VkResult: ERROR_DEVICE_LOST
When I attempted to load the “Hello World” example from Isaac Examples, the terminal shut down due to an error. The same issue occurs when trying to load other examples from Isaac.
I’ve already tried reinstalling the NVIDIA driver and Omniverse, including using the launcher-cleanup function, but the problem persists.
Description: Ubuntu 22.04.2 LTS
Isaac-Version: latest
AMD Ryzen 7 5700X 8-Core Processor
| NVIDIA-SMI 535.86.10 Driver Version: 535.86.10 CUDA Version: 12.2 |
| GPU Name Persistence-M | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 NVIDIA GeForce RTX 4070 On | 00000000:07:00.0 On | N/A |
| 0% 42C P8 16W / 200W | 317MiB / 12282MiB | 10% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 1010 G /usr/lib/xorg/Xorg 146MiB |
| 0 N/A N/A 1488 G /usr/bin/gnome-shell 87MiB |
| 0 N/A N/A 4432 G …85008126,3657705931484999563,262144 73MiB |
kit_20230809_080945.log (1.4 MB)
I solved this problem by replacing 2022.2.1 with 2022.1.1.
Hi, can you try running Isaac Sim 2022.2.1 with the recommended version of the driver: 525.60.11?
I am getting the same VkResult: ERROR_DEVICE_LOST error resulting in Isaac crashing/hanging on version 2022.2.1 and 525.60.11 driver. This would occur shortly after Isaac starts, so I was unable to run even the examples.
Uninstalling and reinstalling Isaac would get me to the ray tracing compilation, but the error would occur again.
Below are my system specs.
$ nvidia-smi
Mon Aug 14 18:47:58 2023
| NVIDIA-SMI 525.60.11    Driver Version: 525.60.11    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:04:00.0 Off |                  N/A |
| 30%   55C    P8    16W / 250W |     10MiB / 24576MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  NVIDIA GeForce ...  On   | 00000000:09:00.0  On |                  N/A |
| 90%   73C    P8    56W / 250W |    582MiB / 24576MiB |      1%      Default |
|                               |                      |                  N/A |
| Processes:        |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      1918      G   /usr/lib/xorg/Xorg                  4MiB |
|    0   N/A  N/A      2905      G   /usr/lib/xorg/Xorg                  4MiB |
|    1   N/A  N/A      1918      G   /usr/lib/xorg/Xorg                 53MiB |
|    1   N/A  N/A      2905      G   /usr/lib/xorg/Xorg                141MiB |
|    1   N/A  N/A      3065      G   /usr/bin/gnome-shell               85MiB |
|    1   N/A  N/A      4817      G   /usr/lib/firefox/firefox          163MiB |
$ lshw -short
WARNING: you should run this program as super-user.
H/W path            Device           Class       Description
                                     system      Computer
/0                                   bus         Motherboard
/0/0                                 memory      130GiB System memory
/0/1                                 processor   AMD Ryzen 9 5900X 12-Core Processor
/0/100                               bridge      Starship/Matisse Root Complex
/0/100/0.2                           generic     Starship/Matisse IOMMU
/0/100/1.1                           bridge      Starship/Matisse GPP Bridge
/0/100/1.1/0                         storage     E16 PCIe4 NVMe Controller
/0/100/1.1/0/0      /dev/nvme0       storage     Force MP600
/0/100/1.1/0/0/1    /dev/nvme0n1     disk        NVMe namespace
/0/100/1.2                           bridge      Starship/Matisse GPP Bridge
/0/100/1.2/0                         bridge      Matisse Switch Upstream
/0/100/1.2/0/2                       bridge      Matisse PCIe GPP Bridge
/0/100/1.2/0/2/0                     display     NVIDIA Corporation
/0/100/1.2/0/2/0.1                   multimedia  NVIDIA Corporation
/0/100/1.2/0/4                       bridge      Matisse PCIe GPP Bridge
/0/100/1.2/0/4/0    enp5s0           network     I211 Gigabit Network Connection
/0/100/1.2/0/8                       bridge      Matisse PCIe GPP Bridge
/0/100/1.2/0/8/0                     generic     Starship/Matisse Reserved SPP
/0/100/1.2/0/8/0.1                   bus         Matisse USB 3.0 Host Controller
/0/100/1.2/0/8/0.3                   bus         Matisse USB 3.0 Host Controller
/0/100/1.2/0/9                       bridge      Matisse PCIe GPP Bridge
/0/100/1.2/0/9/0                     storage     FCH SATA Controller [AHCI mode]
/0/100/1.2/0/a                       bridge      Matisse PCIe GPP Bridge
/0/100/1.2/0/a/0                     storage     FCH SATA Controller [AHCI mode]
/0/100/3.1                           bridge      Starship/Matisse GPP Bridge
/0/100/3.1/0                         display     NVIDIA Corporation
/0/100/3.1/0.1                       multimedia  NVIDIA Corporation
kit_20230814_175205.log (1.3 MB)
Update: I include below the output of vulkaninfo as instructed on the Linux Troubleshooting page.
20230815-vulkaninfo.txt (168.9 KB)
I am getting the same error also for 2022.1.1, however, unlike kinkado115.
kit_20230814_195245.log (1.0 MB)
Update: On the same system in Windows the application also crashes, attached is the log file
kit_20230815_105609.log (1.1 MB)
Update 2: On the system with one GPU unpowered and fresh driver (525.60.11) installation, the application crashes after opening the hello world example.
kit_20230815_142152.log (1.4 MB)
An update of the BIOS seems to have resolved this issue. I can now run Isaac navigation example in both Ubuntu 20.04 and Ubuntu 22.04. FYI, the motherboard model is GIGABYTE X570 AORUS ELITE.
