My issac sim at omniverse in wsl2 can not launch
When I click the button “launch”,the terminal print running but no response.
and another question is my omniverse can’t run again after I close it
GPU: 1660 supper
| NVIDIA-SMI 525.65 Driver Version: 527.37 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA GeForce … On | 00000000:01:00.0 Off | N/A |
| 41% 33C P8 10W / 125W | 0MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
I have exactly the same problem with Create and Code 2022.3.3 (launcher works perfectly) under Ubuntu 20.04-wls2 win 10 pro
nvidia-smi
Wed Mar 22 19:26:51 2023
| NVIDIA-SMI 515.91 Driver Version: 517.89 CUDA Version: 11.7 |
| | | MIG M. |
| 0 Quadro RTX 5000 On | 00000000:01:00.0 Off | N/A |
| N/A 62C P2 47W / N/A | 595MiB / 16384MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| 0 N/A N/A 22 G /Xwayland N/A |
bash log :
amdeld@DESKTOP-NPJKLKS:~$ ./omniverse-launcher-linux.AppImage
[4116:0322/201804.440267:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[4116:0322/201804.440321:ERROR:bus.cc(399)] Failed to connect to the bus: Failed to connect to socket /run/dbus/system_bus_socket: No such file or directory
[4116:0322/201804.464722:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
[4116:0322/201804.464753:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
20:18:04.537 › Omniverse Launcher 1.8.3 (production)
20:18:04.547 › Argv: /tmp/.mount_omniveQaWSGv/omniverse-launcher
20:18:04.548 › Crash dumps directory: /home/amdeld/.config/omniverse-launcher/Crashpad
20:18:04.657 › Running “/home/amdeld/.local/share/ov/pkg/cache-2022.2.0/System Monitor/omni-system-monitor”
20:18:04.661 › Reset current installer.
20:18:04.674 › Running production web server.
20:18:04.680 › HTTP endpoints listening at http://localhost:33480
20:18:04.687 › Sharing: false
[4116:0322/201804.739134:ERROR:bus.cc(399)] Failed to connect to the bus: Could not parse server address: Unknown address type (examples of valid types are “tcp” and on UNIX “unix”)
20:18:04.742 › Started the Navigator web server on 127.0.0.1:34080.
[4149:0322/201806.817745:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
20:18:07.235 › Saving omniverse-launcher.desktop file to /tmp/omniverse-launcher-2PnKA4…
20:18:07.235 ›
[Desktop Entry]
Name=omniverse-launcher
Exec=“/home/amdeld/omniverse-launcher-linux.AppImage” --no-sandbox %u
Type=Application
Terminal=false
MimeType=x-scheme-handler/omniverse-launcher
20:18:07.522 › Logged in.
20:18:07.577 › Saving omniverse.desktop file to /tmp/omniverse-launcher-pLjfbq…
20:18:07.577 ›
[Desktop Entry]
Type=Application
Terminal=false
20:26:48.989 › Running “/home/amdeld/.local/share/ov/pkg/code-2022.3.3/omni.code.sh” --/app/environment/name=‘launcher’
Hi - Someone from our team will review the questions and provide the feedback
Hi. Isaac Sim is currently not supported on WSL2. There is no Vulkan support on WSL2 yet.
Please run Isaac Sim natively on Windows.
