I installed the Isaac Sim 2022.2.0 when the Isaac Sim 2022.1.1 had not yet been deleted. After install finished, Isaac Sim 2022.2.0 did not start correctly, with errors on the terminal. In the end, the terminal suddenly closed.
Here is my monitor video and latest log.
kit_20230111_150613.log (473.0 KB)
[2023. 01.11. added]
Thanks to above mention, I can launch Isaac Sim via terminal, but still cannot launch via Omniverse launcher. I share you my logs which were successful launches and a failed launch.
Launch success
kit_20230111_175018.log (1.1 MB)
kit_20230111_175033.log (1.1 MB) -
Launch failed
kit_20230111_174959.log (473.1 KB)
I am using only one GPU, but the two were detected for a reason. In a successful launch, only one GPU was detected correctly. However, there are several warnings in the successful launch logs. Will it cause problems?
The failed log says the problem was caused by ‘Multiple Installable Client Drivers.’
[gpu.foundation.plugin] Multiple Installable Client Drivers (ICDs) are found for the same GPU on the system. This causes the same GPU to be reported multiple times by more than one driver and leads to instability or crash.
For NVIDIA drivers, please follow troubleshooting docs to uninstall and completely purge Linux-distribution-provided driver packages, and then reinstall your driver cleanly via .run package. Otherwise, updating Ubuntu software may reinstall a secondary ICD or override the existing NVIDIA driver.
To verify the proper NVIDIA driver installation, only one of the following icd.d folders should contain nvidia_icd.json file:
/etc/vulkan/icd.d: Location of ICDs installed from non-Linux-distribution-provided packages
/usr/share/vulkan/icd.d : Location of ICDs installed from Linux-distribution-provided packages
| Driver Version: 525.60.11 | Graphics API: Vulkan
| GPU | Name | Active | LDA | GPU Memory | Vendor-ID | LUID |
| | | | | | Device-ID | UUID |
| 0 | Intel(R) Graphics (ADL-S GT1) | | | 48063 MB | 8086 | 0 |
| | | | | | 4680 | 84e7c1f5.. |
| 1 | NVIDIA GeForce RTX 3090 | Yes: 0 | | 24822 MB | 10de | 0 |
| | | | | | 2204 | be8d84b5.. |
| 2 | NVIDIA GeForce RTX 3090 | Yes: 1 | | 24822 MB | 10de | 0 |
| | | | | | 2204 | be8d84b5.. |
| OS: Linux bak-ubuntu, Version: 5.15.0-57-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12013000 (1.20.13.0)
| Processor: 12th Gen Intel(R) Core(TM) i7-12700K | Cores: Unknown | Logical: 20
| Total Memory (MB): 64085 | Free Memory: 46799
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
