I started isaac-sim and got segmentation fault
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Isaac Lab Version (if applicable)
1.2
1.1
1.0
Operating System
Ubuntu 22.04 (6.8.0-48-generic)
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: GeForce RTX 2070
  • Driver Version: 535.183.01
Topic Description
Detailed Description
I tried to start Isaac-Sim from omniverse launcher and I was getting a crash error.
So I tried to start Isaac-Sim from CUI and got the following error.
Steps to Reproduce
  1. cd $HOME/.local/share/ov/pkg/isaac-sim-4.2.0
  2. ./isaac-sim.sh
Error Messages
Loading user config located at: '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/user.config.json'
[Info] [carb] Logging to file: /home/dai_guard/.nvidia-omniverse/logs/Kit/Isaac-Sim_App_Selector/4.2/kit_20241103_235729.log
[0.151s] [ext: omni.kit.async_engine-0.0.1] startup
[0.203s] [ext: omni.stats-1.0.1] startup
[0.204s] [ext: omni.client-1.2.0] startup
[0.228s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.232s] [ext: omni.assets.plugins-0.0.0] startup
[0.233s] [ext: omni.gpu_foundation-0.0.0] startup
[0.239s] [ext: carb.windowing.plugins-1.0.0] startup
[0.246s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 535.183.01    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 2070 SUPER    | Yes: 0 |     | 8438    MB | 10de      | 0          |
|     |                                  |        |     |            | 1e84      | 14273390.. |
|     |                                  |        |     |            | 1         |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-48-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: Intel(R) Core(TM) i7-10700K CPU @ 3.80GHz | Cores: 8 | Logical: 16
| Total Memory (MB): 32010 | Free Memory: 28778
| Total Page/Swap (MB): 30516 | Free Page/Swap: 30516
[0.707s] [ext: omni.kit.pipapi-0.0.0] startup
[0.708s] [ext: omni.materialx.libs-1.0.4] startup
[0.715s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.715s] [ext: omni.usd.config-1.0.4] startup
[0.719s] [ext: omni.usd.libs-1.0.1] startup
[0.790s] [ext: omni.kit.loop-isaac-1.2.0] startup
[0.791s] [ext: omni.appwindow-1.1.8] startup
[0.795s] [ext: omni.kit.renderer.core-1.0.2] startup
2024-11-03 14:57:30 [769ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INITIALIZATION_FAILED
2024-11-03 14:57:30 [769ms] [Error] [carb.graphics-vulkan.plugin] vkCreateSwapchainKHR failed.
2024-11-03 14:57:30 [769ms] [Error] [carb.graphics-vulkan.plugin] Failed to create a swapchain.
2024-11-03 14:57:30 [769ms] [Error] [omni.kit.renderer.plugin] createSwapchain failed. Width: 65516, height: 565, Format: 9
2024-11-03 14:57:30 [769ms] [Error] [omni.kit.renderer.plugin] Failed to initialize graphics environment.
[0.834s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.837s] [ext: omni.kit.renderer.imgui-1.0.1] startup
2024-11-03 14:57:30 [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-11-03 14:57:30 [25ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip' for upload.
2024-11-03 14:57:30 [130ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp' with 10 retries remaining.
2024-11-03 14:57:30 [136ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.toml' with 10 retries remaining.
'crashreport.gui' exited with code 1272024-11-03 14:57:30 [153ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip'
2024-11-03 14:57:30 [159ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:'/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip' svr:'https://services.nvidia.com/submit'
2024-11-03 14:57:30 [165ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2024-11-03 14:57:30 [172ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'BuildGitlabJobID' = '110521993'
2024-11-03 14:57:30 [178ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'CarbSdkVersion' = '173.5+release.6562.3a7379eb.gl'
2024-11-03 14:57:30 [184ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'CrashTime' = 'Sun Nov  3 14:57:30 2024 GMT'
2024-11-03 14:57:30 [190ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'DriverShaderCacheWrapper' = 'disabled'
2024-11-03 14:57:30 [196ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'DumpId' = '78b92d69-744f-4da0-ab65a4a5-b3aaed19'
2024-11-03 14:57:30 [202ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'LastUploadStatus' = ''
2024-11-03 14:57:30 [208ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'ProductName' = 'OmniverseKit'
2024-11-03 14:57:30 [214ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'PythonTracebackStatus' = ''py-spy' successfully wrote info to '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.py.txt''
2024-11-03 14:57:30 [220ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'RetryCount' = '0'
2024-11-03 14:57:30 [227ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'StartupTime' = '1730645849'
2024-11-03 14:57:30 [233ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UploadSuccessful' = '0'
2024-11-03 14:57:30 [239ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UptimeSeconds' = '1'
2024-11-03 14:57:30 [245ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UserStory' = ''
2024-11-03 14:57:30 [251ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'UserStoryStatus' = ''crashreport.gui' exited with code 127'
2024-11-03 14:57:30 [257ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'Version' = '106.1.0+release.140981.10a4b5c0.gl'
2024-11-03 14:57:30 [263ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_enabled' = '1'
2024-11-03 14:57:30 [269ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_flags' = '3'
2024-11-03 14:57:30 [275ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_status' = 'auto-enabled'
2024-11-03 14:57:30 [281ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'aftermath_version' = '2024.1'
2024-11-03 14:57:30 [287ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'appName' = 'Isaac-Sim_App_Selector'
2024-11-03 14:57:30 [293ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'appState' = 'startup'
2024-11-03 14:57:30 [299ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'appVersion' = '4.2.0'
2024-11-03 14:57:30 [305ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'autoloadExts' = ''
2024-11-03 14:57:30 [311ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildBranch' = 'release'
2024-11-03 14:57:30 [317ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildCi' = 'gl'
2024-11-03 14:57:30 [323ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildConfig' = 'release'
2024-11-03 14:57:30 [330ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildGitlabJobName' = 'kit-build-release-linux-x86_64'
2024-11-03 14:57:30 [336ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildGitlabJobStage' = 'kit-build'
2024-11-03 14:57:30 [342ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildGitlabPipelineID' = '18272252'
2024-11-03 14:57:30 [348ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildHash' = '10a4b5c0'
2024-11-03 14:57:30 [354ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildMajor' = '106'
2024-11-03 14:57:30 [360ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildMinor' = '1'
2024-11-03 14:57:30 [366ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildNumber' = '140981'
2024-11-03 14:57:30 [372ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildPatch' = '0'
2024-11-03 14:57:30 [378ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'buildVersion' = '106.1.0'
2024-11-03 14:57:30 [384ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'commandLine' = './kit/kit ./apps/omni.isaac.sim.selector.kit --ext-folder ./apps'
2024-11-03 14:57:30 [390ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'email' = ''
2024-11-03 14:57:30 [396ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'environmentName' = 'default'
2024-11-03 14:57:30 [402ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'kitRendererDriverVersion' = '535.183'
2024-11-03 14:57:30 [408ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'memoryStats' = '(avail/total) RAM: 27.1737/31.2606GB, Swap: 29.8018/29.8018GB, VM: 1.71799e+10/1.71799e+10GB'
2024-11-03 14:57:30 [414ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'nvidia-smi' = '
==============NVSMI LOG==============
Timestamp                                 : Sun Nov  3 23:57:29 2024
Driver Version                            : 535.183.01
CUDA Version                              : 12.2
Attached GPUs                             : 1
GPU 00000000:01:00.0
    Product Name                          : NVIDIA GeForce RTX 2070 SUPER
    Product Brand                         : GeForce
    Product Architecture                  : Turing
    Display Mode                          : Enabled
    Display Active                        : Enabled
    Persistence Mode                      : Disabled
    Addressing Mode                       : None
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Accounting Mode                       : Disabled
    Accounting Mode Buffer Size           : 4000
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : N/A
    GPU UUID                              : GPU-14273390-9776-9298-c9ac-ed4891430e39
    Minor Number                          : 0
    VBIOS Version                         : 90.04.95.00.58
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Board Part Number                     : N/A
    GPU Part Number                       : 1E84-410-A1
    FRU Part Number                       : N/A
    Module ID                             : 1
    Inforom Version
        Image Version                     : G001.0000.02.04
        OEM Object                        : 1.1
        ECC Object                        : N/A
        Power Management Object           : N/A
    Inforom BBX Object Flush
        Latest Timestamp                  : N/A
        Latest Duration                   : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GSP Firmware Version                  : N/A
    GPU Virtualization Mode
        Virtualization Mode               : None
        Host VGPU Mode                    : N/A
    GPU Reset Status
        Reset Required                    : No
        Drain and Reset Recommended       : N/A
    IBMNPU
        Relaxed Ordering Mode             : N/A
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        Device Id                         : 0x1E8410DE
        Bus Id                            : 00000000:01:00.0
        Sub System Id                     : 0x38601462
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 1
                Device Current            : 1
                Device Max                : 3
                Host Max                  : 3
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
        Replays Since Reset               : 0
        Replay Number Rollovers           : 0
        Tx Throughput                     : 2000 KB/s
        Rx Throughput                     : 102000 KB/s
        Atomic Caps Inbound               : N/A
        Atomic Caps Outbound              : N/A
    Fan Speed                             : 25 %
    Performance State                     : P0
    Clocks Event Reasons
        Idle                              : Not Active
        Applications Clocks Setting       : Not Active
        SW Power Cap                      : Active
        HW Slowdown                       : Not Active
            HW Thermal Slowdown           : Not Active
            HW Power Brake Slowdown       : Not Active
        Sync Boost                        : Not Active
        SW Thermal Slowdown               : Not Active
        Display Clock Setting             : Not Active
    Sparse Operation Mode                 : N/A
    FB Memory Usage
        Total                             : 8192 MiB
        Reserved                          : 225 MiB
        Used                              : 462 MiB
        Free                              : 7503 MiB
    BAR1 Memory Usage
        Total                             : 256 MiB
        Used                              : 17 MiB
        Free                              : 239 MiB
    Conf Compute Protected Memory Usage
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Compute Mode                          : Default
    Utilization
        Gpu                               : 2 %
        Memory                            : 7 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Errors
        Volatile
            SRAM Correctable              : N/A
            SRAM Uncorrectable            : N/A
            DRAM Correctable              : N/A
            DRAM Uncorrectable            : N/A
        Aggregate
    Retired Pages
        Single Bit ECC                    : N/A
        Double Bit ECC                    : N/A
        Pending Page Blacklist            : N/A
    Remapped Rows                         : N/A
    Temperature
        GPU Current Temp                  : 33 C
        GPU T.Limit Temp                  : N/A
        GPU Shutdown Temp                 : 95 C
        GPU Slowdown Temp                 : 92 C
        GPU Max Operating Temp            : 88 C
        GPU Target Temperature            : 83 C
        Memory Current Temp               : N/A
        Memory Max Operating Temp         : N/A
    GPU Power Readings
        Power Draw                        : 14.35 W
        Current Power Limit               : 235.00 W
        Requested Power Limit             : 235.00 W
        Default Power Limit               : 235.00 W
        Min Power Limit                   : 125.00 W
        Max Power Limit                   : 235.00 W
    Module Power Readings
        Power Draw                        : N/A
        Current Power Limit               : N/A
        Requested Power Limit             : N/A
        Default Power Limit               : N/A
        Min Power Limit                   : N/A
        Max Power Limit                   : N/A
    Clocks
        Graphics                          : 1395 MHz
        SM                                : 1395 MHz
        Memory                            : 7000 MHz
        Video                             : 1290 MHz
    Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Default Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 2115 MHz
        SM                                : 2115 MHz
        Memory                            : 7001 MHz
        Video                             : 1950 MHz
    Max Customer Boost Clocks
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
        Auto Boost Default                : N/A
    Voltage
        Graphics                          : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
    Processes
        GPU instance ID                   : N/A
        Compute instance ID               : N/A
        Process ID                        : 3380
            Type                          : G
            Used GPU Memory               : 254 MiB
        Process ID                        : 3529
            Type                          : G
            Used GPU Memory               : 120 MiB
        Process ID                        : 4168
            Type                          : G
            Used GPU Memory               : 28 MiB
        Process ID                        : 15863
            Type                          : G
            Used GPU Memory               : 40 MiB
        Process ID                        : 18916
            Type                          : C
            Used GPU Memory               : 18 MiB
2024-11-03 14:57:30 [420ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'portableMode' = '0'
2024-11-03 14:57:30 [427ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'runningInContainer' = '0'
2024-11-03 14:57:30 [433ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_debugSymbols' = '0'
2024-11-03 14:57:30 [439ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_dumpIncludeOverrides' = '0'
2024-11-03 14:57:30 [445ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_dumpIntermediates' = '0'
2024-11-03 14:57:30 [451ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_obfuscateCode' = '1'
2024-11-03 14:57:30 [457ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'shaderdb_optimizationLevel' = '1'
2024-11-03 14:57:30 [463ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'systemInfo' = '
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
|     |                                  |        |     |            | 1e84      | 14273390.. |
|     |                                  |        |     |            | 1         |            |
2024-11-03 14:57:30 [469ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'telemetrySessionId' = '1843360401883066869'
2024-11-03 14:57:30 [475ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'terminatedByAbort' = '0'
2024-11-03 14:57:30 [481ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'userId' = 'default'
2024-11-03 14:57:30 [487ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'workingDirectory' = '/home/<username>/.local/share/ov/pkg/isaac-sim-4.2.0'
2024-11-03 14:57:30 [493ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash report files for upload:
2024-11-03 14:57:30 [499ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]   'upload_file_minidump' = '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip'
2024-11-03 14:57:31 [1,427ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] uploaded minidump: file: '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip', code:200, response:
2024-11-03 14:57:31 [1,441ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]     f395d400-99f3-11ef-a45d-02c180df6437
2024-11-03 14:57:31 [1,448ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save)
2024-11-03 14:57:31 [1,454ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip' with 10 retries remaining.
2024-11-03 14:57:31 [1,460ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Deleting file: '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip.toml'
2024-11-03 14:57:31 [1,467ms] [Info] [carb.crashreporter-breakpad.plugin] attempting to delete the file '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.dmp.zip.toml' with 10 retries remaining.
2024-11-03 14:57:31 [1,473ms] [Error] [carb.crashreporter-breakpad.plugin] [crash]     dump file size is 0 bytes, file is readable.
2024-11-03 14:57:31 [1,479ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 18916 thread 18916
2024-11-03 14:57:31 [1,485ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2024-11-03 14:57:31 [1,491ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  BuildGitlabJobID = '110521993'
2024-11-03 14:57:31 [1,497ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CarbSdkVersion = '173.5+release.6562.3a7379eb.gl'
2024-11-03 14:57:31 [1,503ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  CrashTime = 'Sun Nov  3 14:57:30 2024 GMT'
2024-11-03 14:57:31 [1,509ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DriverShaderCacheWrapper = 'disabled'
2024-11-03 14:57:31 [1,515ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  DumpId = '78b92d69-744f-4da0-ab65a4a5-b3aaed19'
2024-11-03 14:57:31 [1,521ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  LastUploadStatus = '200'
2024-11-03 14:57:31 [1,527ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  ProductName = 'OmniverseKit'
2024-11-03 14:57:31 [1,534ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/dai_guard/.local/share/ov/data/Kit/Isaac-Sim_App_Selector/4.2/78b92d69-744f-4da0-ab65a4a5-b3aaed19.py.txt''
2024-11-03 14:57:31 [1,540ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  RetryCount = '0'
2024-11-03 14:57:31 [1,546ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  StartupTime = '1730645849'
2024-11-03 14:57:31 [1,553ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UploadSuccessful = '0'
2024-11-03 14:57:31 [1,559ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UptimeSeconds = '1'
2024-11-03 14:57:31 [1,565ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UserStory = ''
2024-11-03 14:57:31 [1,571ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-11-03 14:57:31 [1,577ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  Version = '106.1.0+release.140981.10a4b5c0.gl'
2024-11-03 14:57:31 [1,584ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_enabled = '1'
2024-11-03 14:57:31 [1,590ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_flags = '3'
2024-11-03 14:57:31 [1,596ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_status = 'auto-enabled'
2024-11-03 14:57:31 [1,602ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  aftermath_version = '2024.1'
2024-11-03 14:57:31 [1,608ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appName = 'Isaac-Sim_App_Selector'
2024-11-03 14:57:31 [1,614ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appState = 'startup'
2024-11-03 14:57:31 [1,620ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  appVersion = '4.2.0'
2024-11-03 14:57:31 [1,626ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  autoloadExts = ''
2024-11-03 14:57:31 [1,633ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildBranch = 'release'
2024-11-03 14:57:31 [1,639ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildCi = 'gl'
2024-11-03 14:57:31 [1,645ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildConfig = 'release'
2024-11-03 14:57:31 [1,651ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabJobName = 'kit-build-release-linux-x86_64'
2024-11-03 14:57:31 [1,657ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabJobStage = 'kit-build'
2024-11-03 14:57:31 [1,664ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildGitlabPipelineID = '18272252'
2024-11-03 14:57:31 [1,670ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildHash = '10a4b5c0'
2024-11-03 14:57:31 [1,676ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildMajor = '106'
2024-11-03 14:57:31 [1,682ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildMinor = '1'
2024-11-03 14:57:31 [1,688ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildNumber = '140981'
2024-11-03 14:57:31 [1,694ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildPatch = '0'
2024-11-03 14:57:31 [1,700ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  buildVersion = '106.1.0'
2024-11-03 14:57:31 [1,706ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  commandLine = './kit/kit ./apps/omni.isaac.sim.selector.kit --ext-folder ./apps'
2024-11-03 14:57:31 [1,712ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  email = ''
2024-11-03 14:57:31 [1,718ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  environmentName = 'default'
2024-11-03 14:57:31 [1,724ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  kitRendererDriverVersion = '535.183'
2024-11-03 14:57:31 [1,731ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  memoryStats = '(avail/total) RAM: 27.1737/31.2606GB, Swap: 29.8018/29.8018GB, VM: 1.71799e+10/1.71799e+10GB'
2024-11-03 14:57:31 [1,737ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  nvidia-smi = '
CUDA Version                              : 12.2
Attached GPUs                             : 1
    MIG Mode
        Current                           : N/A
        Pending                           : N/A
    Driver Model
        Current                           : N/A
        Pending                           : N/A
    Serial Number                         : N/A
    Minor Number                          : 0
    MultiGPU Board                        : No
    Board ID                              : 0x100
    Module ID                             : 1
    Inforom Version
        OEM Object                        : 1.1
        ECC Object                        : N/A
    GPU Operation Mode
        Current                           : N/A
        Pending                           : N/A
    GPU Reset Status
        Reset Required                    : No
    IBMNPU
    PCI
        Bus                               : 0x01
        Device                            : 0x00
        Domain                            : 0x0000
        GPU Link Info
            PCIe Generation
                Max                       : 3
                Current                   : 1
                Device Current            : 1
                Device Max                : 3
                Host Max                  : 3
            Link Width
                Max                       : 16x
                Current                   : 16x
        Bridge Chip
            Type                          : N/A
            Firmware                      : N/A
    Fan Speed                             : 25 %
        Idle                              : Not Active
    FB Memory Usage
        Total                             : 8192 MiB
        Reserved                          : 225 MiB
        Used                              : 462 MiB
        Free                              : 7503 MiB
    BAR1 Memory Usage
        Total                             : 256 MiB
        Used                              : 17 MiB
        Free                              : 239 MiB
        Total                             : 0 MiB
        Used                              : 0 MiB
        Free                              : 0 MiB
    Utilization
        Gpu                               : 2 %
        Memory                            : 7 %
        Encoder                           : 0 %
        Decoder                           : 0 %
        JPEG                              : 0 %
        OFA                               : 0 %
    Encoder Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    FBC Stats
        Active Sessions                   : 0
        Average FPS                       : 0
        Average Latency                   : 0
    ECC Mode
        Current                           : N/A
        Pending                           : N/A
    ECC Errors
        Volatile
        Aggregate
    Retired Pages
    Remapped Rows                         : N/A
    Temperature
    GPU Power Readings
        Power Draw                        : N/A
    Clocks
        Graphics                          : 1395 MHz
        SM                                : 1395 MHz
        Memory                            : 7000 MHz
        Video                             : 1290 MHz
    Applications Clocks
        Graphics                          : N/A
        Memory                            : N/A
        Graphics                          : N/A
        Memory                            : N/A
    Deferred Clocks
        Memory                            : N/A
    Max Clocks
        Graphics                          : 2115 MHz
        SM                                : 2115 MHz
        Memory                            : 7001 MHz
        Video                             : 1950 MHz
        Graphics                          : N/A
    Clock Policy
        Auto Boost                        : N/A
    Voltage
        Graphics                          : N/A
    Fabric
        State                             : N/A
        Status                            : N/A
    Processes
        Process ID                        : 3380
            Type                          : G
        Process ID                        : 3529
            Type                          : G
        Process ID                        : 4168
            Type                          : G
        Process ID                        : 15863
            Type                          : G
        Process ID                        : 18916
            Type                          : C
2024-11-03 14:57:31 [1,743ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  portableMode = '0'
2024-11-03 14:57:31 [1,749ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  runningInContainer = '0'
2024-11-03 14:57:31 [1,756ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_debugSymbols = '0'
2024-11-03 14:57:31 [1,762ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_dumpIncludeOverrides = '0'
2024-11-03 14:57:31 [1,768ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_dumpIntermediates = '0'
2024-11-03 14:57:31 [1,775ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_obfuscateCode = '1'
2024-11-03 14:57:31 [1,781ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  shaderdb_optimizationLevel = '1'
2024-11-03 14:57:31 [1,787ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  systemInfo = '
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
|     |                                  |        |     |            | 1e84      | 14273390.. |
|     |                                  |        |     |            | 1         |            |
2024-11-03 14:57:31 [1,793ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  telemetrySessionId = '1843360401883066869'
2024-11-03 14:57:31 [1,799ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  terminatedByAbort = '0'
2024-11-03 14:57:31 [1,805ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  userId = 'default'
2024-11-03 14:57:31 [1,811ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash]  workingDirectory = '/home/<username>/.local/share/ov/pkg/isaac-sim-4.2.0'
2024-11-03 14:57:31 [1,817ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 18916 backtrace follows:
2024-11-03 14:57:32 [1,866ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2024-11-03 14:57:32 [1,873ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libomni.kit.imgui_renderer.plugin.so!std::string::resize(unsigned long, char)+0x2aa (??:?)
2024-11-03 14:57:32 [1,880ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libomni.kit.imgui_renderer.plugin.so!std::string::resize(unsigned long, char)+0x393 (??:?)
2024-11-03 14:57:32 [1,887ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libomni.kit.imgui_renderer.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)+0x4018 (??:?)
2024-11-03 14:57:32 [1,894ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libomni.kit.imgui_renderer.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator<char> const&, std::forward_iterator_tag)+0x5695 (??:?)
2024-11-03 14:57:32 [1,901ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libomni.kit.imgui_renderer.plugin.so!carbOnPluginPreStartup+0x167d (??:?)
2024-11-03 14:57:32 [1,908ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libomni.kit.imgui_renderer.plugin.so!carbOnPluginPreStartup+0x1966 (??:?)
2024-11-03 14:57:32 [1,915ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libomni.kit.renderer.init.plugin.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_get_insert_hint_unique_pos(std::_Rb_tree_const_iterator<std::string>, std::string const&)+0x767f (??:?)
2024-11-03 14:57:32 [1,922ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libomni.kit.renderer.plugin.so!carbOnPluginPreStartup+0x405d (??:?)
2024-11-03 14:57:32 [1,929ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libomni.kit.imgui_renderer.plugin.so!carbOnPluginPreStartup+0x200b (??:?)
2024-11-03 14:57:32 [1,936ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libomni.kit.imgui_renderer.ext.plugin.so!std::string::find(char, unsigned long) const+0x1870 (??:?)
2024-11-03 14:57:32 [1,944ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libomni.ext.plugin.so!std::string& std::vector<std::string, std::allocator<std::string> >::emplace_back<char const*&>(char const*&)+0x4c69 (??:?)
2024-11-03 14:57:32 [1,952ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libomni.ext.plugin.so!std::basic_string<char, std::char_traits<char>, std::allocator<char> >::basic_string(std::string const&, unsigned long, unsigned long)+0x54af (??:?)
2024-11-03 14:57:32 [1,960ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libomni.ext.plugin.so!std::string __gnu_cxx::__to_xstring<std::string, char>(int (*)(char*, unsigned long, char const*, __va_list_tag*), unsigned long, char const*, ...)+0x10480 (??:?)
2024-11-03 14:57:32 [1,968ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libomni.ext.plugin.so!carbOnPluginPreStartup+0x533 (??:?)
2024-11-03 14:57:32 [1,976ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libomni.ext.plugin.so!carbOnPluginPreStartup+0xc99c (??:?)
2024-11-03 14:57:32 [1,983ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libomni.ext.plugin.so!carbOnPluginPreStartup+0xda03 (??:?)
2024-11-03 14:57:32 [1,991ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libomni.kit.app.plugin.so!std::string::compare(std::string const&) const+0x93f3 (??:?)
2024-11-03 14:57:32 [1,999ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libomni.kit.app.plugin.so!std::string::compare(std::string const&) const+0x9dec (??:?)
2024-11-03 14:57:32 [2,007ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libomni.kit.app.plugin.so!_init+0x6cc7 (??:0)
2024-11-03 14:57:32 [2,014ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: kit!_init+0x6c3 (??:0)
2024-11-03 14:57:32 [2,053ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2024-11-03 14:57:32 [2,092ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2024-11-03 14:57:32 [2,099ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: kit!_start+0x29 (??:?)
Screenshots or Videos
I used this post as a guide and it cured me.
Isaac Sim 2023.1.0 Fails Due to Vulkan Issue on Ubuntu 20.04
I’m sorry for troubling you
