I was trying to launch the issac sim on my ubuntu 22.04 but it failed to launch, here is the log: 2024-07-10 21:26:00 [3,709ms] [Error] [carb.graphics-vulkan.plugin] Failed to find device surface formats.
2024-07-10 21:26:00 [3,710ms] [Error] [carb.graphics-vulkan.plugin] Failed to create a swapchain.
free(): invalid pointer
2024-07-10 21:26:00 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-07-10 21:26:00 [17ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip’ for upload.
‘crashreport.gui’ exited with code 1272024-07-10 21:26:01 [149ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip’
2024-07-10 21:26:01 [166ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip’ svr:‘https://services.nvidia.com/submit’
2024-07-10 21:26:01 [178ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2024-07-10 21:26:01 [191ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘158.3+release158.tc9506.b2fcff1c’
2024-07-10 21:26:01 [203ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Wed Jul 10 21:26:00 2024 GMT’
2024-07-10 21:26:01 [216ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2024-07-10 21:26:01 [228ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘f9099011-29f8-4407-e0fd4b9e-5f70375c’
2024-07-10 21:26:01 [235ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2024-07-10 21:26:01 [247ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.py.txt’’
2024-07-10 21:26:01 [260ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2024-07-10 21:26:01 [273ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1720646757’
2024-07-10 21:26:01 [286ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2024-07-10 21:26:01 [298ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘3’
2024-07-10 21:26:01 [310ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2024-07-10 21:26:01 [323ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 127’
2024-07-10 21:26:01 [335ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘105.1.2+release.133510.b82c1e1e.tc’
2024-07-10 21:26:01 [342ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2024-07-10 21:26:01 [348ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2024-07-10 21:26:01 [355ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2024-07-10 21:26:01 [368ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2022.2’
2024-07-10 21:26:01 [380ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim’
2024-07-10 21:26:01 [393ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘startup’
2024-07-10 21:26:01 [405ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘2023.1.1’
2024-07-10 21:26:01 [418ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2024-07-10 21:26:01 [430ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘release’
2024-07-10 21:26:01 [437ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘tc’
2024-07-10 21:26:01 [450ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘b82c1e1e’
2024-07-10 21:26:01 [462ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildId = ‘18571592’
2024-07-10 21:26:01 [475ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘105’
2024-07-10 21:26:01 [487ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘1’
2024-07-10 21:26:01 [494ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMr = ‘0’
2024-07-10 21:26:01 [506ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘133510’
2024-07-10 21:26:01 [519ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘2’
2024-07-10 21:26:01 [531ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘105.1.2’
2024-07-10 21:26:01 [543ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘./kit/kit ./apps/omni.isaac.sim.kit --ext-folder ./apps -vv’
2024-07-10 21:26:01 [556ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 6 Model 183 Stepping 1’
2024-07-10 21:26:01 [562ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘13th Gen Intel(R) Core™ i9-13900HX’
2024-07-10 21:26:01 [575ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘GenuineIntel’
2024-07-10 21:26:01 [588ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2024-07-10 21:26:01 [599ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘1920x1080’
2024-07-10 21:26:01 [612ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘1’
2024-07-10 21:26:01 [625ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] email = ‘’
2024-07-10 21:26:01 [631ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2024-07-10 21:26:01 [644ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] experience = ‘Isaac Sim’
2024-07-10 21:26:01 [657ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2024-07-10 21:26:01 [670ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘550.67’
2024-07-10 21:26:01 [682ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_1 = ‘0x6000003’
2024-07-10 21:26:01 [695ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘8585740288’
2024-07-10 21:26:01 [708ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_1 = ‘25113357312’
2024-07-10 21:26:01 [720ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA GeForce RTX 4060 Laptop GPU’
2024-07-10 21:26:01 [733ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpu_1 = ‘Intel(R) Graphics (RPL-S)’
2024-07-10 21:26:01 [746ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘550.67’
2024-07-10 21:26:01 [758ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 26.2138/31.1848GB, Swap: 4/4GB, VM: 1.71799e+10/1.71799e+10GB’
2024-07-10 21:26:01 [771ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = 'Wed Jul 10 16:25:59 2024
| NVIDIA-SMI 550.67 Driver Version: 550.67 CUDA Version: 12.4 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4060 … Off | 00000000:01:00.0 Off | N/A |
| N/A 47C P0 588W / 115W | 1MiB / 8188MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
2024-07-10 21:26:01 [784ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2024-07-10 21:26:01 [797ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.4 LTS (Jammy Jellyfish)’
2024-07-10 21:26:01 [809ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.4’
2024-07-10 21:26:01 [822ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2024-07-10 21:26:01 [834ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘1920x1080x32bit@144Hz’
2024-07-10 21:26:01 [847ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2024-07-10 21:26:01 [860ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2024-07-10 21:26:01 [872ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2024-07-10 21:26:01 [879ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2024-07-10 21:26:01 [892ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2024-07-10 21:26:01 [904ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2024-07-10 21:26:01 [917ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| Driver Version: 550.67 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 4060 Laptop… | Yes: 0 | | 8188 MB | 10de | 0 |
| | | | | | 28a0 | afdc62df… |
| | | | | | 1 | |
| 1 | Intel(R) Graphics (RPL-S) | | | 23949 MB | 8086 | 0 |
| | | | | | a788 | 868088a7… |
| | | | | | 0 | |
| OS: 22.04.4 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.4, Kernel: 6.9.3-76060903-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 13th Gen Intel(R) Core™ i9-13900HX | Cores: 24 | Logical: 48
| Total Memory (MB): 31933 | Free Memory: 28014
| Total Page/Swap (MB): 4095 | Free Page/Swap: 4095
2024-07-10 21:26:01 [930ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘9717667312662467791’
2024-07-10 21:26:01 [936ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2024-07-10 21:26:01 [949ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2024-07-10 21:26:01 [962ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/home//.local/share/ov/pkg/isaac-sim-2023.1.1’
2024-07-10 21:26:01 [974ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2024-07-10 21:26:01 [987ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] upload_file_minidump = ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip’
2024-07-10 21:26:02 [1,784ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip’, code:200, response:
2024-07-10 21:26:02 [1,792ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] 02177c00-3f03-11ef-95f4-06f35c726b77
2024-07-10 21:26:02 [1,805ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip’ (use setting “/crashreporter/preserveDump=true” to save)
2024-07-10 21:26:02 [1,817ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.dmp.zip.toml’
2024-07-10 21:26:02 [1,822ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] the dump file was deleted due to a successful upload. Its originalsize was 247709 bytes and was readable.
2024-07-10 21:26:02 [1,835ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 28313 thread 28313
2024-07-10 21:26:02 [1,851ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2024-07-10 21:26:02 [1,864ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘158.3+release158.tc9506.b2fcff1c’
2024-07-10 21:26:02 [1,877ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Wed Jul 10 21:26:00 2024 GMT’
2024-07-10 21:26:02 [1,882ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2024-07-10 21:26:02 [1,895ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘f9099011-29f8-4407-e0fd4b9e-5f70375c’
2024-07-10 21:26:02 [1,907ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2024-07-10 21:26:02 [1,920ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/home/jliu/.local/share/ov/data/Kit/Isaac-Sim/2023.1/f9099011-29f8-4407-e0fd4b9e-5f70375c.py.txt’’
2024-07-10 21:26:02 [1,933ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2024-07-10 21:26:02 [1,939ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1720646757’
2024-07-10 21:26:02 [1,952ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2024-07-10 21:26:02 [1,965ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘3’
2024-07-10 21:26:02 [1,977ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2024-07-10 21:26:02 [1,990ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 127’
2024-07-10 21:26:02 [1,996ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘105.1.2+release.133510.b82c1e1e.tc’
2024-07-10 21:26:02 [2,009ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_enabled = ‘1’
2024-07-10 21:26:02 [2,022ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_flags = ‘3’
2024-07-10 21:26:02 [2,034ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_status = ‘auto-enabled’
2024-07-10 21:26:02 [2,047ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] aftermath_version = ‘2022.2’
2024-07-10 21:26:03 [2,054ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim’
2024-07-10 21:26:03 [2,060ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘startup’
2024-07-10 21:26:03 [2,073ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘2023.1.1’
2024-07-10 21:26:03 [2,086ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2024-07-10 21:26:03 [2,099ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘release’
2024-07-10 21:26:03 [2,112ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘tc’
2024-07-10 21:26:03 [2,124ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘b82c1e1e’
2024-07-10 21:26:03 [2,137ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildId = ‘18571592’
2024-07-10 21:26:03 [2,154ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘105’
2024-07-10 21:26:03 [2,160ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘1’
2024-07-10 21:26:03 [2,177ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMr = ‘0’
2024-07-10 21:26:03 [2,190ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘133510’
2024-07-10 21:26:03 [2,203ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘2’
2024-07-10 21:26:03 [2,215ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘105.1.2’
2024-07-10 21:26:03 [2,228ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘./kit/kit ./apps/omni.isaac.sim.kit --ext-folder ./apps -vv’
2024-07-10 21:26:03 [2,240ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 6 Model 183 Stepping 1’
2024-07-10 21:26:03 [2,253ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘13th Gen Intel(R) Core™ i9-13900HX’
2024-07-10 21:26:03 [2,265ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘GenuineIntel’
2024-07-10 21:26:03 [2,278ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] desktopOrigin = ‘(0, 0)’
2024-07-10 21:26:03 [2,291ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] desktopSize = ‘1920x1080’
2024-07-10 21:26:03 [2,304ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] displayCount = ‘1’
2024-07-10 21:26:03 [2,317ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] email = ‘’
2024-07-10 21:26:03 [2,323ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2024-07-10 21:26:03 [2,336ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] experience = ‘Isaac Sim’
2024-07-10 21:26:03 [2,349ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2024-07-10 21:26:03 [2,362ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_0 = ‘550.67’
2024-07-10 21:26:03 [2,375ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuDriver_1 = ‘0x6000003’
2024-07-10 21:26:03 [2,388ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_0 = ‘8585740288’
2024-07-10 21:26:03 [2,400ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpuVRAM_1 = ‘25113357312’
2024-07-10 21:26:03 [2,413ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpu_0 = ‘NVIDIA GeForce RTX 4060 Laptop GPU’
2024-07-10 21:26:03 [2,426ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] gpu_1 = ‘Intel(R) Graphics (RPL-S)’
2024-07-10 21:26:03 [2,438ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] kitRendererDriverVersion = ‘550.67’
2024-07-10 21:26:03 [2,450ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 26.2138/31.1848GB, Swap: 4/4GB, VM: 1.71799e+10/1.71799e+10GB’
2024-07-10 21:26:03 [2,463ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = 'Wed Jul 10 16:25:59 2024
| | | MIG M. |
| | | N/A |
| Processes: |
| ID ID Usage |
2024-07-10 21:26:03 [2,475ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2024-07-10 21:26:03 [2,480ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.4 LTS (Jammy Jellyfish)’
2024-07-10 21:26:03 [2,493ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.4’
2024-07-10 21:26:03 [2,506ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2024-07-10 21:26:03 [2,519ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] primaryDisplayRes = ‘1920x1080x32bit@144Hz’
2024-07-10 21:26:03 [2,532ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2024-07-10 21:26:03 [2,544ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_debugSymbols = ‘0’
2024-07-10 21:26:03 [2,557ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIncludeOverrides = ‘0’
2024-07-10 21:26:03 [2,564ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_dumpIntermediates = ‘0’
2024-07-10 21:26:03 [2,576ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_obfuscateCode = ‘1’
2024-07-10 21:26:03 [2,589ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] shaderdb_optimizationLevel = ‘1’
2024-07-10 21:26:03 [2,602ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ’
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| | | | | | 28a0 | afdc62df… |
| | | | | | 1 | |
| | | | | | a788 | 868088a7… |
| | | | | | 0 | |
2024-07-10 21:26:03 [2,609ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘9717667312662467791’
2024-07-10 21:26:03 [2,621ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2024-07-10 21:26:03 [2,634ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2024-07-10 21:26:03 [2,647ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/home//.local/share/ov/pkg/isaac-sim-2023.1.1’
2024-07-10 21:26:03 [2,660ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 28313 backtrace follows:
2024-07-10 21:26:03 [2,732ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2024-07-10 21:26:03 [2,783ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!pthread_kill+0x12c (./nptl/pthread_kill.c:44)
2024-07-10 21:26:03 [2,833ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!raise+0x16 (./signal/…/sysdeps/posix/raise.c:27)
2024-07-10 21:26:03 [2,883ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libc.so.6!abort+0xd3 (./stdlib/abort.c:81 (discriminator 21))
2024-07-10 21:26:03 [2,933ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libc.so.6!__fsetlocking+0x426 (./libio/…/sysdeps/posix/libc_fatal.c:155)
2024-07-10 21:26:03 [2,998ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libc.so.6!timer_settime+0x2cc (./malloc/malloc.c:5668)
2024-07-10 21:26:04 [3,058ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libc.so.6!__default_morecore+0x494 (./malloc/malloc.c:4439)
2024-07-10 21:26:04 [3,118ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libc.so.6!free+0x73 (./malloc/malloc.c:3394)
2024-07-10 21:26:04 [3,127ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libvulkan.so.1!vkGetPhysicalDeviceSurfaceFormats2KHR+0x2ea (??:?)
2024-07-10 21:26:04 [3,141ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libcarb.graphics-vulkan.plugin.so!void std::vector<unsigned int, std::allocator >::_M_realloc_insert(__gnu_cxx::__normal_iterator<unsigned int*, std::vector<unsigned int, std::allocator > >, unsigned int&&)+0xc17c (??:?)
2024-07-10 21:26:04 [3,153ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.kit.renderer.plugin.so!std::string::insert(unsigned long, char const*, unsigned long)+0x1ae0 (??:?)
2024-07-10 21:26:04 [3,167ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.kit.renderer.plugin.so!std::string::insert(unsigned long, char const*, unsigned long)+0x2b37 (??:?)
2024-07-10 21:26:04 [3,179ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.kit.renderer.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::erase(std::__detail::_Node_const_iterator<void*, true, false>)+0x52b8 (??:?)
2024-07-10 21:26:04 [3,190ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x3345 (??:?)
2024-07-10 21:26:04 [3,203ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x67a8 (??:?)
2024-07-10 21:26:04 [3,216ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x751f (??:?)
2024-07-10 21:26:04 [3,229ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.kit.renderer.init.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identitystd::string, std::lessstd::string, std::allocatorstd::string >::_M_get_insert_hint_unique_pos(std::_Rb_tree_const_iteratorstd::string, std::string const&)+0x3cf7 (??:?)
2024-07-10 21:26:04 [3,241ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x8084 (??:?)
2024-07-10 21:26:04 [3,253ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x88ae (??:?)
2024-07-10 21:26:04 [3,266ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x8bff (??:?)
2024-07-10 21:26:04 [3,278ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libomni.kit.renderer.ext.plugin.so!std::string::find(char, unsigned long) const+0x14cc (??:?)
2024-07-10 21:26:04 [3,293ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libomni.ext.plugin.so!std::string& std::vector<std::string, std::allocatorstd::string >::emplace_back<char const*&>(char const*&)+0x4522 (??:?)
2024-07-10 21:26:04 [3,305ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libomni.ext.plugin.so!std::basic_string<char, std::char_traits, std::allocator >::basic_string(std::string const&, unsigned long, unsigned long)+0x45f9 (??:?)
2024-07-10 21:26:04 [3,317ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libomni.ext.plugin.so!std::string::replace(unsigned long, unsigned long, char const*, unsigned long)+0xa6bd (??:?)
2024-07-10 21:26:04 [3,330ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libomni.ext.plugin.so!carbOnPluginPreStartup+0x2193 (??:?)
2024-07-10 21:26:04 [3,342ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libomni.ext.plugin.so!carbOnPluginPreStartup+0x10e06 (??:?)
2024-07-10 21:26:04 [3,356ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libomni.ext.plugin.so!carbOnPluginPreStartup+0x11e03 (??:?)
2024-07-10 21:26:04 [3,368ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libomni.kit.app.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)+0x7f33 (??:?)
2024-07-10 21:26:04 [3,381ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libomni.kit.app.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)+0x886c (??:?)
2024-07-10 21:26:04 [3,393ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libomni.kit.app.plugin.so!_init+0x5d6e (??:0)
2024-07-10 21:26:04 [3,402ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: kit!_init+0x6eb (??:0)
2024-07-10 21:26:04 [3,461ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libc.so.6!__libc_init_first+0x90 (./csu/…/sysdeps/nptl/libc_start_call_main.h:58)
2024-07-10 21:26:04 [3,509ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libc.so.6!__libc_start_main+0x80 (./csu/…/csu/libc-start.c:128)
2024-07-10 21:26:04 [3,519ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: kit!_start+0x29 (??:?)
Aborted (core dumped)
