ISAAC SIM 2021.1 Launch from Omniverse fail, TypeError: t is not iterable
Hi, when I launch ISAAC Sim from Omniverse, I see a black screen for a split second before it disappears. And then nothing happens. See attached video link.
Omniverse Launcher.log gives
[2021-06-14 16:24:31.408] [debug] [db44b261-b89a-4038-bf9e-b9c9fa7bdfcc] Extracting isaac_sim@2021.1.0 to /home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0...
[2021-06-14 16:24:57.710] [debug] [db44b261-b89a-4038-bf9e-b9c9fa7bdfcc] Deleting /home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/Isaac Sim.zip artifact...
[2021-06-14 16:24:57.795] [debug] [db44b261-b89a-4038-bf9e-b9c9fa7bdfcc] Finishing the isaac_sim@2021.1.0 installation...
[2021-06-14 16:24:57.797] [info] Set isaac_sim version to 2021.1.0.
[2021-06-14 16:24:57.804] [debug] [db44b261-b89a-4038-bf9e-b9c9fa7bdfcc] Installed isaac_sim@2021.1.0 to /home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0.
[2021-06-14 19:16:22.989] [debug] Running "/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/isaac-sim.launcher.sh"
[2021-06-14 19:16:34.316] [debug] Running "/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/isaac-sim.launcher.sh"
[2021-06-14 19:16:58.787] [debug] Running "/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/isaac-sim.launcher.sh"
[2021-06-14 19:17:12.532] [debug] Running "/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/isaac-sim.launcher.sh"
[2021-06-14 19:18:54.841] [warn] Couldn't load featured components:  TypeError: t is not iterable
    at y (file:///tmp/.mount_omnivexzL0SP/resources/app.asar/dist/renderer/js/main.55b1e65609602726407c.js:1:48801)
    at async Object.current (file:///tmp/.mount_omnivexzL0SP/resources/app.asar/dist/renderer/js/exchange-search-page.55b1e65609602726407c.js:1:465)
I have NVIDIA-SMI 460.84, Driver Version: 460.84, CUDA Version: 11.2, 2x GeForce RTX 3080
Install on Ubuntu 18.04, with ROS Melodic and installed ISAAC SDK 2021.1 (Sim, SDK and Omniverse are all fresh installs). ISAAC Sim 2021.1 was installed from Omniverse > Exchange, ISAAC SDK was installed from official zipped file. Both without errors.
If you tell me how I can provide you with more information to solve this problem, let me know. Thanks
It appears that you ran IsaacSim from the Omniverse Launcher, which should have brought up a secondary launcher window that offered several options, including β€˜headless’. Is that how it went, and if so, are you running β€˜headless’ here? Do you have any older versions of IsaacSim installed on this machine?
It’s just a black window for a split second, no Isaac options, no headless.
I tried to install the Sim two weeks ago from a bash script file, but that did not work for me (I think my Cuda version 11 was too high?). The install through Omniverse launcher is fresh.
After I wrote this post, I notice that installing and launching other omniverse apps ends with the same error. It is probably an omniverse issue rather than an Isaac one?
kit_20210616_183958.log (71.4 KB)
I keep digging. I found that in this log found within Kit/Isaac-Sim there are also Fatal errors, namely:
2021-06-16 17:40:00 [1,955ms] [Info] [omni.ext.plugin] About to startup: [ext: omni.isaac.sim.launcher-2021.1.0] (order: 0) Triggered by API/CLI/Config.
2021-06-16 17:40:00 [1,955ms] [Info] [omni.kit.app.plugin] [1.975s] [ext: omni.isaac.sim.launcher-2021.1.0] startup
2021-06-16 17:40:00 [1,955ms] [Info] [omni.kit.app.plugin] [1.975s] app started
2021-06-16 17:40:00 [2,036ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-06-16 17:40:00 [2,036ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2021-06-16 17:40:00 [2,037ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-06-16 17:40:00 [2,038ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2021-06-16 17:40:00 [2,039ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2021-06-16 17:40:00 [2,040ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2021-06-16 17:40:00 [2,042ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-06-16 17:40:00 [2,043ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2021-06-16 17:40:00 [2,043ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-06-16 17:40:00 [2,045ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-06-16 17:40:00 [2,045ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Similar errors found when trying to open Kaolin:
2021-06-15 11:26:10 [1,782ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::Scheduler::*)(unsigned int, int, carb::cpp20::latch*), carb::tasking::Scheduler*, unsigned int, int, carb::cpp20::latch*> > >::_M_run()
2021-06-15 11:26:10 [1,784ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-06-15 11:26:10 [1,785ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Workspace::setShowWindowFn(std::string const&, std::function<void (bool)>)
2021-06-15 11:26:10 [1,787ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Workspace::getWindows()
2021-06-15 11:26:10 [1,788ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ui.so!omni::ui::Workspace::showWindow(std::string const&, bool)
2021-06-15 11:26:10 [1,789ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ui.cpython-36m-x86_64-linux-gnu.so!std::vector<std::shared_ptr<omni::ui::WindowHandle>, std::allocator<std::shared_ptr<omni::ui::WindowHandle> > >::~vector()
2021-06-15 11:26:10 [1,791ms] [Fatal] [carb.crashreporter-breakpad.plugin] _ui.cpython-36m-x86_64-linux-gnu.so!std::vector<bool, std::allocator<bool> >::_M_fill_insert(std::_Bit_iterator, unsigned long, bool)
2021-06-15 11:26:10 [1,793ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!_PyCFunction_FastCallDict
2021-06-15 11:26:10 [1,795ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,797ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!_PyEval_EvalFrameDefault
2021-06-15 11:26:10 [1,799ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,801ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!_PyEval_EvalFrameDefault
2021-06-15 11:26:10 [1,802ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,804ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!_PyEval_EvalFrameDefault
2021-06-15 11:26:10 [1,806ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,808ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,810ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!_PyEval_EvalFrameDefault
2021-06-15 11:26:10 [1,812ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,814ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,816ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!_PyEval_EvalFrameDefault
2021-06-15 11:26:10 [1,818ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalFrame
2021-06-15 11:26:10 [1,820ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalCodeEx
2021-06-15 11:26:10 [1,822ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpython3.6m.so.1.0!PyEval_EvalCode
2021-06-15 11:26:10 [1,824ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-06-15 11:26:10 [1,826ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.scripting-python.plugin.so!carbGetPluginDeps
2021-06-15 11:26:10 [1,827ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::__detail::_Compiler<std::regex_traits<char> >::_M_assertion()
2021-06-15 11:26:10 [1,829ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::__detail::_Compiler<std::regex_traits<char> >::_M_assertion()
2021-06-15 11:26:10 [1,831ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long&&)
2021-06-15 11:26:10 [1,833ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::__detail::_Compiler<std::regex_traits<char> >::_M_assertion()
2021-06-15 11:26:10 [1,835ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::__detail::_Compiler<std::regex_traits<char> >::_M_assertion()
2021-06-15 11:26:10 [1,837ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.ext.plugin.so!std::pair<std::__detail::_Node_iterator<std::string, true, true>, bool> std::_Hashtable<std::string, std::string, std::allocator<std::string>, std::__detail::_Identity, std::equal_to<std::string>, std::hash<std::string>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<true, true, true> >::_M_insert<std::string const&, std::__detail::_AllocNode<std::allocator<std::__detail::_Hash_node<std::string, true> > > >(std::string const&, std::__detail::_AllocNode<std::allocator<std::__detail::_Hash_node<std::string, true> > > const&, std::integral_constant<bool, true>)
2021-06-15 11:26:10 [1,839ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-06-15 11:26:10 [1,839ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-06-15 11:26:10 [1,841ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-06-15 11:26:10 [1,841ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-06-15 11:26:10 [1,841ms] [Error] [carb.crashreporter-breakpad.plugin] breakpad failed to write: /home/dennisushi/.local/share/ov/data/Kit/Kaolin/2021.1/60cb5d26-64d2-444c-be463cb3-d886d9bf.dmp
@ucabds6 a few questions to see if we can get to the bottom of this, can you paste the output to the following commands:
  • nvidia-smi
  • vulkaninfo
  • output from running isaac-sim directly
cd /home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/
./isaac-sim.sh
  • and also running without a gui window
./isaac-sim.sh --no-window
Nvidia-smi:
| NVIDIA-SMI 460.84       Driver Version: 460.84       CUDA Version: 11.2     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  GeForce RTX 3080    Off  | 00000000:1A:00.0 Off |                  N/A |
| 30%   30C    P8    14W / 320W |    222MiB / 10018MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  GeForce RTX 3080    Off  | 00000000:68:00.0  On |                  N/A |
| 30%   36C    P8    33W / 320W |    806MiB / 10014MiB |      7%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      6593      G   /usr/lib/xorg/Xorg                  4MiB |
|    0   N/A  N/A     14601      C   ...ffice/program/soffice.bin      213MiB |
|    1   N/A  N/A      2388      G   /usr/bin/gnome-shell               88MiB |
|    1   N/A  N/A      6593      G   /usr/lib/xorg/Xorg                336MiB |
|    1   N/A  N/A      6975      G   /usr/bin/gnome-shell               62MiB |
|    1   N/A  N/A      7846      G   /usr/lib/firefox/firefox          230MiB |
|    1   N/A  N/A      7981      G   /usr/lib/firefox/firefox            3MiB |
|    1   N/A  N/A      8122      G   ...AAAAAAAAA= --shared-files       49MiB |
|    1   N/A  N/A      8196      G   /usr/lib/firefox/firefox            3MiB |
|    1   N/A  N/A     12106      G   /usr/lib/firefox/firefox            3MiB |
|    1   N/A  N/A     12375      G   /usr/lib/firefox/firefox            3MiB |
|    1   N/A  N/A     12419      G   /usr/lib/firefox/firefox            3MiB |
|    1   N/A  N/A     13352      G   gnome-control-center                3MiB |
Vulkan Info:
vulkaninfo_outputlog.log (79.1 KB)
Isaac bash scripts:
Big Black screen with β€˜force close’ window. The following output
./isaac-sim.sh
[Info] [carb] Logging to file: /home/dennisushi/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1/kit_20210616_191832.log
[Info] [carb] Initializing plugin: carb.events.plugin (interfaces: [carb::events::IEvents v0.2]) (impl: carb.events.plugin)
[0.008s] Loading user config located at: '/home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/user.config.json'
2021-06-16 18:18:32 [69ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/exts/omni.kit.xr', ext 2: '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/extscore/omni.kit.xr'
[0.083s] [ext: omni.kit.pipapi-0.0.0] startup
[0.088s] [ext: omni.usd.config-1.0.0] startup
[0.089s] [ext: omni.usd.libs-1.0.0] startup
[0.246s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.250s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.253s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.256s] [ext: omni.hydra.iray-0.1.0] startup
[0.264s] [ext: omni.kit.async_engine-0.0.0] startup
[0.271s] [ext: omni.stats-0.0.0] startup
[0.273s] [ext: omni.assets.plugins-0.0.0] startup
[0.275s] [ext: omni.kit.loop-default-0.1.0] startup
[0.275s] [ext: omni.client-0.1.0] startup
[0.283s] [ext: omni.appwindow-1.0.0] startup
[0.293s] [ext: omni.kit.renderer.core-0.0.0] startup
| Driver Version: 460.84      | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | GeForce RTX 3080                 | Yes    |     | 10486   MB | 10de      | 0          |
|     |                                  |        |     |            | 2206      | 7fc00bb0.. |
| 1   | GeForce RTX 3080                 |        |     | 10486   MB | 10de      | 0          |
|     |                                  |        |     |            | 2206      | 2e96eabb.. |
| OS: Linux dennis-DLPC, Version: 5.4.0-74-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12008000 (1.20.8.0)
| Processor: Intel(R) Core(TM) i9-10900X CPU @ 3.70GHz | Cores: Unknown | Logical: 20
| Total Memory (MB): 128516 | Free Memory: 116862
| Total Page/Swap (MB): 15623 | Free Page/Swap: 15623
2021-06-16 18:18:33 [719ms] [Error] [carb.graphics-vulkan.plugin] Failed to find a graphics and/or presenting queue.
2021-06-16 18:18:33 [719ms] [Error] [omni.kit.renderer.plugin] Failed to create swapchain
[0.886s] [ext: omni.kit.test-0.0.0] startup
[0.896s] [ext: omni.ui-2.1.8] startup
[0.909s] [ext: omni.kit.mainwindow-0.0.0] startup
[0.912s] [ext: omni.kit.uiapp-0.0.0] startup
[0.919s] [ext: omni.usd.schema.physics-1.0.0] startup
[0.924s] [ext: omni.usd.schema.isaac-0.1.0] startup
[0.953s] [ext: omni.usd.schema.physx-0.0.0] startup
[0.976s] [ext: omni.usd.schema.anim-0.0.0] startup
[0.985s] [ext: omni.services.facilities.base-1.0.0] startup
[0.987s] [ext: omni.services.transport.client.base-1.0.0] startup
[0.989s] [ext: omni.services.core-1.1.0] startup
[1.217s] [ext: omni.services.client-0.2.0] startup
[1.341s] [ext: omni.services.transport.server.base-1.0.0] startup
[1.343s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[1.520s] [ext: omni.kit.agent-0.1.0] startup
[1.522s] [ext: omni.services.transport.server.http-1.0.0] startup
[1.595s] [ext: omni.kit.window.drop_support-1.0.0] startup
[1.598s] [ext: omni.kit.thumbnails.images-0.1.1] startup
[1.604s] [ext: omni.timeline-1.0.0] startup
[1.606s] [ext: omni.kit.widget.path_field-2.0.2] startup
[1.621s] [ext: omni.renderer-rtx-0.0.0] startup
[1.624s] [ext: omni.kit.commands-0.0.0] startup
[1.628s] [ext: omni.hydra.rtx-0.1.0] startup
[1.633s] [ext: omni.kit.window.toolbar-1.0.0] startup
[1.654s] [ext: omni.kit.widget.browser_bar-2.0.1] startup
[1.660s] [ext: carb.audio-0.1.0] startup
[1.684s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.691s] [ext: omni.kit.menu.utils-1.0.1] startup
[1.701s] [ext: omni.usd-1.4.2] startup
[1.923s] [ext: omni.convexdecomposition-1.2.0] startup
[1.931s] [ext: omni.kvdb-0.0.0] startup
[1.936s] [ext: omni.kit.material.library-1.0.4] startup
[1.947s] [ext: omni.kit.menu.create-1.0.1] startup
[1.951s] [ext: omni.localcache-0.0.0] startup
[1.955s] [ext: omni.usdphysics-1.2.0] startup
[1.957s] [ext: omni.kit.context_menu-1.1.0] startup
[1.977s] [ext: omni.kit.numpy.common-0.1.0] startup
[2.231s] [ext: omni.physx-1.2.0-5.1] startup
[2.276s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-06-16 18:18:35 [2,271ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
2021-06-16 18:18:53 [20,952ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[21.290s] [ext: omni.kit.window.popup_dialog-2.0.0] startup
[21.299s] [ext: omni.isaac.dynamic_control-0.1.3] startup
[21.322s] [ext: omni.kit.search_core-1.0.0] startup
[21.328s] [ext: omni.debugdraw-0.0.0] startup
[21.333s] [ext: omni.kit.notification_manager-1.0.0] startup
[21.340s] [ext: omni.kit.widget.filebrowser-2.2.4] startup
[21.364s] [ext: omni.isaac.utils-0.1.4] startup
[21.386s] [ext: omni.kit.window.filepicker-2.3.1] startup
[21.437s] [ext: omni.ansel-0.2.0] startup
2021-06-16 18:18:54 [21,429ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] Failed to load plugins, folder doesn't exist: '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/exts/omni.ansel/bin'.
2021-06-16 18:18:54 [21,429ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/exts/omni.ansel/bin/*.plugin' in '[[native.plugin]]' was not found.
[21.441s] [ext: omni.isaac.dr-0.1.6] startup
[21.460s] [ext: omni.kit.stage_templates-1.0.4] startup
[21.471s] [ext: omni.isaac.occupancy_map-0.1.0] startup
[21.511s] [ext: omni.kit.window.file-1.2.2] startup
[21.573s] [ext: omni.graph.tools-1.0.0] startup
[21.605s] [ext: omni.graph.core-1.0.0] startup
[21.610s] [ext: omni.kit.window.content_browser-2.3.1] startup
[21.644s] [ext: omni.kit.widget.layers-1.5.2] startup
[21.699s] [ext: omni.kit.widget.fast_search-0.3.0] startup
[21.707s] [ext: omni.kit.widget.graph-1.1.2] startup
[21.733s] [ext: omni.graph-1.0.0] startup
[21.775s] [ext: omni.kit.widget.settings-1.0.0] startup
[21.786s] [ext: omni.kit.asset_converter-1.1.23] startup
[21.841s] [ext: omni.syntheticdata-0.1.5] startup
Collecting opencv-python==4.5.1.48
  Downloading opencv_python-4.5.1.48-cp37-cp37m-manylinux2014_x86_64.whl (50.4 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 50.4 MB 36.6 MB/s
Collecting numpy>=1.14.5
  Downloading numpy-1.20.3-cp37-cp37m-manylinux_2_12_x86_64.manylinux2010_x86_64.whl (15.3 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 15.3 MB 28.1 MB/s
Installing collected packages: numpy, opencv-python
Successfully installed numpy-1.20.3 opencv-python-4.5.1.48
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/bin already exists. Specify --upgrade to force replacement.
WARNING: You are using pip version 20.1.1; however, version 21.1.2 is available.
You should consider upgrading via the '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/python/bin/python3 -m pip install --upgrade pip' command.
[30.877s] [ext: omni.graph.ui-1.0.1] startup
Collecting bezier==2020.5.19
  Downloading bezier-2020.5.19-cp37-cp37m-manylinux2010_x86_64.whl (1.4 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 1.4 MB 34.8 MB/s
Collecting numpy>=1.18.1
  Using cached numpy-1.20.3-cp37-cp37m-manylinux_2_12_x86_64.manylinux2010_x86_64.whl (15.3 MB)
Installing collected packages: numpy, bezier
Successfully installed bezier-2020.5.19 numpy-1.20.3
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/numpy.libs already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/numpy already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/numpy-1.20.3.dist-info already exists. Specify --upgrade to force replacement.
[34.703s] [ext: omni.isaac.shapenet-1.0.0] startup
Collecting webbot==0.34
  Downloading webbot-0.34-py3-none-any.whl (12.9 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 12.9 MB 12.6 MB/s
Collecting selenium
  Downloading selenium-3.141.0-py2.py3-none-any.whl (904 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 904 kB 58.0 MB/s
Collecting urllib3
  Downloading urllib3-1.26.5-py2.py3-none-any.whl (138 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 138 kB 60.0 MB/s
Installing collected packages: urllib3, selenium, webbot
Successfully installed selenium-3.141.0 urllib3-1.26.5 webbot-0.34
Collecting requests==2.25.1
  Downloading requests-2.25.1-py2.py3-none-any.whl (61 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 61 kB 8.6 MB/s
Collecting chardet<5,>=3.0.2
  Downloading chardet-4.0.0-py2.py3-none-any.whl (178 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 178 kB 26.8 MB/s
Collecting idna<3,>=2.5
  Downloading idna-2.10-py2.py3-none-any.whl (58 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 58 kB 5.9 MB/s
Collecting certifi>=2017.4.17
  Downloading certifi-2021.5.30-py2.py3-none-any.whl (145 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 145 kB 21.2 MB/s
Collecting urllib3<1.27,>=1.21.1
  Using cached urllib3-1.26.5-py2.py3-none-any.whl (138 kB)
Installing collected packages: chardet, idna, certifi, urllib3, requests
Successfully installed certifi-2021.5.30 chardet-4.0.0 idna-2.10 requests-2.25.1 urllib3-1.26.5
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/urllib3-1.26.5.dist-info already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/urllib3 already exists. Specify --upgrade to force replacement.
env var SHAPENET_LOCAL_DIR not set, using default data dir /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/shapenet
FYI, omni.isaac.shapenet's receiver for external messages has started. on ('localhost', '7011')
[38.046s] [ext: omni.isaac.urdf-0.1.4] startup
[38.071s] [ext: omni.isaac.synthetic_utils-0.1.0] startup
[38.087s] [ext: omni.kit.window.property-0.0.0] startup
[38.096s] [ext: omni.isaac.range_sensor-0.1.2] startup
[38.120s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] startup
[38.133s] [ext: omni.kit.widget.stage-2.4.0] startup
[38.154s] [ext: omni.kit.tool.asset_importer-2.3.2] startup
[38.171s] [ext: omni.physx.commands-1.0.0] startup
[38.180s] [ext: omni.kit.property.usd-3.9.4] startup
[38.223s] [ext: omni.isaac.robot_engine_bridge-0.1.0] startup
Collecting numpy-quaternion==2020.9.5.14.42.2
  Downloading numpy_quaternion-2020.9.5.14.42.2-cp37-cp37m-manylinux2010_x86_64.whl (187 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 187 kB 41.0 MB/s
Collecting scipy
  Downloading scipy-1.6.3-cp37-cp37m-manylinux1_x86_64.whl (27.4 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 27.4 MB 37.7 MB/s
Collecting numba; python_version >= "3.6" and platform_python_implementation != "PyPy"
  Downloading numba-0.53.1-cp37-cp37m-manylinux2014_x86_64.whl (3.4 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 3.4 MB 56.8 MB/s
Collecting numpy>=1.13
Collecting setuptools
  Downloading setuptools-57.0.0-py3-none-any.whl (821 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 821 kB 55.0 MB/s
Collecting llvmlite<0.37,>=0.36.0rc1
  Downloading llvmlite-0.36.0-cp37-cp37m-manylinux2010_x86_64.whl (25.3 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 25.3 MB 45.1 MB/s
Installing collected packages: numpy, scipy, setuptools, llvmlite, numba, numpy-quaternion
Successfully installed llvmlite-0.36.0 numba-0.53.1 numpy-1.20.3 numpy-quaternion-2020.9.5.14.42.2 scipy-1.6.3 setuptools-57.0.0
Collecting numba==0.51.2
  Downloading numba-0.51.2-cp37-cp37m-manylinux2014_x86_64.whl (3.1 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 3.1 MB 25.7 MB/s
Collecting numpy>=1.15
Collecting llvmlite<0.35,>=0.34.0.dev0
  Downloading llvmlite-0.34.0-cp37-cp37m-manylinux2010_x86_64.whl (24.6 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 24.6 MB 18.1 MB/s
  Using cached setuptools-57.0.0-py3-none-any.whl (821 kB)
Installing collected packages: numpy, llvmlite, setuptools, numba
Successfully installed llvmlite-0.34.0 numba-0.51.2 numpy-1.20.3 setuptools-57.0.0
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/numba already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/pkg_resources already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/setuptools already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/distutils-precedence.pth already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/setuptools-57.0.0.dist-info already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/_distutils_hack already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/llvmlite already exists. Specify --upgrade to force replacement.
Collecting scipy==1.5.4
  Downloading scipy-1.5.4-cp37-cp37m-manylinux1_x86_64.whl (25.9 MB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 25.9 MB 15.1 MB/s
Successfully installed numpy-1.20.3 scipy-1.5.4
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/scipy.libs already exists. Specify --upgrade to force replacement.
WARNING: Target directory /home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/pip3-envs/default/scipy already exists. Specify --upgrade to force replacement.
Collecting construct==2.10.61
  Downloading construct-2.10.61.tar.gz (55 kB)
     |β–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆβ–ˆ| 55 kB 3.9 MB/s
Using legacy setup.py install for construct, since package 'wheel' is not installed.
Installing collected packages: construct
    Running setup.py install for construct ... done
Successfully installed construct-2.10.61
[68.990s] [ext: omni.isaac.step_importer-0.1.1] startup
[69.083s] [ext: omni.kit.menu.file-1.0.2] startup
[69.090s] [ext: omni.kit.window.preferences-1.1.1] startup
[69.136s] [ext: omni.physx.ui-1.2.0-5.1] startup
[69.165s] [ext: omni.kit.property.material-1.6.4] startup
[69.181s] [ext: omni.kit.property.layer-1.1.0] startup
[69.192s] [ext: omni.kit.property.light-1.0.4] startup
[69.199s] [ext: omni.physx.demos-1.0.0] startup
[69.205s] [ext: omni.kit.property.physx-0.1.0] startup
[69.265s] [ext: omni.kit.usd_undo-0.1.0] startup
[69.272s] [ext: omni.kit.property.audio-1.0.4] startup
[69.281s] [ext: omni.isaac.manip-0.1.2] startup
[69.289s] [ext: omni.isaac.motion_planning-0.1.4] startup
[69.306s] [ext: omni.physx.vehicle-1.2.0-5.1] startup
[69.342s] [ext: omni.kit.property.transform-1.0.2] startup
[69.358s] [ext: omni.kit.property.camera-1.0.3] startup
[69.367s] [ext: omni.kit.property.geometry-1.1.0] startup
[69.377s] [ext: omni.kit.renderer.capture-0.0.0] startup
[69.386s] [ext: omni.isaac.samples-0.1.6] startup
[69.445s] [ext: omni.kit.property.bundle-1.2.4] startup
[69.454s] [ext: omni.isaac.window.about-1.0.0] startup
[69.460s] [ext: omni.isaac.utils_manager-0.1.0] startup
[69.469s] [ext: omni.kit.thumbnails.usd-0.3.0] startup
[69.494s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[69.512s] [ext: omni.kit.window.tests-0.1.0] startup
[69.635s] [ext: omni.physx.cct-1.2.0-5.1] startup
[69.646s] [ext: omni.command.usd-1.0.1] startup
[69.654s] [ext: omni.kit.window.status_bar-0.0.0] startup
[69.656s] [ext: omni.isaac.tests-0.0.0] startup
[69.666s] [ext: omni.physx.bundle-1.2.0-5.1] startup
[69.666s] [ext: omni.kit.menu.edit-1.0.3] startup
[69.676s] [ext: omni.kit.menu.select-1.0.0] startup
[69.692s] [ext: omni.kit.window.extensions-1.0.2] startup
[69.717s] [ext: omni.graph.examples.python-1.0.0] startup
[69.846s] [ext: omni.kit.tool.collect-2.0.1] startup
[69.867s] [ext: omni.kit.widget.stage_icons-1.0.1] startup
[69.876s] [ext: omni.kit.property.isaac-0.1.0] startup
[69.886s] [ext: omni.isaac.contact_sensor-0.1.0] startup
[69.908s] [ext: omni.kit.window.console-0.0.0] startup
[69.911s] [ext: omni.kit.window.profiler-1.0.0] startup
[69.923s] [ext: omni.kit.window.stage-2.3.3] startup
[69.935s] [ext: omni.kit.widget.prompt-1.0.0] startup
[69.943s] [ext: omni.kit.widget.live-0.0.0] startup
[69.945s] [ext: omni.kit.widget.imageview-1.0.0] startup
[69.955s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[69.966s] [ext: omni.kit.window.cursor-1.0.1] startup
[69.987s] [ext: omni.rtx.window.settings-0.6.0] startup
[70.000s] [ext: semantics.schema.editor-0.1.3] startup
[70.004s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[70.016s] [ext: omni.videoencoding-0.0.0] startup
[70.022s] [ext: omni.kit.window.title-1.1.0] startup
[70.030s] [ext: omni.kit.widget.sliderbar-1.0.3] startup
[70.042s] [ext: omni.rtx.settings.core-0.5.4] startup
[70.056s] [ext: omni.kit.tagging-0.1.0] startup
[70.165s] [ext: omni.iray.settings.core-0.6.2] startup
[70.175s] [ext: omni.kit.capture-0.4.0] startup
[70.192s] [ext: omni.isaac.ros_bridge_ui-0.1.0] startup
[70.203s] [ext: omni.kit.selection-0.0.0] startup
[70.213s] [ext: omni.kit.search.service-0.1.0] startup
[70.226s] [ext: omni.kit.filebrowser_column.tags-1.0.0] startup
[70.235s] [ext: omni.kit.window.script_editor-1.5.0] startup
[70.238s] [ext: omni.kit.window.movie_maker-0.4.9] startup
[70.259s] [ext: omni.isaac.ros_bridge-0.1.0] startup
Checking if ROS_MASTER_URI is set:
Found ROS_MASTER_URI= http://localhost:11311
[70.526s] [ext: omni.kit.window.stats-0.0.0] startup
[70.536s] [ext: omni.isaac.app.setup-0.0.0] startup
[70.546s] [ext: omni.isaac.sim.base-2021.1.0] startup
[70.546s] [ext: omni.isaac.sim-2021.1.0] startup
[70.546s] app started
2021-06-16 18:19:43 [70,733ms] [Fatal] [carb.crashreporter-breakpad.plugin] libpthread.so.0!funlockfile
2021-06-16 18:19:43 [70,736ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!void std::vector<unsigned long, std::allocator<unsigned long> >::_M_realloc_insert<unsigned long const&>(__gnu_cxx::__normal_iterator<unsigned long*, std::vector<unsigned long, std::allocator<unsigned long> > >, unsigned long const&)
2021-06-16 18:19:43 [70,739ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!carbOnPluginRegisterEx
2021-06-16 18:19:43 [70,741ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.renderer.plugin.so!std::__future_base::_State_baseV2::_M_is_deferred_future() const
2021-06-16 18:19:43 [70,745ms] [Fatal] [carb.crashreporter-breakpad.plugin] libcarb.events.plugin.so!void std::this_thread::sleep_for<long, std::ratio<1l, 1000000l> >(std::chrono::duration<long, std::ratio<1l, 1000000l> > const&)
2021-06-16 18:19:43 [70,748ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()
2021-06-16 18:19:43 [70,751ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!_init
2021-06-16 18:19:43 [70,755ms] [Fatal] [carb.crashreporter-breakpad.plugin] libomni.kit.app.plugin.so!carbOnPluginPostShutdown
2021-06-16 18:19:43 [70,755ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
2021-06-16 18:19:43 [70,759ms] [Fatal] [carb.crashreporter-breakpad.plugin] libc.so.6!__libc_start_main
2021-06-16 18:19:43 [70,759ms] [Fatal] [carb.crashreporter-breakpad.plugin] kit!_init
Floating point exception (core dumped)
Isaac without GUI seems to work? Output:
dennisushi@dennis-DLPC:~/.local/share/ov/pkg/isaac_sim-2021.1.0$ ./isaac-sim.sh --no-window
[Info] [carb] Logging to file: /home/dennisushi/.nvidia-omniverse/logs/Kit/Isaac-Sim/2021.1/kit_20210616_192133.log
[0.009s] Loading user config located at: '/home/dennisushi/.local/share/ov/data/Kit/Isaac-Sim/2021.1/user.config.json'
2021-06-16 18:21:33 [73ms] [Warning] [omni.ext.plugin] Extension with the same id is already registered. ext_id: 'omni.kit.xr-1.0.0', ext 1: '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/exts/omni.kit.xr', ext 2: '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/extscore/omni.kit.xr'
[0.087s] [ext: omni.kit.pipapi-0.0.0] startup
[0.092s] [ext: omni.usd.config-1.0.0] startup
[0.093s] [ext: omni.usd.libs-1.0.0] startup
[0.251s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.255s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.258s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.260s] [ext: omni.hydra.iray-0.1.0] startup
[0.263s] [ext: omni.kit.async_engine-0.0.0] startup
[0.270s] [ext: omni.stats-0.0.0] startup
[0.272s] [ext: omni.assets.plugins-0.0.0] startup
[0.273s] [ext: omni.kit.loop-default-0.1.0] startup
[0.274s] [ext: omni.client-0.1.0] startup
[0.282s] [ext: omni.appwindow-1.0.0] startup
[0.290s] [ext: omni.kit.renderer.core-0.0.0] startup
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2206      | 7fc00bb0.. |
|     |                                  |        |     |            | 2206      | 2e96eabb.. |
| Total Memory (MB): 128516 | Free Memory: 115428
[0.870s] [ext: omni.kit.test-0.0.0] startup
[0.881s] [ext: omni.ui-2.1.8] startup
[0.894s] [ext: omni.kit.mainwindow-0.0.0] startup
[0.896s] [ext: omni.kit.uiapp-0.0.0] startup
[0.896s] [ext: omni.usd.schema.physics-1.0.0] startup
[0.902s] [ext: omni.usd.schema.isaac-0.1.0] startup
[0.918s] [ext: omni.usd.schema.physx-0.0.0] startup
[0.932s] [ext: omni.usd.schema.anim-0.0.0] startup
[0.941s] [ext: omni.services.facilities.base-1.0.0] startup
[0.942s] [ext: omni.services.transport.client.base-1.0.0] startup
[0.944s] [ext: omni.services.core-1.1.0] startup
[1.030s] [ext: omni.services.client-0.2.0] startup
[1.099s] [ext: omni.services.transport.server.base-1.0.0] startup
[1.101s] [ext: omni.services.transport.client.http_async-1.0.0] startup
[1.199s] [ext: omni.kit.agent-0.1.0] startup
[1.201s] [ext: omni.services.transport.server.http-1.0.0] startup
[1.239s] [ext: omni.kit.window.drop_support-1.0.0] startup
[1.241s] [ext: omni.kit.thumbnails.images-0.1.1] startup
[1.244s] [ext: omni.timeline-1.0.0] startup
[1.247s] [ext: omni.kit.widget.path_field-2.0.2] startup
[1.251s] [ext: omni.renderer-rtx-0.0.0] startup
[1.251s] [ext: omni.kit.commands-0.0.0] startup
[1.255s] [ext: omni.hydra.rtx-0.1.0] startup
[1.257s] [ext: omni.kit.window.toolbar-1.0.0] startup
[1.267s] [ext: omni.kit.widget.browser_bar-2.0.1] startup
[1.270s] [ext: carb.audio-0.1.0] startup
[1.273s] [ext: omni.hydra.scene_delegate-0.1.0] startup
[1.280s] [ext: omni.kit.menu.utils-1.0.1] startup
[1.285s] [ext: omni.usd-1.4.2] startup
[1.502s] [ext: omni.convexdecomposition-1.2.0] startup
[1.506s] [ext: omni.kvdb-0.0.0] startup
[1.509s] [ext: omni.kit.material.library-1.0.4] startup
[1.517s] [ext: omni.kit.menu.create-1.0.1] startup
[1.520s] [ext: omni.localcache-0.0.0] startup
[1.523s] [ext: omni.usdphysics-1.2.0] startup
[1.524s] [ext: omni.kit.context_menu-1.1.0] startup
[1.542s] [ext: omni.kit.numpy.common-0.1.0] startup
[1.627s] [ext: omni.physx-1.2.0-5.1] startup
[1.670s] [ext: omni.kit.window.viewport-0.0.0] startup
2021-06-16 18:21:35 [1,664ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.viewport-0.0.0] '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/plugins/rtx/rtx.reshade.plugin' in '[[native.plugin]]' was not found.
2021-06-16 18:21:36 [2,393ms] [Warning] [carb] Acquiring non optional plugin interface which is not listed as dependency: [rtx::raytracing::Subsurface v0.1] (plugin: rtx.raytracing.plugin), by client: carb.scenerenderer-rtx.plugin. Add it to CARB_PLUGIN_IMPL_DEPS() macro of a client.
[2.680s] [ext: omni.kit.window.popup_dialog-2.0.0] startup
[2.684s] [ext: omni.isaac.dynamic_control-0.1.3] startup
[2.693s] [ext: omni.kit.search_core-1.0.0] startup
[2.696s] [ext: omni.debugdraw-0.0.0] startup
[2.700s] [ext: omni.kit.notification_manager-1.0.0] startup
[2.704s] [ext: omni.kit.widget.filebrowser-2.2.4] startup
[2.711s] [ext: omni.isaac.utils-0.1.4] startup
[2.719s] [ext: omni.kit.window.filepicker-2.3.1] startup
[2.755s] [ext: omni.ansel-0.2.0] startup
2021-06-16 18:21:36 [2,746ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] Failed to load plugins, folder doesn't exist: '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/exts/omni.ansel/bin'.
2021-06-16 18:21:36 [2,746ms] [Warning] [omni.ext.plugin] [ext: omni.ansel-0.2.0] '/home/dennisushi/.local/share/ov/pkg/isaac_sim-2021.1.0/kit/exts/omni.ansel/bin/*.plugin' in '[[native.plugin]]' was not found.
[2.757s] [ext: omni.isaac.dr-0.1.6] startup
[2.764s] [ext: omni.kit.stage_templates-1.0.4] startup
[2.768s] [ext: omni.isaac.occupancy_map-0.1.0] startup
[2.779s] [ext: omni.kit.window.file-1.2.2] startup
[2.816s] [ext: omni.graph.tools-1.0.0] startup
[2.826s] [ext: omni.graph.core-1.0.0] startup
[2.828s] [ext: omni.kit.window.content_browser-2.3.1] startup
[2.853s] [ext: omni.kit.widget.layers-1.5.2] startup
[2.866s] [ext: omni.kit.widget.fast_search-0.3.0] startup
[2.870s] [ext: omni.kit.widget.graph-1.1.2] startup
[2.877s] [ext: omni.graph-1.0.0] startup
[2.903s] [ext: omni.kit.widget.settings-1.0.0] startup
[2.908s] [ext: omni.kit.asset_converter-1.1.23] startup
[2.922s] [ext: omni.syntheticdata-0.1.5] startup
[3.005s] [ext: omni.graph.ui-1.0.1] startup
[3.042s] [ext: omni.isaac.shapenet-1.0.0] startup
[3.080s] [ext: omni.isaac.urdf-0.1.4] startup
[3.091s] [ext: omni.isaac.synthetic_utils-0.1.0] startup
[3.096s] [ext: omni.kit.window.property-0.0.0] startup
[3.101s] [ext: omni.isaac.range_sensor-0.1.2] startup
[3.110s] [ext: omni.isaac.robot_engine_bridge_ui-0.1.0] startup
[3.115s] [ext: omni.kit.widget.stage-2.4.0] startup
[3.122s] [ext: omni.kit.tool.asset_importer-2.3.2] startup
[3.129s] [ext: omni.physx.commands-1.0.0] startup
[3.133s] [ext: omni.kit.property.usd-3.9.4] startup
[3.150s] [ext: omni.isaac.robot_engine_bridge-0.1.0] startup
[3.433s] [ext: omni.isaac.step_importer-0.1.1] startup
[3.488s] [ext: omni.kit.menu.file-1.0.2] startup
[3.494s] [ext: omni.kit.window.preferences-1.1.1] startup
[3.523s] [ext: omni.physx.ui-1.2.0-5.1] startup
[3.536s] [ext: omni.kit.property.material-1.6.4] startup
[3.543s] [ext: omni.kit.property.layer-1.1.0] startup
[3.549s] [ext: omni.kit.property.light-1.0.4] startup
[3.554s] [ext: omni.physx.demos-1.0.0] startup
[3.559s] [ext: omni.kit.property.physx-0.1.0] startup
[3.603s] [ext: omni.kit.usd_undo-0.1.0] startup
[3.609s] [ext: omni.kit.property.audio-1.0.4] startup
[3.615s] [ext: omni.isaac.manip-0.1.2] startup
[3.621s] [ext: omni.isaac.motion_planning-0.1.4] startup
[3.629s] [ext: omni.physx.vehicle-1.2.0-5.1] startup
[3.643s] [ext: omni.kit.property.transform-1.0.2] startup
[3.651s] [ext: omni.kit.property.camera-1.0.3] startup
[3.656s] [ext: omni.kit.property.geometry-1.1.0] startup
[3.663s] [ext: omni.kit.renderer.capture-0.0.0] startup
[3.670s] [ext: omni.isaac.samples-0.1.6] startup
[3.685s] [ext: omni.kit.property.bundle-1.2.4] startup
[3.691s] [ext: omni.isaac.window.about-1.0.0] startup
[3.696s] [ext: omni.isaac.utils_manager-0.1.0] startup
[3.702s] [ext: omni.kit.thumbnails.usd-0.3.0] startup
[3.726s] [ext: omni.kit.primitive.mesh-1.0.0] startup
[3.733s] [ext: omni.kit.window.tests-0.1.0] startup
[3.805s] [ext: omni.physx.cct-1.2.0-5.1] startup
[3.812s] [ext: omni.command.usd-1.0.1] startup
[3.817s] [ext: omni.kit.window.status_bar-0.0.0] startup
[3.818s] [ext: omni.isaac.tests-0.0.0] startup
[3.823s] [ext: omni.physx.bundle-1.2.0-5.1] startup
[3.824s] [ext: omni.kit.menu.edit-1.0.3] startup
[3.830s] [ext: omni.kit.menu.select-1.0.0] startup
[3.843s] [ext: omni.kit.window.extensions-1.0.2] startup
[3.852s] [ext: omni.graph.examples.python-1.0.0] startup
[3.886s] [ext: omni.kit.tool.collect-2.0.1] startup
[3.895s] [ext: omni.kit.widget.stage_icons-1.0.1] startup
[3.902s] [ext: omni.kit.property.isaac-0.1.0] startup
[3.909s] [ext: omni.isaac.contact_sensor-0.1.0] startup
[3.918s] [ext: omni.kit.window.console-0.0.0] startup
[3.920s] [ext: omni.kit.window.profiler-1.0.0] startup
[3.927s] [ext: omni.kit.window.stage-2.3.3] startup
[3.987s] [ext: omni.kit.widget.prompt-1.0.0] startup
[3.994s] [ext: omni.kit.widget.live-0.0.0] startup
[3.996s] [ext: omni.kit.widget.imageview-1.0.0] startup
[4.003s] [ext: omni.kit.window.usd_paths-1.0.3] startup
[4.011s] [ext: omni.kit.window.cursor-1.0.1] startup
[4.019s] [ext: omni.rtx.window.settings-0.6.0] startup
[4.026s] [ext: semantics.schema.editor-0.1.3] startup
[4.028s] [ext: omni.kit.window.imageviewer-1.0.3] startup
[4.037s] [ext: omni.videoencoding-0.0.0] startup
[4.039s] [ext: omni.kit.window.title-1.1.0] startup
[4.046s] [ext: omni.kit.widget.sliderbar-1.0.3] startup
[4.054s] [ext: omni.rtx.settings.core-0.5.4] startup
[4.062s] [ext: omni.kit.tagging-0.1.0] startup
[4.112s] [ext: omni.iray.settings.core-0.6.2] startup
[4.119s] [ext: omni.kit.capture-0.4.0] startup
[4.129s] [ext: omni.isaac.ros_bridge_ui-0.1.0] startup
[4.135s] [ext: omni.kit.selection-0.0.0] startup
[4.142s] [ext: omni.kit.search.service-0.1.0] startup
[4.152s] [ext: omni.kit.filebrowser_column.tags-1.0.0] startup
[4.160s] [ext: omni.kit.window.script_editor-1.5.0] startup
[4.161s] [ext: omni.kit.window.movie_maker-0.4.9] startup
[4.171s] [ext: omni.isaac.ros_bridge-0.1.0] startup
[4.255s] [ext: omni.kit.window.stats-0.0.0] startup
[4.263s] [ext: omni.isaac.app.setup-0.0.0] startup
[4.271s] [ext: omni.isaac.sim.base-2021.1.0] startup
[4.271s] [ext: omni.isaac.sim-2021.1.0] startup
[4.271s] app started
Ah, interesting, can you plug your monitor into the other GPU and try running?
By default omniverse uses the first GPU it finds and based on the nvidia-smi output you are running your monitor on the second GPU.
Is there a way to force it to use the other GPU? I tried plugging it in but there was no display signal found, not sure if this is a bad sign.
Yes, you can add a
--/renderer/activeGpu=1 when running isaac-sim.sh to specify which gpu is active.
You can verify that its set when kit starts and you see this section, the active gpu should change to the second.
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2206      | 7fc00bb0.. |
|     |                                  |        |     |            | 2206      | 2e96eabb.. |
Can you try this and see if it works? I can try getting my hands on a dual gpu machine to find the correct fix othwerwise.
Hi, I can confirm that doing this launches ISAAC! Thanks a lot! I guess I have to figure out what’s wrong with the other RTX if I want to launch from the launcher in the future?
Is there a way to specify the GPU for OmniKitHelper as well?
Here you can find all the Omnikithelper parameters:
https://docs.omniverse.nvidia.com/py/isaacsim/source/extensions/omni.isaac.python_app/docs/index.html?highlight=helper#omni.isaac.python_app.OmniKitHelper
So no? I’ve seen the documentation. But running it in non headless mode (headfull?) breaks for probably the same reason the Sim was breaking? So I need to somehow specify to run it on the other GPU I assume?
yes, correct. you need to specify the active GPU with the method that Hammad proposed.
Hi, just wanted to answer my own question:
OmniKitHelper according to the link you sent does not list GPU selection as an option, however it is there! I needed to pass "active_gpu": 1 in the config and it started successfully. Perhaps the documentation can be updated to reflect that this is an option?
Sorry about that @ucabds6 , docs for 2021.1.1 went live last night and active_gpu is documented there now.
Hi, I have been running okay like this
cd $ISAAC_SOURCE_LOC && ./isaac-sim.sh --/renderer/activeGpu=1'
I would like to know if I can specify in the omniverse GUI launcher to use the GPU=1 somehow.
Yes. In the Isaac Sim App Selector, enter the flag in the β€œExtra Args:” text box then click START.
Where is that?
See User Interface Reference β€” Omniverse Robotics documentation
