Isaac sim container could not runheadless.native.sh
I pull the isaac sim container from nvrc and install the recommend driver version for windows but when i want to start isaac sim it crash into segfault.
could someone help me out here or provide any future instruction for me to include more debug info
2023-11-29 14:13:01 [21,979ms] [Info] [omni.kit.app.plugin] [22.017s] Isaac Sim Headless Native Version: 2023.1.0-rc.42
2023-11-29 14:13:02 [0ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred. If a debugger should be attached, please set the ‘/crashreporter/debuggerAttachTimeoutMs’ setting to a timeout in milliseconds. This can be used to allow the crash reporter to wait for up to that long for a debugger to attach before processing or sending the crash report.
prctl(PR_SET_PTRACER, 192) failed: 22/Invalid argument
prctl(PR_SET_PTRACER, 0) failed: 222023-11-29 14:13:02 [43ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] compressing 3 files into ‘/root/.local/share/ov/data/Kit/Isaac-Sim/2023.1/d70a01d2-bbd1-42dc-4b0c0a89-33d66cdf.dmp.zip’ for upload.
prctl(PR_SET_PTRACER, 193) failed: 22/Invalid argument
‘crashreport.gui’ exited with code 127prctl(PR_SET_PTRACER, 0) failed: 222023-11-29 14:13:02 [272ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] Wrote dump file ‘/root/.local/share/ov/data/Kit/Isaac-Sim/2023.1/d70a01d2-bbd1-42dc-4b0c0a89-33d66cdf.dmp.zip’
2023-11-29 14:13:02 [274ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] preventing upload of minidump due to user opt-out: ‘/root/.local/share/ov/data/Kit/Isaac-Sim/2023.1/d70a01d2-bbd1-42dc-4b0c0a89-33d66cdf.dmp.zip’
2023-11-29 14:13:02 [275ms] [Error] [carb.crashreporter-breakpad.plugin] [crash] dump file size is 315201 bytes, file is readable.
2023-11-29 14:13:02 [278ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Crash detected in pid 12 thread 12
2023-11-29 14:13:02 [279ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Crash metadata:
2023-11-29 14:13:02 [280ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CarbSdkVersion = ‘156.0+release156.tc9247.e85106ac’
2023-11-29 14:13:02 [281ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] CrashTime = ‘Wed Nov 29 14:13:02 2023 GMT’
2023-11-29 14:13:02 [282ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DriverShaderCacheWrapper = ‘disabled’
2023-11-29 14:13:02 [283ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] DumpId = ‘d70a01d2-bbd1-42dc-4b0c0a89-33d66cdf’
2023-11-29 14:13:02 [284ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] ProductName = ‘OmniverseKit’
2023-11-29 14:13:02 [285ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] PythonTracebackStatus = ‘‘py-spy’ successfully wrote info to ‘/root/.local/share/ov/data/Kit/Isaac-Sim/2023.1/d70a01d2-bbd1-42dc-4b0c0a89-33d66cdf.py.txt’’
2023-11-29 14:13:02 [286ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] RetryCount = ‘0’
2023-11-29 14:13:02 [288ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] StartupTime = ‘1701267160’
2023-11-29 14:13:02 [289ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UploadSuccessful = ‘0’
2023-11-29 14:13:02 [290ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UptimeSeconds = ‘22’
2023-11-29 14:13:02 [291ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStory = ‘’
2023-11-29 14:13:02 [292ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] UserStoryStatus = ‘‘crashreport.gui’ exited with code 127’
2023-11-29 14:13:02 [293ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] Version = ‘105.1+release.130815.04872a84.tc’
2023-11-29 14:13:02 [294ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appName = ‘Isaac-Sim’
2023-11-29 14:13:02 [295ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appState = ‘startup’
2023-11-29 14:13:02 [296ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] appVersion = ‘2023.1.0’
2023-11-29 14:13:02 [297ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] autoloadExts = ‘’
2023-11-29 14:13:02 [298ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildBranch = ‘release’
2023-11-29 14:13:02 [299ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildCi = ‘tc’
2023-11-29 14:13:02 [300ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildHash = ‘04872a84’
2023-11-29 14:13:02 [301ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildId = ‘18000955’
2023-11-29 14:13:02 [302ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMajor = ‘105’
2023-11-29 14:13:02 [303ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMinor = ‘1’
2023-11-29 14:13:02 [304ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildMr = ‘0’
2023-11-29 14:13:02 [305ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildNumber = ‘130815’
2023-11-29 14:13:02 [306ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildPatch = ‘0’
2023-11-29 14:13:02 [307ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] buildVersion = ‘105.1.0’
2023-11-29 14:13:02 [309ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] commandLine = ‘/isaac-sim/kit/kit /isaac-sim/apps/omni.isaac.sim.headless.native.kit --ext-folder /isaac-sim/apps --no-window --/persistent/isaac/asset_root/default=http://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/2023.1.0 --merge-config=/isaac-sim/config/open_endpoint.toml --allow-root -v’
2023-11-29 14:13:02 [310ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuId = ‘Intel64 Family 25 Model 80 Stepping 0’
2023-11-29 14:13:02 [311ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuName = ‘AMD Ryzen 9 5900HX with Radeon Graphics’
2023-11-29 14:13:02 [312ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] cpuVendor = ‘AuthenticAMD’
2023-11-29 14:13:02 [313ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] environmentName = ‘Individual’
2023-11-29 14:13:02 [314ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] experience = ‘Isaac Sim’
2023-11-29 14:13:02 [315ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] externalBuild = ‘1’
2023-11-29 14:13:02 [316ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] lastCommand = ‘URDFCreateImportConfig’
2023-11-29 14:13:02 [317ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] lastCommands = ‘MJCFCreateImportConfig,URDFCreateImportConfig’
2023-11-29 14:13:02 [318ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] memoryStats = ‘(avail/total) RAM: 13.0863/15.5491GB, Swap: 4/4GB, VM: 1.71799e+10/1.71799e+10GB’
2023-11-29 14:13:02 [319ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] nvidia-smi = 'Wed Nov 29 14:12:42 2023
| NVIDIA-SMI 525.85.05 Driver Version: 528.24 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:01:00.0 On | N/A |
| N/A 42C P8 15W / 115W | 1099MiB / 16384MiB | 7% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 24 G /Xwayland N/A |
| 0 N/A N/A 27 G /Xwayland N/A |
| 0 N/A N/A 33 G /Xwayland N/A |
2023-11-29 14:13:02 [320ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osDistro = ‘ubuntu’
2023-11-29 14:13:02 [321ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osName = ‘22.04.3 LTS (Jammy Jellyfish)’
2023-11-29 14:13:02 [322ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] osVersion = ‘22.04.3’
2023-11-29 14:13:02 [323ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] portableMode = ‘0’
2023-11-29 14:13:02 [324ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] runEnvironment = ‘Individual’
2023-11-29 14:13:02 [325ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] systemInfo = ‘’
2023-11-29 14:13:02 [326ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] telemetrySessionId = ‘11408439969067452811’
2023-11-29 14:13:02 [327ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] terminatedByAbort = ‘0’
2023-11-29 14:13:02 [328ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] userId = ‘default’
2023-11-29 14:13:02 [329ms] [Warn] [carb.crashreporter-breakpad.plugin] [crash] workingDirectory = ‘/isaac-sim’
2023-11-29 14:13:02 [330ms] [Fatal] [carb.crashreporter-breakpad.plugin] [crash] Thread 12 backtrace follows:
2023-11-29 14:13:02 [352ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50
2023-11-29 14:13:02 [373ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libimgui.so!ImGui::PushStyleColor(int, ImVec4 const&)+0x2a
2023-11-29 14:13:02 [394ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libcarb.imgui.plugin.so!_init+0x33bf
2023-11-29 14:13:02 [415ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: imgui.cpython-310-x86_64-linux-gnu.so!pybind11::error_already_set::~error_already_set()+0x6f40
2023-11-29 14:13:02 [435ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: imgui.cpython-310-x86_64-linux-gnu.so!pybind11::error_already_set::~error_already_set()+0xc8c1
2023-11-29 14:13:02 [457ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libpython3.10.so.1.0!PyBuffer_ToContiguous+0x9a7
2023-11-29 14:13:02 [479ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libpython3.10.so.1.0!_PyObject_MakeTpCall+0x9a
2023-11-29 14:13:02 [502ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libpython3.10.so.1.0!PyCell_Set+0x8b5
2023-11-29 14:13:02 [523ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libpython3.10.so.1.0!_init+0xbaad
2023-11-29 14:13:02 [546ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x6e78
2023-11-29 14:13:02 [568ms] [Fatal] [carb.crashreporter-breakpad.plugin] 010: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
2023-11-29 14:13:02 [590ms] [Fatal] [carb.crashreporter-breakpad.plugin] 011: libpython3.10.so.1.0!_init+0xbaad
2023-11-29 14:13:02 [612ms] [Fatal] [carb.crashreporter-breakpad.plugin] 012: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x38bc
2023-11-29 14:13:02 [633ms] [Fatal] [carb.crashreporter-breakpad.plugin] 013: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
2023-11-29 14:13:02 [656ms] [Fatal] [carb.crashreporter-breakpad.plugin] 014: libpython3.10.so.1.0!PyVectorcall_Call+0x54
2023-11-29 14:13:02 [677ms] [Fatal] [carb.crashreporter-breakpad.plugin] 015: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x5745
2023-11-29 14:13:02 [699ms] [Fatal] [carb.crashreporter-breakpad.plugin] 016: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
2023-11-29 14:13:02 [721ms] [Fatal] [carb.crashreporter-breakpad.plugin] 017: libpython3.10.so.1.0!_init+0xbaad
2023-11-29 14:13:02 [743ms] [Fatal] [carb.crashreporter-breakpad.plugin] 018: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x38bc
2023-11-29 14:13:02 [765ms] [Fatal] [carb.crashreporter-breakpad.plugin] 019: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
2023-11-29 14:13:02 [787ms] [Fatal] [carb.crashreporter-breakpad.plugin] 020: libpython3.10.so.1.0!_init+0xbaad
2023-11-29 14:13:02 [808ms] [Fatal] [carb.crashreporter-breakpad.plugin] 021: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x38bc
2023-11-29 14:13:02 [830ms] [Fatal] [carb.crashreporter-breakpad.plugin] 022: libpython3.10.so.1.0!PyEval_EvalFrameEx+0xb24
2023-11-29 14:13:03 [852ms] [Fatal] [carb.crashreporter-breakpad.plugin] 023: libpython3.10.so.1.0!_init+0xbaad
2023-11-29 14:13:03 [874ms] [Fatal] [carb.crashreporter-breakpad.plugin] 024: libpython3.10.so.1.0!_PyEval_EvalFrameDefault+0x6e78
2023-11-29 14:13:03 [896ms] [Fatal] [carb.crashreporter-breakpad.plugin] 025: libpython3.10.so.1.0!PyEval_EvalCode+0x504
2023-11-29 14:13:03 [917ms] [Fatal] [carb.crashreporter-breakpad.plugin] 026: libcarb.scripting-python.plugin.so!carbOnPluginPreStartup+0xd31
2023-11-29 14:13:03 [940ms] [Fatal] [carb.crashreporter-breakpad.plugin] 027: libcarb.scripting-python.plugin.so!carbOnPluginPreStartup+0x158f
2023-11-29 14:13:03 [961ms] [Fatal] [carb.crashreporter-breakpad.plugin] 028: libomni.ext.plugin.so!std::string& std::vector<std::string, std::allocatorstd::string >::emplace_back<char const*&>(char const*&)+0x9251
2023-11-29 14:13:03 [983ms] [Fatal] [carb.crashreporter-breakpad.plugin] 029: libomni.ext.plugin.so!std::string::replace(unsigned long, unsigned long, char const*, unsigned long)+0xa7ca
2023-11-29 14:13:03 [1,006ms] [Fatal] [carb.crashreporter-breakpad.plugin] 030: libomni.ext.plugin.so!carbOnPluginPreStartup+0x2113
2023-11-29 14:13:03 [1,027ms] [Fatal] [carb.crashreporter-breakpad.plugin] 031: libomni.ext.plugin.so!carbOnPluginPreStartup+0x10dde
2023-11-29 14:13:03 [1,050ms] [Fatal] [carb.crashreporter-breakpad.plugin] 032: libomni.ext.plugin.so!carbOnPluginPreStartup+0x11e03
2023-11-29 14:13:03 [1,073ms] [Fatal] [carb.crashreporter-breakpad.plugin] 033: libomni.kit.app.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)+0x8473
2023-11-29 14:13:03 [1,096ms] [Fatal] [carb.crashreporter-breakpad.plugin] 034: libomni.kit.app.plugin.so!char* std::string::_S_construct<char*>(char*, char*, std::allocator const&, std::forward_iterator_tag)+0x8dac
2023-11-29 14:13:03 [1,119ms] [Fatal] [carb.crashreporter-breakpad.plugin] 035: libomni.kit.app.plugin.so!_init+0x5cee
2023-11-29 14:13:03 [1,138ms] [Fatal] [carb.crashreporter-breakpad.plugin] 036: kit!_init+0x6eb
2023-11-29 14:13:03 [1,161ms] [Fatal] [carb.crashreporter-breakpad.plugin] 037: libc.so.6!__libc_init_first+0x90
2023-11-29 14:13:03 [1,183ms] [Fatal] [carb.crashreporter-breakpad.plugin] 038: libc.so.6!__libc_start_main+0x80
2023-11-29 14:13:03 [1,203ms] [Fatal] [carb.crashreporter-breakpad.plugin] 039: kit!_start+0x29
Segmentation fault
I stumble into the following thread saying that wsl2 is not supported so I will close the quesiton. My issac sim at omniverse in wsl2 can not launch - Omniverse / Isaac Sim - NVIDIA Developer Forums
