jackal.zip (735.6 KB)
Open this USD and hit play > app hangs and there is no response for over 15 min. Everything loads correctly and I can move around in the worlds as well. However the app hangs up when I hit Play.
I see the same issue when running the Isaac Examples > ROS > Navigation simulation.
I’ve been using the software and the same USD file for quite some time and havent faced any issues. I am not sure if any recent changes (to drivers/USD file) could have affected this.
I noticed that the same warning below is common for when I run the carter navigation example and my attached USD.
2024-04-08 01:51:22 [205,906ms] [Warning] [omni.usd] Unexpected reference count of 2 for UsdStage 'anon:0xcff5bd0:World0.usd' while being closed in UsdContext (this may indicate it is still resident in memory).
2024-04-08 01:51:23 [206,607ms] [Warning] [omni.timeline.plugin] Deprecated: direct use of ITimeline callbacks is deprecated. Use ITimeline::getTimeline (Python: omni.timeline.get_timeline_interface) instead.
I have tried to reinstall Isaac-sim completely and issue is persistent.
System:
Ubuntu 22.04 LTS
ROS2 Humble
Logs:
Loading user config located at: '/home/bool876/.local/share/ov/data/Kit/Isaac-Sim/2023.1/user.config.json'
[Info] [carb] Logging to file: /home/bool876/.nvidia-omniverse/logs/Kit/Isaac-Sim/2023.1/kit_20240407_214757.log
2024-04-08 01:47:57 [1ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.usd-103.4.2+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-08 01:47:57 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.core-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-08 01:47:57 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.sequencer.usd-103.4.0+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-08 01:47:57 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.widget.timeline-105.0.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-08 01:47:57 [4ms] [Warning] [omni.ext.plugin] [ext: omni.kit.window.sequencer-103.4.2-dev.3+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-08 01:47:57 [5ms] [Warning] [omni.ext.plugin] [ext: omni.paint.brush.attributes-1.3.1+105.0] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
2024-04-08 01:47:57 [6ms] [Warning] [omni.ext.plugin] [ext: omni.usd.schema.sequence-2.3.0+105.0.lx64.r.cp310] Built using kit version: 105.0. Current version: 105.1. It is considered compatible, but building with a newer version is recommended.
[0.105s] [ext: omni.kit.async_engine-0.0.0] startup
[0.339s] [ext: omni.assets.plugins-0.0.0] startup
[0.340s] [ext: omni.datastore-0.0.0] startup
[0.340s] [ext: omni.client-1.0.1] startup
[0.344s] [ext: omni.taskagent-0.0.0] startup
[0.345s] [ext: omni.stats-0.0.0] startup
[0.345s] [ext: omni.activity.core-1.0.1] startup
[0.347s] [ext: omni.ujitso-0.0.0] startup
[0.347s] [ext: omni.hsscclient-0.0.0] startup
[0.348s] [ext: omni.activity.profiler-1.0.2] startup
[0.349s] [ext: omni.gpu_foundation-0.0.0] startup
[0.356s] [ext: omni.rtx.shadercache.vulkan-1.0.0] startup
[0.357s] [ext: carb.windowing.plugins-1.0.0] startup
[0.362s] [ext: omni.kit.renderer.init-0.0.0] startup
2024-04-08 01:47:57 [486ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (ADL GT2)
| Driver Version: 535.161.07 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| | | | | | Bus-ID | |
| 0 | NVIDIA GeForce RTX 3080 Laptop.. | Yes: 0 | | 8192 MB | 10de | 0 |
| | | | | | 24dc | cc49432f.. |
| | | | | | 1 | |
| 1 | Intel(R) Graphics (ADL GT2) | | | 23826 MB | 8086 | 0 |
| | | | | | 46a6 | 8680a646.. |
| | | | | | 0 | |
| OS: 22.04.4 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.4, Kernel: 6.5.0-26-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 12th Gen Intel(R) Core(TM) i9-12900H | Cores: 14 | Logical: 28
| Total Memory (MB): 31768 | Free Memory: 27736
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2024-04-08 01:47:57 [811ms] [Warning] [gpu.foundation.plugin] IOMMU is enabled. Found 16 items in /sys/kernel/iommu_groups/.
2024-04-08 01:47:57 [811ms] [Warning] [gpu.foundation.plugin] An input-output memory management unit (IOMMU) appears to be enabled on this system.
On bare-metal Linux systems, CUDA and the display driver do not support IOMMU-enabled PCIe peer to peer memory copy.
If you are on a bare-metal Linux system, please disable the IOMMU. Otherwise you risk image corruption and program instability.
This typically can be controlled via BIOS settings (Intel Virtualization Technology for Directed I/O (VT-d) or AMD I/O Virtualization Technology (AMD-Vi)) and kernel parameters (iommu, intel_iommu, amd_iommu).
Note that in virtual machines with GPU pass-through (vGPU) the IOMMU needs to be enabled.
Since we can not reliably detect whether this system is bare-metal or a virtual machine, we show this warning in any case when an IOMMU appears to be enabled.
2024-04-08 01:47:57 [812ms] [Warning] [gpu.foundation.plugin] -----------------------------------------------------------------------
2024-04-08 01:47:57 [812ms] [Warning] [gpu.foundation.plugin] !!!!! Local system validation failed! Incorrect configuration detected.
2024-04-08 01:47:57 [812ms] [Warning] [gpu.foundation.plugin] Summary below. Details above.
2024-04-08 01:47:57 [812ms] [Warning] [gpu.foundation.plugin] - ECC: OK
2024-04-08 01:47:57 [812ms] [Warning] [gpu.foundation.plugin] - IOMMU: FAILED
[1.180s] [ext: omni.kit.pipapi-0.0.0] startup
[1.181s] [ext: omni.kit.pip_archive-0.0.0] startup
[1.182s] [ext: omni.pip.compute-1.2.0] startup
[1.182s] [ext: omni.mtlx-0.1.0] startup
[1.182s] [ext: omni.usd.config-1.0.3] startup
[1.187s] [ext: omni.gpucompute.plugins-0.0.0] startup
[1.188s] [ext: omni.usd.libs-1.0.0] startup
[1.316s] [ext: omni.pip.cloud-1.0.1] startup
[1.317s] [ext: omni.isaac.core_archive-2.2.1] startup
[1.318s] [ext: omni.usd.schema.audio-0.0.0] startup
[1.487s] [ext: omni.usd.schema.semantics-0.0.0] startup
[1.498s] [ext: omni.iray.libs-0.0.0] startup
[1.502s] [ext: omni.usd_resolver-1.0.1] startup
[1.508s] [ext: omni.volume-0.4.0] startup
[1.511s] [ext: omni.usd.core-1.1.8] startup
[1.516s] [ext: omni.mdl.neuraylib-0.2.0] startup
[1.518s] [ext: omni.hydra.rtx-0.1.0] startup
[1.531s] [ext: omni.hydra.iray-0.1.0] startup
[1.536s] [ext: omni.services.pip_archive-0.13.2] startup
[1.537s] [ext: omni.pip.torch-2_0_1-2.0.2] startup
[1.586s] [ext: omni.kit.telemetry-0.5.0] startup
[1.605s] [ext: omni.isaac.ml_archive-1.1.3] startup
[1.605s] [ext: omni.kit.loop-default-0.2.0] startup
[1.606s] [ext: omni.kit.test-0.0.0] startup
[1.607s] [ext: omni.appwindow-1.1.5] startup
[2.140s] [ext: omni.kit.renderer.core-0.0.0] startup
[6.460s] [ext: omni.kit.renderer.capture-0.0.0] startup
[6.462s] [ext: omni.kit.renderer.imgui-0.0.0] startup
[6.594s] [ext: omni.ui-2.18.5] startup
[6.603s] [ext: carb.audio-0.1.0] startup
[6.606s] [ext: omni.uiaudio-1.0.0] startup
[6.606s] [ext: omni.kit.mainwindow-1.0.1] startup
[6.607s] [ext: omni.kit.uiapp-0.0.0] startup
[6.607s] [ext: omni.usd.schema.metrics.assembler-105.1.2] startup
[6.613s] [ext: omni.anim.navigation.schema-105.2.0] startup
[6.617s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[6.621s] [ext: omni.usd.schema.flow-105.1.18] startup
[6.621s] [ext: omni.schema.audio.boom-0.4.0] startup
[6.624s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[6.626s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[6.631s] [ext: omni.usd.schema.sequence-2.3.0] startup
[6.637s] [ext: omni.usd.schema.physics-0.0.0] startup
[6.653s] [ext: omni.usd.fileformat.sbsar-105.0.5] startup
[6.660s] [ext: omni.usd.schema.anim-0.0.0] startup
[6.674s] [ext: omni.usd.schema.forcefield-0.0.0] startup
[6.679s] [ext: omni.anim.graph.schema-105.2.2] startup
[6.685s] [ext: omni.graph.exec-0.3.0] startup
[6.686s] [ext: omni.kit.actions.core-1.0.0] startup
[6.687s] [ext: omni.kit.exec.core-0.5.0] startup
[6.689s] [ext: omni.kit.commands-1.4.6] startup
[6.692s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[6.693s] [ext: omni.resourcemonitor-105.0.0] startup
[6.694s] [ext: omni.kit.window.popup_dialog-2.0.23] startup
[6.697s] [ext: omni.timeline-1.0.9] startup
[6.699s] [ext: omni.kit.widget.nucleus_connector-1.1.4] startup
[6.700s] [ext: omni.hydra.usdrt_delegate-7.2.34] startup
[6.711s] [ext: omni.hydra.scene_delegate-0.3.2] startup
[6.717s] [ext: omni.usd-1.10.18] startup
[6.764s] [ext: omni.potree_converter-1.0.3] startup
[6.768s] [ext: omni.usd.fileformat.e57-1.1.4] startup
[6.768s] [ext: omni.kit.asset_converter-2.0.19] startup
[6.782s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[6.783s] [ext: omni.usd.schema.physx-0.0.0] startup
[6.808s] [ext: omni.usd.schema.isaac-2.0.1] startup
[6.814s] [ext: omni.usd.schema.destruction-0.7.0] startup
[6.818s] [ext: omni.inspect-1.0.1] startup
[6.819s] [ext: omni.hydra.engine.stats-1.0.1] startup
[6.823s] [ext: omni.graph.tools-1.41.3] startup
[6.836s] [ext: omni.graph.core-2.139.12] startup
[6.839s] [ext: omni.kit.widget.path_field-2.0.8] startup
[6.840s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[6.841s] [ext: omni.kit.widget.browser_bar-2.0.9] startup
[6.841s] [ext: omni.kit.notification_manager-1.0.6] startup
[6.843s] [ext: omni.kit.clipboard-1.0.3] startup
[6.843s] [ext: omni.kit.collaboration.channel_manager-1.0.11] startup
[6.844s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[6.844s] [ext: omni.kit.helper.file_utils-0.1.6] startup
[6.860s] [ext: omni.kit.usd.layers-2.1.27] startup
[6.868s] [ext: omni.kit.menu.utils-1.5.6] startup
[6.876s] [ext: omni.kit.search_core-1.0.5] startup
[6.876s] [ext: omni.kit.widget.filebrowser-2.3.35] startup
[6.879s] [ext: omni.kit.menu.create-1.0.11] startup
[6.880s] [ext: omni.kit.widget.versioning-1.4.6] startup
[6.881s] [ext: omni.ui.scene-1.7.0] startup
[6.886s] [ext: omni.kit.widget.search_delegate-1.0.4] startup
[6.887s] [ext: omni.kit.context_menu-1.6.8] startup
[6.888s] [ext: omni.kit.primitive.mesh-1.0.15] startup
[6.890s] [ext: omni.kit.window.filepicker-2.10.13] startup
[6.898s] [ext: omni.kit.widget.searchfield-1.1.3] startup
[6.899s] [ext: omni.kit.widget.highlight_label-1.0.1] startup
[6.899s] [ext: omni.kit.widget.prompt-1.0.6] startup
[6.900s] [ext: omni.kit.collaboration.presence_layer-1.0.8] startup
[6.901s] [ext: omni.kit.window.property-1.9.6] startup
[6.903s] [ext: omni.kit.stage_templates-1.1.20] startup
[6.904s] [ext: omni.kit.window.file_importer-1.0.22] startup
[6.906s] [ext: omni.kit.window.file_exporter-1.0.22] startup
[6.906s] [ext: omni.kit.window.content_browser_registry-0.0.1] startup
[6.907s] [ext: omni.kit.widget.options_menu-1.0.5] startup
[6.908s] [ext: omni.kit.widget.searchable_combobox-1.0.5] startup
[6.908s] [ext: omni.kit.window.file-1.3.44] startup
[6.910s] [ext: omni.kit.window.drop_support-1.0.1] startup
[6.910s] [ext: omni.kit.widget.filter-1.1.2] startup
[6.911s] [ext: omni.kit.hotkeys.core-1.3.0] startup
[6.913s] [ext: omni.kit.widget.settings-1.0.6] startup
[6.915s] [ext: omni.kit.window.content_browser-2.7.17] startup
[6.923s] [ext: omni.kit.widget.stage-2.9.6] startup
[6.930s] [ext: omni.kit.window.preferences-1.3.23] startup
[6.933s] [ext: omni.kit.widget.live_session_management-1.2.22] startup
[6.935s] [ext: omni.hydra.pxr-1.1.6] startup
[6.939s] [ext: omni.kit.property.usd-3.21.15] startup
[6.946s] [ext: omni.kit.hydra_texture-1.1.12] startup
[6.950s] [ext: omni.mdl-0.2.1] startup
[6.966s] [ext: omni.kit.viewport.registry-104.0.5] startup
[6.967s] [ext: omni.kit.widget.viewport-105.1.7] startup
[6.970s] [ext: omni.kit.viewport.legacy_gizmos-1.0.14] startup
[6.974s] [ext: omni.kit.material.library-1.3.41] startup
[6.978s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[6.979s] [ext: omni.kit.viewport.window-105.1.12] startup
[6.991s] [ext: usdrt.scenegraph-7.2.34] startup
[7.027s] [ext: omni.kit.usd_undo-0.1.2] startup
[7.027s] [ext: omni.kit.viewport.utility-1.0.16] startup
[7.027s] [ext: omni.graph-1.106.1] startup
[7.113s] [ext: omni.debugdraw-0.1.2] startup
[7.119s] [ext: omni.kvdb-0.0.0] startup
[7.121s] [ext: omni.physx.foundation-105.1.12-5.1] startup
[7.122s] [ext: omni.localcache-0.0.0] startup
[7.124s] [ext: omni.convexdecomposition-105.1.12-5.1] startup
[7.131s] [ext: omni.kit.widget.graph-1.8.4] startup
[7.136s] [ext: omni.usdphysics-105.1.12-5.1] startup
[7.139s] [ext: omni.ui_query-1.1.1] startup
[7.140s] [ext: omni.kit.window.extensions-1.3.0] startup
[7.144s] [ext: omni.physx.cooking-105.1.12-5.1] startup
[7.152s] [ext: omni.graph.ui-1.48.0] startup
[7.167s] [ext: omni.physx-105.1.12-5.1] startup
2024-04-08 01:48:04 [7,161ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[7.179s] [ext: omni.graph.nodes-1.106.3] startup
[7.357s] [ext: omni.importer.urdf-1.6.1] startup
[7.414s] [ext: omni.anim.shared.core-105.8.2] startup
[7.433s] [ext: omni.physics.tensors-0.1.0] startup
[7.442s] [ext: omni.kit.numpy.common-0.1.2] startup
[7.444s] [ext: omni.kit.manipulator.viewport-104.0.9] startup
[7.446s] [ext: omni.physx.tensors-0.1.0] startup
[7.453s] [ext: omni.isaac.version-1.0.3] startup
[7.454s] [ext: omni.isaac.dynamic_control-1.2.6] startup
[7.467s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[7.482s] [ext: omni.warp.core-1.0.0-beta.3] startup
Warp 1.0.0-beta.3 initialized:
CUDA Toolkit: 11.5, Driver: 12.2
Devices:
"cpu" | x86_64
"cuda:0" | NVIDIA GeForce RTX 3080 Laptop GPU (sm_86)
Kernel cache: /home/bool876/.cache/warp/1.0.0-beta.3
[7.631s] [ext: omni.kit.ui_test-1.2.13] startup
[7.633s] [ext: omni.isaac.core-3.3.2] startup
[8.922s] [ext: omni.kit.widget.stage_icons-1.0.4] startup
[8.923s] [ext: omni.kit.widget.timeline-105.0.1] startup
[8.927s] [ext: omni.graph.action-1.58.4] startup
2024-04-08 01:48:05 [8,912ms] [Warning] [carb] [Plugin: libomni.graph.action.plugin.so] Module /home/bool876/.local/share/ov/data/exts/v2/omni.graph.action-1.58.4+105.1.lx64.r.cp310/bin/libomni.graph.action.plugin.so remained loaded after unload request
[8.965s] [ext: omni.anim.curve-105.23.0] startup
[8.984s] [ext: omni.isaac.ui-0.13.5] startup
[8.993s] [ext: omni.kit.widget.zoombar-1.0.5] startup
[8.995s] [ext: omni.anim.curve_editor-105.16.0] startup
[9.015s] [ext: omni.isaac.articulation_inspector-0.1.6] startup
[9.019s] [ext: omni.kit.browser.core-2.3.10] startup
[9.024s] [ext: omni.kit.window.stage-2.4.4] startup
[9.029s] [ext: omni.kit.usd.collect-2.2.6] startup
[9.032s] [ext: omni.kit.browser.folder.core-1.9.8] startup
[9.038s] [ext: omni.kit.menu.stage-1.2.3] startup
[9.040s] [ext: omni.activity.usd_resolver-1.0.1] startup
[9.043s] [ext: omni.kit.tool.collect-2.2.3] startup
[9.046s] [ext: omni.activity.pump-1.0.0] startup
[9.048s] [ext: omni.isaac.asset_browser-0.4.3] startup
[9.051s] [ext: omni.anim.timeline-105.0.15] startup
[9.062s] [ext: omni.activity.ui-1.0.27] startup
[9.070s] [ext: omni.kit.graph.delegate.modern-1.9.1] startup
[9.072s] [ext: omni.vdb_timesample_editor-0.1.8] startup
[9.075s] [ext: omni.flowusd-105.1.45] startup
2024-04-08 01:48:06 [9,065ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[9.085s] [ext: omni.slangnode-105.2.2] startup
[9.103s] [ext: omni.flowusd.ui-105.2.2] startup
[9.159s] [ext: omni.kit.widget.imageview-1.0.3] startup
[9.160s] [ext: omni.kit.manipulator.transform-104.6.15] startup
[9.162s] [ext: omni.kit.widget.toolbar-1.5.6] startup
[9.172s] [ext: omni.kit.raycast.query-1.0.1] startup
[9.184s] [ext: omni.kit.manipulator.selector-1.0.1] startup
[9.186s] [ext: omni.anim.retarget.core-105.1.7] startup
[9.196s] [ext: omni.scene.visualization.core-105.4.10] startup
[9.230s] [ext: omni.kit.manipulator.tool.snap-1.4.2] startup
[9.237s] [ext: omni.curve.creator-105.0.3] startup
[9.239s] [ext: omni.anim.skelJoint-105.1.16] startup
[9.247s] [ext: omni.graph.ui_nodes-1.5.10] startup
[9.278s] [ext: omni.curve.manipulator-105.1.8] startup
[9.292s] [ext: omni.anim.graph.core-105.1.15] startup
[9.308s] [ext: omni.kit.window.quicksearch-2.4.1] startup
[9.312s] [ext: omni.graph.bundle.action-2.0.4] startup
[9.312s] [ext: omni.kit.graph.delegate.default-1.1.1] startup
[9.313s] [ext: omni.kit.window.cursor-1.1.2] startup
[9.314s] [ext: omni.kit.widget.spinner-1.0.6] startup
[9.316s] [ext: omni.graph.image.core-0.1.0] startup
[9.317s] [ext: omni.kit.graph.editor.core-1.5.1] startup
[9.319s] [ext: omni.kit.graph.usd.commands-1.3.0] startup
[9.321s] [ext: omni.kit.widget.material_preview-1.0.8] startup
[9.323s] [ext: omni.kit.viewport.menubar.core-105.0.19] startup
[9.341s] [ext: omni.kit.browser.sample-1.4.6] startup
[9.344s] [ext: omni.command.usd-1.0.2] startup
[9.346s] [ext: omni.graph.scriptnode-1.1.6] startup
[9.353s] [ext: omni.kit.window.material_graph-1.8.11] startup
[9.374s] [ext: omni.syntheticdata-0.4.10] startup
[9.397s] [ext: omni.warp-1.0.0-beta.2] startup
[9.464s] [ext: omni.sensors.nv.common-1000.0.0-isaacsim.2023.1.1] startup
[9.472s] [ext: omni.sensors.nv.materials-1000.0.0-isaacsim.2023.1.1] startup
2024-04-08 01:48:06 [9,456ms] [Warning] [omni.ext.plugin] [ext: omni.sensors.nv.materials-1000.0.0-isaacsim.2023.1.1] Native plugin search dir contains several files: /home/bool876/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.sensors.nv.materials-1000.0.0-isaacsim.2023.1.1+lx64.r/bin . It makes dir walk slow, replace with the exact path to the plugin instead of a wildcard.
[9.474s] [ext: omni.sensors.nv.wpm-1000.0.0-isaacsim.2023.1.1] startup
[9.474s] [ext: omni.isaac.debug_draw-0.6.1] startup
2024-04-08 01:48:06 [9,462ms] [Warning] [omni.stageupdate.plugin] Deprecated: direct use of IStageUpdate callbacks is deprecated. Use IStageUpdate::getStageUpdate instead.
[9.483s] [ext: omni.replicator.core-1.10.20] startup
2024-04-08 01:48:06 [9,487ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
[9.662s] [ext: omni.ramp-105.1.14] startup
[9.668s] [ext: omni.sensors.nv.lidar-1000.0.1-isaacsim.2023.1.1] startup
[9.673s] [ext: omni.sensors.nv.radar-1000.0.0-isaacsim.2023.1.1] startup
[9.678s] [ext: omni.isaac.range_sensor-2.0.2] startup
[9.721s] [ext: omni.isaac.core_nodes-1.7.1] startup
[9.747s] [ext: omni.graph.io-1.6.0] startup
[9.752s] [ext: omni.genproc.core-105.1.5] startup
[9.769s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[9.771s] [ext: omni.isaac.sensor-9.11.1] startup
[9.839s] [ext: omni.anim.graph.ui-105.1.3] startup
[9.850s] [ext: omni.flowusd.bundle-1.0.2] startup
[9.850s] [ext: omni.isaac.camera_inspector-0.2.1] startup
[9.853s] [ext: omni.anim.graph.bundle-105.1.1] startup
[9.856s] [ext: omni.isaac.diff_usd-1.0.1] startup
[9.861s] [ext: omni.isaac.lula-2.1.0] startup
[9.870s] [ext: omni.isaac.surface_gripper-0.7.0] startup
[9.881s] [ext: omni.isaac.motion_generation-6.1.0] startup
[9.887s] [ext: omni.isaac.manipulators-1.1.0] startup
[9.892s] [ext: omni.kit.compatibility_checker-0.1.1] startup
[9.894s] [ext: omni.isaac.franka-0.4.0] startup
[9.897s] [ext: omni.isaac.quadruped-1.4.1] startup
[9.910s] [ext: omni.isaac.dofbot-0.3.1] startup
[9.913s] [ext: omni.isaac.cortex-0.3.5] startup
[9.916s] [ext: omni.isaac.wheeled_robots-0.9.0] startup
[9.932s] [ext: omni.isaac.universal_robots-0.3.3] startup
[9.935s] [ext: omni.isaac.cortex.sample_behaviors-1.0.4] startup
[9.937s] [ext: omni.genproc.ui-105.1.0] startup
[9.941s] [ext: omni.isaac.examples-1.7.13] startup
[10.105s] [ext: omni.genproc.bundle-105.1.0] startup
[10.105s] [ext: omni.activity.freeze_monitor-1.0.3] startup
[10.113s] [ext: omni.kit.viewport.actions-105.1.6] startup
[10.118s] [ext: omni.graph.examples.cpp-1.9.3] startup
[10.123s] [ext: omni.kit.viewport.menubar.display-105.1.0] startup
[10.125s] [ext: omni.anim.navigation.core-105.1.4] startup
[10.132s] [ext: omni.isaac.physics_inspector-0.1.4] startup
[10.138s] [ext: omni.isaac.physics_utilities-0.1.2] startup
[10.146s] [ext: omni.anim.navigation.ui-105.1.4] startup
[10.151s] [ext: omni.isaac.robot_assembler-1.1.4] startup
[10.154s] [ext: omni.isaac.robot_description_editor-2.1.3] startup
[10.166s] [ext: omni.isaac.scene_blox-0.1.0] startup
[10.169s] [ext: omni.isaac.synthetic_recorder-1.7.0] startup
[10.174s] [ext: omni.isaac.extension_templates-1.5.1] startup
[10.177s] [ext: omni.anim.navigation.bundle-105.1.0] startup
[10.179s] [ext: omni.kit.widget.calendar-1.0.8] startup
[10.181s] [ext: omni.isaac.throttling-1.0.0] startup
[10.183s] [ext: omni.kit.viewport.menubar.camera-105.1.9] startup
[10.188s] [ext: omni.isaac.unit_converter-0.1.7] startup
[10.191s] [ext: omni.kit.ngsearch-0.3.0] startup
[10.193s] [ext: omni.kit.widget.extended_searchfield-1.0.26] startup
[10.203s] [ext: omni.isaac.urdf-1.1.0] startup
2024-04-08 01:48:07 [10,187ms] [Warning] [omni.isaac.urdf] The extension omni.isaac.urdf has been deprecated. Please use omni.importer.urdf instead.
[10.203s] [ext: omni.isaac.utils-0.6.0] startup
[10.213s] [ext: omni.kit.sequencer.usd-103.4.0] startup
2024-04-08 01:48:07 [10,197ms] [Warning] [pxr.AudioSchema] pxr.AudioSchema is deprecated - please use pxr.OmniAudioSchema instead
[10.216s] [ext: omni.isaac.window.about-1.1.0] startup
[10.218s] [ext: omni.kit.preferences.animation-1.1.0] startup
[10.220s] [ext: omni.kit.browser.deepsearch-1.1.8] startup
[10.225s] [ext: omni.kit.collaboration.selection_outline-1.0.6] startup
[10.227s] [ext: omni.kit.collaboration.stage_columns-1.0.4] startup
[10.230s] [ext: omni.kit.property.sequence-0.3.0] startup
[10.233s] [ext: omni.kit.sequencer.core-103.4.0] startup
[10.236s] [ext: omni.anim.widget.timeline-0.1.8] startup
[10.242s] [ext: omni.kit.widget.layers-1.6.32] startup
[10.251s] [ext: omni.kit.collaboration.viewport.camera-2.0.17] startup
[10.255s] [ext: omni.kit.mesh.raycast-105.3.1] startup
[10.260s] [ext: omni.kit.actions.window-1.1.0] startup
[10.263s] [ext: usdrt.gf-1.0.2] startup
[10.263s] [ext: omni.kit.window.sequencer-103.4.2-dev.3] startup
[10.283s] [ext: omni.kit.property.layer-1.1.5] startup
[10.285s] [ext: omni.kit.selection-0.1.3] startup
[10.287s] [ext: omni.isaac.examples_nodes-0.1.2] startup
[10.297s] [ext: omni.kit.hotkeys.window-1.4.1] startup
[10.301s] [ext: omni.kit.manipulator.tool.mesh_snap-1.4.4] startup
[10.313s] [ext: omni.kit.menu.aov-1.1.3] startup
[10.315s] [ext: omni.kit.property.audio-1.0.9] startup
[10.317s] [ext: omni.kit.menu.edit-1.1.14] startup
[10.319s] [ext: omni.isaac.gain_tuner-0.1.3] startup
[10.322s] [ext: omni.isaac.cloner-0.7.2] startup
[10.324s] [ext: omni.graph.window.core-1.84.0] startup
[10.333s] [ext: omni.anim.curve.ui-1.3.1] startup
[10.336s] [ext: omni.kit.property.camera-1.0.5] startup
[10.338s] [ext: omni.kit.property.geometry-1.2.11] startup
[10.341s] [ext: omni.isaac.gym-0.10.0] startup
[10.343s] [ext: omni.graph.window.action-1.11.2] startup
[10.349s] [ext: omni.anim.curve.bundle-1.2.0] startup
[10.349s] [ext: omni.hydra.scene_api-0.1.2] startup
[10.358s] [ext: omni.kit.property.skel-1.0.4] startup
[10.360s] [ext: omni.kit.property.render-1.1.1] startup
[10.362s] [ext: omni.kit.property.material-1.8.36] startup
[10.366s] [ext: omni.kit.property.transform-1.3.10] startup
[10.369s] [ext: omni.kit.property.light-1.0.8] startup
[10.371s] [ext: omni.kit.tool.asset_importer-2.5.1] startup
[10.375s] [ext: omni.kit.core.collection-0.1.6] startup
[10.376s] [ext: omni.kit.property.bundle-1.2.9] startup
[10.379s] [ext: omni.kit.menu.file-1.1.7] startup
[10.397s] [ext: omni.kit.pointclouds-1.1.2] startup
[10.402s] [ext: omni.kit.property.collection-0.1.15] startup
[10.404s] [ext: omni.kit.property.isaac-0.2.2] startup
[10.406s] [ext: omni.kit.property.sbsar-105.0.5] startup
[10.410s] [ext: omni.isaac.kit-1.4.7] startup
[10.412s] [ext: omni.kit.quicksearch.actions-0.8.11] startup
[10.414s] [ext: omni.kit.quicksearch.commands-1.1.3] startup
[10.415s] [ext: omni.isaac.merge_mesh-0.1.4] startup
[10.420s] [ext: omni.graph.window.generic-1.9.3] startup
[10.427s] [ext: omni.kit.quicksearch.select-0.8.3] startup
[10.428s] [ext: omni.rtx.window.settings-0.6.9] startup
[10.433s] [ext: omni.kit.quicksearch.settings-0.8.6] startup
[10.435s] [ext: omni.kit.scripting-105.1.3] startup
[10.439s] [ext: omni.mdl.usd_converter-1.0.9] startup
[10.441s] [ext: omni.kit.stagerecorder.core-105.0.4] startup
[10.448s] [ext: omni.kit.search.files-1.0.4] startup
[10.449s] [ext: omni.kit.viewport.rtx-104.0.0] startup
[10.449s] [ext: omni.kit.search.service-0.1.11] startup
[10.532s] [ext: omni.kit.stage.copypaste-1.2.2] startup
[10.534s] [ext: omni.kit.stage.mdl_converter-1.0.4] startup
[10.536s] [ext: omni.kit.stagerecorder.ui-105.0.4] startup
[10.539s] [ext: omni.kit.stage_column.payload-1.0.12] startup
[10.541s] [ext: omni.kit.thumbnails.mdl-1.0.23] startup
[10.544s] [ext: omni.kit.usd_presenter.conn.manager-0.1.4] startup
[10.545s] [ext: omni.kit.widgets.custom-1.0.6] startup
[10.551s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[10.553s] [ext: omni.kit.stagerecorder.bundle-105.0.2] startup
[10.553s] [ext: omni.kit.thumbnails.usd-1.0.3] startup
[10.572s] [ext: omni.kit.browser.material-1.4.5] startup
[10.575s] [ext: omni.kit.tool.asset_exporter-1.2.12] startup
[10.578s] [ext: omni.kit.playlist.core-1.3.1] startup
[10.580s] [ext: omni.kit.prim.icon-1.0.11] startup
[10.583s] [ext: omni.kit.tool.measure-105.1.76] startup
2024-04-08 01:48:07 [10,592ms] [Warning] [omni.kit.tool.measure.interface._widgets] Vertex, Edge and Mid Point snap requires `/rtx-transient/scenedb/useUniformsReindexing` setting to be true
[10.623s] [ext: omni.kit.manipulator.camera-105.0.4] startup
[10.626s] [ext: omni.kit.tool.remove_unused.core-0.1.1] startup
[10.627s] [ext: omni.kit.window.material-1.4.0] startup
[10.632s] [ext: omni.kit.manipulator.prim-105.0.11] startup
[10.637s] [ext: omni.kit.viewport.menubar.render-105.1.1] startup
[10.640s] [ext: omni.kit.waypoint.core-1.4.49] startup
[10.645s] [ext: omni.kit.viewport.menubar.settings-105.0.9] startup
[10.649s] [ext: omni.kit.variant.editor-105.1.7] startup
[10.657s] [ext: omni.kit.manipulator.selection-104.0.8] startup
[10.658s] [ext: omni.kit.tool.remove_unused.controller-0.1.3] startup
[10.660s] [ext: omni.hydra.pxr.settings-1.0.5] startup
[10.662s] [ext: omni.services.facilities.base-1.0.4] startup
[10.663s] [ext: omni.kit.waypoint.playlist-1.0.7] startup
[10.666s] [ext: omni.kit.usda_edit-1.1.11] startup
[10.675s] [ext: omni.kit.variant.presenter-105.1.1] startup
[10.678s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[10.678s] [ext: omni.kit.viewport.menubar.lighting-105.0.7] startup
[10.681s] [ext: omni.kit.viewport.pxr-104.0.1] startup
[10.681s] [ext: omni.services.core-1.6.4] startup
[10.734s] [ext: omni.kit.viewport.menubar.waypoint-104.2.16] startup
[10.737s] [ext: omni.services.transport.client.base-1.2.4] startup
[10.738s] [ext: omni.physx.commands-105.1.12-5.1] startup
[10.742s] [ext: omni.usdphysics.ui-105.1.12-5.1] startup
[10.775s] [ext: omni.kit.widget.live-2.1.6] startup
[10.777s] [ext: omni.kit.viewport.ready-1.0.5] startup
[10.779s] [ext: omni.kit.viewport_widgets_manager-1.0.8] startup
[10.781s] [ext: omni.kit.waypoint.bundle-1.0.4] startup
[10.781s] [ext: omni.services.client-0.5.3] startup
[10.782s] [ext: omni.kit.widget.collection-0.1.16] startup
[10.785s] [ext: omni.physx.ui-105.1.12-5.1] startup
[10.813s] [ext: omni.kit.widget.cache_indicator-2.0.8] startup
[10.815s] [ext: omni.iray.settings.core-0.6.4] startup
[10.819s] [ext: omni.kit.capture.viewport-1.3.7] startup
[10.822s] [ext: omni.rtx.settings.core-0.5.13] startup
[10.830s] [ext: omni.services.transport.client.http_async-1.3.6] startup
[10.832s] [ext: omni.kit.window.collection-0.1.17] startup
[10.834s] [ext: omni.kit.property.physx-0.1.0] startup
[10.849s] [ext: omni.physx.demos-105.1.12-5.1] startup
[10.853s] [ext: omni.kit.window.commands-0.2.4] startup
[10.854s] [ext: omni.kit.window.console-0.2.10] startup
[10.865s] [ext: omni.kit.window.imageviewer-1.0.7] startup
[10.870s] [ext: omni.kit.window.movie_capture-2.3.9] startup
[10.875s] [ext: omni.kit.window.toolbar-1.5.4] startup
[10.878s] [ext: omni.kit.window.privacy-0.1.0] startup
[10.879s] [ext: omni.physx.camera-105.1.12-5.1] startup
[10.887s] [ext: omni.kit.converter.common-200.1.0-rc.4] startup
[10.889s] [ext: omni.physx.cct-105.1.12-5.1] startup
[10.902s] [ext: omni.physx.graph-105.1.12-5.1] startup
[10.914s] [ext: omni.particle.system.core-105.1.6] startup
2024-04-08 01:48:07 [10,902ms] [Warning] [omni.particle.system.core.scripts.extension]
ATTENTION!: omni.particle.system.core is currently undergoing extensive (breaking) changes.
Please be aware that systems built with the existing extension will need to be rebuilt in
the USD Composer 2023.2 release.
[10.926s] [ext: omni.physx.supportui-105.1.12-5.1] startup
[10.940s] [ext: omni.physx.vehicle-105.1.12-5.1] startup
[10.952s] [ext: omni.kit.quicksearch.hdri-0.8.12] startup
[10.954s] [ext: omni.kit.converter.cad_core-200.1.0-rc.22] startup
[10.963s] [ext: omni.kit.converter.jt_core-200.1.0-rc.14] startup
[10.984s] [ext: omni.kit.window.script_editor-1.7.4] startup
[10.987s] [ext: omni.graph.window.particle.system-105.1.18] startup
DYNAMICS_TODO:
Make sure "omni.particle.system.core2" is a proper dependency.
For now, it can just be set to autoload.
DYNAMICS_TODO:
[10.993s] [ext: omni.particle.system.ui-105.1.10] startup
[11.007s] [ext: omni.kit.browser.asset-1.3.7] startup
[11.010s] [ext: omni.physx.bundle-105.1.12-5.1] startup
[11.010s] [ext: omni.scene.optimizer.core-105.1.8] startup
[11.015s] [ext: omni.kit.converter.cad-200.1.0-rc.18] startup
[11.019s] [ext: omni.kit.window.status_bar-0.1.6] startup
[11.024s] [ext: omni.kit.window.usd_paths-1.0.5] startup
[11.027s] [ext: omni.particle.system.bundle-105.1.0] startup
[11.027s] [ext: omni.physx.zerogravity-105.1.12-5.1] startup
2024-04-08 01:48:08 [11,018ms] [Warning] [omni.kit.app._impl] "import omni.kit.window.toolbar.builtin_tools.models.setting_model" is deprecated. Please use "import omni.kit.widget.toolbar.builtin_tools.models.setting_model"
2024-04-08 01:48:08 [11,018ms] [Warning] [omni.kit.app._impl] "import omni.kit.window.toolbar.hotkey" is deprecated. Please use "import omni.kit.widget.toolbar.hotkey"
2024-04-08 01:48:08 [11,529ms] [Warning] [omni.kit.app._impl] Imported from /home/bool876/.local/share/ov/pkg/isaac_sim-2023.1.1/extsPhysics/omni.physx.zerogravity-105.1.12-5.1/omni/physxzerogravity/scripts/toolbar_button.py
2024-04-08 01:48:08 [11,529ms] [Warning] [omni.kit.app._impl] "import omni.kit.window.toolbar.widget_group" is deprecated. Please use "import omni.kit.widget.toolbar.widget_group"
2024-04-08 01:48:08 [11,694ms] [Warning] [omni.kit.app._impl] Imported from /home/bool876/.local/share/ov/pkg/isaac_sim-2023.1.1/extsPhysics/omni.physx.zerogravity-105.1.12-5.1/omni/physxzerogravity/scripts/toolbar_button.py
[11.718s] [ext: omni.replicator.composer-1.2.17] startup
[11.728s] [ext: omni.scene.optimizer.ui-105.1.3] startup
[11.733s] [ext: omni.scene.visualization.ui-105.1.1] startup
[11.736s] [ext: omni.replicator.isaac-1.11.3] startup
[11.762s] [ext: omni.services.transport.server.base-1.1.1] startup
[11.763s] [ext: omni.kit.quicksearch.material-0.8.12] startup
[11.765s] [ext: omni.isaac.mjcf-1.0.0] startup
2024-04-08 01:48:08 [11,748ms] [Warning] [omni.isaac.mjcf] The extension omni.isaac.mjcf has been deprecated. Please use omni.importer.mjcf instead.
[11.765s] [ext: omni.replicator.replicator_yaml-2.0.4] startup
[11.775s] [ext: omni.scene.optimizer.bundle-105.1.8] startup
[11.775s] [ext: omni.scene.visualization.bundle-105.1.0] startup
[11.775s] [ext: omni.services.starfleet.auth-0.1.5] startup
[11.779s] [ext: omni.services.transport.server.http-1.3.0] startup
[11.791s] [ext: omni.usd.metrics.assembler-105.1.8] startup
[11.799s] [ext: omni.services.usd-1.1.0] startup
[11.802s] [ext: omni.simready.explorer-1.0.26] startup
[11.808s] [ext: omni.tools.array-105.0.4] startup
[11.816s] [ext: omni.tools.distribute-105.0.4] startup
[11.828s] [ext: omni.tools.pivot-105.0.3] startup
[11.838s] [ext: omni.tools.randomizer-105.0.2] startup
[11.844s] [ext: omni.usd.metrics.assembler.ui-105.1.17] startup
[11.847s] [ext: omni.kit.quicksearch.menu-0.8.7] startup
[11.849s] [ext: semantics.schema.editor-0.3.4] startup
[11.851s] [ext: semantics.schema.property-1.0.2] startup
[11.853s] [ext: omni.kit.menu.common-1.1.4] startup
[11.855s] [ext: omni.kit.quicklayout-1.0.5] startup
[11.856s] [ext: omni.anim.retarget.ui-105.1.4] startup
[11.862s] [ext: omni.kit.window.title-1.1.3] startup
[11.864s] [ext: omni.isaac.onshape-0.7.0] startup
[12.329s] [ext: omni.kit.profiler.window-2.2.0] startup
2024-04-08 01:48:09 [12,315ms] [Warning] [omni.kit.profiler.window] remove _SpanInstance.__lt__ and use insort 'key' arg instead
[12.335s] [ext: omni.kit.quicksearch.props-0.8.7] startup
[12.337s] [ext: omni.isaac.occupancy_map-0.3.2] startup
[12.356s] [ext: omni.importer.mjcf-1.1.0] startup
[12.364s] [ext: omni.anim.retarget.bundle-105.1.1] startup
[12.365s] [ext: omni.isaac.app.setup-0.11.2] startup
2024-04-08 01:48:09 [12,349ms] [Warning] [omni.kit.app._impl] carb.imgui is deprecated. Use omni.kit.imgui instead.
[12.366s] Isaac Sim Version: 2023.1.1-rc.8
[12.377s] [ext: omni.isaac.ros2_bridge-2.5.1] startup
[12.410s] Attempting to load system rclpy
[12.431s] rclpy loaded
[12.490s] Writing Isaac Sim icon file
[12.492s] [ext: omni.kit.window.stats-0.1.4] startup
[12.493s] [ext: omni.isaac.assets_check-0.3.3] startup
[12.495s] [ext: omni.isaac.sim.base-2023.1.1] startup
[12.495s] [ext: omni.isaac.sim-2023.1.1] startup
2024-04-08 01:48:09 [12,534ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-04-08 01:48:09 [12,534ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[12.610s] app ready
2024-04-08 01:48:10 [13,065ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] duplicated action as SPACE (On Press) with omni.kit.widget.toolbar.omni.kit.widget.toolbar::toolbar::play!
2024-04-08 01:48:10 [13,065ms] [Warning] [omni.kit.hotkeys.core.registry] [Hotkey] Cannot register Global [omni.kit.widget.toolbar] omni.kit.widget.toolbar::toolbar::play.SPACE, error code: Duplicated action definition
[15.707s] RTX ready
[15.714s] Isaac Sim App is loaded.
server omniverse://localhost: ConnectionStatus.CONNECTING
server omniverse://localhost: ConnectionStatus.CONNECTED
2024-04-08 01:51:23 [206,672ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/rear_left_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:23 [206,672ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/front_right_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:23 [206,674ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/rear_right_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:23 [206,675ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/front_left_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:33 [216,858ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/front_left_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:33 [216,858ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/front_right_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:33 [216,859ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/rear_left_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:33 [216,859ms] [Warning] [omni.physx.plugin] PhysicsUSD: Prim at path /World/jackal/rear_right_wheel_link/collisions is using obsolete 'customGeometry' attribute. To toggle custom geometry for cylinders, use the physics settings option.
2024-04-08 01:51:33 [216,867ms] [Warning] [omni.physx.plugin] Detected an articulation at /World/jackal with more than 4 velocity iterations being added to a TGS scene.The related behavior changed recently, please consult the changelog. This warning will only print once.
2024-04-08 01:51:33 [216,900ms] [Warning] [omni.fabric.plugin] No source has valid data array=0x1f3d4cb0 usdValid=0 cpuValid=0
