My issac sim at omniverse in wsl2 can not launch
I have exactly the same problem with Create and Code 2022.3.3 (launcher works perfectly) under Ubuntu 20.04-wls2 win 10 pro
nvidia-smi
Wed Mar 22 19:26:51 2023
| NVIDIA-SMI 515.91 Driver Version: 517.89 CUDA Version: 11.7 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 Quadro RTX 5000 On | 00000000:01:00.0 Off | N/A |
| N/A 62C P2 47W / N/A | 595MiB / 16384MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 22 G /Xwayland N/A |
bash log :
amdeld@DESKTOP-NPJKLKS:~$ ./omniverse-launcher-linux.AppImage
[4116:0322/201804.440267:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[4116:0322/201804.440321:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[4116:0322/201804.464722:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[4116:0322/201804.464753:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
20:18:04.537 › Omniverse Launcher 1.8.3 (production)
20:18:04.547 › Argv: /tmp/.mount_omniveQaWSGv/omniverse-launcher
20:18:04.548 › Crash dumps directory: /home/amdeld/.config/omniverse-launcher/Crashpad
20:18:04.657 › Running “/home/amdeld/.local/share/ov/pkg/cache-2022.2.0/System Monitor/omni-system-monitor”
20:18:04.661 › Reset current installer.
20:18:04.674 › Running production web server.
20:18:04.680 › HTTP endpoints listening at http://localhost:33480
20:18:04.687 › Sharing: false
[4116:0322/201804.739134:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
20:18:04.742 › Started the Navigator web server on 127.0.0.1:34080.
[4149:0322/201806.817745:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
20:18:07.235 › Saving omniverse-launcher.desktop file to /tmp/omniverse-launcher-2PnKA4…
20:18:07.235 ›
[Desktop Entry]
Name=omniverse-launcher
Exec=“/home/amdeld/omniverse-launcher-linux.AppImage” --no-sandbox %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/omniverse-launcher
20:18:07.522 › Logged in.
20:18:07.577 › Saving omniverse.desktop file to /tmp/omniverse-launcher-pLjfbq…
20:18:07.577 ›
[Desktop Entry]
Type=Application
Terminal=false
20:26:48.989 › Running “/home/amdeld/.local/share/ov/pkg/code-2022.3.3/omni.code.sh” --/app/environment/name=‘launcher’
