1.3.4] startup
[1.601s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[1.640s] [ext: omni.usd.schema.sequence-2.2.1] startup
[1.648s] [ext: omni.usd.schema.flow-104.1.6] startup
[1.649s] [ext: omni.inspect-1.0.1] startup
[1.651s] [ext: omni.kit.widget.path_field-2.0.4] startup
[1.653s] [ext: omni.debugdraw-0.1.1] startup
[1.656s] [ext: omni.kit.notification_manager-1.0.5] startup
[1.660s] [ext: omni.graph.core-2.65.4] startup
[1.662s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[1.663s] [ext: omni.kit.widget.versioning-1.3.8] startup
[1.667s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[1.679s] [ext: omni.kit.search_core-1.0.2] startup
[1.681s] [ext: omni.hydra.pxr-1.1.2] startup
[1.685s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[1.688s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[1.735s] [ext: omni.kit.menu.utils-1.4.7] startup
[1.745s] [ext: omni.kit.usd.layers-2.0.11] startup
[1.753s] [ext: omni.mdl-0.1.0] startup
[1.769s] [ext: omni.kit.window.file_importer-1.0.10] startup
[1.771s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[1.772s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[1.777s] [ext: omni.kit.material.library-1.3.21] startup
[1.785s] [ext: omni.kit.clipboard-1.0.0] startup
[1.785s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[1.786s] [ext: omni.kit.stage_templates-1.1.13] startup
[1.789s] [ext: omni.kit.menu.create-1.0.8] startup
[1.791s] [ext: omni.ui_query-1.1.1] startup
[1.792s] [ext: omni.kit.context_menu-1.5.12] startup
[1.796s] [ext: omni.activity.core-1.0.1] startup
[1.802s] [ext: omni.kit.window.file-1.3.32] startup
[1.805s] [ext: omni.kit.window.drop_support-1.0.1] startup
[1.806s] [ext: omni.kit.ui_test-1.2.9] startup
[1.809s] [ext: omni.kit.widget.stage-2.7.24] startup
[1.815s] [ext: omni.kit.window.property-1.8.2] startup
[1.818s] [ext: omni.kit.window.content_browser-2.6.8] startup
[1.829s] [ext: omni.kit.usd_undo-0.1.2] startup
[1.830s] [ext: omni.graph.tools-1.17.2] startup
[1.855s] [ext: omni.hydra.engine.stats-1.0.0] startup
[1.856s] [ext: omni.kit.property.usd-3.18.17] startup
[1.868s] [ext: omni.graph-1.50.2] startup
[1.913s] [ext: omni.kit.hydra_texture-1.0.11] startup
[1.917s] [ext: omni.kit.viewport.registry-104.0.2] startup
[1.921s] [ext: omni.ui.scene-1.5.18] startup
[1.927s] [ext: omni.kit.widget.viewport-104.1.16] startup
[1.930s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[1.932s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[1.935s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[1.967s] [ext: omni.kit.viewport.window-104.1.23] startup
[1.988s] [ext: omni.kit.widget.prompt-1.0.5] startup
[1.989s] [ext: omni.kit.window.extensions-1.1.1] startup
[1.995s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[1.998s] [ext: omni.kit.viewport.utility-1.0.14] startup
[1.999s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[2.002s] [ext: omni.kit.widget.settings-1.0.1] startup
[2.004s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[2.006s] [ext: omni.kit.window.preferences-1.3.8] startup
[2.033s] [ext: omni.graph.ui-1.24.2] startup
[2.072s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[2.075s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[2.079s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.082s] [ext: omni.kvdb-0.0.0] startup
[2.086s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[2.087s] [ext: omni.usdphysics-104.2.4-5.1] startup
[2.088s] [ext: omni.localcache-0.0.0] startup
[2.091s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[2.093s] [ext: omni.kit.widget.imageview-1.0.3] startup
[2.094s] [ext: omni.physx-104.2.4-5.1] startup
[2.124s] [ext: omni.isaac.debug_draw-0.2.3] startup
[2.128s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[2.132s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[2.139s] [ext: omni.graph.examples.cpp-1.4.2] startup
[2.145s] [ext: omni.graph.window.core-1.43.3] startup
[2.155s] [ext: omni.isaac.version-1.0.0] startup
[2.156s] [ext: usdrt.scenegraph-4.3.2] startup
[2.174s] [ext: omni.kit.widgets.custom-1.0.4] startup
[2.192s] [ext: omni.graph.window.action-1.5.5] startup
[2.194s] [ext: omni.graph.nodes-1.48.3] startup
[2.216s] [ext: omni.anim.retarget.core-104.2.1] startup
[2.227s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[2.228s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[2.235s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[2.237s] [ext: omni.anim.graph.core-104.2.1] startup
[2.243s] [ext: omni.kit.browser.core-2.2.2] startup
[2.251s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[2.257s] [ext: omni.curve.creator-104.1.2] startup
[2.262s] [ext: omni.physics.tensors-0.1.0] startup
[2.269s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[2.276s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[2.278s] [ext: omni.scene.visualization.core-104.4.0] startup
[2.314s] [ext: omni.ramp-104.1.3] startup
[2.318s] [ext: omni.kit.window.stage-2.3.12] startup
[2.322s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[2.325s] [ext: omni.genproc.core-104.5.14] startup
[2.348s] [ext: omni.curve.manipulator-104.7.3] startup
[2.363s] [ext: omni.physx.tensors-0.1.0] startup
[2.409s] [ext: omni.command.usd-1.0.2] startup
[2.413s] [ext: omni.kit.browser.sample-1.2.5] startup
[2.415s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[2.423s] [ext: omni.graph.io-1.2.5] startup
[2.429s] [ext: omni.graph.action-1.31.1] startup
[2.438s] [ext: omni.kit.window.cursor-1.1.1] startup
[2.440s] [ext: omni.kit.widget.spinner-1.0.4] startup
[2.442s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[2.443s] [ext: omni.graph.bundle.action-1.3.0] startup
[2.443s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[2.466s] [ext: omni.anim.graph.ui-104.2.0] startup
[2.482s] [ext: omni.isaac.core-1.46.3] startup
[3.243s] [ext: omni.graph.scriptnode-0.10.0] startup
[3.247s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 12.2
Devices:
“cpu” | AMD64 Family 25 Model 33 Stepping 2, AuthenticAMD
“cuda:0” | NVIDIA GeForce GTX 980 Ti (sm_52)
Kernel cache: C:\Users\Lukianovici\AppData\Local\NVIDIA Corporation\warp\Cache\0.6.3
[3.464s] [ext: omni.syntheticdata-0.2.4] startup
2023-10-05 10:45:46 [3,435ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[3.484s] [ext: omni.anim.graph.bundle-104.2.0] startup
[3.485s] [ext: omni.isaac.ui-0.8.0] startup
[3.489s] [ext: omni.isaac.lula-1.2.1] startup
[3.521s] [ext: omni.isaac.motion_planning-0.2.2] startup
[3.530s] [ext: omni.replicator.core-1.7.8] startup
2023-10-05 10:45:46 [3,580ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[3.678s] [ext: omni.isaac.utils-0.2.4] startup
[3.683s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[3.690s] [ext: omni.isaac.motion_generation-4.5.6] startup
[3.698s] [ext: omni.isaac.range_sensor-0.8.1] startup
[3.734s] [ext: omni.isaac.core_nodes-0.23.2] startup
[3.750s] [ext: omni.isaac.demos-0.3.3] startup
[3.767s] [ext: omni.isaac.sensor-5.6.3] startup
[3.782s] [ext: omni.isaac.manipulators-1.1.0] startup
[3.784s] [ext: omni.isaac.quadruped-1.3.0] startup
[4.091s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[4.094s] [ext: omni.isaac.universal_robots-0.3.2] startup
[4.096s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[4.107s] [ext: omni.isaac.franka-0.4.0] startup
[4.109s] [ext: omni.isaac.dofbot-0.3.0] startup
[4.110s] [ext: omni.isaac.diff_usd-1.0.1] startup
[4.112s] [ext: omni.isaac.examples-1.5.6] startup
2023-10-05 10:45:49 [6,205ms] [Warning] [omni.client.plugin] Tick: authentication: Discovery(ws://localhost:3333): Auth/Credentials service not found!
2023-10-05 10:45:49 [6,207ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
[6.336s] [ext: omni.activity.pump-1.0.0] startup
[6.338s] [ext: omni.activity.usd_resolver-1.0.1] startup
[6.340s] [ext: omni.anim.skelJoint-104.2.22] startup
[6.342s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[6.347s] [ext: omni.graph.window.generic-1.3.15] startup
[6.349s] [ext: omni.isaac.extension_templates-1.0.0] startup
[6.351s] [ext: omni.activity.ui-1.0.20] startup
[6.359s] [ext: omni.anim.retarget.ui-104.2.0] startup
[6.367s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-10-05 10:45:49 [6,326ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[6.368s] [ext: omni.kit.profiler.window-2.0.5] startup
[6.503s] [ext: omni.isaac.kit-1.4.1] startup
[6.504s] [ext: omni.anim.retarget.bundle-104.2.0] startup
[6.505s] [ext: omni.activity.freeze_monitor-1.0.1] startup
[6.507s] [ext: omni.isaac.merge_mesh-0.1.2] startup
[6.509s] [ext: omni.isaac.mjcf-0.3.1] startup
[6.514s] [ext: omni.isaac.articulation_inspector-0.1.3] startup
[6.516s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[6.527s] [ext: omni.isaac.shapenet-2.0.1] startup
[6.537s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[6.547s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[6.550s] [ext: omni.isaac.synthetic_recorder-1.5.0] startup
[6.554s] [ext: omni.isaac.unit_converter-0.1.6] startup
[6.555s] [ext: omni.kit.widget.calendar-1.0.5] startup
[6.557s] [ext: omni.kit.ngsearch-0.0.10] startup
2023-10-05 10:45:49 [6,537ms] [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
[6.597s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[6.598s] [ext: omni.kit.widget.layers-1.6.11] startup
[6.611s] [ext: omni.kit.menu.stage-1.2.1] startup
[6.613s] [ext: omni.kit.tool.collect-2.1.20] startup
[6.619s] [ext: omni.kit.widget.extended_searchfield-1.0.17] startup
[6.632s] [ext: omni.isaac.urdf-0.5.9] startup
[6.661s] [ext: omni.kit.actions.window-1.1.0] startup
[6.667s] [ext: omni.kit.property.layer-1.1.4] startup
[6.669s] [ext: omni.isaac.window.about-1.1.0] startup
[6.671s] [ext: omni.kit.browser.asset-1.2.3] startup
[6.674s] [ext: omni.kit.browser.deepsearch-1.0.20] startup
[6.679s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[6.682s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[6.690s] [ext: omni.kit.property.audio-1.0.6] startup
[6.692s] [ext: omni.kit.property.camera-1.0.3] startup
[6.693s] [ext: omni.kit.property.geometry-1.2.2] startup
[6.696s] [ext: omni.kit.property.light-1.0.6] startup
[6.698s] [ext: omni.hydra.scene_api-0.1.1] startup
[6.700s] [ext: omni.kit.tool.asset_importer-2.4.0] startup
[6.705s] [ext: omni.kit.property.material-1.8.19] startup
[6.709s] [ext: omni.services.facilities.base-1.0.2] startup
[6.711s] [ext: omni.kit.property.render-1.1.0] startup
[6.712s] [ext: omni.kit.property.skel-1.0.1] startup
[6.714s] [ext: omni.kit.property.transform-1.3.5] startup
[6.718s] [ext: omni.kit.importer.cad-0.3.4] startup
2023-10-05 10:45:49 [6,677ms] [Warning] [omni.ext.plugin] [ext: omni.kit.importer.cad-0.3.4] Native plugin search dir contains several files: f:/omniverse/library path/isaac_sim-2022.2.1/extscache/omni.kit.importer.cad-0.3.4+wx64.r.cp37/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[6.734s] [ext: omni.isaac.gain_tuner-0.1.1] startup
[6.736s] [ext: omni.services.core-1.3.0] startup
[6.840s] [ext: omni.anim.curve-104.16.6] startup
[6.851s] [ext: omni.anim.shared-104.14.1] startup
[6.858s] [ext: omni.kit.property.bundle-1.2.6] startup
[6.860s] [ext: omni.services.transport.client.base-1.2.1] startup
[6.863s] [ext: omni.slangnode-104.2.3] startup
[6.871s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[6.875s] [ext: omni.isaac.asset_browser-0.2.4] startup
[6.877s] [ext: omni.anim.timeline-104.0.7] startup
[6.881s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[6.886s] [ext: omni.services.client-0.4.0] startup
[6.888s] [ext: omni.kit.menu.aov-1.1.3] startup
[6.890s] [ext: omni.kit.selection-0.1.0] startup
[6.892s] [ext: omni.flowusd-104.2.4] startup
[6.909s] [ext: omni.services.transport.client.http_async-1.3.2] startup
[6.911s] [ext: omni.kit.core.collection-0.1.1] startup
[6.914s] [ext: omni.kit.menu.edit-1.1.6] startup
[6.917s] [ext: omni.isaac.physics_inspector-0.1.3] startup
[6.920s] [ext: omni.kit.menu.file-1.1.4] startup
[6.922s] [ext: omni.kit.pointclouds-0.0.16] startup
[6.925s] [ext: omni.services.starfleet.auth-0.1.4] startup
[6.932s] [ext: omni.kit.property.collection-0.1.10] startup
[6.934s] [ext: omni.kit.property.isaac-0.2.0] startup
[6.936s] [ext: omni.kit.property.sbsar-0.9.9] startup
[6.939s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[6.941s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[6.943s] [ext: omni.kit.quicksearch.hdri-0.8.11] startup
[6.945s] [ext: omni.kit.quicksearch.material-0.8.10] startup
[6.946s] [ext: semantics.schema.editor-0.3.3] startup
[6.951s] [ext: omni.kit.quicksearch.props-0.8.6] startup
[6.953s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[6.954s] [ext: omni.genproc.ui-104.1.6] startup
[6.958s] [ext: omni.rtx.window.settings-0.6.2] startup
[6.965s] [ext: omni.services.transport.server.base-1.1.0] startup
[6.967s] [ext: omni.kit.scripting-104.2.2] startup
2023-10-05 10:45:50 [6,925ms] [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] ‘f:/omniverse/library path/isaac_sim-2022.2.1/extscache/omni.kit.scripting-104.2.2+104.2.wx64.r.cp37/bin’ in ‘[[native.plugin]]’ was not found.
[6.973s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[6.974s] [ext: omni.isaac.physics_utilities-0.1.1] startup
[6.979s] [ext: omni.genproc.bundle-104.0.1] startup
[6.979s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[6.980s] [ext: omni.kit.agent-0.1.5] startup
[6.981s] [ext: omni.services.transport.server.http-1.1.2] startup
[7.049s] [ext: omni.kit.search.files-1.0.4] startup
[7.052s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[7.056s] [ext: omni.kit.thumbnails.mdl-1.0.20] startup
[7.060s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[7.062s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[7.065s] [ext: omni.kit.thumbnails.usd-0.5.2] startup
[7.068s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[7.070s] [ext: omni.kit.browser.material-1.3.3] startup
[7.072s] [ext: omni.kit.window.material_graph-1.6.15] startup
[7.083s] [ext: omni.kit.window.toolbar-1.4.0] startup
[7.086s] [ext: omni.kit.tool.asset_exporter-1.2.0] startup
[7.090s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[7.092s] [ext: omni.physx.commands-104.2.4-5.1] startup
[7.097s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[7.097s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[7.099s] [ext: omni.kit.window.material-1.1.3] startup
[7.105s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[7.110s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[7.111s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[7.116s] [ext: omni.physx.ui-104.2.4-5.1] startup
[7.142s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[7.145s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[7.149s] [ext: omni.kit.tool.remove_unused.controller-0.1.2] startup
[7.151s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[7.153s] [ext: omni.kit.usda_edit-1.1.10] startup
[7.166s] [ext: omni.kit.viewport.actions-104.0.3] startup
[7.169s] [ext: omni.kit.property.physx-0.1.0] startup
[7.180s] [ext: omni.physx.demos-104.2.4-5.1] startup
[7.183s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[7.183s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[7.187s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[7.187s] [ext: omni.kit.viewport.ready-1.0.2] startup
[7.188s] [ext: omni.kit.viewport_widgets_manager-1.0.6] startup
[7.191s] [ext: omni.kit.widget.live-2.0.3] startup
[7.194s] [ext: omni.physx.camera-104.2.4-5.1] startup
[7.200s] [ext: omni.physx.cct-104.2.4-5.1] startup
[7.208s] [ext: omni.kit.mesh.raycast-104.3.2] startup
[7.212s] [ext: omni.kit.widget.collection-0.1.11] startup
[7.215s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[7.227s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[7.239s] [ext: omni.kit.search.service-0.1.5] startup
[7.244s] [ext: omni.isaac.robot_description_editor-2.1.1] startup
[7.246s] [ext: omni.videoencoding-0.1.0] startup
[7.251s] [ext: omni.paint.system.core-104.5.8] startup
[7.338s] [ext: omni.kit.window.collection-0.1.11] startup
[7.340s] [ext: omni.kit.window.commands-0.2.4] startup
[7.342s] [ext: omni.iray.settings.core-0.6.4] startup
[7.347s] [ext: omni.kit.sequencer.usd-103.3.1] startup
[7.351s] [ext: omni.kit.capture.viewport-1.1.24] startup
[7.356s] [ext: omni.paint.system.ui-104.3.14] startup
[7.365s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[7.365s] [ext: omni.physx.zerogravity-104.2.4-5.1] startup
[7.376s] [ext: omni.rtx.settings.core-0.5.8] startup
[7.385s] [ext: omni.kit.preferences.time-0.2.0] startup
[7.388s] [ext: omni.kit.property.sequence-0.2.0] startup
[7.390s] [ext: omni.kit.sequencer.core-103.3.0] startup
[7.393s] [ext: omni.kit.window.console-0.2.3] startup
[7.401s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[7.406s] [ext: omni.paint.brush.scatter-104.2.12] startup
[7.414s] [ext: omni.kit.window.movie_capture-2.1.8] startup
[7.421s] [ext: omni.kit.window.privacy-0.1.0] startup
[7.422s] [ext: omni.kit.window.script_editor-1.7.2] startup
[7.427s] [ext: omni.kit.window.sequencer-103.3.4] startup
[7.457s] [ext: omni.particle.system.core-104.7.19] startup
[7.471s] [ext: omni.paint.brush.attributes-1.1.2] startup
[7.477s] [ext: omni.paint.brush.modify-104.3.2] startup
[7.483s] [ext: omni.paint.brush.scripting-104.7.0] startup
[7.494s] [ext: omni.paint.brush.select-104.3.2] startup
[7.504s] [ext: omni.scene.optimizer.core-104.1.5] startup
[7.509s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.2] startup
[7.527s] [ext: omni.graph.window.particle.system-104.5.3] startup
[7.532s] [ext: omni.particle.system.ui-104.5.1] startup
[7.541s] [ext: omni.kit.window.status_bar-0.1.5] startup
[7.544s] [ext: omni.kit.window.usd_paths-1.0.4] startup
[7.547s] [ext: omni.paint.system.bundle-104.8.26] startup
[7.547s] [ext: omni.scene.optimizer.ui-104.1.5] startup
[7.550s] [ext: omni.scene.visualization.ui-104.0.6] startup
[7.554s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load …
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[7.557s] [ext: omni.particle.system.bundle-104.2.24] startup
[7.557s] [ext: omni.replicator.composer-1.2.10] startup
[7.564s] [ext: omni.replicator.isaac-1.7.4] startup
[7.584s] [ext: omni.resourcemonitor-1.0.0] startup
[7.589s] [ext: omni.scene.optimizer.bundle-104.1.5] startup
[7.589s] [ext: omni.scene.visualization.bundle-104.0.1] startup
[7.590s] [ext: omni.kit.stage.mdl_converter-1.0.1] startup
[7.592s] [ext: omni.services.usd-1.1.0] startup
[7.595s] [ext: omni.tools.array-104.0.12] startup
[7.606s] [ext: omni.tools.pivot-104.1.0] startup
[7.615s] [ext: omni.kit.widget.timeline-104.0.3] startup
[7.619s] [ext: omni.tools.randomizer-104.0.9] startup
[7.624s] [ext: omni.kit.quicklayout-1.1.1] startup
[7.627s] [ext: omni.kit.window.title-1.1.2] startup
[7.628s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[7.630s] [ext: omni.isaac.scene_blox-0.1.0] startup
[7.631s] [ext: omni.isaac.cortex-0.3.2] startup
[7.632s] [ext: omni.anim.curve_editor-104.12.7] startup
[7.654s] [ext: omni.isaac.onshape-0.6.2] startup
[8.206s] [ext: omni.kit.window.stats-0.1.2] startup
[8.208s] [ext: omni.isaac.app.setup-0.8.1] startup
[8.212s] Isaac Sim Version: 2022.2.1-rc.14
[8.213s] [ext: omni.isaac.assets_check-0.3.2] startup
[8.214s] [ext: omni.isaac.sim.base-2022.2.1] startup
[8.214s] [ext: omni.isaac.sim-2022.2.1] startup
[8.692s] app ready
2023-10-05 10:45:52 [9,354ms] [Warning] [omni.hydra.rtx] HydraEngine rtx failed creating scene renderer.
Isaac Sim requires a GPU that supports Ray Tracing (RTX), so unfortunately you cannot launch it with your current 980 Ti GPU.
if i get a rx 6800 xt which is equivalent to a rtx 3080 can it run?
Hi @luca.radu.alexandru - You can find Isaac Sim requirements here: 1. Isaac Sim Requirements — Omniverse IsaacSim latest documentation
