Isaac sim unable to load after restart [ VkResult: ERROR_OUT_OF_DEVICE_MEMORY]
I used Isaac sim to do some simulation on my Ubuntu laptop for a while and it worked fine. But after once I restarted my computer. I was not able to launch Isaac Sim in Omniverse. I tried to launch Isaac sim using provided isaac_sim.sh and it showed:
[0.357s] [ext: omni.kit.renderer.init-0.0.0] startup
2024-01-12 06:32:13 [1,539ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (ADL GT2)
| Driver Version: 545.29.06     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA GeForce RTX 3070 Ti Lap.. | Yes: 0 |     | 8438    MB | 10de      | 0          |
|     |                                  |        |     |            | 24e0      | a8ffd185.. |
|     |                                  |        |     |            | 1         |            |
| 1   | Intel(R) Graphics (ADL GT2)      |        |     | 48018   MB | 8086      | 0          |
|     |                                  |        |     |            | 46a6      | 3fc767c9.. |
|     |                                  |        |     |            | 0         |            |
| OS: 22.04.3 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.3, Kernel: 6.5.0-14-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 12th Gen Intel(R) Core(TM) i7-12700H | Cores: 14 | Logical: 20
| Total Memory (MB): 64024 | Free Memory: 59934
| Total Page/Swap (MB): 9999 | Free Page/Swap: 9999
[1.866s] [ext: omni.kit.pipapi-0.0.0] startup
[1.867s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.867s] [ext: omni.kit.telemetry-0.5.0] startup
[1.880s] [ext: omni.kit.loop-default-0.2.0] startup
[1.880s] [ext: omni.kit.test-0.0.0] startup
[1.921s] [ext: omni.mtlx-0.1.0] startup
[1.921s] [ext: omni.usd.config-1.0.3] startup
[1.923s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.924s] [ext: omni.usd.libs-1.0.0] startup
[2.018s] [ext: omni.pip.compute-1.2.0] startup
[2.018s] [ext: omni.pip.cloud-1.0.1] startup
[2.022s] [ext: omni.isaac.core_archive-2.2.1] startup
[2.022s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[2.023s] [ext: omni.usd.schema.anim-0.0.0] startup
[2.169s] [ext: omni.usd.schema.audio-0.0.0] startup
[2.172s] [ext: omni.appwindow-1.1.5] startup
[2.229s] [ext: omni.kit.renderer.core-0.0.0] startup
2024-01-12 06:32:13 [2,287ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_OUT_OF_DEVICE_MEMORY
2024-01-12 06:32:13 [2,287ms] [Error] [carb.graphics-vulkan.plugin] vkCreateSwapchainKHR failed.
2024-01-12 06:32:13 [2,287ms] [Error] [carb.graphics-vulkan.plugin] Failed to create a swapchain.
2024-01-12 06:32:13 [2,287ms] [Error] [omni.kit.renderer.plugin] createSwapchain failed. Width: 1440, height: 900, Format: 9
2024-01-12 06:32:13 [2,287ms] [Error] [omni.kit.renderer.plugin] Failed to initialize graphics environment.
[2.314s] [ext: omni.kit.renderer.capture-0.0.0] startup
[2.317s] [ext: omni.kit.renderer.imgui-0.0.0] startup
2024-01-12 06:32:14 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2024-01-12 06:32:14 [35ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into '/home/zheng/.local/share/ov/data/Kit/Isaac-Sim/2023.1/ab03b37a-c678-409b-4b8347a9-cadabfca.dmp.zip' for upload.
'crashreport.gui' exited with code 1272024-01-12 06:32:14 [180ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file '/home/zheng/.local/share/ov/data/Kit/Isaac-Sim/2023.1/ab03b37a-c678-409b-4b8347a9-cadabfca.dmp.zip'
2024-01-12 06:32:14 [185ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Uploading minidump: file:'/home/zheng/.local/share/ov/data/Kit/Isaac-Sim/2023.1/ab03b37a-c678-409b-4b8347a9-cadabfca.dmp.zip' svr:'https://services.nvidia.com/submit'
2024-01-12 06:32:14 [190ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata for upload:
2024-01-12 06:32:14 [195ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   CarbSdkVersion = '156.0+release156.tc9247.e85106ac'
2024-01-12 06:32:14 [201ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   CrashTime = 'Fri Jan 12 06:32:14 2024 GMT'
2024-01-12 06:32:14 [206ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   DriverShaderCacheWrapper = 'disabled'
2024-01-12 06:32:14 [211ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   DumpId = 'ab03b37a-c678-409b-4b8347a9-cadabfca'
2024-01-12 06:32:14 [216ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   ProductName = 'OmniverseKit'
2024-01-12 06:32:14 [221ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   PythonTracebackStatus = ''py-spy' successfully wrote info to '/home/zheng/.local/share/ov/data/Kit/Isaac-Sim/2023.1/ab03b37a-c678-409b-4b8347a9-cadabfca.py.txt''
2024-01-12 06:32:14 [226ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   RetryCount = '0'
2024-01-12 06:32:14 [231ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   StartupTime = '1705041131'
2024-01-12 06:32:14 [237ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UploadSuccessful = '0'
2024-01-12 06:32:14 [242ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UptimeSeconds = '3'
2024-01-12 06:32:14 [247ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UserStory = ''
2024-01-12 06:32:14 [252ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   UserStoryStatus = ''crashreport.gui' exited with code 127'
2024-01-12 06:32:14 [258ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   Version = '105.1+release.130815.04872a84.tc'
2024-01-12 06:32:14 [263ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_enabled = '1'
2024-01-12 06:32:14 [268ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_flags = '3'
2024-01-12 06:32:14 [273ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_status = 'auto-enabled'
2024-01-12 06:32:14 [279ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   aftermath_version = '2022.2'
2024-01-12 06:32:14 [284ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appName = 'Isaac-Sim'
2024-01-12 06:32:14 [289ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appState = 'startup'
2024-01-12 06:32:14 [294ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   appVersion = '2023.1.0'
2024-01-12 06:32:14 [300ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   autoloadExts = 'omni.isaac.quadruped-1.3.2'
2024-01-12 06:32:14 [305ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildBranch = 'release'
2024-01-12 06:32:14 [310ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildCi = 'tc'
2024-01-12 06:32:14 [315ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildHash = '04872a84'
2024-01-12 06:32:14 [320ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildId = '18000955'
2024-01-12 06:32:14 [325ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMajor = '105'
2024-01-12 06:32:14 [331ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMinor = '1'
2024-01-12 06:32:14 [336ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildMr = '0'
2024-01-12 06:32:14 [341ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildNumber = '130815'
2024-01-12 06:32:14 [347ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildPatch = '0'
2024-01-12 06:32:14 [352ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   buildVersion = '105.1.0'
2024-01-12 06:32:14 [357ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   commandLine = './kit/kit ./apps/omni.isaac.sim.kit --ext-folder ./apps'
2024-01-12 06:32:14 [362ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   cpuId = 'Intel64 Family 6 Model 154 Stepping 3'
2024-01-12 06:32:14 [368ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   cpuName = '12th Gen Intel(R) Core(TM) i7-12700H'
2024-01-12 06:32:14 [373ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   cpuVendor = 'GenuineIntel'
2024-01-12 06:32:14 [379ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   desktopOrigin = '(0, 0)'
2024-01-12 06:32:14 [384ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   desktopSize = '2560x1600'
2024-01-12 06:32:14 [389ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   displayCount = '1'
2024-01-12 06:32:14 [395ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   displayRes_0 = '2560x1600x32bit@165Hz'
2024-01-12 06:32:14 [400ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   environmentName = 'Individual'
2024-01-12 06:32:14 [405ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   experience = 'Isaac Sim'
2024-01-12 06:32:14 [411ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   externalBuild = '1'
2024-01-12 06:32:14 [417ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   gpuDriver_0 = '545.29'
2024-01-12 06:32:14 [422ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   gpuDriver_1 = '0x5c00004'
2024-01-12 06:32:14 [427ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   gpuVRAM_0 = '8847884288'
2024-01-12 06:32:14 [433ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   gpuVRAM_1 = '50350728192'
2024-01-12 06:32:14 [438ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   gpu_0 = 'NVIDIA GeForce RTX 3070 Ti Laptop GPU'
2024-01-12 06:32:14 [443ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   gpu_1 = 'Intel(R) Graphics (ADL GT2)'
2024-01-12 06:32:14 [449ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   kitRendererDriverVersion = '545.29'
2024-01-12 06:32:14 [454ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   memoryStats = '(avail/total) RAM: 57.2758/62.5237GB, Swap: 9.76562/9.76562GB, VM: 1.71799e+10/1.71799e+10GB'
2024-01-12 06:32:14 [459ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   nvidia-smi = 'Fri Jan 12 14:32:13 2024
| NVIDIA-SMI 545.29.06              Driver Version: 545.29.06    CUDA Version: 12.3     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 3070 ...    Off | 00000000:01:00.0 Off |                  N/A |
| N/A   37C    P3             752W /  50W |      1MiB /  8192MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
2024-01-12 06:32:14 [465ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   osDistro = 'ubuntu'
2024-01-12 06:32:14 [470ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   osName = '22.04.3 LTS (Jammy Jellyfish)'
2024-01-12 06:32:14 [476ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   osVersion = '22.04.3'
2024-01-12 06:32:14 [482ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   portableMode = '0'
2024-01-12 06:32:14 [487ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   primaryDisplayRes = '2560x1600x32bit@165Hz'
2024-01-12 06:32:14 [493ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   runEnvironment = 'Individual'
2024-01-12 06:32:14 [499ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   shaderdb_debugSymbols = '0'
2024-01-12 06:32:14 [505ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   shaderdb_dumpIncludeOverrides = '0'
2024-01-12 06:32:14 [510ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   shaderdb_dumpIntermediates = '0'
2024-01-12 06:32:14 [516ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   shaderdb_obfuscateCode = '1'
2024-01-12 06:32:14 [521ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   shaderdb_optimizationLevel = '1'
2024-01-12 06:32:14 [526ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash]   systemInfo = '
It worn ERROR_OUT_OF_DEVICE_MEMORY, but nothing was running. I tried to kill all processes used nvidia, but issue still remains.
What I did before I restarted computer:
Installed Isaac Orbit and ran some demo using it.
Installed SimpleScreenRecorder and recorded the screen while running Isaac sim demos. Meanwhile It showed some out of memory warnings, but Isaac sim can still run or relaunch from the omniverse.
Then I restarted the computer and this issue appeared.
May I know how to fix this?
Best regards!
kit_20240112_143211.log (574.8 KB)
a most recent log
The log for the last time I successfully run isaac sim
kit_20240112_114853.log (1.3 MB)
Do need your help, thanks a lot!
Hi. Thanks for including your log files.
It looks like the 8GB VRAM on the 3070 Ti is the bare minimum to run Isaac Sim. It still shows the memory error even when Isaac Sim runs.
Do you see the same error when running USD Composer or Code?
Try running Isaac Sim right after a reboot. You could also try disabling some extensions that run with Isaac Sim.
Another thing to try is to use the 525 drivers instead. We have not fully tested with the new 545 drivers.
Thanks for your instant replay.
I tried to reboot and ran:
./python.sh standalone_examples/api/omni.isaac.franka/follow_target_with_rmpflow.py
but it shows the same error as before.
However when I tried to run
./jupyter_notebook.sh standalone_examples/notebooks/hello_world.ipynb
It seems to work-ish with some errors. The cube pose is printed in the cell, but GUI is not popped out.
Error shows in the first cell:
2024-01-15 01:10:58 [10,374ms] [Error] [omni.kit.app.plugin] Can’t delay app ready event, it was already sent. Requester name: omni.usd
Error shows in the last cell
2023-12-22 03:43:02 [497,153ms] [Error] [carb.graphics-vulkan.plugin] pipelineLayouts: 2 or descriptorSetLayouts: 9 is leaking memory. Missing call to destroyResourceBindingSignature()
log:
kit_20240115_091048.log (782.6 KB)
Any comments on that?
I am trying to dowload the usd composer and reinstall the drivers and see how it works. Can you provide any guidance to fully uninstall the old driver and reinstall the new one? And how to disable the extensions run with isaac sim in command line without isaac sim to be opened?
Best
not sure if this will help?
Thanks for your reply. That do helps.
However, when I try to reinstall the driver, it shows error: You appear to be running an X server; please exit X before installing, which was not shown last time I installed. Don’t know if this could be the problem cause Isaac unable to launch. I am trying to fix that to reinstall the driver.
Are you able to reinstall the drivers with the linux trouble shooting link above?
Run this command to get into an environment without X server running:
sudo systemctl isolate multi-user.target
