Dear @sheikh-nv ,
I followed the steps to uninstall all the drivers, and I re-installed the latest 535.104.05 driver as recommended on the link you shared.
When I start omniverse using the trminal, I get the following:
Loading user config located at: '/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/user.config.json'
[Info] [carb] Logging to file: /home/betsi/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230830_185134.log
2023-08-30 16:51:34 [40ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config 'extension.toml' doesn't exist '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar' or '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar/config'
2023-08-30 16:51:34 [40ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config 'extension.toml' doesn't exist '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar' or '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar/config'
[0.146s] [ext: omni.stats-0.0.0] startup
[0.163s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.168s] [ext: omni.assets.plugins-0.0.0] startup
[0.169s] [ext: omni.gpu_foundation-0.0.0] startup
[0.174s] [ext: carb.windowing.plugins-1.0.0] startup
2023-08-30 16:51:35 [168ms] [Warning] [carb.windowing-glfw.gamepad] Joystick with unknown remapping detected (will be ignored): Microsoft Xbox Series S|X Controller [030000005e040000120b000009050000]
[0.186s] [ext: omni.kit.renderer.init-0.0.0] startup
| Driver Version: 535.104.05 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | NVIDIA GeForce RTX 4060 Ti | Yes: 0 | | 16380 MB | 10de | 0 |
| | | | | | 2805 | 262da99c.. |
| OS: Linux betsi-station, Version: 6.2.0-31-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 9 7900X3D 12-Core Processor | Cores: Unknown | Logical: 24
| Total Memory (MB): 31816 | Free Memory: 26017
| Total Page/Swap (MB): 34723 | Free Page/Swap: 34723
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. Found 26 items in /sys/kernel/iommu_groups/.
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] !!!!! Local system validation failed! Incorrect configuration detected.
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] Summary below. Details above.
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] - ECC: OK
2023-08-30 16:51:35 [432ms] [Warning] [gpu.foundation.plugin] - IOMMU: FAILED
[0.639s] [ext: omni.kit.pipapi-0.0.0] startup
[0.646s] [ext: omni.usd.config-1.0.0] startup
[0.648s] [ext: omni.usd.libs-1.0.0] startup
[0.730s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.732s] [ext: omni.kit.async_engine-0.0.0] startup
[0.733s] [ext: omni.kit.loop-default-0.1.1] startup
[0.733s] [ext: omni.kit.test-0.0.0] startup
[0.765s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.792s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.796s] [ext: omni.client-0.1.1] startup
[0.800s] [ext: omni.iray.libs-0.0.0] startup
[0.808s] [ext: omni.volume-0.1.0] startup
[0.810s] [ext: omni.usd.core-1.0.4] startup
[0.812s] [ext: omni.mdl.neuraylib-0.1.0] startup
[0.815s] [ext: omni.hydra.rtx-0.1.0] startup
[0.818s] [ext: omni.hydra.iray-0.1.0] startup
[0.820s] [ext: omni.isaac.core_archive-2.0.1] startup
[0.888s] [ext: omni.services.pip_archive-0.4.2] startup
[0.890s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[0.892s] [ext: omni.isaac.ml_archive-1.1.0] startup
[0.910s] [ext: omni.appwindow-1.0.1] startup
[0.913s] [ext: omni.kit.renderer.core-0.0.0] startup
[0.938s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.939s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[0.975s] [ext: omni.ui-2.14.4] startup
[0.980s] [ext: carb.audio-0.1.0] startup
[0.982s] [ext: omni.uiaudio-1.0.0] startup
[0.983s] [ext: omni.kit.mainwindow-1.0.0] startup
[0.983s] [ext: omni.kit.uiapp-0.0.0] startup
[0.983s] [ext: omni.usd.schema.physics-1.0.0] startup
[0.990s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.035s] [ext: omni.usd.schema.isaac-1.1.0] startup
[1.047s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[1.049s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.068s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[1.074s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.079s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.084s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.090s] [ext: omni.kit.actions.core-1.0.0] startup
[1.092s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[1.093s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.093s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[1.097s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[1.107s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[1.109s] [ext: omni.timeline-1.0.5] startup
[1.110s] [ext: omni.kit.commands-1.4.5] startup
[1.112s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[1.115s] [ext: omni.usd-1.6.30] startup
[1.141s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[1.142s] [ext: omni.usd.schema.destruction-0.4.0] startup
[1.148s] [ext: omni.kit.asset_converter-1.3.4] startup
[1.159s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[1.192s] [ext: omni.usd.schema.sequence-2.2.1] startup
[1.199s] [ext: omni.usd.schema.flow-104.1.6] startup
[1.200s] [ext: omni.inspect-1.0.1] startup
[1.201s] [ext: omni.kit.widget.path_field-2.0.4] startup
[1.202s] [ext: omni.debugdraw-0.1.1] startup
[1.205s] [ext: omni.kit.notification_manager-1.0.5] startup
[1.207s] [ext: omni.graph.core-2.65.4] startup
[1.209s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[1.210s] [ext: omni.kit.widget.versioning-1.3.8] startup
[1.212s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[1.220s] [ext: omni.kit.search_core-1.0.2] startup
[1.221s] [ext: omni.hydra.pxr-1.1.2] startup
[1.225s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[1.227s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[1.263s] [ext: omni.kit.menu.utils-1.4.7] startup
[1.269s] [ext: omni.kit.usd.layers-2.0.11] startup
[1.275s] [ext: omni.mdl-0.1.0] startup
[1.290s] [ext: omni.kit.window.file_importer-1.0.10] startup
[1.291s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[1.292s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[1.295s] [ext: omni.kit.material.library-1.3.21] startup
[1.299s] [ext: omni.kit.clipboard-1.0.0] startup
[1.300s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[1.300s] [ext: omni.kit.stage_templates-1.1.13] startup
[1.302s] [ext: omni.kit.menu.create-1.0.8] startup
[1.303s] [ext: omni.ui_query-1.1.1] startup
[1.303s] [ext: omni.kit.context_menu-1.5.12] startup
[1.306s] [ext: omni.activity.core-1.0.1] startup
[1.308s] [ext: omni.kit.window.file-1.3.32] startup
[1.310s] [ext: omni.kit.window.drop_support-1.0.1] startup
[1.310s] [ext: omni.kit.ui_test-1.2.9] startup
[1.312s] [ext: omni.kit.widget.stage-2.7.24] startup
[1.315s] [ext: omni.kit.window.property-1.8.2] startup
[1.317s] [ext: omni.kit.window.content_browser-2.6.8] startup
[1.328s] [ext: omni.kit.usd_undo-0.1.2] startup
[1.329s] [ext: omni.graph.tools-1.17.2] startup
[1.341s] [ext: omni.hydra.engine.stats-1.0.0] startup
[1.343s] [ext: omni.kit.property.usd-3.18.17] startup
[1.350s] [ext: omni.graph-1.50.2] startup
[1.385s] [ext: omni.kit.hydra_texture-1.0.11] startup
[1.389s] [ext: omni.kit.viewport.registry-104.0.2] startup
[1.390s] [ext: omni.ui.scene-1.5.18] startup
[1.393s] [ext: omni.kit.widget.viewport-104.1.16] startup
[1.395s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[1.397s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[1.399s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[1.416s] [ext: omni.kit.viewport.window-104.1.23] startup
[1.427s] [ext: omni.kit.widget.prompt-1.0.5] startup
[1.428s] [ext: omni.kit.window.extensions-1.1.1] startup
[1.432s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[1.433s] [ext: omni.kit.viewport.utility-1.0.14] startup
[1.434s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[1.435s] [ext: omni.kit.widget.settings-1.0.1] startup
[1.437s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[1.438s] [ext: omni.kit.window.preferences-1.3.8] startup
[1.454s] [ext: omni.graph.ui-1.24.2] startup
[1.478s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[1.480s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[1.481s] [ext: omni.kit.numpy.common-0.1.0] startup
[1.483s] [ext: omni.kvdb-0.0.0] startup
[1.484s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[1.485s] [ext: omni.usdphysics-104.2.4-5.1] startup
[1.487s] [ext: omni.localcache-0.0.0] startup
[1.488s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[1.489s] [ext: omni.kit.widget.imageview-1.0.3] startup
[1.489s] [ext: omni.physx-104.2.4-5.1] startup
[1.503s] [ext: omni.isaac.debug_draw-0.2.3] startup
[1.506s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[1.508s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[1.515s] [ext: omni.graph.examples.cpp-1.4.2] startup
[1.518s] [ext: omni.graph.window.core-1.43.3] startup
[1.523s] [ext: omni.isaac.version-1.0.0] startup
[1.524s] [ext: usdrt.scenegraph-4.3.2] startup
[1.535s] [ext: omni.kit.widgets.custom-1.0.4] startup
[1.541s] [ext: omni.graph.window.action-1.5.5] startup
[1.542s] [ext: omni.graph.nodes-1.48.3] startup
[1.550s] [ext: omni.anim.retarget.core-104.2.1] startup
[1.556s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[1.557s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[1.561s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[1.562s] [ext: omni.anim.graph.core-104.2.1] startup
[1.566s] [ext: omni.kit.browser.core-2.2.2] startup
[1.570s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[1.574s] [ext: omni.curve.creator-104.1.2] startup
[1.576s] [ext: omni.physics.tensors-0.1.0] startup
[1.581s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[1.584s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[1.585s] [ext: omni.scene.visualization.core-104.4.0] startup
[1.621s] [ext: omni.ramp-104.1.3] startup
[1.624s] [ext: omni.kit.window.stage-2.3.12] startup
[1.626s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[1.628s] [ext: omni.genproc.core-104.5.14] startup
[1.639s] [ext: omni.curve.manipulator-104.7.3] startup
[1.648s] [ext: omni.physx.tensors-0.1.0] startup
[1.653s] [ext: omni.command.usd-1.0.2] startup
[1.656s] [ext: omni.kit.browser.sample-1.2.5] startup
[1.657s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[1.661s] [ext: omni.graph.io-1.2.5] startup
[1.665s] [ext: omni.graph.action-1.31.1] startup
[1.670s] [ext: omni.kit.window.cursor-1.1.1] startup
[1.671s] [ext: omni.kit.widget.spinner-1.0.4] startup
[1.672s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[1.673s] [ext: omni.graph.bundle.action-1.3.0] startup
[1.673s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[1.685s] [ext: omni.anim.graph.ui-104.2.0] startup
[1.693s] [ext: omni.isaac.core-1.46.3] startup
[2.210s] [ext: omni.graph.scriptnode-0.10.0] startup
[2.211s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
CUDA Toolkit: 11.5, Driver: 12.2
Devices:
"cpu" | x86_64
"cuda:0" | NVIDIA GeForce RTX 4060 Ti (sm_89)
Kernel cache: /home/betsi/.cache/warp/0.6.3
[2.349s] [ext: omni.syntheticdata-0.2.4] startup
2023-08-30 16:51:37 [2,341ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[2.362s] [ext: omni.anim.graph.bundle-104.2.0] startup
[2.362s] [ext: omni.isaac.ui-0.8.0] startup
[2.365s] [ext: omni.isaac.lula-1.2.1] startup
[2.372s] [ext: omni.isaac.motion_planning-0.2.2] startup
[2.377s] [ext: omni.replicator.core-1.7.8] startup
2023-08-30 16:51:37 [2,418ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[2.468s] [ext: omni.isaac.utils-0.2.4] startup
[2.470s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[2.473s] [ext: omni.isaac.motion_generation-4.5.6] startup
[2.478s] [ext: omni.isaac.range_sensor-0.8.1] startup
[2.498s] [ext: omni.isaac.core_nodes-0.23.2] startup
[2.507s] [ext: omni.isaac.demos-0.3.3] startup
[2.515s] [ext: omni.isaac.sensor-5.6.3] startup
2023-08-30 16:51:37 [2,498ms] [Warning] [omni.ext.plugin] [ext: omni.isaac.sensor-5.6.3] Native plugin search dir contains several files: /home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.sensor/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[2.543s] [ext: omni.isaac.manipulators-1.1.0] startup
[2.544s] [ext: omni.isaac.quadruped-1.3.0] startup
[2.711s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[2.713s] [ext: omni.isaac.universal_robots-0.3.2] startup
[2.714s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[2.719s] [ext: omni.isaac.franka-0.4.0] startup
[2.720s] [ext: omni.isaac.dofbot-0.3.0] startup
[2.721s] [ext: omni.isaac.diff_usd-1.0.1] startup
[2.722s] [ext: omni.isaac.examples-1.5.6] startup
/bin/bash: warning: setlocale: LC_ALL: cannot change locale (en_US.UTF-8)
Gtk-Message: 18:51:37.833: Not loading module "atk-bridge": The functionality is provided by GTK natively. Please try to not load it.
2023-08-30 16:51:40 [5,388ms] [Error] [omni.client.plugin] Auth Token: authentication: Auth: Tokens.subscribe returned Username Required
2023-08-30 16:51:40 [5,388ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
2023-08-30 16:51:40 [5,389ms] [Warning] [omni.client.plugin] HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for http://omniverse-content-production.s3-us-west-2.amazonaws.com/.cloudfront.toml
2023-08-30 16:51:40 [5,389ms] [Warning] [omni.client.plugin] HTTP Client: omniclient: CC-873: Bypassing cache until the application is restarted
2023-08-30 16:51:45 [10,781ms] [Warning] [omni.client.plugin] HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/2022.2.1/
[11.013s] [ext: omni.activity.pump-1.0.0] startup
[11.015s] [ext: omni.activity.usd_resolver-1.0.1] startup
[11.017s] [ext: omni.anim.skelJoint-104.2.22] startup
[11.022s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[11.024s] [ext: omni.graph.window.generic-1.3.15] startup
[11.026s] [ext: omni.isaac.extension_templates-1.0.0] startup
[11.026s] [ext: omni.activity.ui-1.0.20] startup
[11.031s] [ext: omni.anim.retarget.ui-104.2.0] startup
[11.036s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-08-30 16:51:45 [11,019ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[11.037s] [ext: omni.kit.profiler.window-2.0.5] startup
[11.086s] [ext: omni.isaac.kit-1.4.1] startup
[11.086s] [ext: omni.anim.retarget.bundle-104.2.0] startup
[11.087s] [ext: omni.activity.freeze_monitor-1.0.1] startup
[11.091s] [ext: omni.isaac.merge_mesh-0.1.2] startup
[11.092s] [ext: omni.isaac.mjcf-0.3.1] startup
[11.096s] [ext: omni.isaac.articulation_inspector-0.1.3] startup
[11.097s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[11.103s] [ext: omni.isaac.shapenet-2.0.1] startup
[11.111s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[11.117s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[11.118s] [ext: omni.isaac.synthetic_recorder-1.5.0] startup
[11.121s] [ext: omni.isaac.unit_converter-0.1.6] startup
[11.122s] [ext: omni.kit.widget.calendar-1.0.5] startup
[11.123s] [ext: omni.kit.ngsearch-0.0.10] startup
2023-08-30 16:51:46 [11,112ms] [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
[11.142s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[11.142s] [ext: omni.kit.widget.layers-1.6.11] startup
[11.150s] [ext: omni.kit.menu.stage-1.2.1] startup
[11.151s] [ext: omni.kit.tool.collect-2.1.20] startup
[11.154s] [ext: omni.kit.widget.extended_searchfield-1.0.17] startup
[11.162s] [ext: omni.isaac.urdf-0.5.9] startup
[11.178s] [ext: omni.kit.actions.window-1.1.0] startup
[11.181s] [ext: omni.kit.property.layer-1.1.4] startup
[11.182s] [ext: omni.isaac.window.about-1.1.0] startup
[11.183s] [ext: omni.kit.browser.asset-1.2.3] startup
[11.185s] [ext: omni.kit.browser.deepsearch-1.0.20] startup
[11.187s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[11.189s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[11.193s] [ext: omni.kit.property.audio-1.0.6] startup
[11.194s] [ext: omni.kit.property.camera-1.0.3] startup
[11.194s] [ext: omni.kit.property.geometry-1.2.2] startup
[11.196s] [ext: omni.kit.property.light-1.0.6] startup
[11.197s] [ext: omni.hydra.scene_api-0.1.1] startup
[11.201s] [ext: omni.kit.tool.asset_importer-2.4.0] startup
[11.203s] [ext: omni.kit.property.material-1.8.19] startup
[11.205s] [ext: omni.services.facilities.base-1.0.2] startup
[11.206s] [ext: omni.kit.property.render-1.1.0] startup
[11.206s] [ext: omni.kit.property.skel-1.0.1] startup
[11.207s] [ext: omni.kit.property.transform-1.3.5] startup
[11.210s] [ext: omni.kit.importer.cad-0.3.4] startup
[11.239s] [ext: omni.isaac.gain_tuner-0.1.1] startup
[11.240s] [ext: omni.services.core-1.3.0] startup
[11.306s] [ext: omni.anim.curve-104.16.6] startup
[11.315s] [ext: omni.anim.shared-104.14.1] startup
[11.320s] [ext: omni.kit.property.bundle-1.2.6] startup
[11.321s] [ext: omni.services.transport.client.base-1.2.1] startup
[11.322s] [ext: omni.slangnode-104.2.3] startup
[11.337s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[11.339s] [ext: omni.isaac.asset_browser-0.2.4] startup
[11.340s] [ext: omni.anim.timeline-104.0.7] startup
[11.342s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[11.344s] [ext: omni.services.client-0.4.0] startup
[11.345s] [ext: omni.kit.menu.aov-1.1.3] startup
[11.346s] [ext: omni.kit.selection-0.1.0] startup
[11.347s] [ext: omni.flowusd-104.2.4] startup
[11.359s] [ext: omni.services.transport.client.http_async-1.3.2] startup
[11.360s] [ext: omni.kit.core.collection-0.1.1] startup
[11.362s] [ext: omni.kit.menu.edit-1.1.6] startup
[11.364s] [ext: omni.isaac.physics_inspector-0.1.3] startup
[11.365s] [ext: omni.kit.menu.file-1.1.4] startup
[11.366s] [ext: omni.kit.pointclouds-0.0.16] startup
[11.368s] [ext: omni.services.starfleet.auth-0.1.4] startup
[11.372s] [ext: omni.kit.property.collection-0.1.10] startup
[11.373s] [ext: omni.kit.property.isaac-0.2.0] startup
[11.374s] [ext: omni.kit.property.sbsar-0.9.9] startup
[11.376s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[11.377s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[11.377s] [ext: omni.kit.quicksearch.hdri-0.8.11] startup
[11.378s] [ext: omni.kit.quicksearch.material-0.8.10] startup
[11.379s] [ext: semantics.schema.editor-0.3.3] startup
[11.382s] [ext: omni.kit.quicksearch.props-0.8.6] startup
[11.382s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[11.383s] [ext: omni.genproc.ui-104.1.6] startup
[11.385s] [ext: omni.rtx.window.settings-0.6.2] startup
[11.389s] [ext: omni.services.transport.server.base-1.1.0] startup
[11.389s] [ext: omni.kit.scripting-104.2.2] startup
2023-08-30 16:51:46 [11,371ms] [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/extscache/omni.kit.scripting-104.2.2+104.2.lx64.r.cp37/bin' in '[[native.plugin]]' was not found.
[11.392s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[11.393s] [ext: omni.isaac.physics_utilities-0.1.1] startup
[11.395s] [ext: omni.genproc.bundle-104.0.1] startup
[11.395s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[11.395s] [ext: omni.kit.agent-0.1.5] startup
[11.396s] [ext: omni.services.transport.server.http-1.1.2] startup
[11.404s] [ext: omni.kit.search.files-1.0.4] startup
[11.405s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[11.407s] [ext: omni.kit.thumbnails.mdl-1.0.20] startup
[11.409s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[11.411s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[11.412s] [ext: omni.kit.thumbnails.usd-0.5.2] startup
[11.413s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[11.414s] [ext: omni.kit.browser.material-1.3.3] startup
[11.416s] [ext: omni.kit.window.material_graph-1.6.15] startup
[11.421s] [ext: omni.kit.window.toolbar-1.4.0] startup
[11.423s] [ext: omni.kit.tool.asset_exporter-1.2.0] startup
[11.424s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[11.426s] [ext: omni.physx.commands-104.2.4-5.1] startup
[11.429s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[11.429s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[11.430s] [ext: omni.kit.window.material-1.1.3] startup
[11.433s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[11.436s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[11.437s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[11.440s] [ext: omni.physx.ui-104.2.4-5.1] startup
[11.474s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[11.475s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[11.478s] [ext: omni.kit.tool.remove_unused.controller-0.1.2] startup
[11.478s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[11.479s] [ext: omni.kit.usda_edit-1.1.10] startup
[11.534s] [ext: omni.kit.viewport.actions-104.0.3] startup
[11.536s] [ext: omni.kit.property.physx-0.1.0] startup
[11.545s] [ext: omni.physx.demos-104.2.4-5.1] startup
[11.547s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[11.547s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[11.549s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[11.549s] [ext: omni.kit.viewport.ready-1.0.2] startup
[11.550s] [ext: omni.kit.viewport_widgets_manager-1.0.6] startup
[11.552s] [ext: omni.kit.widget.live-2.0.3] startup
[11.553s] [ext: omni.physx.camera-104.2.4-5.1] startup
[11.558s] [ext: omni.physx.cct-104.2.4-5.1] startup
[11.564s] [ext: omni.kit.mesh.raycast-104.3.2] startup
[11.567s] [ext: omni.kit.widget.collection-0.1.11] startup
[11.569s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[11.580s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[11.594s] [ext: omni.kit.search.service-0.1.5] startup
[11.597s] [ext: omni.isaac.robot_description_editor-2.1.1] startup
[11.599s] [ext: omni.videoencoding-0.1.0] startup
[11.601s] [ext: omni.paint.system.core-104.5.8] startup
[11.650s] [ext: omni.kit.window.collection-0.1.11] startup
[11.651s] [ext: omni.kit.window.commands-0.2.4] startup
[11.653s] [ext: omni.iray.settings.core-0.6.4] startup
[11.655s] [ext: omni.kit.sequencer.usd-103.3.1] startup
[11.658s] [ext: omni.kit.capture.viewport-1.1.24] startup
[11.660s] [ext: omni.paint.system.ui-104.3.14] startup
[11.665s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[11.666s] [ext: omni.physx.zerogravity-104.2.4-5.1] startup
[11.673s] [ext: omni.rtx.settings.core-0.5.8] startup
[11.678s] [ext: omni.kit.preferences.time-0.2.0] startup
[11.680s] [ext: omni.kit.property.sequence-0.2.0] startup
[11.681s] [ext: omni.kit.sequencer.core-103.3.0] startup
[11.683s] [ext: omni.kit.window.console-0.2.3] startup
[11.689s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[11.691s] [ext: omni.paint.brush.scatter-104.2.12] startup
[11.695s] [ext: omni.kit.window.movie_capture-2.1.8] startup
[11.699s] [ext: omni.kit.window.privacy-0.1.0] startup
[11.700s] [ext: omni.kit.window.script_editor-1.7.2] startup
[11.702s] [ext: omni.kit.window.sequencer-103.3.4] startup
[11.719s] [ext: omni.particle.system.core-104.7.19] startup
[11.727s] [ext: omni.paint.brush.attributes-1.1.2] startup
[11.729s] [ext: omni.paint.brush.modify-104.3.2] startup
[11.732s] [ext: omni.paint.brush.scripting-104.7.0] startup
[11.737s] [ext: omni.paint.brush.select-104.3.2] startup
[11.742s] [ext: omni.scene.optimizer.core-104.1.5] startup
[11.745s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.2] startup
[11.755s] [ext: omni.graph.window.particle.system-104.5.3] startup
[11.757s] [ext: omni.particle.system.ui-104.5.1] startup
[11.766s] [ext: omni.kit.window.status_bar-0.1.5] startup
[11.768s] [ext: omni.kit.window.usd_paths-1.0.4] startup
[11.769s] [ext: omni.paint.system.bundle-104.8.26] startup
[11.770s] [ext: omni.scene.optimizer.ui-104.1.5] startup
[11.771s] [ext: omni.scene.visualization.ui-104.0.6] startup
[11.773s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load ...
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[11.775s] [ext: omni.particle.system.bundle-104.2.24] startup
[11.775s] [ext: omni.replicator.composer-1.2.10] startup
[11.778s] [ext: omni.replicator.isaac-1.7.4] startup
[11.789s] [ext: omni.resourcemonitor-1.0.0] startup
[11.793s] [ext: omni.scene.optimizer.bundle-104.1.5] startup
[11.793s] [ext: omni.scene.visualization.bundle-104.0.1] startup
[11.793s] [ext: omni.kit.stage.mdl_converter-1.0.1] startup
[11.794s] [ext: omni.services.usd-1.1.0] startup
[11.796s] [ext: omni.tools.array-104.0.12] startup
[11.802s] [ext: omni.tools.pivot-104.1.0] startup
[11.807s] [ext: omni.kit.widget.timeline-104.0.3] startup
[11.809s] [ext: omni.tools.randomizer-104.0.9] startup
[11.813s] [ext: omni.kit.quicklayout-1.1.1] startup
[11.815s] [ext: omni.kit.window.title-1.1.2] startup
[11.816s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[11.816s] [ext: omni.isaac.scene_blox-0.1.0] startup
[11.817s] [ext: omni.isaac.cortex-0.3.2] startup
[11.817s] [ext: omni.anim.curve_editor-104.12.7] startup
[11.831s] [ext: omni.isaac.onshape-0.6.2] startup
[12.165s] [ext: omni.kit.window.stats-0.1.2] startup
[12.166s] [ext: omni.isaac.app.setup-0.8.1] startup
[12.168s] Isaac Sim Version: 2022.2.1-rc.14
[12.175s] [ext: omni.isaac.ros_bridge-1.11.2] startup
2023-08-30 16:51:47 [12,207ms] [Warning] [omni.isaac.ros_bridge.scripts.extension] ROS_MASTER_URI not set, using default, ROS_MASTER_URI=http://localhost:11311
[12.248s] Writing Isaac Sim icon file
[12.249s] [ext: omni.isaac.assets_check-0.3.2] startup
[12.254s] [ext: omni.isaac.sim.base-2022.2.1] startup
[12.255s] [ext: omni.isaac.sim-2022.2.1] startup
[12.507s] app ready
[15.289s] RTX ready
[15.293s] Isaac Sim App is loaded.
When I then try to open a USD file, it still crashes with the following terminal output:
2023-08-30 16:55:17 [222,403ms] [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.kit.window.filepicker/data/thumbnails/folder_256.png:2023-08-30@18:45:05'
2023-08-30 16:55:17 [222,404ms] [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.kit.window.filepicker/data/thumbnails/folder_256.png:2023-08-30@18:45:05'
2023-08-30 16:55:17 [222,404ms] [Warning] [omni.ui] omni::ui::GpuResourcesCache: trying to release non-existent cached GPU resource '/home/betsi/.local/share/ov/pkg/isaac_sim-2022.2.1/kit/exts/omni.kit.window.filepicker/data/thumbnails/unknown_file_256.png:2023-08-30@18:45:05'
DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
terminate called after throwing an instance of 'NvOFException'
what(): DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
2023-08-30 16:55:25 [230,288ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-08-30 16:55:25 [230,288ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred. If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-08-30 16:55:25 [230,288ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 2 files into '/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/10ad93f5-3129-49ac-9793e496-1d2d5d61.dmp.zip' for upload.
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/10ad93f5-3129-49ac-9793e496-1d2d5d61.dmp.zip' svr:'https://services.nvidia.com/submit'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = '10ad93f5-3129-49ac-9793e496-1d2d5d61'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1693414294'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '231'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Isaac-Sim'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.1'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ''
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Isaac Sim'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '535.104'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 20.8276/31.0709GB, Swap: 33.9084/33.9101GB, VM: 1.71799e+10/1.71799e+10GB'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] stageUrl = '/home/betsi/Documents/omniverse/cube.usd'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| | | | | | Device-ID | UUID |
| | | | | | 2805 | 262da99c.. |
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '3591254679609441099'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = 'lWv5b7pRdGiSaRVjEbFXKveSE66ugIsnZL2hh6ZArWM'
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
2023-08-30 16:55:25 [230,507ms] [Warning] [carb.crashreporter-breakpad.plugin] upload_file_minidump = '/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/10ad93f5-3129-49ac-9793e496-1d2d5d61.dmp.zip'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] uploaded minidump: file: '/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/10ad93f5-3129-49ac-9793e496-1d2d5d61.dmp.zip', code:200, response:
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] 00000189095e18cb-21fcaa
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] deleting minidump: '/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/10ad93f5-3129-49ac-9793e496-1d2d5d61.dmp.zip' (use setting "/crashreporter/preserveDump=true" to save).
2023-08-30 16:55:28 [233,054ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/home/betsi/.local/share/ov/data/Kit/Isaac-Sim/2022.2/10ad93f5-3129-49ac-9793e496-1d2d5d61.dmp.zip'
2023-08-30 16:55:28 [233,054ms] [Error] [carb.crashreporter-breakpad.plugin] the dump file was deleted due to a successful upload. Its originalsize was 513093 bytes and was readable.
2023-08-30 16:55:28 [233,054ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 9077 thread 9077
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] DumpId = '10ad93f5-3129-49ac-9793e496-1d2d5d61'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] ProductName = 'OmniverseKit'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] RetryCount = '0'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] StartupTime = '1693414294'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] UploadSuccessful = '0'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] UptimeSeconds = '231'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] Version = '104.2+release.295.529af2e4.tc'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] appName = 'Isaac-Sim'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] appState = 'started'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] appVersion = '2022.2.1'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] autoloadExts = ''
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildBranch = 'release'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildCi = 'tc'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildHash = '529af2e4'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildId = '14001715'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMajor = '104'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMinor = '2'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildMr = '0'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildNumber = '295'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildPatch = '0'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] buildVersion = '104.2.0'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] environmentName = 'default'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] experience = 'Isaac Sim'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] kitRendererDriverVersion = '535.104'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommand = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] lastCommands = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] memoryStats = '(avail/total) RAM: 20.8276/31.0709GB, Swap: 33.9084/33.9101GB, VM: 1.71799e+10/1.71799e+10GB'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] portableMode = '0'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] stageUrl = '/home/betsi/Documents/omniverse/cube.usd'
2023-08-30 16:55:28 [233,054ms] [Warning] [carb.crashreporter-breakpad.plugin] systemInfo = '
| | | | | | Device-ID | UUID |
| | | | | | 2805 | 262da99c.. |
2023-08-30 16:55:28 [233,055ms] [Warning] [carb.crashreporter-breakpad.plugin] telemetrySessionId = '3591254679609441099'
2023-08-30 16:55:28 [233,055ms] [Warning] [carb.crashreporter-breakpad.plugin] userId = 'lWv5b7pRdGiSaRVjEbFXKveSE66ugIsnZL2hh6ZArWM'
2023-08-30 16:55:28 [233,055ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 9077 backtrace follows:
2023-08-30 16:55:28 [233,206ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2023-08-30 16:55:28 [233,345ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!pthread_kill+0x12c (./nptl/pthread_kill.c:44)
2023-08-30 16:55:28 [233,482ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!raise+0x16 (./signal/../sysdeps/posix/raise.c:27)
2023-08-30 16:55:28 [233,619ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libc.so.6!abort+0xd3 (./stdlib/abort.c:81 (discriminator 21))
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: 196!+0x102905
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: 196!+0x100e66
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: 196!+0x100ea1
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: 196!+0x100d03
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: 196!+0xf9be2
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: 196!+0xf593f
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: 196!+0xfab47
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: 196!+0xd1690
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: 196!+0xd4110
2023-08-30 16:55:28 [233,620ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: 196!+0xb55c8
2023-08-30 16:55:28 [233,621ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: 196!+0x92cdd
2023-08-30 16:55:28 [233,621ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: 196!+0x6e9cd
2023-08-30 16:55:28 [233,732ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x7187 (??:?)
2023-08-30 16:55:28 [233,847ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x640e (??:?)
2023-08-30 16:55:28 [233,959ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: librtx.postprocessing.plugin.so!_init+0x1de80 (??:0)
2023-08-30 16:55:29 [234,071ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: librtx.postprocessing.plugin.so!_init+0x2027a (??:0)
2023-08-30 16:55:29 [234,183ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: librtx.postprocessing.plugin.so!_init+0x207c3 (??:0)
2023-08-30 16:55:29 [234,298ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator<unsigned char> >::_M_default_append(unsigned long)+0xdb39 (??:?)
2023-08-30 16:55:29 [234,410ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x142be (??:?)
2023-08-30 16:55:29 [234,522ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1b4c9 (??:?)
2023-08-30 16:55:29 [234,634ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1bb63 (??:?)
2023-08-30 16:55:29 [234,747ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4a7db (??:?)
2023-08-30 16:55:29 [234,861ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4e21b (??:?)
2023-08-30 16:55:29 [234,974ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libcarb.scenerenderer-rtx.plugin.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned int, false>*)+0x1a917 (??:?)
2023-08-30 16:55:30 [235,087ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0x78e4 (??:?)
2023-08-30 16:55:30 [235,201ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0xae01 (??:?)
2023-08-30 16:55:30 [235,315ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x5e7a (??:?)
2023-08-30 16:55:30 [235,427ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xbfe1 (??:?)
2023-08-30 16:55:30 [235,541ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xc9c6 (??:?)
2023-08-30 16:55:30 [235,654ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xcf41 (??:?)
2023-08-30 16:55:30 [235,768ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libomni.usd.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)+0x4f9f (??:?)
2023-08-30 16:55:30 [235,885ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x188c (??:?)
2023-08-30 16:55:30 [236,001ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x2026 (??:?)
2023-08-30 16:55:31 [236,115ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0x8ac (??:?)
2023-08-30 16:55:31 [236,231ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0xe8e3 (??:?)
2023-08-30 16:55:31 [236,348ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libomni.kit.app.plugin.so!_init+0x28c7 (??:0)
2023-08-30 16:55:31 [236,464ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libomni.kit.app.plugin.so!carbOnPluginPostShutdown+0x907 (??:?)
2023-08-30 16:55:31 [236,576ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: kit!_init+0x635 (??:0)
2023-08-30 16:55:31 [236,717ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: libc.so.6!__libc_init_first+0x90 (./csu/../sysdeps/nptl/libc_start_call_main.h:58)
2023-08-30 16:55:31 [236,856ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: libc.so.6!__libc_start_main+0x80 (./csu/../csu/libc-start.c:128)
2023-08-30 16:55:31 [236,966ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: kit!_init+0x9cb (??:0)
Aborted (core dumped)
Do you think, the IOMMU could be the issue?
