Isaac_sim crashed when I clicke "load world" in my extension
I developed a extension for simulate in Isaac Example.I works normal in version 2021.2.1,but it crashed in version 2022.2.1 when I click “load world” in the extension.How can I fix this problem? Here is logs:
[4.849s] app ready
[7.069s] RTX ready
[7.074s] Isaac Sim App is loaded.
DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
terminate called after throwing an instance of 'NvOFException'
  what():  DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
2023-05-24 07:45:58 [13,290ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-05-24 07:45:58 [13,290ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-05-24 07:45:58 [13,290ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 2 files into '/home/lyc/.local/share/ov/data/Kit/Isaac-Sim/2022.2/0f62a1ac-68dc-4e77-624b308b-7a69b264.dmp.zip' for upload.
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/home/lyc/.local/share/ov/data/Kit/Isaac-Sim/2022.2/0f62a1ac-68dc-4e77-624b308b-7a69b264.dmp.zip' svr:'https://services.nvidia.com/submit'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   DumpId = '0f62a1ac-68dc-4e77-624b308b-7a69b264'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   ProductName = 'OmniverseKit'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   RetryCount = '0'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   StartupTime = '1684914345'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   UploadSuccessful = '0'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   UptimeSeconds = '13'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   Version = '104.2+release.295.529af2e4.tc'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   appName = 'Isaac-Sim'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   appState = 'started'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   appVersion = '2022.2.1'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   autoloadExts = ''
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildBranch = 'release'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildCi = 'tc'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildHash = '529af2e4'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildId = '14001715'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMajor = '104'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMinor = '2'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMr = '0'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildNumber = '295'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildPatch = '0'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildVersion = '104.2.0'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   environmentName = 'default'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   experience = 'Isaac Sim'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   kitRendererDriverVersion = '530.41'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommand = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommands = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   memoryStats = '(avail/total) RAM: 49.2307/62.6156GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   portableMode = '0'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   stageUrl = ''
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   systemInfo = '
| Driver Version: 530.41.03     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 4080          | Yes: 0 |     | 16622   MB | 10de      | 0          |
|     |                                  |        |     |            | 2704      | 8308f670.. |
| OS: Linux lyc-dm, Version: 5.15.0-71-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: 13th Gen Intel(R) Core(TM) i7-13700KF | Cores: Unknown | Logical: 24
| Total Memory (MB): 64118 | Free Memory: 55399
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '5397421495489495471'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   userId = '1324539608@QQ.COM'
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
2023-05-24 07:45:58 [13,471ms] [Warning] [carb.crashreporter-breakpad.plugin]   upload_file_minidump = '/home/lyc/.local/share/ov/data/Kit/Isaac-Sim/2022.2/0f62a1ac-68dc-4e77-624b308b-7a69b264.dmp.zip'
2023-05-24 07:46:05 [20,147ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: '/home/lyc/.local/share/ov/data/Kit/Isaac-Sim/2022.2/0f62a1ac-68dc-4e77-624b308b-7a69b264.dmp.zip', code:200, response:
2023-05-24 07:46:05 [20,147ms] [Warning] [carb.crashreporter-breakpad.plugin]     00000187348fe6bd-1bd160
2023-05-24 07:46:05 [20,147ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/home/lyc/.local/share/ov/data/Kit/Isaac-Sim/2022.2/0f62a1ac-68dc-4e77-624b308b-7a69b264.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save).
2023-05-24 07:46:05 [20,147ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/home/lyc/.local/share/ov/data/Kit/Isaac-Sim/2022.2/0f62a1ac-68dc-4e77-624b308b-7a69b264.dmp.zip'
2023-05-24 07:46:05 [20,147ms] [Error] [carb.crashreporter-breakpad.plugin]     the dump file was deleted due to a successful upload.  Its originalsize was 494781 bytes and was readable.
2023-05-24 07:46:05 [20,148ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 38191 thread 38191
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   DumpId = '0f62a1ac-68dc-4e77-624b308b-7a69b264'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   ProductName = 'OmniverseKit'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   RetryCount = '0'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   StartupTime = '1684914345'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   UploadSuccessful = '0'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   UptimeSeconds = '13'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   Version = '104.2+release.295.529af2e4.tc'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   appName = 'Isaac-Sim'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   appState = 'started'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   appVersion = '2022.2.1'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   autoloadExts = ''
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildBranch = 'release'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildCi = 'tc'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildHash = '529af2e4'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildId = '14001715'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMajor = '104'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMinor = '2'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMr = '0'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildNumber = '295'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildPatch = '0'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildVersion = '104.2.0'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   environmentName = 'default'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   experience = 'Isaac Sim'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   kitRendererDriverVersion = '530.41'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommand = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommands = 'SetLightingMenuModeCommand(lighting_mode=stage,usd_context_name=)'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   memoryStats = '(avail/total) RAM: 49.2307/62.6156GB, Swap: 2/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   portableMode = '0'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   stageUrl = ''
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   systemInfo = '
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2704      | 8308f670.. |
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '5397421495489495471'
2023-05-24 07:46:05 [20,148ms] [Warning] [carb.crashreporter-breakpad.plugin]   userId = '1324539608@QQ.COM'
2023-05-24 07:46:05 [20,148ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 38191 backtrace follows:
2023-05-24 07:46:05 [20,212ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libpthread.so.0!funlockfile+0x60 (sigaction.c:?)
/usr/bin/addr2line: DWARF error: section .debug_info is larger than its filesize! (0x93ef57 vs 0x530ea0)
2023-05-24 07:46:05 [20,274ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!gsignal+0xcb (??:?)
2023-05-24 07:46:05 [20,335ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!abort+0x12b (??:?)
2023-05-24 07:46:05 [20,335ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: 191!+0x102905
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: 191!+0x100e66
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: 191!+0x100ea1
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: 191!+0x100d03
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: 191!+0xf9be2
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: 191!+0xf593f
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: 191!+0xfab47
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: 191!+0xd1690
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: 191!+0xd4110
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: 191!+0xb55c8
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: 191!+0x92cdd
2023-05-24 07:46:05 [20,336ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: 191!+0x6e9cd
2023-05-24 07:46:05 [20,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x7187 (??:?)
2023-05-24 07:46:05 [20,456ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x640e (??:?)
2023-05-24 07:46:05 [20,515ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: librtx.postprocessing.plugin.so!_init+0x1de80 (??:0)
2023-05-24 07:46:05 [20,574ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: librtx.postprocessing.plugin.so!_init+0x2027a (??:0)
2023-05-24 07:46:06 [20,633ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: librtx.postprocessing.plugin.so!_init+0x207c3 (??:0)
2023-05-24 07:46:06 [20,693ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator<unsigned char> >::_M_default_append(unsigned long)+0xdb39 (??:?)
2023-05-24 07:46:06 [20,752ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x142be (??:?)
2023-05-24 07:46:06 [20,821ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1b4c9 (??:?)
2023-05-24 07:46:06 [20,882ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1bb63 (??:?)
2023-05-24 07:46:06 [20,943ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4a7db (??:?)
2023-05-24 07:46:06 [21,002ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4e21b (??:?)
2023-05-24 07:46:06 [21,062ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libcarb.scenerenderer-rtx.plugin.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned int, false>*)+0x1a917 (??:?)
2023-05-24 07:46:06 [21,122ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0x78e4 (??:?)
2023-05-24 07:46:06 [21,182ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0xae01 (??:?)
2023-05-24 07:46:06 [21,243ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x5e7a (??:?)
2023-05-24 07:46:06 [21,304ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xbfe1 (??:?)
2023-05-24 07:46:06 [21,364ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xc9c6 (??:?)
2023-05-24 07:46:06 [21,423ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xcf41 (??:?)
2023-05-24 07:46:06 [21,482ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libomni.usd.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)+0x4f9f (??:?)
2023-05-24 07:46:06 [21,543ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x188c (??:?)
2023-05-24 07:46:07 [21,604ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x2026 (??:?)
2023-05-24 07:46:07 [21,664ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0x8ac (??:?)
2023-05-24 07:46:07 [21,725ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0xe8e3 (??:?)
2023-05-24 07:46:07 [21,786ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libomni.kit.app.plugin.so!_init+0x28c7 (??:0)
2023-05-24 07:46:07 [21,847ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libomni.kit.app.plugin.so!carbOnPluginPostShutdown+0x907 (??:?)
2023-05-24 07:46:07 [21,906ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: kit!_init+0x635 (??:0)
2023-05-24 07:46:07 [21,968ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: libc.so.6!__libc_start_main+0xf3 (??:?)
2023-05-24 07:46:07 [22,026ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: kit!_init+0x9cb (??:0)
Aborted (core dumped)
Hi @1324539608. Please try reinstall the production branch drivers: 525.116.04.
