Launching omniverse streaming client pop blank screen and it dont shows error or warnings. Hepl me with this issue
Hi. Is the Streaming Client on the same machine or network as Isaac Sim? Can you share the full Isaac Sim logs?
I have installed omniverse launcher on ubuntu server and am running omniverse from same machine. Client streaming app on launching shows black screen window. I have not installed Isssac yet, but previously installed but stuck on same error. Now I have installed only client streaming app first. I was trying running note book code provided as a traning by Nvidia on issac simulation learning.
You follow these steps to install and run Isaac Sim. The Streaming Client works with Isaac Sim’s Headless Native mode.
Please share the full logs if you get any errors.
I followed the steps and installed and started in Native Headless mode
it shows
Loading user config located at: ‘/home/k.ovais/nvidiaDwn/Kit/Isaac-Sim/2022.2/user.config.json’
[Info] [carb] Logging to file: /home/k.ovais/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230927_180241.log
2023-09-27 12:32:41 [278ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config ‘extension.toml’ doesn’t exist ‘/home/k.ovais/nvidiaDwn/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar’ or ‘/home/k.ovais/nvidiaDwn/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar/config’
2023-09-27 12:32:41 [278ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config ‘extension.toml’ doesn’t exist ‘/home/k.ovais/nvidiaDwn/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar’ or ‘/home/k.ovais/nvidiaDwn/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar/config’
[0.767s] [ext: omni.stats-0.0.0] startup
[0.819s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.837s] [ext: omni.assets.plugins-0.0.0] startup
[0.840s] [ext: omni.gpu_foundation-0.0.0] startup
[0.852s] [ext: carb.windowing.plugins-1.0.0] startup
[0.868s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-09-27 12:32:42 [1,001ms] [Warning] [carb.graphics-vulkan.plugin] No command queue family supports flags: 0x100, queue type: 3. No queues of this type will be created
| Driver Version: 470.199.02 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 2080 Ti | Yes: 0 | | 11510 MB | 10de | 0 |
| | | | | | 1e04 | 7dfa249c… |
| OS: Linux CSE-BLADE, Version: 6.2.0-33-generic
| XServer Vendor: Cendio ThinLinc, XServer Version: 12013000
| Processor: Intel(R) Xeon(R) Silver 4114 CPU @ 2.20GHz | Cores: Unknown | Logical: 40
| Total Memory (MB): 515565 | Free Memory: 507890
| Total Page/Swap (MB): 975 | Free Page/Swap: 975
[3.743s] [ext: omni.kit.pipapi-0.0.0] startup
[3.774s] [ext: omni.usd.config-1.0.0] startup
[3.782s] [ext: omni.usd.libs-1.0.0] startup
[3.978s] [ext: omni.kit.pip_archive-0.0.0] startup
[3.984s] [ext: omni.kit.async_engine-0.0.0] startup
[3.987s] [ext: omni.kit.loop-default-0.1.1] startup
[3.988s] [ext: omni.kit.test-0.0.0] startup
[4.064s] [ext: omni.usd.schema.semantics-0.0.0] startup
[4.134s] [ext: omni.usd.schema.audio-0.0.0] startup
[4.154s] [ext: omni.client-0.1.1] startup
[4.169s] [ext: omni.iray.libs-0.0.0] startup
[4.176s] [ext: omni.volume-0.1.0] startup
[4.180s] [ext: omni.usd.core-1.0.4] startup
[4.185s] [ext: omni.mdl.neuraylib-0.1.0] startup
[4.191s] [ext: omni.hydra.rtx-0.1.0] startup
[4.203s] [ext: omni.hydra.iray-0.1.0] startup
[4.208s] [ext: omni.isaac.core_archive-2.0.1] startup
[4.412s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[4.417s] [ext: omni.isaac.ml_archive-1.1.0] startup
[4.468s] [ext: omni.services.pip_archive-0.4.2] startup
[4.473s] [ext: omni.appwindow-1.0.1] startup
[4.476s] [ext: omni.kit.renderer.core-0.0.0] startup
[4.489s] [ext: omni.kit.renderer.capture-0.0.0] startup
[4.493s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[4.643s] [ext: omni.ui-2.14.4] startup
[4.657s] [ext: carb.audio-0.1.0] startup
[4.664s] [ext: omni.uiaudio-1.0.0] startup
[4.665s] [ext: omni.kit.mainwindow-1.0.0] startup
[4.668s] [ext: omni.kit.uiapp-0.0.0] startup
[4.668s] [ext: omni.usd.schema.physics-1.0.0] startup
[4.683s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[4.686s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[4.701s] [ext: omni.usd.schema.physx-0.0.0] startup
[4.751s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[4.764s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[4.778s] [ext: omni.usd.schema.anim-0.0.0] startup
[4.896s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[4.909s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[4.912s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[4.922s] [ext: omni.kit.actions.core-1.0.0] startup
[4.926s] [ext: omni.gpucompute.plugins-0.0.0] startup
[4.927s] [ext: omni.kit.commands-1.4.5] startup
[4.933s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[4.960s] [ext: omni.timeline-1.0.5] startup
[4.963s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[4.972s] [ext: omni.usd-1.6.30] startup
[5.044s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[5.045s] [ext: omni.usd.schema.flow-104.1.6] startup
[5.047s] [ext: omni.usd.schema.destruction-0.4.0] startup
[5.059s] [ext: omni.usd.schema.sequence-2.2.1] startup
[5.078s] [ext: omni.usd.schema.isaac-1.1.0] startup
[5.105s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[5.194s] [ext: omni.kit.asset_converter-1.3.4] startup
[5.223s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[5.239s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[5.243s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[5.246s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[5.254s] [ext: omni.hydra.engine.stats-1.0.0] startup
[5.263s] [ext: omni.kit.usd.layers-2.0.11] startup
[5.276s] [ext: omni.kit.menu.utils-1.4.7] startup
[5.292s] [ext: omni.ui_query-1.1.1] startup
[5.293s] [ext: omni.kvdb-0.0.0] startup
[5.296s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[5.302s] [ext: omni.kit.ui_test-1.2.9] startup
[5.306s] [ext: omni.kit.notification_manager-1.0.5] startup
[5.312s] [ext: omni.activity.core-1.0.1] startup
[5.319s] [ext: omni.kit.stage_templates-1.1.13] startup
[5.322s] [ext: omni.kit.widget.path_field-2.0.4] startup
[5.323s] [ext: omni.kit.widget.versioning-1.3.8] startup
[5.326s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[5.343s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[5.345s] [ext: omni.kit.search_core-1.0.2] startup
[5.346s] [ext: omni.kit.window.drop_support-1.0.1] startup
[5.347s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[5.432s] [ext: omni.mdl-0.1.0] startup
[5.464s] [ext: omni.kit.window.file_importer-1.0.10] startup
[5.466s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[5.467s] [ext: omni.kit.material.library-1.3.21] startup
[5.476s] [ext: omni.kit.clipboard-1.0.0] startup
[5.476s] [ext: omni.kit.menu.create-1.0.8] startup
[5.479s] [ext: omni.hydra.pxr-1.1.2] startup
[5.485s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[5.487s] [ext: omni.kit.context_menu-1.5.12] startup
[5.492s] [ext: omni.kit.hydra_texture-1.0.11] startup
[5.500s] [ext: omni.kit.widget.stage-2.7.24] startup
[5.505s] [ext: omni.kit.window.file-1.3.32] startup
[5.509s] [ext: omni.kit.window.property-1.8.2] startup
[5.512s] [ext: omni.kit.window.content_browser-2.6.8] startup
[5.543s] [ext: omni.kit.widget.viewport-104.1.16] startup
[5.547s] [ext: omni.ui.scene-1.5.18] startup
[5.554s] [ext: omni.kit.viewport.registry-104.0.2] startup
[5.555s] [ext: omni.kit.property.usd-3.18.17] startup
[5.568s] [ext: omni.physics.tensors-0.1.0] startup
[5.581s] [ext: omni.kit.viewport.window-104.1.23] startup
[5.607s] [ext: omni.localcache-0.0.0] startup
[5.610s] [ext: omni.ramp-104.1.3] startup
[5.618s] [ext: omni.usdphysics-104.2.4-5.1] startup
[5.623s] [ext: omni.kit.viewport.utility-1.0.14] startup
[5.624s] [ext: omni.kit.widget.prompt-1.0.5] startup
[5.625s] [ext: omni.physx-104.2.4-5.1] startup
[5.675s] [ext: omni.kit.numpy.common-0.1.0] startup
[5.679s] [ext: omni.inspect-1.0.1] startup
[5.683s] [ext: omni.kit.usd_undo-0.1.2] startup
[5.685s] [ext: omni.graph.tools-1.17.2] startup
[5.711s] [ext: omni.graph.core-2.65.4] startup
[5.716s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[5.753s] [ext: omni.debugdraw-0.1.1] startup
[5.761s] [ext: omni.graph-1.50.2] startup
[5.835s] [ext: omni.kit.window.extensions-1.1.1] startup
[5.843s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[5.846s] [ext: omni.kit.widget.settings-1.0.1] startup
[5.849s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[5.852s] [ext: omni.kit.window.preferences-1.3.8] startup
[5.903s] [ext: omni.scene.visualization.core-104.4.0] startup
[6.001s] [ext: omni.graph.ui-1.24.2] startup
[6.053s] [ext: omni.physx.tensors-0.1.0] startup
[6.075s] [ext: omni.genproc.core-104.5.14] startup
[6.104s] [ext: omni.isaac.version-1.0.0] startup
[6.105s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[6.121s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[6.131s] [ext: omni.isaac.core-1.46.3] startup
[7.415s] [ext: omni.graph.action-1.31.1] startup
[7.429s] [ext: omni.graph.io-1.2.5] startup
[7.440s] [ext: omni.isaac.ui-0.8.0] startup
[7.448s] [ext: omni.genproc.ui-104.1.6] startup
[7.453s] [ext: usdrt.scenegraph-4.3.2] startup
[7.485s] [ext: omni.genproc.bundle-104.0.1] startup
[7.485s] [ext: omni.graph.examples.cpp-1.4.2] startup
[7.491s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[7.493s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[7.495s] [ext: omni.command.usd-1.0.2] startup
[7.500s] [ext: omni.kit.browser.core-2.2.2] startup
[7.509s] [ext: omni.kit.widget.spinner-1.0.4] startup
[7.511s] [ext: omni.kit.window.cursor-1.1.1] startup
[7.512s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[7.518s] [ext: omni.graph.nodes-1.48.3] startup
[7.538s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[7.567s] [ext: omni.kit.browser.sample-1.2.5] startup
[7.571s] [ext: omni.graph.scriptnode-0.10.0] startup
[7.575s] [ext: omni.syntheticdata-0.2.4] startup
2023-09-27 12:32:48 [7,536ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[7.600s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 11.4
Devices:
“cpu” | x86_64
“cuda:0” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:1” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:2” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:3” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:4” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:5” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:6” | NVIDIA GeForce RTX 2080 Ti (sm_75)
“cuda:7” | NVIDIA GeForce RTX 2080 Ti (sm_75)
Kernel cache: /home/k.ovais/.cache/warp/0.6.3
[7.938s] [ext: omni.anim.curve-104.16.6] startup
[7.962s] [ext: omni.isaac.debug_draw-0.2.3] startup
[7.970s] [ext: omni.replicator.core-1.7.8] startup
2023-09-27 12:32:49 [8,047ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[8.172s] [ext: omni.kit.widget.timeline-104.0.3] startup
[8.175s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[8.177s] [ext: omni.isaac.range_sensor-0.8.1] startup
[8.229s] [ext: omni.isaac.core_nodes-0.23.2] startup
[8.251s] [ext: omni.anim.curve_editor-104.12.7] startup
[8.270s] [ext: omni.isaac.sensor-5.6.3] startup
2023-09-27 12:32:49 [8,215ms] [Warning] [omni.ext.plugin] [ext: omni.isaac.sensor-5.6.3] Native plugin search dir contains several files: /home/k.ovais/nvidiaDwn/isaac_sim-2022.2.1/exts/omni.isaac.sensor/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[8.332s] [ext: omni.isaac.lula-1.2.1] startup
[8.349s] [ext: omni.isaac.motion_planning-0.2.2] startup
[8.365s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[8.372s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[8.375s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[8.392s] [ext: omni.isaac.motion_generation-4.5.6] startup
[8.400s] [ext: omni.isaac.manipulators-1.1.0] startup
[8.403s] [ext: omni.kit.widget.layers-1.6.11] startup
[8.419s] [ext: omni.isaac.franka-0.4.0] startup
[8.421s] [ext: omni.isaac.utils-0.2.4] startup
[8.426s] [ext: omni.isaac.cortex-0.3.2] startup
[8.427s] [ext: omni.isaac.demos-0.3.3] startup
[8.449s] [ext: omni.isaac.dofbot-0.3.0] startup
[8.450s] [ext: omni.isaac.quadruped-1.3.0] startup
[8.816s] [ext: omni.kit.property.layer-1.1.4] startup
[8.819s] [ext: omni.isaac.universal_robots-0.3.2] startup
[8.820s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[8.824s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[8.828s] [ext: omni.kit.widget.imageview-1.0.3] startup
[8.829s] [ext: omni.kit.property.camera-1.0.3] startup
[8.831s] [ext: omni.kit.property.audio-1.0.6] startup
[8.833s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[8.845s] [ext: omni.isaac.diff_usd-1.0.1] startup
[8.848s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[8.853s] [ext: omni.kit.property.render-1.1.0] startup
[8.855s] [ext: omni.kit.property.material-1.8.19] startup
[8.858s] [ext: omni.kit.property.light-1.0.6] startup
[8.860s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[8.863s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[8.873s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[8.875s] [ext: omni.kit.widgets.custom-1.0.4] startup
[8.887s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[8.888s] [ext: omni.kit.window.stage-2.3.12] startup
[8.893s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[8.902s] [ext: omni.curve.creator-104.1.2] startup
[8.909s] [ext: omni.anim.retarget.core-104.2.1] startup
[8.919s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[8.922s] [ext: omni.hydra.scene_api-0.1.1] startup
[8.932s] [ext: omni.curve.manipulator-104.7.3] startup
[8.954s] [ext: omni.graph.bundle.action-1.3.0] startup
[8.955s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[8.956s] [ext: omni.anim.graph.core-104.2.1] startup
[8.967s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[8.969s] [ext: omni.kit.property.transform-1.3.5] startup
[8.975s] [ext: omni.kit.property.skel-1.0.1] startup
[8.977s] [ext: omni.kit.property.geometry-1.2.2] startup
[8.980s] [ext: omni.anim.graph.ui-104.2.0] startup
[8.995s] [ext: omni.kit.property.bundle-1.2.6] startup
[8.996s] [ext: omni.isaac.examples-1.5.6] startup
2023-09-27 12:32:50 [9,081ms] [Warning] [omni.client.plugin] Tick: authentication: Discovery(ws://localhost:3333): Auth/Credentials service not found!
2023-09-27 12:32:50 [9,082ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
[9.252s] [ext: omni.graph.window.core-1.43.3] startup
[9.263s] [ext: omni.slangnode-104.2.3] startup
[9.281s] [ext: omni.anim.graph.bundle-104.2.0] startup
[9.282s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[9.286s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-09-27 12:32:50 [9,231ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[9.287s] [ext: omni.graph.window.generic-1.3.15] startup
[9.290s] [ext: omni.activity.freeze_monitor-1.0.1] startup
[9.301s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[9.305s] [ext: omni.flowusd-104.2.4] startup
[9.342s] [ext: omni.kit.tool.asset_importer-2.4.0] startup
[9.349s] [ext: omni.anim.skelJoint-104.2.22] startup
[9.356s] [ext: omni.graph.window.action-1.5.5] startup
[9.358s] [ext: omni.isaac.gain_tuner-0.1.1] startup
[9.360s] [ext: omni.anim.retarget.ui-104.2.0] startup
[9.369s] [ext: omni.kit.pointclouds-0.0.16] startup
[9.375s] [ext: omni.isaac.kit-1.4.1] startup
[9.377s] [ext: omni.isaac.merge_mesh-0.1.2] startup
[9.379s] [ext: omni.anim.retarget.bundle-104.2.0] startup
[9.380s] [ext: omni.activity.pump-1.0.0] startup
[9.382s] [ext: omni.isaac.mjcf-0.3.1] startup
[9.391s] [ext: omni.activity.usd_resolver-1.0.1] startup
[9.395s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[9.418s] [ext: omni.isaac.articulation_inspector-0.1.3] startup
[9.421s] [ext: omni.activity.ui-1.0.20] startup
[9.431s] [ext: omni.isaac.scene_blox-0.1.0] startup
[9.433s] [ext: omni.isaac.shapenet-2.0.1] startup
[9.462s] [ext: omni.isaac.synthetic_recorder-1.5.0] startup
[9.466s] [ext: omni.isaac.unit_converter-0.1.6] startup
[9.468s] [ext: omni.kit.widget.calendar-1.0.5] startup
[9.472s] [ext: omni.kit.ngsearch-0.0.10] startup
2023-09-27 12:32:50 [9,534ms] [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
[9.616s] [ext: omni.kit.menu.stage-1.2.1] startup
[9.617s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[9.619s] [ext: omni.kit.tool.collect-2.1.20] startup
[9.624s] [ext: omni.kit.widget.extended_searchfield-1.0.17] startup
[9.641s] [ext: omni.isaac.urdf-0.5.9] startup
[9.686s] [ext: omni.isaac.window.about-1.1.0] startup
[9.688s] [ext: omni.kit.actions.window-1.1.0] startup
[9.694s] [ext: omni.kit.browser.asset-1.2.3] startup
[9.696s] [ext: omni.kit.browser.deepsearch-1.0.20] startup
[9.703s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[9.708s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[9.710s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[9.718s] [ext: omni.kit.importer.cad-0.3.4] startup
[9.791s] [ext: omni.kit.selection-0.1.0] startup
[9.796s] [ext: omni.isaac.extension_templates-1.0.0] startup
[9.798s] [ext: omni.scene.visualization.ui-104.0.6] startup
[9.802s] [ext: omni.kit.menu.aov-1.1.3] startup
[9.803s] [ext: omni.kit.core.collection-0.1.1] startup
[9.807s] [ext: omni.kit.menu.edit-1.1.6] startup
[9.810s] [ext: omni.kit.menu.file-1.1.4] startup
[9.812s] [ext: omni.scene.visualization.bundle-104.0.1] startup
[9.812s] [ext: omni.kit.profiler.window-2.0.5] startup
[9.821s] [ext: omni.kit.property.collection-0.1.10] startup
[9.822s] [ext: omni.kit.property.isaac-0.2.0] startup
[9.825s] [ext: omni.kit.property.sbsar-0.9.9] startup
[9.829s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[9.834s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[9.835s] [ext: omni.kit.quicksearch.hdri-0.8.11] startup
[9.837s] [ext: omni.services.facilities.base-1.0.2] startup
[9.838s] [ext: omni.kit.quicksearch.material-0.8.10] startup
[9.840s] [ext: omni.kit.quicksearch.props-0.8.6] startup
[9.841s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[9.843s] [ext: omni.isaac.asset_browser-0.2.4] startup
[9.845s] [ext: omni.kit.renderer.cuda_interop-1.0.0] startup
[9.848s] [ext: omni.services.core-1.3.0] startup
[10.014s] [ext: omni.rtx.window.settings-0.6.2] startup
[10.028s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[10.030s] [ext: omni.kit.streamsdk.plugins-1.0.1] startup
[10.030s] [ext: omni.kit.livestream.core-0.0.0] startup
[10.034s] [ext: omni.services.transport.client.base-1.2.1] startup
[10.036s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[10.037s] [ext: omni.isaac.physics_inspector-0.1.3] startup
[10.041s] [ext: omni.kit.livestream.native-0.1.5] startup
Active user not found. Using default user [kiosk]Streaming server started.
[10.338s] [ext: omni.services.client-0.4.0] startup
[10.340s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[10.340s] [ext: omni.services.transport.server.base-1.1.0] startup
[10.342s] [ext: omni.kit.agent-0.1.5] startup
[10.344s] [ext: omni.services.transport.client.http_async-1.3.2] startup
[10.345s] [ext: omni.kit.thumbnails.mdl-1.0.20] startup
[10.350s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[10.354s] [ext: omni.services.transport.server.http-1.1.2] startup
[10.371s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[10.375s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[10.377s] [ext: omni.kit.window.toolbar-1.4.0] startup
[10.381s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[10.383s] [ext: omni.kit.browser.material-1.3.3] startup
[10.386s] [ext: omni.kit.window.material_graph-1.6.15] startup
[10.400s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[10.404s] [ext: omni.kit.thumbnails.usd-0.5.2] startup
[10.409s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[10.409s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[10.419s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[10.419s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[10.424s] [ext: omni.kit.window.material-1.1.3] startup
[10.431s] [ext: omni.physx.commands-104.2.4-5.1] startup
[10.439s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[10.446s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[10.449s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[10.454s] [ext: omni.kit.tool.asset_exporter-1.2.0] startup
[10.458s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[10.460s] [ext: omni.kit.tool.remove_unused.controller-0.1.2] startup
[10.462s] [ext: omni.physx.ui-104.2.4-5.1] startup
[10.563s] [ext: omni.kit.usda_edit-1.1.10] startup
[10.752s] [ext: omni.kit.viewport.actions-104.0.3] startup
[10.758s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[10.759s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[10.764s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[10.764s] [ext: omni.kit.widget.collection-0.1.11] startup
[10.769s] [ext: omni.kit.property.physx-0.1.0] startup
[10.795s] [ext: omni.physx.demos-104.2.4-5.1] startup
[10.802s] [ext: omni.kit.viewport.ready-1.0.2] startup
[10.804s] [ext: omni.kit.viewport_widgets_manager-1.0.6] startup
[10.809s] [ext: omni.kit.widget.live-2.0.3] startup
[10.813s] [ext: omni.kit.mesh.raycast-104.3.2] startup
[10.825s] [ext: omni.kit.window.collection-0.1.11] startup
[10.829s] [ext: omni.kit.window.commands-0.2.4] startup
[10.833s] [ext: omni.physx.camera-104.2.4-5.1] startup
[10.844s] [ext: omni.physx.cct-104.2.4-5.1] startup
[10.862s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[10.888s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[10.908s] [ext: omni.paint.system.core-104.5.8] startup
[11.042s] [ext: omni.kit.scripting-104.2.2] startup
2023-09-27 12:32:52 [10,986ms] [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] ‘/home/k.ovais/nvidiaDwn/isaac_sim-2022.2.1/extscache/omni.kit.scripting-104.2.2+104.2.lx64.r.cp37/bin’ in ‘[[native.plugin]]’ was not found.
[11.050s] [ext: omni.kit.search.files-1.0.4] startup
[11.053s] [ext: omni.isaac.physics_utilities-0.1.1] startup
[11.061s] [ext: omni.kit.window.console-0.2.3] startup
[11.081s] [ext: omni.videoencoding-0.1.0] startup
[11.088s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[11.095s] [ext: omni.paint.system.ui-104.3.14] startup
[11.107s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[11.107s] [ext: omni.kit.sequencer.usd-103.3.1] startup
[11.113s] [ext: omni.iray.settings.core-0.6.4] startup
[11.120s] [ext: omni.kit.capture.viewport-1.1.24] startup
[11.126s] [ext: omni.rtx.settings.core-0.5.8] startup
[11.140s] [ext: omni.physx.zerogravity-104.2.4-5.1] startup
[11.161s] [ext: omni.kit.preferences.time-0.2.0] startup
[11.167s] [ext: omni.kit.property.sequence-0.2.0] startup
[11.171s] [ext: omni.kit.sequencer.core-103.3.0] startup
[11.175s] [ext: omni.particle.system.core-104.7.19] startup
[11.194s] [ext: omni.kit.window.movie_capture-2.1.8] startup
[11.206s] [ext: omni.paint.brush.scatter-104.2.12] startup
[11.216s] [ext: omni.kit.window.privacy-0.1.0] startup
[11.217s] [ext: omni.kit.window.script_editor-1.7.2] startup
[11.222s] [ext: omni.kit.window.sequencer-103.3.4] startup
[11.262s] [ext: omni.graph.window.particle.system-104.5.3] startup
[11.267s] [ext: omni.paint.brush.attributes-1.1.2] startup
[11.274s] [ext: omni.paint.brush.modify-104.3.2] startup
[11.282s] [ext: omni.paint.brush.scripting-104.7.0] startup
[11.295s] [ext: omni.scene.optimizer.core-104.1.5] startup
[11.304s] [ext: omni.paint.brush.select-104.3.2] startup
[11.316s] [ext: omni.particle.system.ui-104.5.1] startup
[11.347s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.2] startup
[11.374s] [ext: omni.kit.window.status_bar-0.1.5] startup
[11.382s] [ext: omni.kit.window.usd_paths-1.0.4] startup
[11.384s] [ext: omni.scene.optimizer.ui-104.1.5] startup
[11.388s] [ext: omni.paint.system.bundle-104.8.26] startup
[11.389s] [ext: omni.particle.system.bundle-104.2.24] startup
[11.389s] [ext: omni.replicator.composer-1.2.10] startup
[11.397s] [ext: omni.replicator.isaac-1.7.4] startup
[11.420s] [ext: omni.resourcemonitor-1.0.0] startup
[11.432s] [ext: omni.scene.optimizer.bundle-104.1.5] startup
[11.432s] [ext: omni.kit.search.service-0.1.5] startup
[11.444s] [ext: omni.services.starfleet.auth-0.1.4] startup
[11.455s] [ext: omni.services.usd-1.1.0] startup
[11.459s] [ext: omni.tools.array-104.0.12] startup
[11.474s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load …
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[11.478s] [ext: omni.tools.pivot-104.1.0] startup
[11.492s] [ext: omni.anim.shared-104.14.1] startup
[11.505s] [ext: omni.tools.randomizer-104.0.9] startup
[11.515s] [ext: omni.kit.quicklayout-1.1.1] startup
[11.519s] [ext: omni.kit.window.title-1.1.2] startup
[11.521s] [ext: semantics.schema.editor-0.3.3] startup
[11.528s] [ext: omni.kit.stage.mdl_converter-1.0.1] startup
[11.532s] [ext: omni.isaac.robot_description_editor-2.1.1] startup
[11.535s] [ext: omni.anim.timeline-104.0.7] startup
[11.543s] [ext: omni.isaac.onshape-0.6.2] startup
[12.376s] [ext: omni.kit.window.stats-0.1.2] startup
[12.379s] [ext: omni.isaac.app.setup-0.8.1] startup
[12.384s] Isaac Sim Headless Native Version: 2022.2.1-rc.14
[12.416s] [ext: omni.isaac.ros_bridge-1.11.2] startup
2023-09-27 12:32:53 [12,407ms] [Warning] [omni.isaac.ros_bridge.scripts.extension] ROS_MASTER_URI not set, using default, ROS_MASTER_URI=http://localhost:11311
[12.487s] Writing Isaac Sim icon file
[12.487s] [ext: omni.isaac.assets_check-0.3.2] startup
[12.501s] [ext: omni.isaac.sim.base-2022.2.1] startup
[12.502s] [ext: omni.isaac.sim.headless.native-2022.2.1] startup
2023-09-27 12:32:53 [12,573ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : CUDA module initialization failed.
2023-09-27 12:32:53 [12,573ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : The version of your CUDA driver is 11.4, but 11.6 is the required minimum
2023-09-27 12:32:53 [12,573ms] [Warning] [rtx.neuraylib.plugin] [CUDA:RENDER] 0.1 CUDA rend warn : Please update your display driver (current version 470.199.2) (www.nvidia.com) to at least 510.73.05.
2023-09-27 12:32:53 [12,753ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : Your NVIDIA driver supports CUDA version up to 11.4; iray photoreal requires CUDA version 11.6; iray photoreal can only run in CPU mode. Please update your NVIDIA driver (www.nvidia.com) to at least 510.73.05.
2023-09-27 12:32:53 [12,753ms] [Warning] [rtx.neuraylib.plugin] [IRAY:RENDER] 1.1 IRAY rend warn : There is no CUDA-capable GPU available to the iray photoreal renderer.
[13.146s] app ready
[19.379s] RTX ready
[19.440s] Isaac Sim Headless Native App is loaded.
Can you update to the 525 drivers?
I run command sudo ubuntu-drivers list --gpgpu
it shows following drivers
nvidia-driver-535-server-open, (kernel modules provided by linux-modules-nvidia-535-server-open-generic-hwe-22.04)
nvidia-driver-520, (kernel modules provided by nvidia-dkms-520)
nvidia-driver-525-server, (kernel modules provided by linux-modules-nvidia-525-server-generic-hwe-22.04)
nvidia-driver-535-server, (kernel modules provided by linux-modules-nvidia-535-server-generic-hwe-22.04)
nvidia-driver-470-server, (kernel modules provided by linux-modules-nvidia-470-server-generic-hwe-22.04)
nvidia-driver-418-server, (kernel modules provided by nvidia-dkms-418-server)
nvidia-driver-535-open, (kernel modules provided by linux-modules-nvidia-535-open-generic-hwe-22.04)
nvidia-driver-525-open, (kernel modules provided by linux-modules-nvidia-525-open-generic-hwe-22.04)
nvidia-driver-530, (kernel modules provided by nvidia-dkms-530)
nvidia-driver-450-server, (kernel modules provided by linux-modules-nvidia-450-server-generic-hwe-22.04)
nvidia-driver-535, (kernel modules provided by linux-modules-nvidia-535-generic-hwe-22.04)
Hi @voffice.org - Can you try to update to 525-server driver? if that doesn’t work then 525-open driver.
Thanks@ [Sheikh_Dawood], @ [rthaker] for respoce, Upadating dricers is not feasible for now as other colleague are accessing the same server. I have to wait till admin updates the server drivers,
once again thankd for your help
