Isaac sim launch stuck after "RTX ready"
Isaac sim launch stuck after “RTX ready”. The shader is built successfully. But it keeps “progress…” forever.
Same here
Anyone??
I 'm still facing the same problem. I have to remove omniverse entirelly to get the Isaac Sim to work… After a few success launch, the problem came back again. RTX ready then the ‘progress’ indicator keep running and Isaac Sim is not responding.
I got the same one. No solutions yet??
Please share full logs.
Here’s the log
Loading user config located at: '/home/dev/.local/share/ov/data/Kit/Isaac-Sim/2022.2/user.config.json'
[Info] [carb] Logging to file: /home/dev/.nvidia-omniverse/logs/Kit/Isaac-Sim/2022.2/kit_20230721_154907.log
2023-07-21 07:49:07 [42ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.lidar] Extensions config 'extension.toml' doesn't exist '/home/dev/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar' or '/home/dev/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.lidar/config'
2023-07-21 07:49:07 [42ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.radar] Extensions config 'extension.toml' doesn't exist '/home/dev/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar' or '/home/dev/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.sensors.nv.radar/config'
[0.141s] [ext: omni.stats-0.0.0] startup
[0.155s] [ext: omni.rtx.shadercache-1.0.0] startup
[0.160s] [ext: omni.assets.plugins-0.0.0] startup
[0.161s] [ext: omni.gpu_foundation-0.0.0] startup
[0.164s] [ext: carb.windowing.plugins-1.0.0] startup
[0.169s] [ext: omni.kit.renderer.init-0.0.0] startup
2023-07-21 07:49:07 [375ms] [Warning] [carb.graphics-vulkan.plugin] No command queue family supports flags: 0x100, queue type: 3. No queues of this type will be created
2023-07-21 07:49:07 [386ms] [Warning] [gpu.foundation.plugin] Raytracing is not supported on GPU: 0. Skipping this device.
| Driver Version: 525.125.06    | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | AMD Unknown (RADV GFX1036)       |        |     | 21485   MB | 1002      | 0          |
|     |                                  |        |     |            | 164e      | 00000000.. |
| 1   | NVIDIA GeForce RTX 4070          | Yes: 0 |     | 12282   MB | 10de      | 0          |
|     |                                  |        |     |            | 2786      | 988c6261.. |
| OS: Linux dev-MS-7D69, Version: 5.19.0-46-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: AMD Ryzen 9 7900 12-Core Processor              | Cores: Unknown | Logical: 24
| Total Memory (MB): 63433 | Free Memory: 48686
| Total Page/Swap (MB): 4095 | Free Page/Swap: 4095
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. Found 28 items in /sys/kernel/iommu_groups/.
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin] On Linux only, CUDA and the display driver does not support IOMMU-enabled bare-metal PCIe peer to peer memory copy.
However, CUDA and the display driver does support IOMMU via VM pass through. As a consequence, users on Linux,
when running on a native bare metal system, should disable the IOMMU. The IOMMU should be enabled and the VFIO driver
be used as a PCIe pass through for virtual machines.
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin] !!!!! Local system validation failed! Incorrect configuration detected.
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin]       Summary below. Details above.
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin]  - ECC:                         OK
2023-07-21 07:49:07 [423ms] [Warning] [gpu.foundation.plugin]  - IOMMU:                       FAILED
[0.631s] [ext: omni.kit.pipapi-0.0.0] startup
[0.638s] [ext: omni.usd.config-1.0.0] startup
[0.640s] [ext: omni.usd.libs-1.0.0] startup
[0.721s] [ext: omni.kit.pip_archive-0.0.0] startup
[0.724s] [ext: omni.kit.async_engine-0.0.0] startup
[0.724s] [ext: omni.kit.loop-default-0.1.1] startup
[0.724s] [ext: omni.kit.test-0.0.0] startup
[0.750s] [ext: omni.usd.schema.semantics-0.0.0] startup
[0.775s] [ext: omni.usd.schema.audio-0.0.0] startup
[0.780s] [ext: omni.client-0.1.1] startup
[0.783s] [ext: omni.iray.libs-0.0.0] startup
[0.786s] [ext: omni.volume-0.1.0] startup
[0.787s] [ext: omni.usd.core-1.0.4] startup
[0.788s] [ext: omni.mdl.neuraylib-0.1.0] startup
[0.790s] [ext: omni.hydra.rtx-0.1.0] startup
[0.794s] [ext: omni.hydra.iray-0.1.0] startup
[0.795s] [ext: omni.isaac.core_archive-2.0.1] startup
[0.853s] [ext: omni.services.pip_archive-0.4.2] startup
[0.856s] [ext: omni.pip.torch-1_13_1-0.1.4] startup
[0.859s] [ext: omni.isaac.ml_archive-1.1.0] startup
[0.883s] [ext: omni.appwindow-1.0.1] startup
[0.885s] [ext: omni.kit.renderer.core-0.0.0] startup
[0.918s] [ext: omni.kit.renderer.capture-0.0.0] startup
[0.919s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[0.956s] [ext: omni.ui-2.14.4] startup
[0.962s] [ext: carb.audio-0.1.0] startup
[0.963s] [ext: omni.uiaudio-1.0.0] startup
[0.964s] [ext: omni.kit.mainwindow-1.0.0] startup
[0.964s] [ext: omni.kit.uiapp-0.0.0] startup
[0.964s] [ext: omni.usd.schema.physics-1.0.0] startup
[0.971s] [ext: omni.usd.schema.anim-0.0.0] startup
[1.012s] [ext: omni.usd.schema.isaac-1.1.0] startup
[1.022s] [ext: omni.usd.schema.scene.visualization-1.0.0] startup
[1.022s] [ext: omni.usd.schema.physx-0.0.0] startup
[1.039s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[1.044s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[1.049s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[1.053s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[1.059s] [ext: omni.kit.actions.core-1.0.0] startup
[1.060s] [ext: omni.kit.audiodeviceenum-1.0.0] startup
[1.061s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.061s] [ext: omni.kit.window.popup_dialog-2.0.16] startup
[1.064s] [ext: omni.hydra.usdrt_delegate-4.3.2] startup
[1.073s] [ext: omni.kit.widget.nucleus_connector-1.0.3] startup
[1.075s] [ext: omni.timeline-1.0.5] startup
[1.075s] [ext: omni.kit.commands-1.4.5] startup
[1.077s] [ext: omni.hydra.scene_delegate-0.3.0] startup
[1.080s] [ext: omni.usd-1.6.30] startup
[1.103s] [ext: omni.usd.fileformat.e57-0.1.11] startup
[1.104s] [ext: omni.usd.schema.destruction-0.4.0] startup
[1.108s] [ext: omni.kit.asset_converter-1.3.4] startup
[1.116s] [ext: omni.usd.fileformat.sbsar-0.9.11] startup
[1.146s] [ext: omni.usd.schema.sequence-2.2.1] startup
[1.151s] [ext: omni.usd.schema.flow-104.1.6] startup
[1.152s] [ext: omni.inspect-1.0.1] startup
[1.153s] [ext: omni.kit.widget.path_field-2.0.4] startup
[1.153s] [ext: omni.debugdraw-0.1.1] startup
[1.155s] [ext: omni.kit.notification_manager-1.0.5] startup
[1.158s] [ext: omni.graph.core-2.65.4] startup
[1.159s] [ext: omni.kit.widget.browser_bar-2.0.5] startup
[1.160s] [ext: omni.kit.widget.versioning-1.3.8] startup
[1.161s] [ext: omni.kit.widget.filebrowser-2.3.10] startup
[1.167s] [ext: omni.kit.search_core-1.0.2] startup
[1.167s] [ext: omni.hydra.pxr-1.1.2] startup
[1.171s] [ext: omni.kit.collaboration.channel_manager-1.0.9] startup
[1.172s] [ext: omni.kit.window.filepicker-2.7.15] startup
UsdE57FileFormat
[1.203s] [ext: omni.kit.menu.utils-1.4.7] startup
[1.208s] [ext: omni.kit.usd.layers-2.0.11] startup
[1.212s] [ext: omni.mdl-0.1.0] startup
[1.222s] [ext: omni.kit.window.file_importer-1.0.10] startup
[1.223s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[1.223s] [ext: omni.kit.primitive.mesh-1.0.8] startup
[1.225s] [ext: omni.kit.material.library-1.3.21] startup
[1.228s] [ext: omni.kit.clipboard-1.0.0] startup
[1.228s] [ext: omni.kit.window.file_exporter-1.0.10] startup
[1.229s] [ext: omni.kit.stage_templates-1.1.13] startup
[1.230s] [ext: omni.kit.menu.create-1.0.8] startup
[1.231s] [ext: omni.ui_query-1.1.1] startup
[1.231s] [ext: omni.kit.context_menu-1.5.12] startup
[1.233s] [ext: omni.activity.core-1.0.1] startup
[1.235s] [ext: omni.kit.window.file-1.3.32] startup
[1.236s] [ext: omni.kit.window.drop_support-1.0.1] startup
[1.236s] [ext: omni.kit.ui_test-1.2.9] startup
[1.238s] [ext: omni.kit.widget.stage-2.7.24] startup
[1.239s] [ext: omni.kit.window.property-1.8.2] startup
[1.240s] [ext: omni.kit.window.content_browser-2.6.8] startup
[1.250s] [ext: omni.kit.usd_undo-0.1.2] startup
[1.250s] [ext: omni.graph.tools-1.17.2] startup
[1.259s] [ext: omni.hydra.engine.stats-1.0.0] startup
[1.260s] [ext: omni.kit.property.usd-3.18.17] startup
[1.265s] [ext: omni.graph-1.50.2] startup
[1.290s] [ext: omni.kit.hydra_texture-1.0.11] startup
[1.293s] [ext: omni.kit.viewport.registry-104.0.2] startup
[1.294s] [ext: omni.ui.scene-1.5.18] startup
[1.296s] [ext: omni.kit.widget.viewport-104.1.16] startup
[1.298s] [ext: omni.kit.viewport.legacy_gizmos-1.0.10] startup
[1.299s] [ext: omni.kit.widget.searchfield-1.0.10] startup
[1.300s] [ext: omni.kit.widget.graph-1.5.6-104_2] startup
[1.312s] [ext: omni.kit.viewport.window-104.1.23] startup
[1.320s] [ext: omni.kit.widget.prompt-1.0.5] startup
[1.321s] [ext: omni.kit.window.extensions-1.1.1] startup
[1.323s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[1.324s] [ext: omni.kit.viewport.utility-1.0.14] startup
[1.325s] [ext: omni.kit.graph.delegate.default-1.0.18] startup
[1.326s] [ext: omni.kit.widget.settings-1.0.1] startup
[1.327s] [ext: omni.kit.graph.delegate.modern-1.6.5] startup
[1.327s] [ext: omni.kit.window.preferences-1.3.8] startup
[1.342s] [ext: omni.graph.ui-1.24.2] startup
[1.359s] [ext: omni.kit.graph.editor.core-1.4.7] startup
[1.360s] [ext: omni.convexdecomposition-104.2.4-5.1] startup
[1.361s] [ext: omni.kit.numpy.common-0.1.0] startup
[1.362s] [ext: omni.kvdb-0.0.0] startup
[1.364s] [ext: omni.kit.graph.widget.variables-2.0.4] startup
[1.364s] [ext: omni.usdphysics-104.2.4-5.1] startup
[1.366s] [ext: omni.localcache-0.0.0] startup
[1.367s] [ext: omni.kit.graph.usd.commands-1.2.0] startup
[1.367s] [ext: omni.kit.widget.imageview-1.0.3] startup
[1.368s] [ext: omni.physx-104.2.4-5.1] startup
[1.412s] [ext: omni.isaac.debug_draw-0.2.3] startup
[1.416s] [ext: omni.kit.window.quicksearch-2.3.3] startup
[1.417s] [ext: omni.isaac.dynamic_control-1.2.3] startup
[1.422s] [ext: omni.graph.examples.cpp-1.4.2] startup
[1.424s] [ext: omni.graph.window.core-1.43.3] startup
[1.428s] [ext: omni.isaac.version-1.0.0] startup
[1.429s] [ext: usdrt.scenegraph-4.3.2] startup
[1.439s] [ext: omni.kit.widgets.custom-1.0.4] startup
[1.443s] [ext: omni.graph.window.action-1.5.5] startup
[1.444s] [ext: omni.graph.nodes-1.48.3] startup
[1.450s] [ext: omni.anim.retarget.core-104.2.1] startup
[1.455s] [ext: omni.kit.widget.zoombar-1.0.4] startup
[1.455s] [ext: omni.kit.widget.toolbar-1.4.0] startup
[1.458s] [ext: omni.kit.manipulator.transform-104.6.12] startup
[1.459s] [ext: omni.anim.graph.core-104.2.1] startup
[1.462s] [ext: omni.kit.browser.core-2.2.2] startup
[1.465s] [ext: omni.kit.manipulator.tool.snap-1.2.4] startup
[1.468s] [ext: omni.curve.creator-104.1.2] startup
[1.470s] [ext: omni.physics.tensors-0.1.0] startup
[1.474s] [ext: omni.kit.browser.folder.core-1.7.3] startup
[1.476s] [ext: omni.kit.widget.stage_icons-1.0.2] startup
[1.476s] [ext: omni.scene.visualization.core-104.4.0] startup
[1.506s] [ext: omni.ramp-104.1.3] startup
[1.509s] [ext: omni.kit.window.stage-2.3.12] startup
[1.511s] [ext: omni.kit.manipulator.viewport-104.0.7] startup
[1.512s] [ext: omni.genproc.core-104.5.14] startup
[1.521s] [ext: omni.curve.manipulator-104.7.3] startup
[1.529s] [ext: omni.physx.tensors-0.1.0] startup
[1.532s] [ext: omni.command.usd-1.0.2] startup
[1.533s] [ext: omni.kit.browser.sample-1.2.5] startup
[1.534s] [ext: omni.graph.visualization.nodes-2.0.0] startup
[1.538s] [ext: omni.graph.io-1.2.5] startup
[1.541s] [ext: omni.graph.action-1.31.1] startup
[1.545s] [ext: omni.kit.window.cursor-1.1.1] startup
[1.546s] [ext: omni.kit.widget.spinner-1.0.4] startup
[1.546s] [ext: omni.kit.widget.searchable_combobox-1.0.4] startup
[1.547s] [ext: omni.graph.bundle.action-1.3.0] startup
[1.547s] [ext: omni.kit.viewport.menubar.core-104.4.3] startup
[1.556s] [ext: omni.anim.graph.ui-104.2.0] startup
[1.561s] [ext: omni.isaac.core-1.46.3] startup
[1.989s] [ext: omni.graph.scriptnode-0.10.0] startup
[1.991s] [ext: omni.warp-0.6.3] startup
Warp 0.6.3 initialized:
   CUDA Toolkit: 11.5, Driver: 12.0
   Devices:
     "cpu"    | x86_64
     "cuda:0" | NVIDIA GeForce RTX 4070 (sm_89)
   Kernel cache: /home/dev/.cache/warp/0.6.3
[2.115s] [ext: omni.syntheticdata-0.2.4] startup
2023-07-21 07:49:09 [2,111ms] [Warning] [omni.kit.viewport.menubar.core.menu_item.viewport_menu_item] ViewportMenuItem order argument is deprecated, use order_setting_path
[2.126s] [ext: omni.anim.graph.bundle-104.2.0] startup
[2.126s] [ext: omni.isaac.ui-0.8.0] startup
[2.128s] [ext: omni.isaac.lula-1.2.1] startup
[2.134s] [ext: omni.isaac.motion_planning-0.2.2] startup
[2.138s] [ext: omni.replicator.core-1.7.8] startup
2023-07-21 07:49:09 [2,172ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[2.209s] [ext: omni.isaac.utils-0.2.4] startup
[2.211s] [ext: omni.isaac.surface_gripper-0.4.0] startup
[2.213s] [ext: omni.isaac.motion_generation-4.5.6] startup
[2.216s] [ext: omni.isaac.range_sensor-0.8.1] startup
[2.233s] [ext: omni.isaac.core_nodes-0.23.2] startup
[2.240s] [ext: omni.isaac.demos-0.3.3] startup
[2.247s] [ext: omni.isaac.sensor-5.6.3] startup
2023-07-21 07:49:09 [2,235ms] [Warning] [omni.ext.plugin] [ext: omni.isaac.sensor-5.6.3] Native plugin search dir contains several files: /home/dev/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.sensor/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[2.268s] [ext: omni.isaac.manipulators-1.1.0] startup
[2.269s] [ext: omni.isaac.quadruped-1.3.0] startup
[2.409s] [ext: omni.isaac.synthetic_utils-0.4.3] startup
[2.410s] [ext: omni.isaac.universal_robots-0.3.2] startup
[2.411s] [ext: omni.isaac.wheeled_robots-0.6.3] startup
[2.415s] [ext: omni.isaac.franka-0.4.0] startup
[2.415s] [ext: omni.isaac.dofbot-0.3.0] startup
[2.416s] [ext: omni.isaac.diff_usd-1.0.1] startup
[2.416s] [ext: omni.isaac.examples-1.5.6] startup
2023-07-21 07:49:09 [2,447ms] [Warning] [omni.isaac.core.utils.nucleus] /persistent/app/omniverse/mountedDrives setting not found
2023-07-21 07:49:09 [2,447ms] [Warning] [omni.client.plugin]  HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for http://omniverse-content-production.s3-us-west-2.amazonaws.com/.cloudfront.toml
2023-07-21 07:49:09 [2,447ms] [Warning] [omni.client.plugin]  HTTP Client: omniclient: CC-873: Bypassing cache until the application is restarted
2023-07-21 07:49:10 [2,786ms] [Warning] [omni.client.plugin]  HTTP Client: provider_http: CC-493: Request through cache failed. Retrying without cache for http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/2022.2.1/
[2.978s] [ext: omni.activity.pump-1.0.0] startup
[2.979s] [ext: omni.activity.usd_resolver-1.0.1] startup
[2.980s] [ext: omni.anim.skelJoint-104.2.22] startup
[2.982s] [ext: omni.isaac.examples_nodes-0.1.0] startup
[2.984s] [ext: omni.graph.window.generic-1.3.15] startup
[2.985s] [ext: omni.isaac.extension_templates-1.0.0] startup
[2.985s] [ext: omni.activity.ui-1.0.20] startup
[2.989s] [ext: omni.anim.retarget.ui-104.2.0] startup
[2.993s] [ext: omni.isaac.isaac_sensor-2.0.0] startup
2023-07-21 07:49:10 [2,981ms] [Warning] [omni.isaac.isaac_sensor] omni.isaac.isaac_sensor is deprecated and was renamed; use omni.isaac.sensor
[2.993s] [ext: omni.kit.profiler.window-2.0.5] startup
[3.034s] [ext: omni.isaac.kit-1.4.1] startup
[3.034s] [ext: omni.anim.retarget.bundle-104.2.0] startup
[3.035s] [ext: omni.activity.freeze_monitor-1.0.1] startup
[3.039s] [ext: omni.isaac.merge_mesh-0.1.2] startup
[3.040s] [ext: omni.isaac.mjcf-0.3.1] startup
[3.044s] [ext: omni.isaac.articulation_inspector-0.1.3] startup
[3.045s] [ext: omni.isaac.occupancy_map-0.2.7] startup
[3.051s] [ext: omni.isaac.shapenet-2.0.1] startup
[3.057s] [ext: omni.kit.hotkeys.core-1.0.8] startup
[3.062s] [ext: omni.kit.widget.live_session_management-1.1.3] startup
[3.063s] [ext: omni.isaac.synthetic_recorder-1.5.0] startup
[3.065s] [ext: omni.isaac.unit_converter-0.1.6] startup
[3.066s] [ext: omni.kit.widget.calendar-1.0.5] startup
[3.067s] [ext: omni.kit.ngsearch-0.0.10] startup
2023-07-21 07:49:10 [3,060ms] [Warning] [idl.telemetry.opentelemetry] opentelemetry package is not available, context propagation will be disabled
[3.081s] [ext: omni.kit.widget.highlight_label-1.0.0] startup
[3.082s] [ext: omni.kit.widget.layers-1.6.11] startup
[3.087s] [ext: omni.kit.menu.stage-1.2.1] startup
[3.087s] [ext: omni.kit.tool.collect-2.1.20] startup
[3.090s] [ext: omni.kit.widget.extended_searchfield-1.0.17] startup
[3.095s] [ext: omni.isaac.urdf-0.5.9] startup
[3.110s] [ext: omni.kit.actions.window-1.1.0] startup
[3.112s] [ext: omni.kit.property.layer-1.1.4] startup
[3.113s] [ext: omni.isaac.window.about-1.1.0] startup
[3.114s] [ext: omni.kit.browser.asset-1.2.3] startup
[3.115s] [ext: omni.kit.browser.deepsearch-1.0.20] startup
[3.117s] [ext: omni.kit.compatibility_checker-0.1.0] startup
[3.119s] [ext: omni.kit.hotkeys.window-1.1.3] startup
[3.121s] [ext: omni.kit.property.audio-1.0.6] startup
[3.122s] [ext: omni.kit.property.camera-1.0.3] startup
[3.122s] [ext: omni.kit.property.geometry-1.2.2] startup
[3.123s] [ext: omni.kit.property.light-1.0.6] startup
[3.124s] [ext: omni.hydra.scene_api-0.1.1] startup
[3.128s] [ext: omni.kit.tool.asset_importer-2.4.0] startup
[3.129s] [ext: omni.kit.property.material-1.8.19] startup
[3.130s] [ext: omni.services.facilities.base-1.0.2] startup
[3.131s] [ext: omni.kit.property.render-1.1.0] startup
[3.131s] [ext: omni.kit.property.skel-1.0.1] startup
[3.132s] [ext: omni.kit.property.transform-1.3.5] startup
[3.134s] [ext: omni.kit.importer.cad-0.3.4] startup
[3.160s] [ext: omni.isaac.gain_tuner-0.1.1] startup
[3.161s] [ext: omni.services.core-1.3.0] startup
[3.218s] [ext: omni.anim.curve-104.16.6] startup
[3.226s] [ext: omni.anim.shared-104.14.1] startup
[3.230s] [ext: omni.kit.property.bundle-1.2.6] startup
[3.230s] [ext: omni.services.transport.client.base-1.2.1] startup
[3.231s] [ext: omni.slangnode-104.2.3] startup
[3.237s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[3.238s] [ext: omni.isaac.asset_browser-0.2.4] startup
[3.239s] [ext: omni.anim.timeline-104.0.7] startup
[3.241s] [ext: omni.vdb_timesample_editor-0.1.5] startup
[3.243s] [ext: omni.services.client-0.4.0] startup
[3.244s] [ext: omni.kit.menu.aov-1.1.3] startup
[3.244s] [ext: omni.kit.selection-0.1.0] startup
[3.245s] [ext: omni.flowusd-104.2.4] startup
[3.256s] [ext: omni.services.transport.client.http_async-1.3.2] startup
[3.257s] [ext: omni.kit.core.collection-0.1.1] startup
[3.258s] [ext: omni.kit.menu.edit-1.1.6] startup
[3.259s] [ext: omni.isaac.physics_inspector-0.1.3] startup
[3.260s] [ext: omni.kit.menu.file-1.1.4] startup
[3.261s] [ext: omni.kit.pointclouds-0.0.16] startup
[3.263s] [ext: omni.services.starfleet.auth-0.1.4] startup
[3.267s] [ext: omni.kit.property.collection-0.1.10] startup
[3.267s] [ext: omni.kit.property.isaac-0.2.0] startup
[3.268s] [ext: omni.kit.property.sbsar-0.9.9] startup
[3.269s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[3.270s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[3.270s] [ext: omni.kit.quicksearch.hdri-0.8.11] startup
[3.271s] [ext: omni.kit.quicksearch.material-0.8.10] startup
[3.271s] [ext: semantics.schema.editor-0.3.3] startup
[3.274s] [ext: omni.kit.quicksearch.props-0.8.6] startup
[3.275s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[3.275s] [ext: omni.genproc.ui-104.1.6] startup
[3.276s] [ext: omni.rtx.window.settings-0.6.2] startup
[3.280s] [ext: omni.services.transport.server.base-1.1.0] startup
[3.280s] [ext: omni.kit.scripting-104.2.2] startup
2023-07-21 07:49:10 [3,268ms] [Warning] [omni.ext.plugin] [ext: omni.kit.scripting-104.2.2] '/home/dev/.local/share/ov/pkg/isaac_sim-2022.2.1/extscache/omni.kit.scripting-104.2.2+104.2.lx64.r.cp37/bin' in '[[native.plugin]]' was not found.
[3.283s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[3.283s] [ext: omni.isaac.physics_utilities-0.1.1] startup
[3.285s] [ext: omni.genproc.bundle-104.0.1] startup
[3.285s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[3.285s] [ext: omni.kit.agent-0.1.5] startup
[3.286s] [ext: omni.services.transport.server.http-1.1.2] startup
[3.292s] [ext: omni.kit.search.files-1.0.4] startup
[3.293s] [ext: omni.kit.stage_column.variant-1.0.9] startup
[3.294s] [ext: omni.kit.thumbnails.mdl-1.0.20] startup
[3.296s] [ext: omni.kit.widget.material_preview-1.0.7] startup
[3.297s] [ext: omni.kit.thumbnails.images-0.2.3] startup
[3.298s] [ext: omni.kit.thumbnails.usd-0.5.2] startup
[3.299s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[3.300s] [ext: omni.kit.browser.material-1.3.3] startup
[3.301s] [ext: omni.kit.window.material_graph-1.6.15] startup
[3.305s] [ext: omni.kit.window.toolbar-1.4.0] startup
[3.306s] [ext: omni.kit.tool.asset_exporter-1.2.0] startup
[3.307s] [ext: omni.kit.viewport.menubar.display-104.1.11] startup
[3.308s] [ext: omni.physx.commands-104.2.4-5.1] startup
[3.311s] [ext: omni.kit.manipulator.camera-104.0.23] startup
[3.311s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[3.312s] [ext: omni.kit.window.material-1.1.3] startup
[3.314s] [ext: omni.kit.manipulator.prim-104.10.7] startup
[3.316s] [ext: omni.kit.manipulator.selection-104.0.6] startup
[3.316s] [ext: omni.kit.viewport.menubar.camera-104.1.9] startup
[3.319s] [ext: omni.physx.ui-104.2.4-5.1] startup
[3.349s] [ext: omni.kit.viewport.menubar.render-104.0.20] startup
[3.350s] [ext: omni.kit.viewport.menubar.settings-104.3.5] startup
[3.352s] [ext: omni.kit.tool.remove_unused.controller-0.1.2] startup
[3.353s] [ext: omni.hydra.pxr.settings-1.0.3] startup
[3.353s] [ext: omni.kit.usda_edit-1.1.10] startup
[3.418s] [ext: omni.kit.viewport.actions-104.0.3] startup
[3.419s] [ext: omni.kit.property.physx-0.1.0] startup
[3.427s] [ext: omni.physx.demos-104.2.4-5.1] startup
[3.429s] [ext: omni.kit.viewport.bundle-104.0.2] startup
[3.429s] [ext: omni.kit.viewport.menubar.lighting-104.0.9] startup
[3.430s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[3.430s] [ext: omni.kit.viewport.ready-1.0.2] startup
[3.431s] [ext: omni.kit.viewport_widgets_manager-1.0.6] startup
[3.432s] [ext: omni.kit.widget.live-2.0.3] startup
[3.433s] [ext: omni.physx.camera-104.2.4-5.1] startup
[3.438s] [ext: omni.physx.cct-104.2.4-5.1] startup
[3.443s] [ext: omni.kit.mesh.raycast-104.3.2] startup
[3.446s] [ext: omni.kit.widget.collection-0.1.11] startup
[3.447s] [ext: omni.physx.supportui-104.2.4-5.1] startup
[3.456s] [ext: omni.physx.vehicle-104.2.4-5.1] startup
[3.463s] [ext: omni.kit.search.service-0.1.5] startup
[3.466s] [ext: omni.isaac.robot_description_editor-2.1.1] startup
[3.467s] [ext: omni.videoencoding-0.1.0] startup
[3.469s] [ext: omni.paint.system.core-104.5.8] startup
[3.515s] [ext: omni.kit.window.collection-0.1.11] startup
[3.515s] [ext: omni.kit.window.commands-0.2.4] startup
[3.516s] [ext: omni.iray.settings.core-0.6.4] startup
[3.519s] [ext: omni.kit.sequencer.usd-103.3.1] startup
[3.521s] [ext: omni.kit.capture.viewport-1.1.24] startup
[3.523s] [ext: omni.paint.system.ui-104.3.14] startup
[3.527s] [ext: omni.physx.bundle-104.2.4-5.1] startup
[3.527s] [ext: omni.physx.zerogravity-104.2.4-5.1] startup
[3.533s] [ext: omni.rtx.settings.core-0.5.8] startup
[3.538s] [ext: omni.kit.preferences.time-0.2.0] startup
[3.540s] [ext: omni.kit.property.sequence-0.2.0] startup
[3.540s] [ext: omni.kit.sequencer.core-103.3.0] startup
[3.541s] [ext: omni.kit.window.console-0.2.3] startup
[3.547s] [ext: omni.kit.window.imageviewer-1.0.6] startup
[3.549s] [ext: omni.paint.brush.scatter-104.2.12] startup
[3.552s] [ext: omni.kit.window.movie_capture-2.1.8] startup
[3.555s] [ext: omni.kit.window.privacy-0.1.0] startup
[3.555s] [ext: omni.kit.window.script_editor-1.7.2] startup
[3.557s] [ext: omni.kit.window.sequencer-103.3.4] startup
[3.569s] [ext: omni.particle.system.core-104.7.19] startup
[3.575s] [ext: omni.paint.brush.attributes-1.1.2] startup
[3.577s] [ext: omni.paint.brush.modify-104.3.2] startup
[3.580s] [ext: omni.paint.brush.scripting-104.7.0] startup
[3.584s] [ext: omni.paint.brush.select-104.3.2] startup
[3.588s] [ext: omni.scene.optimizer.core-104.1.5] startup
[3.591s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.2] startup
[3.600s] [ext: omni.graph.window.particle.system-104.5.3] startup
[3.601s] [ext: omni.particle.system.ui-104.5.1] startup
[3.609s] [ext: omni.kit.window.status_bar-0.1.5] startup
[3.611s] [ext: omni.kit.window.usd_paths-1.0.4] startup
[3.612s] [ext: omni.paint.system.bundle-104.8.26] startup
[3.612s] [ext: omni.scene.optimizer.ui-104.1.5] startup
[3.613s] [ext: omni.scene.visualization.ui-104.0.6] startup
[3.615s] [ext: omni.mdl.usd_converter-1.0.0] startup
MDL python binding about to load ...
MDL python binding loaded
[omni.mdl.usd_converter] MDL to USD converter startup
[3.616s] [ext: omni.particle.system.bundle-104.2.24] startup
[3.616s] [ext: omni.replicator.composer-1.2.10] startup
[3.618s] [ext: omni.replicator.isaac-1.7.4] startup
[3.625s] [ext: omni.resourcemonitor-1.0.0] startup
[3.629s] [ext: omni.scene.optimizer.bundle-104.1.5] startup
[3.629s] [ext: omni.scene.visualization.bundle-104.0.1] startup
[3.629s] [ext: omni.kit.stage.mdl_converter-1.0.1] startup
[3.631s] [ext: omni.services.usd-1.1.0] startup
[3.632s] [ext: omni.tools.array-104.0.12] startup
[3.637s] [ext: omni.tools.pivot-104.1.0] startup
[3.641s] [ext: omni.kit.widget.timeline-104.0.3] startup
[3.643s] [ext: omni.tools.randomizer-104.0.9] startup
[3.646s] [ext: omni.kit.quicklayout-1.1.1] startup
[3.647s] [ext: omni.kit.window.title-1.1.2] startup
[3.648s] [ext: omni.kit.stage_column.payload-1.0.8] startup
[3.648s] [ext: omni.isaac.scene_blox-0.1.0] startup
[3.649s] [ext: omni.isaac.cortex-0.3.2] startup
[3.649s] [ext: omni.anim.curve_editor-104.12.7] startup
[3.659s] [ext: omni.isaac.onshape-0.6.2] startup
[3.907s] [ext: omni.kit.window.stats-0.1.2] startup
[3.908s] [ext: omni.isaac.app.setup-0.8.1] startup
[3.910s] Isaac Sim Version: 2022.2.1-rc.14
[3.917s] [ext: omni.isaac.ros2_bridge-humble-1.12.2] startup
[3.994s] Writing Isaac Sim icon file
[3.994s] [ext: omni.isaac.assets_check-0.3.2] startup
[3.999s] [ext: omni.isaac.sim.base-2022.2.1] startup
[4.000s] [ext: omni.isaac.sim-2022.2.1] startup
[4.217s] app ready
[6.703s] RTX ready
There’s no errors in the log file. Can you run Isaac Sim from terminal using the -v flag or add it as an extra argument in the Isaac Sim Selector? Please share the logs.
Also wondering if you can successfully run Create?
Hi, I also experienced the same problem. The window is forzen after RTX ready shown in the terminal. I have added -v flag to isaac sim and generated the log. The log also didn’t reveal the reason behind the freeze.
kit_20230724_161627.log (1.3 MB)
@chris.tung Yes, there are no errors in the logs. Seems to be ok. Does Isaac Sim starts after about 5-10mins?
Do you see the same behavior with other Omniverse apps?
If you are seeing the same with other apps, try updating you drivers to the “Latest Production Branch Version” here: Unix Drivers | NVIDIA
Hi, I ran omni.isaac.sim.warmup.sh and now it’s ready to roll. Thank you for your help.
Not work for me. After running this script RTX recompiled. After that, when launching isaac sim still stuck at RTX ready.
did you reinstall the driver as mentioned by Sheikh in previous message?
after I reinstall the nvidia driver 525. I met the same problem. is there any solution?
@yoni-cmd i am just another user, but it would greatly help the mods/devs help troubleshoot if you can upload your most recent log file. you can find it located here - Setup FAQ — Omniverse IsaacSim latest documentation
for helping the others reading my comment later.
the cause of my problem: I didn’t uninstall the ppa driver part of nvidia when I reinstall the nvidia driver
solution: run sudo apt-get remove --purge nvidia-* sudo apt autoremove sudo apt autoclean
which is mentioned in Linux Troubleshooting — Omniverse Developer Guide latest documentation
