Isaac Sim 2022.2.1 stuck opening Hello World or any .USD saved file
Using fresh install, default configurations, trying to open ANY .usd file, including any of the examples (e.g Hello World) Isaac Sim GUI gets stuck indefinitely in the loading phase. Logs show nothing, no errors, no warnings.
Launching the Isaac Sim works fine, it’s just trying to load any .usd file. Even an empty one that only has one cube with no textures.
Shaders are already compiled.
Downgrading to Isaac Sim 2022.2.0, everything works exactly like expected.
Using propriety NVIDIA drivers 535
Hi @fayezsalka - Would it be possible to share the log file for the issue you are facing on Isaac Sim 2022.2.1?
Have you tried reinstalling the Isaac Sim 2022.2.1 and updating the GPU drivers as mentioned in the document? https://docs.omniverse.nvidia.com/isaacsim/latest/requirements.html
I met the same problem, I can’t open any .USD saved files, including any examples.
Launching the Isaac Sim 2022.2.1 in remote server on docker with client
here is the log:
[20.943s] Isaac Sim Headless Native App is loaded.
DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
terminate called after throwing an instance of 'NvOFException'
  what():  DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
2023-07-25 06:47:51 [63,958ms] [Error] [carb.crashreporter-breakpad.plugin] crash detected
2023-07-25 06:47:51 [63,958ms] [Warning] [carb.crashreporter-breakpad.plugin] A crash has occurred.  If a debugger should be attached, please set the '/crashreporter/debuggerAttachTimeoutMs' setting to a timeout in milliseconds.  This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
2023-07-25 06:47:51 [63,959ms] [Warning] [carb.crashreporter-breakpad.plugin] compressing 2 files into '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/40bb8565-b93c-4038-69b46780-25d6b4d4.dmp.zip' for upload.
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin] Uploading minidump: file:'/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/40bb8565-b93c-4038-69b46780-25d6b4d4.dmp.zip' svr:'https://services.nvidia.com/submit'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata for upload:
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   DumpId = '40bb8565-b93c-4038-69b46780-25d6b4d4'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   ProductName = 'OmniverseKit'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   RetryCount = '0'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   StartupTime = '1690267607'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   UploadSuccessful = '0'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   UptimeSeconds = '65'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   Version = '104.2+release.295.529af2e4.tc'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   appName = 'Isaac-Sim'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   appState = 'started'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   appVersion = '2022.2.1'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   autoloadExts = ''
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildBranch = 'release'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildCi = 'tc'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildHash = '529af2e4'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildId = '14001715'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMajor = '104'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMinor = '2'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMr = '0'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildNumber = '295'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildPatch = '0'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildVersion = '104.2.0'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   environmentName = 'default'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   experience = 'Isaac Sim'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   kitRendererDriverVersion = '535.54'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommand = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-07-25 06:47:52 [64,939ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommands = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   memoryStats = '(avail/total) RAM: 959.474/1007.33GB, Swap: 1.87288/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   portableMode = '0'
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   stageUrl = '/Projects/eee.usd'
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   systemInfo = '
| Driver Version: 535.54.03     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
| 0   | NVIDIA GeForce RTX 4090          | Yes: 0 |     | 24810   MB | 10de      | 0          |
|     |                                  |        |     |            | 2684      | d6268c7f.. |
| 1   | NVIDIA GeForce RTX 4090          | Yes: 1 |     | 24810   MB | 10de      | 0          |
|     |                                  |        |     |            | 2684      | 1fff2750.. |
| OS: Linux hw-2288H-V6, Version: 5.15.0-76-generic
| Processor: Intel(R) Xeon(R) Platinum 8352Y CPU @ 2.20GHz | Cores: Unknown | Logical: 128
| Total Memory (MB): 1031501 | Free Memory: 990673
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '17510991064438514683'
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   userId = 'default'
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash report files for upload:
2023-07-25 06:47:52 [64,940ms] [Warning] [carb.crashreporter-breakpad.plugin]   upload_file_minidump = '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/40bb8565-b93c-4038-69b46780-25d6b4d4.dmp.zip'
2023-07-25 06:47:52 [64,940ms] [Error] [carb.crashreporter-breakpad.plugin] failed to upload minidump: file: '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/40bb8565-b93c-4038-69b46780-25d6b4d4.dmp.zip', code: 0, error: 'libcurl.so: cannot open shared object file: No such file or directory', response:
2023-07-25 06:47:52 [64,940ms] [Error] [carb.crashreporter-breakpad.plugin]      {status = InitFailed (3)}
2023-07-25 06:47:52 [64,940ms] [Error] [carb.crashreporter-breakpad.plugin] Wrote dump file '/root/.local/share/ov/data/Kit/Isaac-Sim/2022.2/40bb8565-b93c-4038-69b46780-25d6b4d4.dmp.zip'
2023-07-25 06:47:52 [64,940ms] [Error] [carb.crashreporter-breakpad.plugin]     dump file size is 732495 bytes, file is readable.
2023-07-25 06:47:52 [64,941ms] [Fatal] [carb.crashreporter-breakpad.plugin] Crash detected in pid 1021 thread 1021
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin] Crash metadata:
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   CarbSdkVersion = '129.11+129.tc565.0f371ae5'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   DumpId = '40bb8565-b93c-4038-69b46780-25d6b4d4'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   ProductName = 'OmniverseKit'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   RetryCount = '0'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   StartupTime = '1690267607'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   UploadSuccessful = '0'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   UptimeSeconds = '65'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   Version = '104.2+release.295.529af2e4.tc'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   appName = 'Isaac-Sim'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   appState = 'started'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   appVersion = '2022.2.1'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   autoloadExts = ''
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildBranch = 'release'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildCi = 'tc'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildHash = '529af2e4'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildId = '14001715'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMajor = '104'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMinor = '2'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildMr = '0'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildNumber = '295'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildPatch = '0'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   buildVersion = '104.2.0'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   environmentName = 'default'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   experience = 'Isaac Sim'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   kitRendererDriverVersion = '535.54'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommand = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   lastCommands = 'SetLightingMenuModeCommand(lighting_mode=,usd_context_name=)'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   memoryStats = '(avail/total) RAM: 959.474/1007.33GB, Swap: 1.87288/2GB, VM: 1.71799e+10/1.71799e+10GB'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   portableMode = '0'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   stageUrl = '/Projects/eee.usd'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   systemInfo = '
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2684      | d6268c7f.. |
|     |                                  |        |     |            | 2684      | 1fff2750.. |
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   telemetrySessionId = '17510991064438514683'
2023-07-25 06:47:52 [64,941ms] [Warning] [carb.crashreporter-breakpad.plugin]   userId = 'default'
2023-07-25 06:47:52 [64,941ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 1021 backtrace follows:
2023-07-25 06:47:52 [65,459ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libpthread.so.0!funlockfile+0x60
2023-07-25 06:47:53 [66,018ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!gsignal+0xcb
2023-07-25 06:47:53 [66,562ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!abort+0x12b
2023-07-25 06:47:53 [66,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: 254!+0x102905
2023-07-25 06:47:53 [66,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: 254!+0x100e66
2023-07-25 06:47:53 [66,563ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: 254!+0x100ea1
2023-07-25 06:47:53 [66,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: 254!+0x100d03
2023-07-25 06:47:53 [66,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: 254!+0xf9be2
2023-07-25 06:47:53 [66,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: 254!+0xf593f
2023-07-25 06:47:53 [66,564ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: 254!+0xfab47
2023-07-25 06:47:53 [66,565ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: 254!+0xd1690
2023-07-25 06:47:53 [66,565ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: 254!+0xd4110
2023-07-25 06:47:53 [66,565ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: 254!+0xb55c8
2023-07-25 06:47:53 [66,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: 254!+0x92cdd
2023-07-25 06:47:53 [66,566ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: 254!+0x6e9cd
2023-07-25 06:47:54 [67,091ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x7187
2023-07-25 06:47:54 [67,599ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libcarb.graphics-vulkan.plugin.so!std::_Hashtable<void*, void*, std::allocator<void*>, std::__detail::_Identity, std::equal_to<void*>, std::hash<void*>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<void*, false>*)+0x640e
2023-07-25 06:47:55 [68,115ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: librtx.postprocessing.plugin.so!_init+0x1de80
2023-07-25 06:47:55 [68,657ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: librtx.postprocessing.plugin.so!_init+0x2027a
2023-07-25 06:47:56 [69,176ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: librtx.postprocessing.plugin.so!_init+0x207c3
2023-07-25 06:47:56 [69,695ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libgpu.foundation.plugin.so!std::vector<unsigned char, std::allocator<unsigned char> >::_M_default_append(unsigned long)+0xdb39
2023-07-25 06:47:57 [70,223ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x142be
2023-07-25 06:47:57 [70,760ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libcarb.scenerenderer-rtx.plugin.so!std::unordered_map<unsigned long, unsigned int, std::hash<unsigned long>, std::equal_to<unsigned long>, std::allocator<std::pair<unsigned long const, unsigned int> > >::~unordered_map()+0x18e
2023-07-25 06:47:58 [71,307ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::ThreadPool::*)(), carb::tasking::ThreadPool*> > >::~_State_impl()+0x279d
2023-07-25 06:47:59 [71,827ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::ThreadPool::*)(), carb::tasking::ThreadPool*> > >::~_State_impl()+0xbb0b
2023-07-25 06:47:59 [72,369ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libcarb.tasking.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<void (carb::tasking::ThreadPool::*)(), carb::tasking::ThreadPool*> > >::~_State_impl()+0xbe0e
2023-07-25 06:48:00 [72,884ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1b463
2023-07-25 06:48:00 [73,396ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x1bb63
2023-07-25 06:48:01 [73,905ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4a7db
2023-07-25 06:48:01 [74,438ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libcarb.scenerenderer-rtx.plugin.so!void std::vector<int, std::allocator<int> >::emplace_back<int>(int&&)+0x4e21b
2023-07-25 06:48:02 [75,015ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libcarb.scenerenderer-rtx.plugin.so!std::_Hashtable<unsigned int, unsigned int, std::allocator<unsigned int>, std::__detail::_Identity, std::equal_to<unsigned int>, std::hash<unsigned int>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned int, false>*)+0x1a917
2023-07-25 06:48:02 [75,524ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0x78e4
2023-07-25 06:48:03 [76,039ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: librtx.hydra.so!carb::progress::ScopedLoadingEvent* std::__uninitialized_copy<false>::__uninit_copy<std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*>(std::move_iterator<carb::progress::ScopedLoadingEvent*>, std::move_iterator<carb::progress::ScopedLoadingEvent*>, carb::progress::ScopedLoadingEvent*)+0xae01
2023-07-25 06:48:03 [76,553ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0x5e7a
2023-07-25 06:48:04 [77,061ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xbfe1
2023-07-25 06:48:04 [77,569ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xc9c6
2023-07-25 06:48:05 [78,076ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: libomni.usd.so!std::_Function_handler<std::unique_ptr<std::__future_base::_Result_base, std::__future_base::_Result_base::_Deleter> (), std::__future_base::_Task_setter<std::unique_ptr<std::__future_base::_Result<void>, std::__future_base::_Result_base::_Deleter>, std::thread::_Invoker<std::tuple<omni::usd::UsdContext::Impl::saveLayers(std::string const&, std::vector<std::string, std::allocator<std::string> > const&, bool)::{lambda()#1}> >, void> >::_M_invoke(std::_Any_data const&)+0xcf41
2023-07-25 06:48:05 [78,611ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libomni.usd.so!std::_Rb_tree<std::string, std::string, std::_Identity<std::string>, std::less<std::string>, std::allocator<std::string> >::_M_erase(std::_Rb_tree_node<std::string>*)+0x4f9f
2023-07-25 06:48:06 [79,160ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x188c
2023-07-25 06:48:06 [79,683ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: libcarb.events.plugin.so!std::_Hashtable<unsigned long, unsigned long, std::allocator<unsigned long>, std::__detail::_Identity, std::equal_to<unsigned long>, std::hash<unsigned long>, std::__detail::_Mod_range_hashing, std::__detail::_Default_ranged_hash, std::__detail::_Prime_rehash_policy, std::__detail::_Hashtable_traits<false, true, true> >::_M_insert_unique_node(unsigned long, unsigned long, std::__detail::_Hash_node<unsigned long, false>*)+0x2026
2023-07-25 06:48:07 [80,196ms] [Fatal] [carb.crashreporter-breakpad.plugin] 040: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0x8ac
2023-07-25 06:48:07 [80,709ms] [Fatal] [carb.crashreporter-breakpad.plugin] 041: libomni.kit.loop-default.plugin.so!std::thread::_State_impl<std::thread::_Invoker<std::tuple<omni::kit::RunLoopThread::run()::{lambda()#1}> > >::~_State_impl()+0xe8e3
2023-07-25 06:48:08 [81,235ms] [Fatal] [carb.crashreporter-breakpad.plugin] 042: libomni.kit.app.plugin.so!_init+0x28c7
2023-07-25 06:48:08 [81,749ms] [Fatal] [carb.crashreporter-breakpad.plugin] 043: libomni.kit.app.plugin.so!carbOnPluginPostShutdown+0x907
2023-07-25 06:48:09 [82,288ms] [Fatal] [carb.crashreporter-breakpad.plugin] 044: kit!_init+0x635
2023-07-25 06:48:10 [82,806ms] [Fatal] [carb.crashreporter-breakpad.plugin] 045: libc.so.6!__libc_start_main+0xf3
2023-07-25 06:48:10 [83,308ms] [Fatal] [carb.crashreporter-breakpad.plugin] 046: kit!_init+0x9cb
Aborted (core dumped)
system:ubuntu20.04
driver:535.54.03
Then, I try your method that Downgrading to Isaac Sim 2022.2.0, and It works. Thanks for your advice!
I provide the same problem log, would it help you?
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2684      | d6268c7f.. |
|     |                                  |        |     |            | 2684      | 1fff2750.. |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | 2684      | d6268c7f.. |
|     |                                  |        |     |            | 2684      | 1fff2750.. |
I fixed the problem by downgrading Nvidia drivers from 535 to 525. Using Ubuntu and RTX 4090.
Any idea when Isaac Sim will support driver 535? On my new machine, 525 is not supported by the laptop RTX 4090 card. Which means it’s not possible to downgrade to 525
I met the exact same problem and fixed it by downgrading the driver to 525.
